dingy Posted September 29, 2008 Share #1 Posted September 29, 2008 What is the correct location of the thick washer on the right side of rear axle? Is it against the wheel hub or against the swing arm? This affects the rear caliper arm mounting position. The service manual does not clearly show this that I can find. Thanks, Gary gary@dinges.com Link to comment Share on other sites More sharing options...
Freebird Posted September 29, 2008 Share #2 Posted September 29, 2008 It goes up against the caliper bracket on the swingarm side. Not against the hub. See this thread for some close-up pictures. http://www.venturerider.org/forum/showthread.php?t=515 Link to comment Share on other sites More sharing options...
lonestarmedic Posted September 29, 2008 Share #3 Posted September 29, 2008 Dingy- Sent you an e-mail with a couple pictures. Also look at the threads I mentioned. That should get you straight. JB Link to comment Share on other sites More sharing options...
dingy Posted September 30, 2008 Author Share #4 Posted September 30, 2008 Thank you for the replies !! Gary Link to comment Share on other sites More sharing options...
