FROG MAN Posted May 28, 2012 Share #1 Posted May 28, 2012 What do you think?I put a new battery in the 89 today it had been 3 months since I had it started. It started on the first crank and everything seemed OK. Then I noticed fuel pouring out from under it.The fuel pump and connecting hoses from the pump are dry. I can only see one hose hanging down in front of the swing arm it's dry.Do you think the float bowels are sticking and my fuel is flowing out the overflows? I can't see them but thinking there should be 4 of them. Or maybe a fuel line has ruptured. I have major fuel not dripping but pouring off the fuel pump side of the swing arm. Then again on the side stand it's leaning that way. Link to comment Share on other sites More sharing options...
Squidley Posted May 28, 2012 Share #2 Posted May 28, 2012 Tap on the bowls Froggy, this will be a sure tell sign if it quits, I'll bet it's a stuck float Link to comment Share on other sites More sharing options...
FROG MAN Posted May 28, 2012 Author Share #3 Posted May 28, 2012 Thanks Squid. Scoot setting down at the camp. I just came up to get some fuel,seafoam, and my new license plates. Link to comment Share on other sites More sharing options...
Yammer Dan Posted May 28, 2012 Share #4 Posted May 28, 2012 :sign yeah that: Putting it to bed without Sea-Foam or Sta-Built. New gas really sucks. Just can't leave it sit. See how our gobbermint helps us... Link to comment Share on other sites More sharing options...
FROG MAN Posted May 28, 2012 Author Share #5 Posted May 28, 2012 Tapped on the bowels several times but no luck. It's definitely floats sticking. I mixed some sea foam with gallon of fresh fuel then pumped some into the carbs. It looks like the two on the kick stand side may be stuck. Going to let it set for a week might have more time to look at it then.Always something more grass to cut later. Link to comment Share on other sites More sharing options...
FROG MAN Posted July 15, 2012 Author Share #6 Posted July 15, 2012 I took another look at the 89 this morning. Fuel pouring out of one overflow line. I worked on it about 30 minutes tapping on the float bowel after a mixture of Seafoam was put in a few weeks ago. No luck she's pumping a pint a minute from that one line. Looks like I might have to pull the carbs when I have more time. Link to comment Share on other sites More sharing options...
KIC Posted July 15, 2012 Share #7 Posted July 15, 2012 Try getting as can of carb cleaner and the little red straw sprayer. open the drain screw, after the gas drains out of the carb, push the red straw up the drain hose and cover the hose end and straw with a cloth. Then spray into the bowl for 15 seconds or so. Let the cleaner drain out and do it again. close the drain screw fast and let it sit. You can do each one while the other(s) sit. Good luck Link to comment Share on other sites More sharing options...
Yammer Dan Posted July 15, 2012 Share #8 Posted July 15, 2012 Try getting as can of carb cleaner and the little red straw sprayer. open the drain screw, after the gas drains out of the carb, push the red straw up the drain hose and cover the hose end and straw with a cloth. Then spray into the bowl for 15 seconds or so. Let the cleaner drain out and do it again. close the drain screw fast and let it sit. You can do each one while the other(s) sit. Good luck :sign yeah that:And keep fingers crossed:fingers crossed:If you can get the bowl full of cleaner and let it sit for a while it will probally cure it. 15 20 min should do it. You don't want to run a lot of the harsher cleaners thru the whole system but a little shouldn't hurt the one that is sticking. Link to comment Share on other sites More sharing options...
Venturous Randy Posted July 15, 2012 Share #9 Posted July 15, 2012 I have had an overflow one time and I took the inlet line loose from the carb and used compressed air and blew into the fuel bowl. It immediately solved my problem and has not occured again. It appears I had something in the float valve. RandyA Link to comment Share on other sites More sharing options...
