2Flights Posted May 24, 2010 Share #1 Posted May 24, 2010 Hello, I just purchased the Morgan Carbtune Pro and will soon attempt (first) to synchronize the carburetors on my 2006 RSTD which has almost 8,00 miles and is experienced some occasional back fire and pops on deceleration. Before attempting this work I need to clear up some confusion about doing this work. Thanks Subject: Seeking Clarification Reference: Article on Synchronizing the Carburetors. (RS Venture and 2006 – Royal Star Tour Deluxe) In this article (page 5) of the text under the lower picture you write, you’ll want to adjust 1 and 2 on the left side and 3 and 4 on the right side of the bike (again when sitting on the seat). These adjustments are made with a #2 Phillips screwdriver from the right side of the bike. My comment…aren’t the adjustment to carb’s 1 and 2 made from the right side of the bike looking through the V of the engine to the left bank of carburetors. Isn’t the same adjustment to carb’s 3 and 4 made in a similar way from the left side of the bike (not right side) looking through the V of the engine to the right bank of carburetors using the long #2 Phillips screwdriver? In the picture (top – page 7) where the text indicates [Here is the screw for synching both sides together]. It is accessed from the left side, just above the choke knob. This is a hex head screw with a slot for a screwdriver. On my 06 RSTD this screw is located on the right side of the bike or am I confused on the location of these adjustment screws and their physical location. Thanks for your input. Link to comment Share on other sites More sharing options...
Freebird Posted May 24, 2010 Share #2 Posted May 24, 2010 Unless they have recently corrected it, the procedure outlined in the manual is incorrect. Review the writeup here and see if you still have any questions. http://www.venturerider.org/forum/showthread.php?t=258 Link to comment Share on other sites More sharing options...
RandyR Posted May 24, 2010 Share #3 Posted May 24, 2010 And a long single blade screwdriver will work if you don't have a phillips head. Link to comment Share on other sites More sharing options...
Sling Posted May 24, 2010 Share #4 Posted May 24, 2010 Reference: Article on Synchronizing the Carburetors. (RS Venture and 2006 – Royal Star Tour Deluxe) In this article (page 5) of the text under the lower picture you write, you’ll want to adjust 1 and 2 on the left side and 3 and 4 on the right side of the bike (again when sitting on the seat). These adjustments are made with a #2 Phillips screwdriver from the right side of the bike. My comment…aren’t the adjustment to carb’s 1 and 2 made from the right side of the bike looking through the V of the engine to the left bank of carburetors. Isn’t the same adjustment to carb’s 3 and 4 made in a similar way from the left side of the bike (not right side) looking through the V of the engine to the right bank of carburetors using the long #2 Phillips screwdriver? No, 3 and 4 are also adjusted from the right side In the picture (top – page 7) where the text indicates [Here is the screw for synching both sides together]. It is accessed from the left side, just above the choke knob. This is a hex head screw with a slot for a screwdriver. Yes adjusting both sides together is done fron the left side On my 06 RSTD this screw is located on the right side of the bike or am I confused on the location of these adjustment screws and their physical location. I think you are confused the hex head screw on the right side located towards the rear of the gas tank is for adjusting the idle speed Hope this helps. Link to comment Share on other sites More sharing options...
Freebird Posted May 24, 2010 Share #5 Posted May 24, 2010 Sling is correct of course. The ONLY screw that you have to reach though with a long screwdriver is on the left side. You reach it from the right side with a long screwdriver. The same is NOT true for the right side. Link to comment Share on other sites More sharing options...
slick97spirit Posted May 24, 2010 Share #6 Posted May 24, 2010 The hardest part of the entire process is locating the screws. Everytime I do a sync I have a hard time (as was unfortunately witnessed at B2Dads M&E) finding the screws. Once you find them, it's like, I knew it was right there all along. Link to comment Share on other sites More sharing options...
