islandmech Posted October 26, 2009 Share #1 Posted October 26, 2009 Hi there, can anyone recommend a retrofit for the rear air shock and compressor system for the first gen bikes?.... mine is toast and I think I want to just install a quality monoshock and chuck all the old components. thanks for any advice Gary Link to comment Share on other sites More sharing options...
Rocket Posted October 26, 2009 Share #2 Posted October 26, 2009 Hi there, can anyone recommend a retrofit for the rear air shock and compressor system for the first gen bikes?.... mine is toast and I think I want to just install a quality monoshock and chuck all the old components. thanks for any advice Gary If you have the CLASS (built in compressor), most likely problem is cold solder joints, on the controller board. Progressive Suspension 420 Series http://progressivesuspension.com/productsearch.aspx No pricing on line, you will probably need the 420-1014. I think this, is in the $500. USD range. Works Performance lists one for the 1st gen $689. USD http://www.worksperformance.com/html/street.html Link to comment Share on other sites More sharing options...
elag Posted October 26, 2009 Share #3 Posted October 26, 2009 Can go with a manual ajustment air shock like the standard Venture. Usually lots on Ebay. Link to comment Share on other sites More sharing options...
islandmech Posted October 27, 2009 Author Share #4 Posted October 27, 2009 thanks for the info! I am in the process of doing a restoration on my new to me 1986 Venture. will post pics soon. Link to comment Share on other sites More sharing options...
bald josh Posted October 28, 2009 Share #5 Posted October 28, 2009 Im real lo-tech, my ? went south and i got tired of fiddling with it so i took out the compressor and installed vales in the ends of the air lines, and use a small bike pump and tire pressure guage to check. i ride mostly solo so theres not alot of adjusting. not as convenient but it was cheap, easy, and it works till I can get the $ for something more pemanant. used to check the pressure every ride but found that it holds air perfect so i only check once in a while Link to comment Share on other sites More sharing options...
GaryZ Posted October 28, 2009 Share #6 Posted October 28, 2009 Im real lo-tech, my ? went south and i got tired of fiddling with it so i took out the compressor and installed vales in the ends of the air lines, and use a small bike pump and tire pressure guage to check. i ride mostly solo so theres not alot of adjusting. not as convenient but it was cheap, easy, and it works till I can get the $ for something more pemanant. used to check the pressure every ride but found that it holds air perfect so i only check once in a while I also removed the control panel and compressor and added separate air valves. I installed the valves with pressure gauges in the compressor cover behind the seat. Now I simply peek behind the seat to check air pressure and fill with a hand pump carried in a saddle bag. Link to comment Share on other sites More sharing options...
islandmech Posted October 29, 2009 Author Share #7 Posted October 29, 2009 This sounds like a logical solution to my problem..... on another note, If I take out the control head and CB radio{which I will never use} is there any drop-in filler trays to fill the area in the front fairing? Would be a good place for gloves etc. I think the older basic Ventures just had a plastic cover over a storage bin? cheers, Gary Link to comment Share on other sites More sharing options...
bald josh Posted October 29, 2009 Share #8 Posted October 29, 2009 dont know about the controll head space, i left mine there so i would have access to the coolant reservoir. the fairing is off of mine for a few more days, so i cant get a pic right now, but the cb sits in a plastic box with a lip at the bottom. i cut a piece plexi glass and dropped it down inside with a little adhesive and viola, storage. used the cb cover plate, black spray paint and screwed in a knob on the face and i got covered storage. I did the same with the stereo. its a great spot for smokes, lighter cell phone tire guage, etc. i will try and get some pics up soon, Link to comment Share on other sites More sharing options...
