luvmy40 Posted July 13, 2020 Share #1 Posted July 13, 2020 There is a small button switch next to the power port in left inner fairing of my '06 RSV. It does not seem to do anything. One would assume by it's location that it was intended to turn the power port on or off. I had 12.5VDC at the power port regardless of the switch position. So; What Does This Button Do? Link to comment Share on other sites More sharing options...
Condor Posted July 13, 2020 Share #2 Posted July 13, 2020 If I remember correctly it is used to turn the aux driving lights on or off..... It's been awhile since doing any night riding... Link to comment Share on other sites More sharing options...
Freebird Posted July 13, 2020 Share #3 Posted July 13, 2020 Condor is correct. Link to comment Share on other sites More sharing options...
luvmy40 Posted July 13, 2020 Author Share #4 Posted July 13, 2020 OK, Thanks. Now I need to check to see if I have the aux. lights turned on or off! I was mucking about with that button a good bit when I was installing the phone mount/charger. Link to comment Share on other sites More sharing options...
Condor Posted July 14, 2020 Share #5 Posted July 14, 2020 OK, Thanks. Now I need to check to see if I have the aux. lights turned on or off! I was mucking about with that button a good bit when I was installing the phone mount/charger. That's always been my problem when running during daylight hours for visibility. Can never remember if they are on or off after a day in the saddle.... Link to comment Share on other sites More sharing options...
videoarizona Posted July 14, 2020 Share #6 Posted July 14, 2020 Replacing the headlight and aux lights with LEDs is "almost" mandatory as the the alternator output is marginal at best. I replaced my headlight with an LED bulb and like the pattern and throw far better. I haven't been able to find the parts needed to put aux lights on...yet. Link to comment Share on other sites More sharing options...
BlueSky Posted July 14, 2020 Share #7 Posted July 14, 2020 Hey, I never noticed the power port!! And now that I've found it, I don't see the subject switch? Link to comment Share on other sites More sharing options...
videoarizona Posted July 14, 2020 Share #8 Posted July 14, 2020 No switchie...no lights from factory(dealer). My switch area is vacant as well..... Link to comment Share on other sites More sharing options...
Freebird Posted July 14, 2020 Share #9 Posted July 14, 2020 The switch came with the OEM passing lamp kit. If you don't have the lights, you won't have the switch. Even if you have the lights, it would depend upon the installer using the switch. They should have but you never know. Link to comment Share on other sites More sharing options...
BlueSky Posted July 14, 2020 Share #10 Posted July 14, 2020 (edited) Thanks, I googled photos and saw what those lights look like. I don't really like the looks of them. They make the bike look even more like a Hardley. Just my smelly opinion of course! Apologize for any offense! Edited July 15, 2020 by BlueSky Link to comment Share on other sites More sharing options...
SilveradoCA Posted July 16, 2020 Share #11 Posted July 16, 2020 Replacing the headlight and aux lights with LEDs is "almost" mandatory as the the alternator output is marginal at best. I replaced my headlight with an LED bulb and like the pattern and throw far better. I haven't been able to find the parts needed to put aux lights on...yet. I just ordered some 15W LED PAR36 lamps for mine. I'll let you know how (and if) they work once I get them. Link to comment Share on other sites More sharing options...
SilveradoCA Posted July 17, 2020 Share #12 Posted July 17, 2020 After seeing this thread, I had a look at my bike; the little button near the power port turns my driving lamps off, but only while the button is depressed. When I let go, the lights come back on, as if it were wired as a temporary flash switch. I don't know if they were wired wrong or if this is one way it could normally be done, but it seems kind of useless? It's a long, awkward reach forward and under the bars just to flash those lamps. I actually thought that button was to reset the power port like a breaker, in case too much load was applied, like from a compressor or something. The next time I have the fairing open I'm going to try to re-wire those lights, to make them pull power from a relay rather than through the ignition switch. Maybe I can get the on/off button to work too. Link to comment Share on other sites More sharing options...
