User Tag List
Thanks Thanks:  0
Likes Likes:  0
Results 1 to 6 of 6
Thread: experience with a battery desulfater?
  1. #1
    Join Date
    Aug 2006
    Carlyle, SK
    Canada
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default experience with a battery desulfater?
    I have been looking at ads and info on the net about battery desulfators. Given the long rest periods over our Canadian winters, I have had the experience of replacing batteries come spring and thereafter.
    Anybody have experience with these?
    They look like a great deal to me!
    Harvey
  2. #2
    Join Date
    Aug 2006
    Renton
    WA
    Post Thanks / Like
    Mentioned
    8 Post(s)
    Tagged
    0 Thread(s)
    Default Batteries
    Better yet, on your next replacement, get a Gell Cell, or, the
    Odyssey Dry Cell ( PC-680 )
    The PC-680 puts out 3 times the cranking amps as any Lead Acid battery. They run 12.7 volts.
  3. #3
    Join Date
    Aug 2006
    Oberlin, OH
    OH
    Post Thanks / Like
    Mentioned
    167 Post(s)
    Tagged
    0 Thread(s)
    Default
    I agree about the Odyssey. I've had mine for almost 4 years I think. Great battery. Also recommend a battery tender. Keep it topped off through the winter and it will last a lot longer.
  4. #4
    Join Date
    Aug 2007
    Virginia Beach
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default desulfators
    Can someone give me a good explaination how on this 'desulfator" works etc? Would that make my battery last longer? Rejuvinate it? Battery Viagra??
    MIKE aka Uturn
  5. #5
    Join Date
    Jun 2007
    Gravel Switch
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Uturn View Post
    MIKE aka Uturn
    My very basic understanding is that you take a complete electrically drained battery and do a reverse charge. This can cause all the crap that's built up on the lead plates to come off. You then clean the battery out by draining the acid and refill with fresh and it gives new life to an old battery.
    It's a lot of work and LEGAL disposal of the sulphuric acid can be a pain in butt.
    If you used very large expensive batteries, it would most likely be a viable solution, but for standard automotive and motorcycle batteries, new ones with warranties are cheaper.
    Once again, that's just a very, very, very, simplified, basic overview from my understanding and is not 100 percent correct.
  6. #6
    Join Date
    Jan 2007
    Keetonville
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    One method uses a high rate charge initially, trying to send the sulfate coating the lead plates back into solution. Don't try this at home, unless you like explosions.
    Chuck M, '87 Venture XVZ1300T 115,000 miles
    "I know I'm going to Heaven, because I've been to hell."
    '03 Operation Iraqi Freedom- Task Force RIO
    '08 Operation Iraqi Freedom- Task Force 134
    '14 Operation Enduring Freedom- USFOR-A
    Hidden Content
Similar Threads
  1. 1st Gen new rider experience
    By nonextant in forum Watering Hole
    Last Post: 09-15-2008, 01:11 PM
  2. Experience with RMStator?
    By NewfoundlandVenture in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 07-19-2008, 09:44 PM
  3. Good vendor experience
    By BluesLover in forum Watering Hole
    Last Post: 07-10-2008, 07:28 PM
  4. Great E-Bay Experience
    By Orrin in forum Watering Hole
    Last Post: 11-09-2007, 11:01 AM
  5. Experience with this gasket kit?
    By timshosvt in forum General Tech Talk
    Last Post: 03-22-2007, 07:29 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
