dingy Posted December 7, 2009 Share #1 Posted December 7, 2009 (edited) Attached is a Microsoft Excel 2003 spreadsheet that can be used as an aid in selecting replacement valve shims. This should work for 1983 through 2009 models, I did not see any variances in the sizing charts in the service manuals. 1st sheet in file is in Metric format. 2nd sheet in file is in Inch format. I expanded upon the valve clearance charts that are in the service manuals to include the shims that end in 2 and 8. The reason for this is that these shims can be reused in the bike if available. I don't believe you can readily buy the --2 and --8 sizes. Screen shot below shows cylinder 2 area. The only cells that are selectable are the "Shim in Now" & "Measured Clearance" data fields. The "Shim in Now" field will only accept valid shim sizes. There is a pull down menu for valid sizes or size can be keyed in. The only other value that is accepted as input is a zero. I included this to set chart to neutral setting. The "Measured Clearance" field has no error checking built in. Use millimeters on Metric sheet or inches on Inch sheet. The decimal point needs to be entered, the "mm" or "in" does not need to be entered. Below the "Measured Clearance" field is a calculated field for "Shim Needed". This field will display the correct shim size to set valve clearance to the high end of acceptable range. Next is "Expected Clearance" field. This is a calculated field to show what valve clearance should be with the shim size shown in "Shim Needed" field. Next is "2nd Choice Shim" field. This field will display the next larger size shim that will work. This shim may be selected due to "Shim Needed" is an odd size or not available. This shim willset valve clearance to the low end of acceptable range. Next is another "Expected Clearance" field. This is a calculated field to show what valve clearance should be with the shim size shown in "2nd Choice Shim" field. In the upper left hand example, the lower "Expected Clearance" field is highlighted in Red. This will happen when any of the calculated sizes fall outside of acceptable range. If value cannot be calculated, the "Shim Needed" field will be blank and error will display in "Second Choice Shim" field. This will happen if an out of range clearance value is entered. The two right hand charts in screen shot do not have data entered in so there are errors shown. This should print out on 8 1/2" x 11" paper very readable. This is just an aid for shim selection. Verify Clearances if you use this after shims are installed. Gary http://i1007.photobucket.com/albums/af193/gdingy101/valvechartclip1.jpg 39118.xls 39118.xls 39120.xls Edited November 27, 2016 by Freebird Re-Attached Spreadsheets Link to comment Share on other sites More sharing options...
Black Owl Posted December 7, 2009 Share #2 Posted December 7, 2009 Very nice job. Thanks for the effort. Link to comment Share on other sites More sharing options...
RedRider Posted December 7, 2009 Share #3 Posted December 7, 2009 Very nicely done. Thank you. This is on my To-Do list this winter. RR Link to comment Share on other sites More sharing options...
RandyR Posted December 7, 2009 Share #4 Posted December 7, 2009 Looks good Gary. Thanks for the spreadsheet. I was told some Triumph dealers carry 25mm shims in .025mm increments, but they are hard to find. Does the kit I sent have all the shims in it that you need? Link to comment Share on other sites More sharing options...
dingy Posted December 7, 2009 Author Share #5 Posted December 7, 2009 I've got to go to dealer or one of the local used bike guys. I need seven 270's total. I only had 3 valves in spec. Gary Link to comment Share on other sites More sharing options...
N3FOL Posted December 8, 2009 Share #6 Posted December 8, 2009 This is a very useful tool. Thank You for sharing the file to the forum. Link to comment Share on other sites More sharing options...
rzodrow Posted November 27, 2016 Share #7 Posted November 27, 2016 unable to download excel spreadsheet could someone tell me where to look? Link to comment Share on other sites More sharing options...
M61A1MECH Posted November 27, 2016 Share #8 Posted November 27, 2016 You need to PM Freebird, this thread is 7 years old, many of the old attachments were removed during one of the upgrades or something, often Don (Freebird) can go back and get the original attachment and restore it to the thread. I can not recall the last time I saw Dingy on the forum, it has been a couple of years I think, but you could also try PMing Gary (Dingy) also. Link to comment Share on other sites More sharing options...
Freebird Posted November 27, 2016 Share #9 Posted November 27, 2016 Done. I found the old files and re-attached them to the first post. Link to comment Share on other sites More sharing options...
yamagrl Posted November 27, 2016 Share #10 Posted November 27, 2016 Try this. it's easier to use when your hands are greasy http://www.venturerider.org/forum/showthread.php?118690-Easy-Peazy-Valve-Shim-Calculator Link to comment Share on other sites More sharing options...
