User Tag List
Thanks Thanks:  0
Results 1 to 6 of 6
Thread: My XVZ1200
  1. #1
    Join Date
    Nov 2019
    Morden
    Canada
    MB
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default My XVZ1200
    Has any one ever moved the forks up through the steering head ...Up high enough to install the air fittings above the triple tree on a 1983 XVZ1200
  2. #2
    Join Date
    Aug 2006
    Carmichael CA
    CA
    Post Thanks / Like
    Mentioned
    103 Post(s)
    Tagged
    0 Thread(s)
    Default Re: My XVZ1200
    Quote Originally Posted by larrydr View Post
    they used to sell an equalizer kit that fit in the top cap. for some reason they stopped making them, or the company went out of biz?
    it basically had Schroeder valves tapped into the cap.
  3. #3
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    133 Post(s)
    Tagged
    0 Thread(s)
    There is a spring clip on the fork that prevents the fork from sliding up any further into the tree. The torque on the clamps of the triple tree is not enough to hold the forks in place, so the spring clip is used. If you remove the clips then the forks will slide higher and if you want to keep them from sliding you'll have to increase the torque on the clamps. Don't have any idea how much.
    Nothing in this life
    will
    Get in the way of my future
  4. #4
    Join Date
    Nov 2019
    Morden
    Canada
    MB
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Marcarl View Post
    Thanks......
    Would adding a aluminum set of clamps around each fork below the tree do the job
  5. #5
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    133 Post(s)
    Tagged
    0 Thread(s)
    Getting the forks exactly to the same length is kind of tricky, a little bit off and you screw up the ride and handling. The spring clips are dead on so you can depend on those to be right, maybe not so much on adhoc measures. Forks are smooth, and not much for any clamp to grab onto and hold through a serious bump or constant bumpering vibration. I would go with the drilling out of the caps and install a valve there.
    Keep in mind also, that if you bring the forks up through the triple tree you will be lowering the whole bike, which will play with the dynamics of the ride and clearance issues with the front fender, ground clearance with the nose cone, oil in the crankcase, braking on the rear wheel,,,,,,,
    will
  6. Likes WRIDR liked this post
  7. #6
    Join Date
    Nov 2019
    Morden
    Canada
    MB
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks what you are saying makes sense ...There also a saying always simple , but not so easy
Similar Threads
  1. XVZ1200 Front End
    By larrydr in forum Watering Hole
    Last Post: 07-07-2020, 08:25 PM
  2. My xvz1200
    Last Post: 06-27-2020, 12:06 AM
  3. XVZ1200 seat
    By Huggy in forum Watering Hole
    Last Post: 07-22-2013, 11:40 AM
  4. xvz1200 trunk pad
    By Daitan in forum Watering Hole
    Last Post: 02-17-2013, 01:06 PM
  5. Ever seen a yellow XVZ1200?
    By Sandbagger in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 10-31-2009, 01:28 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
