User Tag List
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Weeping Carb - on top
  1. #1
    Join Date
    Oct 2008
    Moore, OK
    OK
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Weeping Carb - on top
    My 1985 VR is weeping gas out of a plug on the top of carb #1. The manual is not much help. The plug is about the size of a dime and has four very small slots around the perimeter (maybe used to remove?). You can see it in the picture below (its the shiny spot next to the #1 carb throat).
    Can anyone help me with ideas on a fix?
  2. Thanks Dave P gave thanks for this post
  3. #2
    Join Date
    Aug 2006
    Oceanside
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I believe that is the plug over the inlet screen (filter) and the fuel bowl, float needle seat. Item 40 in the micro fische. (<!--StartFragment --> 41R-14118-01-00 $6.35 from Zanotti)
    https://www.zanottimotor.com/shopping/pLookUp.php
  4. #3
    Join Date
    Mar 2007
    Omaha Nebraska
    NE
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Default
    Yep that is the plug for the hole that you use to change the needle seats. The net filter is just inside of it and the the needle seat is below that.
    They are a bear to remove and replace. To get it out you need to drill part way into it and blind tap it to fit a small bolt. Then you can use a claw hammer to pry it up and out. If you chose to drill all the way through it plan on replacing the net fitler along with the plug.
    They are a soft metal so you MAY be able to remove the carb rack and then supporting the bottoms of the carbs on a solid base be able to use a point punch and hit it hard enough to get it to expand a bit and reseat itself. No promises on that.
    It would be my quess that the only reason it is leaking is the net filter is badly clogged or blocked. That is the only reason there would be any pressure (from the fuel pump) at that point.
    If you open the carbs to the fuel bowl and spray carb cleaner through from the inside through the needle seat you should get a good flow from the fuel inlet pipe. If not, the net is clogged.
    Go ahead, ask me how I know all this. LOL! I hate carbs!
    Mike
    "Male menopause is a lot more fun than female menopause. With female menopause you gain weight and get hot flashes. Male menopause - you get to date young girls and ride motorcycles."
  5. Thanks jfman gave thanks for this post
  6. #4
    Join Date
    Oct 2008
    Moore, OK
    OK
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thanks Guys!
    The local Yamaha shop has a mechanic that is very experienced with the Vmax. He says the plug is not available as a replacement and he suggested getting another carb. We discussed sealing the plug with epoxy and he seemed to think that would work. I have sealed Q-Jet carbs with epoxy and this seems to make sense to me. Any comments?
  7. #5
    Join Date
    Aug 2006
    Oceanside
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Did you ask him about the part number supplied and the vendor pricing supplied?
    I've heard several guys that have replaced the float seat... and you have to destroy this plug to get there...
  8. #6
    Join Date
    Oct 2008
    Moore, OK
    OK
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default
    mbrood: Did not ask about the part number that you found.
    The function of the cap appears to be for plugging a hole left over from casting the body of the carb. It was much easier to simply epoxy the old cap. The epoxy is in place and seems to be sealing the gas leak. I will ride it around for a bit and re-check.
    1992 Yamaha Venture Royale
    1985 Yamaha Venture Royale with 1300 engine & Vmax cams
    1999 Kawasaki ZX11 Ninja
    1993 Kawasaki ZX11 "Adventure" custom
  9. #7
    Join Date
    Aug 2006
    Oceanside
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    "The function of the cap appears to be for plugging a hole left over from casting the body of the carb."
    Um, no... as was said, it's the cap over the fuel screen and float needle seat...
    It IS replaceable... but if epoxy works for you... so be it...
    37 1FK-14190-15-00 NEEDLE VALVE ASSY 1
    38 1J7-14994-00-00 NET, FILTER 1
    39 1FK-14147-00-00 O-RING 1
    40 41R-14118-01-00 CAP
  10. #8
    Join Date
    Aug 2006
    Carmichael CA
    CA
    Post Thanks / Like
    Mentioned
    101 Post(s)
    Tagged
    0 Thread(s)
    Default
    Dang that is one dirty looking engine. Time for three of four cans of carb cleaner....
