User Tag List
Thanks Thanks:  0
Likes Likes:  0
Results 1 to 9 of 9
Thread: New front rim try # 2
  1. #1
    Join Date
    Sep 2008
    Mansfield, Ohio
    OH
    Post Thanks / Like
    Mentioned
    21 Post(s)
    Tagged
    0 Thread(s)
    Default New front rim try # 2
    Found another Vmax front rim for a decent price, this one is straight unlike last one I got. The seller did cheerfully refund money & shipping, plus didn't want rim back. $8 in scrap aluminum.
    Little bit of shimming and get the just broke in Avon on it and it will be one step closer to being a born again VMax.
    This one doesn't have red stripe though. But I do have a vinyl cutter I just got from my brother in law, so I might try cutting stripes for it.
    Gary
    Venture Maximized
    VMax
  2. #2
    Join Date
    May 2008
    437 Reeves Branch,Olive Hill 41164
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Nice Dingy .... Glad all worked out for you. I like those ANON tires too.....
    "Little bit of shimming and get the just broke in Anon on it and it will be one step closer to being a born again VMax."
    Fuzzy
  3. #3
    Join Date
    Sep 2008
    Mansfield, Ohio
    OH
    Post Thanks / Like
    Mentioned
    21 Post(s)
    Tagged
    0 Thread(s)
    Default
    Not sure what an Anon is, but spell checker liked it.
    Gary
    Venture Maximized
    VMax
  4. #4
    Join Date
    May 2008
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by dingy View Post
    Gary
  5. #5
    Join Date
    Sep 2006
    Litchfield County
    CT
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Rim size
    check that rim size. I thought Vmax used a 2.15 wide rim...IE...rated for a 110 size tire not 120 tire. Using a 120 tire on a 2.15 rim will not help stability.
    My 87 Venture, still a corner carving, tire smoking, beast
  6. #6
    Join Date
    Jan 2007
    Stuttgart, Germany
    Germany
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Hey Gary, i'd look at a FJR front Rim. It's 3.5x17 and it's great Conversion on the 1Gen VMax.
    Jason is right, the 2.15" Rim will take a 110/80R18 Tire, but not a 120/70.
  7. #7
    Join Date
    Sep 2008
    Mansfield, Ohio
    OH
    Post Thanks / Like
    Mentioned
    21 Post(s)
    Tagged
    0 Thread(s)
    Default Cover me, I'm going in !!
    Quote Originally Posted by jasonm. View Post
    Quote Originally Posted by Squeeze View Post
    I measured outside width on the stock Venture rim and the VMax rim.
    Stock rim is 3.005" wide
    Vmax is 2.9005" wide
    That is .100" difference. I am going to use this thing, my sidewall profile is a 90, which gives the sidewall some more distance to flex in, as opposed to the 70 or 80's referred to.
    Gary
    Venture Maximized
    VMax
  8. #8
    Join Date
    Sep 2006
    Litchfield County
    CT
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default
    Dingy, you are missing the measurement. There is a number on the outside of the rim. That number is the BEAD mounting width. '83 Venture had 2.15" BUT '84 and on years went to 2.5" because of less than ideal handling with the 120 tire on a 2.15" rim. Some know this as the wobble in front. The 2.15 rim made this issue worse than the 2.5 rim, depending on tires. If you are running an '83 rim originally. Then my posts mean little. Then you will not notice a difference from what you are used to. But Yamaha changed to 2.5" for valid reasons. I have had my '87 for 20+ years. But I had an '83 prior. There is a difference in handling from the '84's I had ridden while owning my '83... that I could feel when friends switched bikes...back in the 80's.
  9. #9
    Join Date
    Sep 2008
    Mansfield, Ohio
    OH
    Post Thanks / Like
    Mentioned
    21 Post(s)
    Tagged
    0 Thread(s)
    Default
    I do have an 83 stock rim on the bike, which is what I am comparing the VMax rim to.
    Just have to see if I like it. I have one of Condors super fork braces on which has helped handling.
    Gary
    Venture Maximized
    VMax
Similar Threads
  1. Front End Wobble
    By GlennTuc in forum Honda Goldwing Tech Talk
    Last Post: 01-23-2011, 12:52 PM
  2. Front Fender
    By t_hole in forum Watering Hole
    Last Post: 07-15-2010, 01:52 AM
  3. Oil on Front Tire
    By Rickster in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 07-11-2010, 09:31 PM
  4. My Front brakes
    By Cruser in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 07-01-2010, 10:55 PM
  5. 130 front tire......
    By Ruffy in forum Watering Hole
    Last Post: 11-02-2007, 05:45 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
