Condor Posted August 19, 2011 Share #1 Posted August 19, 2011 Need some advice guys. I picked up a refurb 'famous maker' (HP ) 23" LED monitor off WOOT a couple of weeks ago. Installed it using the VGA cable and I'm not getting any reds ecept when I bring up the internal RBG control menu. On the internal RGB adjustment the bar shows nice red/green/blue colors, but the screen is only shows BLUE and GREEN. Thought it might be the VGA cable so fiddled with it, but no improvement(red). The computor is a DELL XPS 400 that I picked up 2-3 years ago. I have no problem with the color display with the original Dell Monitor using their priority cable, but now I'm wondering if the original Graphics Card is doing it's job?? The optimum resolution is 1920x1080. I can get close and the screen is really sharp but the resolution adjustment only offers 13 something by 8 something?? WOOT offered to take it back at their cost, but I'm not ready to give up on this thing yet. Any ideas?? Link to comment Share on other sites More sharing options...
SilvrT Posted August 19, 2011 Share #2 Posted August 19, 2011 Do a search on the net for driver software for the monitor ... maybe even on Dell's site as the video card is probably one of theirs. Check this site... http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=5076897#N152 Link to comment Share on other sites More sharing options...
Condor Posted August 19, 2011 Author Share #3 Posted August 19, 2011 Do a search on the net for driver software for the monitor ... maybe even on Dell's site as the video card is probably one of theirs. Check this site... http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=5076897#N152 Thanks Rick. I did, and installed the updated driver for the Monitor. Rebooted. Still no good news. I can't verify the VGA cable is good since I don't have another to compare it to... It may be the cable??? Link to comment Share on other sites More sharing options...
albyzee Posted August 19, 2011 Share #4 Posted August 19, 2011 Two things come to mind. Look in the inside of the cable end (both sides) and look for a bent pin. As for getting 1920x1080 see if you have a setting for wide screen or aspect ratio 16:9. Link to comment Share on other sites More sharing options...
etcswjoe Posted August 19, 2011 Share #5 Posted August 19, 2011 Thanks Rick. I did, and installed the updated driver for the Monitor. Rebooted. Still no good news. I can't verify the VGA cable is good since I don't have another to compare it to... It may be the cable??? If you do not know the cable is good it is most likley your culprit, if the mointor shows red when you adjust it internally it could also be the connection in the back of the monitor. Does the mointor have a DVI or HDMI connection that you could plug your blu ray or cable box into it? Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted August 19, 2011 Share #6 Posted August 19, 2011 Just for grins, loosen the screws on the connector(s) and slightly wiggle the connector while watching the screen. Sometimes those connectors and receptacles have some play in them. Link to comment Share on other sites More sharing options...
SilvrT Posted August 19, 2011 Share #7 Posted August 19, 2011 the original Dell Monitor using their priority cable Priority cable?? .... Dunno what that means Jack... I've been working with Dell products for many years and their cables don't appear any different than any other "clone" PC. Is this some kinda special Video card / monitor that came with the PC? I looked up the Dell XPS400 online and it doesn't appear out of the ordinary. Is it using a DVI cable maybe? One thing I did read is... (The bad: No HDTV capabilities; wired mouse and keyboard; no dual graphics card upgrade path.) Link to comment Share on other sites More sharing options...
Condor Posted August 19, 2011 Author Share #8 Posted August 19, 2011 If you do not know the cable is good it is most likley your culprit, if the mointor shows red when you adjust it internally it could also be the connection in the back of the monitor. Does the mointor have a DVI or HDMI connection that you could plug your blu ray or cable box into it? It does have an HDMI port. Maybe I'll give that a try. Just for grins, loosen the screws on the connector(s) and slightly wiggle the connector while watching the screen. Sometimes those connectors and receptacles have some play in them. Already tried that... No luck... Priority cable?? .... Dunno what that means Jack... I've been working with Dell products for many years and their cables don't appear any different than any other "clone" PC. Is this some kinda special Video card / monitor that came with the PC? I looked up the Dell XPS400 online and it doesn't appear out of the ordinary. Is it using a DVI cable maybe? One thing I did read is... (The bad: No HDTV capabilities; wired mouse and keyboard; no dual graphics card upgrade path.) Here's a pic of the plug Rick. You tell me... I've never run into one of these before. It came with the 19" Dell LCD Monitor. The card has this and a VGA port in it... The old monitor has a VGA port also. At least it looks like a VGA... 9 pin..?? The new monitor has an HDMI. Don't see why it can't be hooked up to a cable box?? Link to comment Share on other sites More sharing options...
