User Tag List
Thanks Thanks:  0
Results 1 to 11 of 11
Thread: Cutting spring coils
  1. #1
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    144 Post(s)
    Tagged
    0 Thread(s)
    Default Cutting spring coils
    I bought a 2014 Ram 2500 with rear coil springs to pull my 5th trailer. Turns out that the truck is to high to properly level the whole unit for towing. I need to lower the truck, max I can do that is about 2inches. Looked for shorter coils, but they are not available on short notice, guess some would make them on special order but that would take about 6 months. The only solution for me at this point is to cut the coils to lower things the 2 inch that there is room for. Plan to use no heat, keep air moving over the cut as we cut with a disc.
    Flipped the axle on the trailer, but that was not a good idea, looks like it's on stilts now and is too high.
    Any experience to learn from? input?
    Nothing in this life
    will
    Get in the way of my future
  2. #2
    Join Date
    Jan 2009
    Bessemer City, NC
    NC
    Post Thanks / Like
    Mentioned
    17 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Cutting spring coils
    I would install air bags so you can set the highth where ever you want. Cutting coils is a dangerous situation unless they are removed from the truck. My worth.
    Jim aka Sylvester
    Where did all the years go? I'm trying to catch up with my father.
  3. #3
    Join Date
    Aug 2006
    Rock Bridge
    WI
    Post Thanks / Like
    Mentioned
    23 Post(s)
    Tagged
    0 Thread(s)
    I have a2001 ram 2500 and a number of years ago I was thinking the same thing.
    After talking with lots of people, I put a 2" leveling kit on which raises the front and it is now level.
    Not sure that will solve your problem with a 5th wheel.
    I assume you know about drop hitches?
  4. #4
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    144 Post(s)
    Tagged
    0 Thread(s)
    Thanks so far. My issue comes with the truck bed rails getting too close to the 5th wheel overhang. Raising and/or adjusting the hitch or pinbox will not change that dimension.
    will
  5. #5
    Join Date
    Nov 2007
    falling waters
    WV
    Post Thanks / Like
    Mentioned
    20 Post(s)
    Tagged
    0 Thread(s)
    Carl you should be able to get a set of coil spring compression kit. Most auto stores sell them and any speed shop should carry them. They consist of two bolts and a muffler type clamp. You tighten the bolts and the spring compresses. Cheap and easy fix for what you want.
    [SIGPIC] Kevin Smith (Revks) If you waited until there is nothing else left to do but pray, you started praying too late.
  6. #6
    Join Date
    Apr 2014
    Wilmington, NC
    NC
    Post Thanks / Like
    Mentioned
    21 Post(s)
    Tagged
    0 Thread(s)
    I have cut coil springs before in my 1970 Mustang (long time ago). It came with a 302 cu in V8 and C4 auto. I wanted it to handle better and part of what I did was to install 428 cu in V8 springs. Naturally they raised the front way too high so I removed them and cut 3/4 of one coil off with a hack saw. The hack saw easily cut through the steel used for coil springs. They aren't that hard because they have to have lots of tensile strength.
    But, cutting the coils will cause the suspension to bottom out quicker. I don't know if that will be a problem in your situation.
    2007 Yamaha Royal Star Venture
    1989 Yamaha Venture Royale
    1985 Kawasaki ZN700 4cyl shaft
  7. #7
    Join Date
    Sep 2013
    Canandaigua,NY
    NY
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    (Turns out that the truck is to high to properly level the whole unit for towing. I need to lower the truck)
    Let the air out of the tires.
  8. Likes chabicheka liked this post
  9. #8
    Join Date
    May 2013
    Indianapolis
    IN
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    If flipping the axle made the 5r too high, can you fabricate a block between the axle, get longer U bolts, to just raise it some? I'm on a RV Forum, and this is not uncommon, really pisses some off. Most guys just run their 5r nose high and forget about it. I would be concerned personally to lower the truck by cutting spring, It has to weigh in on the whole dynamics, and you still will have all that weight on them. Have you actually hitched up? The squat on your truck might be a more than you expect, making the tape measured values not so bad. Good Luck.
  10. #9
    Join Date
    Aug 2006
    Carmichael CA
    CA
    Post Thanks / Like
    Mentioned
    104 Post(s)
    Tagged
    0 Thread(s)
    Back when I was a kid we just heated one of the coils and they collapsed.... Never cut them...
  11. #10
    Join Date
    Aug 2006
    Grovertown,IN.
    IN
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
  12. #11
    Join Date
    Sep 2010
    Sebring FL
    FL
    Post Thanks / Like
    Mentioned
    17 Post(s)
    Tagged
    0 Thread(s)
    Heating coils softens the springs, cutting coils out shortening them normally stiffness them up. I use to do both for my street stock race car. Depended what I needed.
    2013 Black Victory XCT
    Trailers are for when your bike is broke, aint they?
Similar Threads
  1. Replies: 4
    Last Post: 04-02-2014, 04:17 PM
  2. Rock cutting
    By dray in forum Watering Hole
    Last Post: 07-19-2013, 03:35 PM
  3. cutting out
    By warrior/honeybee in forum Watering Hole
    Last Post: 08-01-2010, 08:03 PM
  4. cutting my windshield
    By Donde in forum Watering Hole
    Last Post: 11-03-2009, 11:11 PM
  5. Radio cutting out
    By Goofeychuck in forum GPS, Audio, Electronics
    Last Post: 09-15-2009, 08:04 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
