54chevybelair Posted May 7, 2011 Share #1 Posted May 7, 2011 Hello everyone, I just finished my trailer wiring. I used a hopkins converter so I could use the brake/turn signal combo on my trailer. Everything seemed to be easy and the trailer lights work fine. Until I use my 4-way flasher, they do not work with the trailer connected. Disconnect the trailer and they work fine. Any Thoughts? The bike is a 2004 RSV. Link to comment Share on other sites More sharing options...
straycatt Posted May 8, 2011 Share #2 Posted May 8, 2011 I have the same problem. I chased connections for a while and then decided since the chances of needing the fourways when I'm towing the trailer is nil, I stopped worrying about it. Link to comment Share on other sites More sharing options...
54chevybelair Posted May 8, 2011 Author Share #3 Posted May 8, 2011 Thanks Straycatt, atleast I'm not alone. I'm sure I wired everything correctly. I guess I'll just follow in your footsteps and not worry about it. Link to comment Share on other sites More sharing options...
jonesy Posted May 8, 2011 Share #4 Posted May 8, 2011 Lcd lights on trailer??? If I remember right I read somewhere they can affect the flashers. Link to comment Share on other sites More sharing options...
kj5ix Posted May 8, 2011 Share #5 Posted May 8, 2011 I use a Hoppy converter also, and cant remember if I even checked the 4 ways, but the mail function does. I have LED tail lights on the Trike and trailer & camper. I am like straycatt. Come to think about it I don't think I have ever used the 4 ways on either the Honda or the RSV..... Link to comment Share on other sites More sharing options...
Owen Posted May 8, 2011 Share #6 Posted May 8, 2011 I just recently wired my bike for the trailer connection. I upgraded the trailer lights to leds and used the Hoppy Led compatible 5 wire/4 wire convertor. All lights function normally including the 'back off' brake light flasher, emergency flashers, and turn signal auto cancel. I don't know what the difference might be that is keeping yours from working correctly. The only thing I changed was running the white ground wires directly to the connector and did not rely on the frame for grounding... Link to comment Share on other sites More sharing options...
54chevybelair Posted May 8, 2011 Author Share #7 Posted May 8, 2011 Lcd lights on trailer??? If I remember right I read somewhere they can affect the flashers. The lights on the trailer are just the old standard lights. They are not LED or LCD. Link to comment Share on other sites More sharing options...