  11. #9
    Join Date
    Oct 2008
    Moore, OK
    OK
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Condor View Post
    You noticed!
    I was a bit surprised myself when I pulled off the air cleaner.
    Although the grime made it easy to find the fuel leak!
    I have had the bike for a year and thought I had cleaned it up pretty good.
    It had 61,000+ miles on it when I got it, 63,000+ now.
  12. #10
    Join Date
    Oct 2008
    Moore, OK
    OK
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by mbrood View Post
    Thanks for the drawing and part numbers. I may need them.
  13. #11
    Join Date
    Aug 2006
    Johnson City TN
    TN
    Post Thanks / Like
    Mentioned
    21 Post(s)
    Tagged
    0 Thread(s)
    Default
    I have found that to seal anything that is gasoline related, I use "Seals All". It works very good, is resistant to gas and seems to be readily available.
    RandyA
    Ride as though you are invisible, not invincible.
  14. #12
    Join Date
    Apr 2015
    Montreal
    Canada
    QC
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Weeping Carb - on top
    I have the exact same problem on one of my carbs. It weeps fuel from this plug on the leaft rear carb.
    I am considering tapping on it using a small socket as a "punch"
    Maybe that will seat it correctly.
  15. #13
    Join Date
    Sep 2010
    Mount Palatine
    IL
    Post Thanks / Like
    Mentioned
    45 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jfman View Post
    That plug is the cap for the float valve seat with net filter. The cap has an O-ring.
    Looking at the pic, it appears that the cap has been replaced (the original cap was staked into the carb body, but the new one has not been staked to secure it).
    Click image for larger version.
Name:	Float valve assembly part numbers.jpg
ID:	118175Click image for larger version.
Name:	Float valve replacement.jpg
ID:	118176Click image for larger version.
Name:	Float valve RetainingCap,  41R-14118-​01-00.jpg
ID:	118177Click image for larger version.
Name:	Float Valve Retaining Cap Stakes (Large).jpg
ID:	118178Click image for larger version.
Name:	Fuel leak potential.jpg
    Kevin M. Campbell https://www.facebook.com/Prairiehammer
    1974 Honda CB750, 1991 Venture Royale "the Tuxedo"
  16. Thanks BlueSky, jfman gave thanks for this post
    Likes jfman liked this post
  17. #14
    Join Date
    Apr 2015
    Montreal
    Canada
    QC
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Thank you for this info.
    I used a photo from another set of carbs I am working on because I was too lazy to go get an actual photo from the bike in the garage.
    I guess there is no point tapping on it as the culprit is probably the little oring.
    These carbs habe been off the bike for 4 years. I wonder if there is a chance the oring will swell and the leak fix itself.
    I had that happen on another bike that had been sitting. It leaked fuel from a injector connector for a short while then it quit as the seal swelled up.
  18. #15
    Join Date
    Apr 2015
    Montreal
    Canada
    QC
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    I was a bad boy. I tapped it and it sunk in about 1mm and it quit leaking. Gonna add JB weld on top just to be certain.
Similar Threads
  1. CARB TUNE #1 carb o
    By talonsx2 in forum General Tech Talk
    Last Post: 03-29-2011, 09:30 PM
  2. Carb help
    By Bob Myers in forum Royal Star and Royal Star Tour Deluxe Tech Talk
    Last Post: 06-06-2009, 01:37 PM
  3. Carb Jet Kit for Gen 2 RSV
    By wm.butler in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 03-02-2009, 09:06 PM
  4. Carb #1 at O
    By talonsx2 in forum Watering Hole
    Last Post: 07-15-2008, 11:10 AM
  5. Carb Help PLEASE!!!
    By buford7657 in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 04-17-2008, 08:26 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
