User Tag List
Thanks Thanks:  0
Likes Likes:  0
Results 1 to 1 of 1
Thread: 1st Gen Venture Starting Circuit schematics
  1. #1
    Join Date
    Sep 2008
    Mansfield, Ohio
    OH
    Post Thanks / Like
    Mentioned
    21 Post(s)
    Tagged
    0 Thread(s)
    Default 1st Gen Venture Starting Circuit schematics
    Attached are redrawn schematics of the starting circuits for the 1st Gen's.
    I thought these might help people that have cranking & starting issues.
    There is a narrative above each circuit detailing operation. This text assumes a charged battery and intact fuses.
    There are three views of each circuit.
    Left side shows circuit in normal condition, key off, side stand down, transmission in neutral.
    Center view shows circuit with key on, transmission in neutral. clutch and side stand switches not shown as they are irrelevant in this configuration. All switches and relays shown in position to energize starting motor.
    RIght view shows key on, transmission in gear, side stand up and cluth pulled in. Neutral switch not shown as it is irrelevant in this configuration. All switches and relays shown in position to energize starting motor.
    Also, the side stand relay and Emergency stop sensor are shown. Neither of these affect the cranking circuit but will shut down the Ignitor unit. Actually, the bike will start and run with either of these pulled out.
    84-85 one is almost identical to 86-93 version. Only difference is positive wire at starting solenoid coil.
    37977.pdf
    Gary
    Venture Maximized
    VMax
Similar Threads
  1. 1st Gen Venture Starting Circuit schematics
    By dingy in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 11-02-2009, 12:38 AM
  2. New to the Venture Circuit as of Yesterday morning :)
    By LilBeaver in forum Watering Hole
    Last Post: 04-14-2009, 12:56 AM
  3. 2009 VMax Starting point for 3rd Gen Venture???
    By Yamaman in forum Watering Hole
    Last Post: 11-19-2008, 09:32 PM
  4. '86 royale idle circuit???
    By hipshot in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 10-07-2008, 06:08 PM
  5. Try the circuit
    By Eugene in forum Watering Hole
    Last Post: 10-16-2007, 04:38 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