SilvrT Posted August 19, 2011 Share #9 Posted August 19, 2011 Here's a pic of the plug Rick. You tell me... I've never run into one of these before. It came with the 19" Dell LCD Monitor. The card has this and a VGA port in it... The old monitor has a VGA port also. At least it looks like a VGA... 9 pin..?? The new monitor has an HDMI. Don't see why it can't be hooked up to a cable box?? 9 pin is VGA Try a different VGA cable or the DVI cable if it will interface ( Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted August 20, 2011 Share #10 Posted August 20, 2011 Thats a standard (more or less) DVI connector. Its not a proprietary connector. It combines both analog and digital signals in one connector. They have been known to fail now and then.. Link to comment Share on other sites More sharing options...
Condor Posted August 20, 2011 Author Share #11 Posted August 20, 2011 Thats a standard (more or less) DVI connector. Its not a proprietary connector. It combines both analog and digital signals in one connector. They have been known to fail now and then.. That's the plug from the old monitor and apparently it works fine. Nice to know what to call it. I'm going to invest in another VGA cable and see what happens. If it's still FUBAR I'll return the thing to WOOT. Too bad 'cause it's a great monitor for the money..... Link to comment Share on other sites More sharing options...
Trader Posted August 20, 2011 Share #12 Posted August 20, 2011 I had a monitor do that and it WAS a bent pin on the cable. Link to comment Share on other sites More sharing options...
Condor Posted August 20, 2011 Author Share #13 Posted August 20, 2011 I had a monitor do that and it WAS a bent pin on the cable. Wish that was the problem on this one. Just checked both ends of the cable. Everything is perfect..... Link to comment Share on other sites More sharing options...
etcswjoe Posted August 20, 2011 Share #14 Posted August 20, 2011 I am surprised it has HDMI and not a DVI connection. Link to comment Share on other sites More sharing options...
Dano Posted August 20, 2011 Share #15 Posted August 20, 2011 Damn Jack, you and wiring again......... I'm just sayin'...... Link to comment Share on other sites More sharing options...
Condor Posted August 20, 2011 Author Share #16 Posted August 20, 2011 I am surprised it has HDMI and not a DVI connection. I think it does have a DVI, but it doesn't have the flat spade like the one in the pic that I posted.... What's the advantage of DVI over VGA?? Link to comment Share on other sites More sharing options...
Condor Posted August 20, 2011 Author Share #17 Posted August 20, 2011 Damn Jack, you and wiring again......... I'm just sayin'...... Yeah, and to think my first major in college was Electrical Engr. Good thing I switched to Marine Biology huh?? :rotf: Link to comment Share on other sites More sharing options...
Dano Posted August 20, 2011 Share #18 Posted August 20, 2011 And now you're hawking sails....... Link to comment Share on other sites More sharing options...
Condor Posted August 20, 2011 Author Share #19 Posted August 20, 2011 And now you're hawking sails....... Hey it has somethin' to do with water.... Link to comment Share on other sites More sharing options...
Condor Posted August 21, 2011 Author Share #20 Posted August 21, 2011 Fixed the cotton picker.... Still not sure exactely what the problem might have been. It was a toss up between the VGA port on the graphics card being bad because of no use, the VGA cable supplied with the monitor being bad. or possibily the VGA port on the monitor being bad. What I ended up doing is buying two cables to do some testing before sending the monitor back. One VGA-VGA, and one DVI-HDMI. Tried the later first and it worked. I now have red, and I ain't screwing with it no more. Picture is as sharp as a tack, and the color is awesome.... Link to comment Share on other sites More sharing options...
Guest tx2sturgis Posted August 21, 2011 Share #21 Posted August 21, 2011 Glad it worked...those cables have been known to fail: RWKG 'Replace With Known Good'. A wonderful troubleshooting tool. Link to comment Share on other sites More sharing options...
