User Tag List
Page 1 of 3 123 LastLast
Results 1 to 15 of 34
Thread: First time I am saying " this is a must have" for your bike or your whole stable.
  1. #1
    Join Date
    Apr 2013
    Portland
    OR
    Post Thanks / Like
    Mentioned
    53 Post(s)
    Tagged
    0 Thread(s)
    Default First time I am saying " this is a must have" for your bike or your whole stable.
    Hi all.
    I am always searching for motorcycle products to review and I came across an awesome one.
    Take that "emergency" $100 bill out of your wallet and get ready to use it.
    Even my brother cowpuc isn't fond of laying down on his back to check the tire pressure on Tweeks.
    I know I don't look forward to doing it, especially if I have 'nice' clothes on.
    This is a bluetooth remote tire pressure monitoring system where you see your tire pressure on your phone. Of course you get warnings of leaks, but the real value in my estimation is the weekly check before your Saturday ride or the concern while on the road that some punk let some air out of your tires at the motel....
    I hope this is a good read for you.
    https://ultimatemotorcycling.com/202...toring-system/
    VentureFar...
    VentureFar...
    IBA 55699
    6/ 8/ 2013 1054 miles in 21 Hours
    12/ 29/ 2013 1024 miles in 17 Hours - why 2? really want that Mile Eater IBA Shirt
  2. Thanks divey, cami, SilveradoCA, gmarshall, cowpuc gave thanks for this post
    Likes divey, cami, cowpuc liked this post
  3. #2
    Join Date
    Jul 2016
    Youngstown
    OH
    Post Thanks / Like
    Mentioned
    13 Post(s)
    Tagged
    0 Thread(s)
    Default Re: First time I am saying " this is a must have" for your bike or your whole stable.
    Thanks! I just order a set of these and the T fittings for the '06.
    TANSTAAFL
  4. #3
    Join Date
    Sep 2010
    Dunlap, IL
    IL
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Neil,
    Does the device need to be removed to add/remove air from the tire?
    Are the batteries unusual or readily available?
    The current 2 wheel fleet:
    2012 Venture, 1980 Kawasaki KZ750, 1978 Honda CB750,
    1977 Honda GL1000, 1977 Honda GL1000,
    2007 Kymco Grand Vista
  5. #4
    Join Date
    Aug 2006
    Oberlin, OH
    OH
    Post Thanks / Like
    Mentioned
    205 Post(s)
    Tagged
    0 Thread(s)
    It appears that the tires has to be removed to install these. Am I correct?
    And luvmy40. What T Fittings are you talking about?
  6. #5
    Join Date
    Apr 2013
    Portland
    OR
    Post Thanks / Like
    Mentioned
    53 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by vzuden View Post
    Neil,
    Battery is cr1632 readily available, and extra set comes in the box. The app shows you the battery life.
    Yes theyhave to be removed to add air but screw in just like the plastic dust cap if you are not using the locking nuts. Just unscrew the “cap” like normal and when done then replace.
    the T valve is a nice thing because you leave the unit screwed on and use the T off to fill the tire. But you need to make sure you have enough physical space for the T to work.
    I don’t see a reason go to the extra hassle of installing the T valve. You will be be checking your tire pressure from your phone from now on and maybe once a month or two months will you need to unscrew the unit off. And like I said it is just like the plastic cap you have now.
    you can see the T on the my-FOBO.com website under accessories
    remember to set the UPPER limit to the rating on the side wall. I first set mine too low and got an earful on the freeway about 15 minute in when the rear heated and gained 7#.
    so I have them set now as 33 low. Optimum 36 and high 44.
    VentureFar...
    IBA 55699
  7. #6
    Join Date
    Apr 2013
    Portland
    OR
    Post Thanks / Like
    Mentioned
    53 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Freebird View Post
    No. You do not need to remove the tire to install them. Just the plastic valve stem cap. That’s all.
    they suggest that you have METAL valve stems and actually put two in the box. But not required.
    VentureFar...
    VentureFar...
    IBA 55699
  8. #7
    Join Date
    Jul 2017
    Winnipeg
    Canada
    MB
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Just spent the last half hour reading thru the FOBO info. Looks to be a fairly well thought out setup. The "manual" is very clear and easy to follow, and installation looks to be as simple as threading on new valve caps and following the phone prompts. I don't normally get too fired up about on-line "you need this in your life" stuff, but this seems to be a good place to spend a bit of my retirement fund, so I ordered a set.
    I am making an assumption on the "T" valves, in that they look to be needed if you are running rubber stems, or are installing new shoes and are going to put new valves in anyway. Nice idea having one leg of the "T" as an air fill point. I've got steel stems so I'll find out when the package arrives if I should have ordered the "T"s.
    I've had RideOn Tire Sealant in both tires for a couple of months and so far have seen a drop of only 2 pounds per tire...possibly from the daily pressure check before each ride, so I'm not worried about the occasional time I would have to pull the sensors off to add air, since having the sensors on means my daily pressure check is now on my phone. Plus, RideOn will balance out the slight weight of the sensors. Under 8 grams..just slightly more than most credit cards.
    As is often said...time will tell.
    Cheers....
    Papa Fred
  9. #8
    Join Date
    Jul 2017
    Winnipeg
    Canada
    MB
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Cheers....