XV1100SE Posted July 17, 2020 Share #13 Posted July 17, 2020 After seeing this thread, I had a look at my bike; the little button near the power port turns my driving lamps off, but only while the button is depressed. When I let go, the lights come back on.... The button switch is a "click". If when you push it and release it doesn't turn the lights off (and stay off) then it sounds like you need to replace the switch. When I installed mine I had read issues with the button switch so I installed a toggle instead. Just make sure what you put in is waterproof. For those that don't know... there is a write up about how to install the passing lights with switch and relay. The OEM instructions put load on the ignition switch (from memory so I may be incorrect on where the load is). The write up on here says what wires to tap into for the relay. You can wire them so that the passing lights only come on with low or high beam....or be on all the time (and controlled by the switch on the back of the fairing). I wired mine so that they are controlled by the switch. Power to the relay comes from a 6 gang fuse block I installed inside the fairing (provides power for GPS, passing lights.... ) Link to comment Share on other sites More sharing options...
SilveradoCA Posted July 17, 2020 Share #14 Posted July 17, 2020 What you describe is exactly the functionality I'm looking for, and I remember seeing at least one post about how to wire it, maybe another on the other Venture site too. Thanks friend-o. Link to comment Share on other sites More sharing options...
BratmanXj Posted July 17, 2020 Share #15 Posted July 17, 2020 BTW, it's helpful to get a lighted switch that shows if its on or off...how else do you tell if your spot lamps are on while your seated on the bike with no cars to check for your reflection Link to comment Share on other sites More sharing options...
Freebird Posted July 17, 2020 Share #16 Posted July 17, 2020 The original switch is NOT a temporary push to flash button. It should turn the light on and off. If it is not staying off, then I would say that the switch is bad. Link to comment Share on other sites More sharing options...
SilveradoCA Posted July 17, 2020 Share #17 Posted July 17, 2020 The original switch is NOT a temporary push to flash button. It should turn the light on and off. If it is not staying off, then I would say that the switch is bad. You may be right Freebird. Since I didn't know it existed prior to this, my life isn't diminished by the deficiency of it though LOL. Just another item to put on THE LIST... Link to comment Share on other sites More sharing options...
rbig1 Posted July 29, 2020 Share #18 Posted July 29, 2020 did away with my switch rather replace bulbs, than have them off. More light during the day the better and at nite. Link to comment Share on other sites More sharing options...
Marcarl Posted July 29, 2020 Share #19 Posted July 29, 2020 I didn't do anything to mine either,,,, come to realize I don't have that bike and so don't need to worry about such things. It's nice to have a Spyder.!.! And it was time to add to my post count??? Link to comment Share on other sites More sharing options...
Jthomas Posted July 30, 2020 Share #20 Posted July 30, 2020 Replacing the headlight and aux lights with LEDs is "almost" mandatory as the the alternator output is marginal at best. I replaced my headlight with an LED bulb and like the pattern and throw far better. I haven't been able to find the parts needed to put aux lights on...yet. I got into a minor wreck in the spring. The body shop said that Yamaha discontinued the aux lights that I have, but they replaced them with new LED ones. I'm out of town right now, once I get home I'll try to remember to see if I can find invoice with all the parts they replaced. They say their LEDs but they still have a yellowish-incandescent tint and look. However, I do notice a HUGE difference now when they are on. Before they were more for increasing the chance of being seen but little on lighting up the road. Now it's about 25% increase when I turn them on. I'll also try to post a picture, although for some reason this forum never accepts my pictures. Link to comment Share on other sites More sharing options...
fltmedic Posted August 1, 2020 Share #21 Posted August 1, 2020 Rich, When i owned the bike I rarely to never turned them off with the switch... so the switch could be stuck in the closed position. Would be an easy job to replace the button switch with a toggle switch if its not working correctly. Link to comment Share on other sites More sharing options...
fltmedic Posted August 1, 2020 Share #22 Posted August 1, 2020 For the passing or aux lights on the Gen 2 I had replaced the incandescent lights with the following from Amazon last year (early 2019): LX-LIGHT Dot approved 2 PCS Chrome 4.5 Inch Cree LED Passing Light LED Fog Lamps for Motorcycles Auxiliary Light Bulb Motorcycle Projector Driving Lamp Sold by: LX-LIGHT Amazon still has them for $38.59 for the pair. I liked the way they work, but you can ask luvmy40 his opinion as this faithful steed is now his. LX-LIGHT Dot approved 2 PCS Chrome 4.5 Inch Cree LED Passing Light LED Fog Lamps for Motorcycles Auxiliary Light Bulb Motorcycle Projector Driving Lamp Sold by: LX-LIGHT Link to comment Share on other sites More sharing options...
DanPort Posted August 4, 2020 Share #23 Posted August 4, 2020 I like the idea of being seen all that much better during the day. I leave mine on all the time. Link to comment Share on other sites More sharing options...
