1983-1985 Clutch Side Electrical Switch Disassembly and Cleaning
I have made the following write up of the process of cleaning the clutch side switch housing that came off of a 1983 Venture.
The pictures show the switch completely removed from the bike.
It is fairly lengthy, 37 pictures, but thorough.
I would recommend removing switch from bike if you perform this cleaning. There are a number of small springs and ball detents that are very easy to lose unless you have a large well lit working area.
If you are unable to open the PDF file, PM me with your email address and I will send it to you.
I have detailed the throttle side switch in another thread.
Picture below is of the switch detailed in this PDF file.
This is the style of switch that the turn signal button is pressed downward to cancel.
38772.pdf
Edited by Freebird
