Marco Air Horn install question.
I am almost positive you need to use the relay or you can draw too much power on the wires. I would guess there is already a relay there, but is it good enough? Other smarter than I, will be along soon with better answers, I just wanted to give a quick, I wouldn't before you do and regret it. Good luck :happy34:
You need to run a hot wire from the battery through a relay. Use the factory wires to trip the relay.
So do you mean the factory horn wires?
I will be disconnecting the factory horn so should I be able to use them for power, correct?
