nexen tire
wild hair 39
I run the Kumho. It's made in China too and I'm totally satisfied with it. But it's 2-ply tread and 1-ply side. Don't know that I would believe the Nexen is a 4-ply sidewall tho. Usually the only time you see a tire with more than a 2-ply side it's a heavy duty truck tire or a high-end off-road tire.
And the Nexen has a 320 tread wear rating which means it's probably a softer compound. The Kumho has a 400 rating.
Just more info to help in your picking a tire.
  • 2 weeks later...
the nexen is here,BUT they lied to me,the tire 165-80-15 1 ply side 2 ply tread,sidewal is alot harder ,now to see if i can BLOW IT OUT load range is 1200#,don't look as wide as the fed,setting side by side,will get the pict to day,got a 3-5 hr ride to day
What do you attribute the "Blow-Out" to? Did you hit something?
