User Tag List
Thanks Thanks:  0
Likes Likes:  0
Results 1 to 10 of 10
Thread: Intake Manifold Boots (Question)
  1. #1
    Join Date
    Sep 2008
    Crockett
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Intake Manifold Boots (Question)
    Why does it always seem when you try to get ready for a road trip your motorcycles mechanics become a problem.
    I bought a new "to me" Venture a few months back. My brother, son and myself are getting ready for a trip through Arkansas and I decided to bring the Venture in for a good check out a few weeks ago.
    All looked fine until the mechanic saw large cracks (not all the way through) on the Intake Manifold Boots. He has dicked around for almost 3 weeks and we are scheduled to leave Saturday.
    Of course the parts came in yesterday and were wrong
    We are trying to overnight the new ones in and will have to see what happens.
    I got on the phone to call around Houston and see if the parts are available locally (I know it's a long shot) and couldn't find any. But I did find out the price was about $167.16 for the 4 carbs.
    He had quoted me $436.00 for the parts that he ordered. They were the wrong ones but I am interested to see what he says on these one.
    Of course there could be more parts that I am not aware of?
    If he says $436 and I have priced all the parts, then we will part ways in a not so nice manner. I don't want to confront him and find out that I omitted a few parts that justify the cost.
    Any input will be helpful.
    P.S. Nice site and I apoligize for jumping in with a post like this.
  2. #2
    Join Date
    Aug 2006
    Cleveland
    TX
    Post Thanks / Like
    Mentioned
    16 Post(s)
    Tagged
    0 Thread(s)
    Default
    1st off, do you need them right now. The reason I say this is that MANY of the Ventures have cracks in the boots, as long as they aren't leaking it's not going to hurt anything. That price is way steep too unless he's doing all the work and that would still be a bit high. I have seen many cracked carb boots, but never 1 that was bad enough to leak. If your really worried about it spray some either or carb cleaner on the boot and see if your rpm's pick up. That will tell you if they are bad. I know some folks have used liquid electric tape and painted it on the boots to ensure there wasn't a problem.
    Gunboat....I eagerly await the day we can ride together again, Godspeed my brother
  3. #3
    Join Date
    Oct 2006
    Fond du Lac
    WI
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Default
    First - Welcome to the family.
    Second - The intake carb boots are double walled. If you are not seeing performance problems, you likely don't need to worry about them immediately. Also, there is a plastic spray coating that can be used that will fill in these cracks and extend the life of your current boots. It is available at your local hardware store - will have to advise you the name of the product later - it is in my shop and I don't remember the name.
    Someone else may jump on here and let you know.
    Again, welcome to the family.
    RR
  4. #4
    Join Date
    Aug 2006
    Renton
    WA
    Post Thanks / Like
    Mentioned
    8 Post(s)
    Tagged
    0 Thread(s)
    Default Intake Vaccume
    The Intake Vaccume pressure is not all that much.
    I had one that Was leaking, I could actually Hear it, running at 65MPH.
    I stopped and wrapped it with several layers of 'black tape, Everything just fine until I got it replaced.
    Even if yours is leaking, you don't need a set of 4. Just replace the one thats leaking .
  5. #5
    Join Date
    Aug 2006
    Carmichael CA
    CA
    Post Thanks / Like
    Mentioned
    99 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by crockettrider View Post
    The manifold boot bodies don't leak, even with the cracks. They're lined with a metal sleeve up the center. You DON'T need to replace them...and you're getting screwed by the wrench. If you want to make the cracks go away spray them with Plasti-Dip. It's available in the paint dept of Home Depot. The 'O' ring seals on the base will dry out over time and are still available...cheap!! To test, spray volatile carb cleaner around the base. The motor R's will increase if they're leaking. You can also find manifolds on ebay for next to nothing. Like I said you're getting taken for a ride.
  6. #6
    Join Date
    Oct 2006
    Fond du Lac
    WI
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Condor View Post
    Yeah - Plasti-Dip - that's the product I was thinking of.
    RR
  7. #7
    Join Date
    Aug 2006
    Oceanside
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I believe the boots have a center metal "base" in JUST the lower half and THAT'S where most of the cracks show up which means NOTHING to the boot performace, purely cosmetic. The lower half mounts to the engine "firmly" and the upper part has to stretch to accept the carb venturi with clamps.
    Now cracks in the upper half needs addressed but that's real rare.
  8. #8
    Join Date
    Sep 2008
    Crockett
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Wow, all I can say is thanks for all your input.
    I have been running real busy as of late but really look forward to getting to know more of you folks.
    I truly thank you for your input....it is much valued and a relief to boot.
    Let me get through this trip and I would love to do a proper introduction. Thanks again
  9. #9
    Join Date
    Nov 2006
    cleveland
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    hi mark
    welcome to the site, hope you have a great and safe trip. you will be hard pressed to find a nicer bunch of folks anywhere. i have a '99 rsv also with the carb boots that have cracks. i have not noticed any performance issuses. as already stated from the other folks don't worry about the cracks. if you live in crocket your not that far away from me, will be glade to help any time.
    best reguards
    don c.
  10. #10
    Join Date
    Aug 2006
    Ruidoso area, NM
    NM
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Cool Where are you?
    I don't know where you are in Texas, but if near DFW you need to bring that thing over here and let me do a quick once-over for you and sync the carbs. Won't take us more than about 30 minutes unless we find something wrong.
    Goose
    Hidden Content V7Goose - Patriot Guard Rider
    Venture Riders meet on Channel 29!
    Hidden Content
    Iron Horses in the stable: 05 RSV QuickSilver, 79 Guzzi G5 LAPD, 75 Guzzi Eldorado Police, 73 Guzzi Ambassador/hack
    Iron Mules in the stable: 07 Yamaha Rhino 660 Sport, 94 F250 4x4
Similar Threads
  1. What I learned today about intake manifolds
    By Dragonslayer in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 03-12-2015, 11:26 PM
  2. boots
    By treeman in forum Watering Hole
    Last Post: 01-07-2009, 01:52 PM
  3. Linked intake
    By az1103 in forum Watering Hole
    Last Post: 06-24-2008, 05:38 PM
  4. Intake Boots?
    By yamahamer in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 02-25-2008, 03:52 PM
  5. Intake restriction?
    By Numb Knuckles in forum General Tech Talk
    Last Post: 09-07-2007, 09:49 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
