calperin Posted August 25, 2008 Share #1 Posted August 25, 2008 I finished to receive the two LED's from e-bay that has both position lights and brakes. I forget the simplest thing when I order it about how the socket was facing to.... So, I get the light looking to the side metal piece instead of the red plastic. Did someone knows if there is any adapter made for 90º angle for 1157 lamps? Thanks in advance. I know that I saw in the past those lamps, but when you need it you never find where was their website. Again thanks, :crying::crying: Link to comment Share on other sites More sharing options...
Steve S Posted August 25, 2008 Share #2 Posted August 25, 2008 (edited) Calperin Super Bright LEDs, www.superbrightleds.com , makes a 90 degree replacement LED in both 1156 and 1157. They also have electronic flashers that will run the LEDs. I'm kicking around getting a set to try em out. I know the turn signal uses a 2 prong flasher, but I'm not sure about the emergency flasher. I'll have to pull it to see. Good luck with your search. Edited August 25, 2008 by Steve S Link to comment Share on other sites More sharing options...
