ToolmanRR Posted July 29, 2009 Share #1 Posted July 29, 2009 The RSV manual states that the size of the rear tire should be 150/90B15 M/C 74H. I'm looking at getting the following: * Front = Avon 150/80-16 71H * Rear = Avon 150/90B-15 M/C 80H 1) What does the M/C stand for? 2) What does the 74H and 80H stand for? 3) Being the manual states 74H and Avon has a 80H, will that be a problem? 4) Avon also has a 74V. What does the "V" stand for? (Which one is better, the "H" or the "V" series?) Link to comment Share on other sites More sharing options...
GunnyButch Posted July 29, 2009 Share #2 Posted July 29, 2009 Here is the info you need, all decoded here. http://www.webbikeworld.com/Motorcycle-tires/tire-data.htm I used the sizes you are looking at, * Front = Avon 150/80-16 71H * Rear = Avon 150/90B-15 M/C 80H. The 80 is just a higher load rating and H is the speed rating. Link to comment Share on other sites More sharing options...
Scooter Bob Posted July 29, 2009 Share #3 Posted July 29, 2009 (edited) m/c=motorcycle tire 71 and 74 and 80 are the load range, the 80 load range rear is around a hundred pounds more capacity than the stock 74. I think the letter is the speed rating, V is way higer than you need Many here, including me, run the AVON AM42 Venom on the rear 150/90vb-15 Scooter Bob Edited July 29, 2009 by Scooter Bob never mind, someone beat me to it Link to comment Share on other sites More sharing options...
bull463 Posted July 29, 2009 Share #4 Posted July 29, 2009 Hi Be carefule of the Avon Tires I had mine start to crack in the tread area. Avon was not at all helpful in this matter. Just my 2 cents I went to a dunlop and no Im not a tire salesman. Bull463 Link to comment Share on other sites More sharing options...
ToolmanRR Posted July 29, 2009 Author Share #5 Posted July 29, 2009 Thanks for the info. I'm in Phoenix, AZ and I'm getting the bike ready for a ride up to Yellowstone in early September. Then down through Denver and westward accross Colorado (if weather permits) The trees will hopefully be very colorfull. Link to comment Share on other sites More sharing options...
