59ndroy Posted March 12, 2012 Share #1 Posted March 12, 2012 I took my (new to me) 1986 Royale out for the first time this weekend for a shake-down run. But when I got back, I noticed that my headlight was not working. In after-thought, I don't remember if it was working when I took off, I checked turn signals and brake lights, etc, but not headlight. No warning indicators on the dash lit up. I know before this "Sea-foam drive it like I stole event", it was working when I was checking the bike over. Anyways, I've checked the bulb - ohm'd good. filiments intact but only 1.2 volts present. Opened, cleaned left side handle bar switch, also minimum (1.2) voltage present on both low and high. Now, I'm thinking that it might be in the starter switch, since I'm not getting any indication of problems on the cmu and I never started it until yesterday. Am I on the right track? Link to comment Share on other sites More sharing options...
sgn Posted March 12, 2012 Share #2 Posted March 12, 2012 Check for cold solder joint inside the cmu (center of dash that has warning lights) there or four places that seem to turn loose and will stop headlight from working. Took me awhile to find in my 83 ... more information on this in the forum Good luck I took my (new to me) 1986 Royale out for the first time this weekend for a shake-down run. But when I got back, I noticed that my headlight was not working. In after-thought, I don't remember if it was working when I took off, I checked turn signals and brake lights, etc, but not headlight. No warning indicators on the dash lit up. I know before this "Sea-foam drive it like I stole event", it was working when I was checking the bike over. Anyways, I've checked the bulb - ohm'd good. filiments intact but only 1.2 volts present. Opened, cleaned left side handle bar switch, also minimum (1.2) voltage present on both low and high. Now, I'm thinking that it might be in the starter switch, since I'm not getting any indication of problems on the cmu and I never started it until yesterday. Am I on the right track? Link to comment Share on other sites More sharing options...
Yammer Dan Posted March 12, 2012 Share #3 Posted March 12, 2012 Make sure the starting switch is returning to the position it should when you release it. Once bike starts pull out on it a little. My 85 sticks when started at times and no headlight. Link to comment Share on other sites More sharing options...
utadventure Posted March 12, 2012 Share #4 Posted March 12, 2012 I lost my headlight on my '86 on the last day of the Cody rally last year. Everything seem to check out at first. When I got home I found that the fuse holder (on the side after the fuse) had broken. It visually looked fine but wasn't making good contact. When I went to remove the fuse, half of the holder fell off. It was time to do the fuse box upgrade. I had the parts, just hadn't taken the time. Made the complete change out in about 30 min. If you're checking power using a meter, check power at the wire after the fuse, not just the fuse itself. Dave Link to comment Share on other sites More sharing options...
Prairiehammer Posted March 12, 2012 Share #5 Posted March 12, 2012 Yep, like Dave says. I'll bet it is the fuse holder. Link to comment Share on other sites More sharing options...
KIC Posted March 12, 2012 Share #6 Posted March 12, 2012 Make sure the starting switch is returning to the position it should when you release it. Once bike starts pull out on it a little. My 85 sticks when started at times and no headlight. My 89 same thing. If the starter switch doesn't return all the way...no headlight. Link to comment Share on other sites More sharing options...
saddlebum Posted March 12, 2012 Share #7 Posted March 12, 2012 My 89 same thing. If the starter switch doesn't return all the way...no headlight. Same here. Best thing is just take the whole assembly off the handle bar, take it all apart and clean all the contacts and moving parts. Beware of the little springs and balls inside, they like to travel. Link to comment Share on other sites More sharing options...
dingy Posted March 12, 2012 Share #8 Posted March 12, 2012 Attached below are links to clean the handle bar switches and the bracke /clucth switches on the MKII 1st gen. These are located in the Technical Library - Read Only > First Gen Tech Library - READ ONLY! > Computer, Lights, Horns, Other Electrical Clutch side http://www.venturerider.org/forum/showthread.php?t=42721 Throttle side http://www.venturerider.org/forum/showthread.php?t=42433 Brakes/clutch switch http://www.venturerider.org/forum/showthread.php?t=42720 Gary Link to comment Share on other sites More sharing options...
KIC Posted March 13, 2012 Share #9 Posted March 13, 2012 Attached below are links to clean the handle bar switches and the bracke /clucth switches on the MKII 1st gen. These are located in the Technical Library - Read Only > First Gen Tech Library - READ ONLY! > Computer, Lights, Horns, Other Electrical Clutch side http://www.venturerider.org/forum/showthread.php?t=42721 Throttle side http://www.venturerider.org/forum/showthread.php?t=42433 Brakes/clutch switch http://www.venturerider.org/forum/showthread.php?t=42720 Gary Thanks for the hard work in documenting these procedures. I know I need to do that to both of mine. This will make it much, much easier. :happy65: P.S. My printer and cartridges are still recovering... Link to comment Share on other sites More sharing options...
59ndroy Posted March 14, 2012 Author Share #10 Posted March 14, 2012 The problem is solved!!! It was the starter switch hanging up and not letting the headlight to come on. Now to take those controls apart and clean before the weekend. Thanks a bunch and let the riding begin in ND. Bugs beware, my windshield is hungry. Link to comment Share on other sites More sharing options...
friesman Posted March 14, 2012 Share #11 Posted March 14, 2012 The problem is solved!!! It was the starter switch hanging up and not letting the headlight to come on. Now to take those controls apart and clean before the weekend. Thanks a bunch and let the riding begin in ND. Bugs beware, my windshield is hungry. Glad that you're back and running, maybe we will cross paths around the border someday, lol Brian Link to comment Share on other sites More sharing options...
