Barnie Posted July 28, 2020 Share #1 Posted July 28, 2020 I wanted to go for a ride last week and when I turned the key there was no power. The battery tested good, I did the test on the ignition switch and there is continuity in the switch. There is power going to the ignition switch. I checked the 30 amp fuse and all is good. I read on the form that the starter relay can get corroded and fail. I cleaned all connections on the relay yet still no power. Any suggestions Link to comment Share on other sites More sharing options...
XV1100SE Posted July 28, 2020 Share #2 Posted July 28, 2020 Hello from Kitchener ! What lights come on the dash? Headlight come on? If everything powers on (radio?) ...dumb question...check the kill switch on the handlebars? One other thing that can cause no starting is issue with the kickstand switch. There is a test for this on the forum. If you aren't getting any power at all...check the fuses in the lower cowls? If everything powers up but the starter doesn't activate...are you getting power there? Link to comment Share on other sites More sharing options...
XV1100SE Posted July 28, 2020 Share #3 Posted July 28, 2020 Check this thread - https://www.venturerider.org/forum/showthread.php?118081-Starter-just-quit&highlight=kickstand+switch https://www.venturerider.org/forum/showthread.php?80892-Bike-Didn-t-Crank-No-Noise-at-All&highlight=kickstand+switch https://www.venturerider.org/forum/showthread.php?50371-bypassing-kickstand-switch&highlight=kickstand+switch When you turn the key do you hear the fuel pump clicking? If your battery tests as good...double check your grounds. Link to comment Share on other sites More sharing options...
Barnie Posted July 31, 2020 Author Share #4 Posted July 31, 2020 Afternoon All: When I say no power I mean it. If I slowly turn the ignition switch I get a flick of light in one of my marker lights, that’s it. I tested the ignition switch as per the form and saw all the ways to by-pass it, I believe the ignition switch is good, I’ve had one of them fail in the past. I believe it is the starter relay or a bad ground. 30 amp fuse also good. Also battery load tested and passed with flying colours Link to comment Share on other sites More sharing options...
sldunker Posted August 1, 2020 Share #5 Posted August 1, 2020 Two things come to my mind right away. Kill switch and starter relay. The starter relay has been known to corrode up and cause problems. If the kill switch was on you should still get power to dash but nothing else. Link to comment Share on other sites More sharing options...
Barnie Posted August 1, 2020 Author Share #6 Posted August 1, 2020 Thanks will give it a try in the next couple of days. Just paid for my membership. Was a member in 2006, never had a problem with the bike since. Can’t run these forms for nothing. Link to comment Share on other sites More sharing options...
Barnie Posted August 3, 2020 Author Share #7 Posted August 3, 2020 Nope not the starter relay. Has anyone ever had the ignition switch go so bad that it cuts out all power. Really ripped into the bike. Starting to trace and test all wires. Link to comment Share on other sites More sharing options...
djh3 Posted August 4, 2020 Share #8 Posted August 4, 2020 They have like 2 positions. An acc and a run. The contacts can get arc and then dont make good contact. There is a thread here in the 2nd gen fix on how to take it apart and clean the contacts. I make a relay that by pass the high amps from the switch. But figure out what you got going first. So you have no lights at all? Try switching the kill switch on and off a few times and may clean contacts. If you decide to take that switch apart be advised there are some tiny springs in there. Link to comment Share on other sites More sharing options...
