REDRIDER52 Posted March 14, 2010 Share #1 Posted March 14, 2010 Has any one else notice that with the front raked that the oil level in site gage at 3.5qt oil is above the gage filled mine to top of gage which is not the full 3.5 qt that the mannual calls for will this cause any problems on starving the motor on oil Link to comment Share on other sites More sharing options...
Condor Posted March 14, 2010 Share #2 Posted March 14, 2010 Has any one else notice that with the front raked that the oil level in site gage at 3.5qt oil is above the gage filled mine to top of gage which is not the full 3.5 qt that the mannual calls for will this cause any problems on starving the motor on oil It shouldn't cause any problems. Carefull you don't overfill to where it'll cause foaming. On the amount. There are a lot of nooks and cranies where old oil will remain after draining and you may not need to fill to factory specs. Put in 3 quarts and then fill to the middle of the inspection window a bit at a time. Link to comment Share on other sites More sharing options...
04Midnight Posted April 1, 2010 Share #3 Posted April 1, 2010 What's the best way to remove excess oil? I figure losening the oil filter is probably the safest bet. I wouldn't dare touch the drain plug. I know I'll drop it in the pan along with 3 quarts of fresh oil ;-) Link to comment Share on other sites More sharing options...
V7Goose Posted April 1, 2010 Share #4 Posted April 1, 2010 Has any one else notice that with the front raked that the oil level in site gage at 3.5qt oil is above the gage filled mine to top of gage which is not the full 3.5 qt that the mannual calls for will this cause any problems on starving the motor on oil RAKED????? What the HEEDOUBELEL - did you turn a Venture into a chopper??? Link to comment Share on other sites More sharing options...
Cougar Posted April 5, 2010 Share #5 Posted April 5, 2010 Its kinda like when I did the tank venting --the 6 deg rake (EZ-STEER) tilts everything down a bit, I am keeping my oil level at 1/2 at the site glass. and yes the front end is lowered. I think that there is still plenty of oil splash in the engine to get everything lubed right. I do not see any extra oil any place . just me 2 cents. Jeff Link to comment Share on other sites More sharing options...