    Papa Fred
  10. #9
    Join Date
    Jul 2016
    Youngstown
    OH
    Post Thanks / Like
    Mentioned
    13 Post(s)
    Tagged
    0 Thread(s)
    If you look in the accessories section, there are two different styles of T fitting. One is installed in place of your valve stem and the other just screws onto your existing valve stem. I ordered the ones that screw on.
    I put angled valve stems on The beast to make checking and filling easier. I am going to try these Ts on the '06. They look to be about an 1-1/2" long with a side stem, so you mount the TPS sensor on the top leg and fill through the side leg, 90 deg. opposed from the standard stem.
    TANSTAAFL
  11. Likes videoarizona liked this post
  12. #10
    Join Date
    Apr 2013
    Portland
    OR
    Post Thanks / Like
    Mentioned
    53 Post(s)
    Tagged
    0 Thread(s)
    Since you are actually going to “touch” your valve stem once a month or less now, fully knowing what you pressure is, I don’t see a need for the extra convenience of the T valve stem. But that’s just me.
    The screw in process is obviously simple. But when you do the first installation FOLLOW THE INSTRUCTIONS EXACTLY.
    They are Bluetooth and will “compete” to be read by the install app. So put the first one on the FRONT. There is no front or rear unit identified until you register one or the other in the app. Follow the instructions. Then when the front is showing on the app then screw in the rear and install it. You have to “touch” the unit with your phone in the app install process . Don’t have the other unit in your big mitt at the same time Since both will be touching the phone. Keep the second unit on your work bench or several feet away.
    like I said, this thing works and works well. It will keep you off your back/ knees until needed to be.
    Enjoy the new free time :-)
    VentureFar...
    VentureFar...
    IBA 55699
  13. #11
    Join Date
    Oct 2010
    Abington
    MA
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I've been running these since 2015 and have loved them. The set I have is the first generation which is no longer available, I have not felt the need to upgrade to the new FOBO Bike 2. The battery life leaves a little to be desired, I change them in the spring, and then again halfway through the riding season, but other than that I think this is excellent technology and a great investment for the price.
  14. #12
    Join Date
    Apr 2013
    Portland
    OR
    Post Thanks / Like
    Mentioned
    53 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by bostonlawman2003 View Post
    I have only had them for a few weeks but I am already seeing the benefits.
    thanks for the reply
    VentureFar...
    VentureFar...
    IBA 55699
  15. #13
    Join Date
    Sep 2006
    Burlington, ON
    Canada
    ON
    Post Thanks / Like
    Mentioned
    72 Post(s)
    Tagged
    0 Thread(s)
    I notice it states that it is Dust and waterproofing: IEC 60529 compliant but does not state to what degree of IP standard it measures up to. For example is the unit only water spray resistant or is it water proof in standing water or high pressure water spray. It would really suck if after spending all that money that you discover water got into the electronic portion and ruined it.
    Also what kind of permissions does the APP require. I find some APPS like the one for my BBQ temp monitor wants access to everything on my phone. Just to measure my meat Temp? Needless to say I do not use the APP, its not that hard to get up and walk over to my BBQ.
    I AM A DRINKER OF THE WIND
  16. #14
    Join Date
    Apr 2013
    Portland
    OR
    Post Thanks / Like
    Mentioned
    53 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by saddlebum View Post
    Hi Good catch. The editor didn't finish the compliant.... to IP57(sensor)
    it is waterproof. I asked him to finish that line in the specs
    This is what it asked for to give you immediate alerts:
    on the iPhone, background refresh must be on as well as locations services on Always for the FOBO Bike 2 app. The Android smartphone must have Android Service running, ...
    I use an iphone and turn off location services ALWAYS and BACKGROUND app refresh when I am not on the bike as they do use battery power. When I am going for a ride I turn those on to get ALERTS.
    If you don't care about low or high pressure alerts while riding then location and backgroud refresh can be off.
    As I said earlier, just not having to lay on my back to check the rear pressure and not have to get down my my rickety knees for the front pressure are worth the admission price.
    Good questions.
    VentureFar...
    VentureFar...
    IBA 55699
  17. #15
    Join Date
    Sep 2011
    Colorado Springs
    CO
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    I like the idea of a TPMS for my bike but have three issues with this system:
    1. non-metal stems. My current ride has spoked wheels, and consequently tubes in the tires. FOBO does not recommend rubber stems.
    2. Location services on. The only apps on my iPhone that can track my location are ones that I deem should have them. All others are off. The reason (altitude adjustment) just seems a little overkill to me.
    3. Automatic updates on. I update apps when I want to, using Wifi, not whenever the app decides it needs a new version. This updates are mainly to change the ads anyway.
    These concerns may keep me from purchasing this product, maybe some other company has a different setup?
    My
    I didn’t say you did it, I said I was blaming you.
Similar Threads
  1. Replies: 34
    Last Post: 11-24-2019, 03:04 PM
  2. Replies: 5
    Last Post: 06-15-2019, 09:34 PM
  3. Replies: 12
    Last Post: 06-11-2017, 12:20 AM
  4. Replies: 39
    Last Post: 08-16-2010, 01:32 PM
  5. "Wheels Through Time" RafFle Today
    By stardbog in forum Watering Hole
    Last Post: 11-10-2007, 11:34 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
