Wiring Polk rear speakers for true stereo sound
1BigDog
In the process of wiring up my new Polk 401 speakers. From what I have read the rear speakers are only mono. Has anyone rewired the rears for a true stereo sound? Can this be done? Everything is apart so I can run new wires to the rear, bypassing the stock wiring.
Thanks for any info.
The only way I could see to make it true stero would be to tap off the front speakers, however I might worry about the extra impedance load.
I do not see rear speakers standard on the Gen 1 MKII schematic, only the fronts.
Why do you think they would be mono?
Speakers and power amps:
Your power amplifier is rated at a max power into a specified load.
I think the stock speakers are 4 ohms and the power amp is rated into 4 ohms.
If your Polk speakers are 8 ohms, you can parallel two speakers per channel for 4 ohms.
Half the amplifier power will go to each speaker.
  • 7 years later...
  • 1 year later...
