There is no speaker ballance per say. To test the speakers, put in a tape, and see if you still have the problem. If it seems pretty ballanced then your radio is getting a weak stereo signal and it is more or less mono phonic. Check the antenna connections. If the tape does the same thing, (louder on one side) Clean with contact cleaner and use dielectric grease on all of the connections between the speakers and the radio. If you still have the stock 20 year old speakers it might be time to replace them.
Earl
