User Tag List
Results 1 to 15 of 15
Thread: Asking for opinions
  1. #1
    Join Date
    May 2020
    Chippewa Falls
    WI
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Asking for opinions
    Hello all!
    I just purchased a 1985 Venture Royale. I am real excited about putting some miles on this bike. Your forum help me check many components before making the buy, and so far it seems like a great bike. I have found some manuals online, and got the original owner's manual(water damaged)with the bike. I recently refurbished my 1986 Yamaha radian. I could use some help learning the finer points of the air suspension, and what everyone prefers for tires, oil, and plugs. Thanks to all who respond!
  2. #2
    Join Date
    Apr 2014
    Wilmington, NC
    NC
    Post Thanks / Like
    Mentioned
    19 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Asking for opinions
    Tires and oil are both popcorn time. Lots of opinions and they may all be good. Sticking with Jaso rated oil would be my recommendation. Tires? Anything that fits and has the proper rating. Dunlop elites seem to be a favorite as well as a less expensive Shinko.
    If you haven't gone to the tech section you should and read all about the Gen Is.
    2007 Yamaha Royal Star Venture
    1989 Yamaha Venture Royale
    1985 Kawasaki ZN700 4cyl shaft
  3. Likes Bemental, Patch liked this post
  4. #3
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    120 Post(s)
    Tagged
    0 Thread(s)
    Other than the normal stuff like brakes, tires, wheel bearings, head bearings, wire connectors, light bulbs, switches, rust and polish, leaky gaskets, torn seats, cracked tupperware, scratched windshield, leaky forks, there is some other stuff that might be hidden.
    Poor starter, cracked starter clutch, worn clutch plates, but most of all,,, missing second gear and that would depend on the vin number. The thrust washer that caused the 2nd gear issue was upgraded mid 85, but I don't know the vin number of the change. @Parriehammer would know this maybe.
    Do it now, before you forget again.
    Register today
    Rally @ T h e S h o r e s
    July 16-19th 2020
  5. Likes Patch liked this post
  6. #4
    Join Date
    May 2013
    Indianapolis
    IN
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Welcome to the Forum.
    Tires: I'm a fan of Shinko's
    Oil: I'm a fan of Rotella with a Wix filter, change every 3k
    Air: I run my front with maybe 1 psi, rears at 40
    Plugs: I run stock what the manual calls for, replaced my boots a couple years back.
    I ride mostly afternoons in the country, never out of state. I put maybe 6k miles a year on my 83, mostly country cruising speeds, occasionally wide open
  7. Likes Patch liked this post
  8. #5
    Join Date
    Apr 2019
    Katy
    TX
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Asking for opinions on this site could be dangerous:
    Don't end up in pieces. Riding should be your Peace.
  9. Likes Patch liked this post
  10. #6
    Join Date
    Jul 2016
    Black Hills
    SD
    Post Thanks / Like
    Mentioned
    21 Post(s)
    Tagged
    0 Thread(s)
    Which tires are best is a huge topic. I'm using a set of Dunlop E3, and I like em enough to use E4 next time around. I did not like the Metzler Marathons r/t uneven wear and cupping. There are a lot of good tire choices.
    Oil: another big subject, but an overwhelming number of folks here and in the Vmax world prefer to use good ol' Rotella T4 (non-synthetic) 15 40. T5 and T6 are semi and full synthetic and many of us avoid that and just use conventional Rotella. It's listed as a diesel oil but it works quite well. I use in both my 1st gen Vmax and Venture and have been for a few years now.
    For filters, really avoid Fram or any Chinese no-names. NAPA Golds are WIX and great quality. There are other parts house brands that are decent and some to avoid, but those escape my brain right now. There is an oil thread here somewhere (probably many) that talk about the best filters to use.
    Congrats on your new bike!
  11. Likes Patch liked this post
  12. #7
    Join Date
    Jul 2013
    Calgary
    Canada
    AB
    Post Thanks / Like
    Mentioned
    16 Post(s)
    Tagged
    0 Thread(s)
    Unlike SOME CANADIANS I am much less opinionated this early in the DAY!
    Now there once was this Canadian feller went of to California'a! He went a cruising one Californian rainless day in his kinda old ford thru demdare hills.!
    He got'so inspired he wrote himself a tune, it goes somethin like
  13. Likes SpencerPJ liked this post
  14. #8
    Join Date
    Apr 2014
    Wilmington, NC
    NC
    Post Thanks / Like
    Mentioned
    19 Post(s)
    Tagged
    0 Thread(s)
    Oh, I remembered that several bikers have had chunks of the tread thrown when riding on the interstates when they used Metzler 880's.
  15. #9
    Join Date
    May 2020
    Chippewa Falls
    WI
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the heads up on the oil.
    I am about 180 lbs, anyone else similar in weight, what do you have your psi at?
  16. #10
    Join Date
    Jul 2016
    Youngstown
    OH
    Post Thanks / Like
    Mentioned
    10 Post(s)
    Tagged
    0 Thread(s)
    I run my '86 at "Low/Low" for 1 up and "Med/High" 2 up, loaded. I weigh in at 180 as well.
    TANSTAAFL
  17. Thanks Bemental gave thanks for this post
  18. #11
    Join Date
    Sep 2006
    Burlington, ON
    Canada
    ON
    Post Thanks / Like
    Mentioned
    63 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by bpate4home View Post
    That is a totally unfair statement
    This forum is known to be very open and friendly with opinions
    and opinions, and opinions, and opinions, and opinions, and opinions, and opinions, and opinions, and opinions,and opinions,
    Ok you may have a point there
    I AM A DRINKER OF THE WIND
  19. Likes bpate4home liked this post
  20. #12
    Join Date
    Sep 2006
    Burlington, ON
    Canada
    ON
    Post Thanks / Like
    Mentioned
    63 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Patch View Post
    Yeh but you make up for it the other 23 hours
  21. #13
    Join Date
    Sep 2006
    Burlington, ON
    Canada
    ON
    Post Thanks / Like
    Mentioned
    63 Post(s)
    Tagged
    0 Thread(s)
    Sure this aint more your speed patch
  22. #14
    Join Date
    Jul 2013
    Calgary
    Canada
    AB
    Post Thanks / Like
    Mentioned
    16 Post(s)
    Tagged
    0 Thread(s)
    OH Brothers, leave it to the Canadians to forkup a perfectly fare question/opinion request
  23. #15
    Join Date
    Apr 2019
    Katy
    TX
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    I told y'all it was dangerous, darn Canadians. LOL
    Well I guess this American did open the door, just a little. Hit, Run, Watch the fun.
  24. Likes Patch liked this post
Similar Threads
  1. opinions on which to buy 83 or 86
    By cruiserlover in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 05-22-2018, 10:31 PM
  2. I need your opinions
    By Pretty Hips McGee in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 02-28-2013, 10:20 PM
  3. Opinions please
    By USCG-RET in forum Watering Hole
    Last Post: 07-29-2012, 08:35 AM
  4. opinions please
    By Condor in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 10-05-2009, 05:12 PM
  5. any opinions
    By Midnight Rider in forum Watering Hole
    Last Post: 05-25-2009, 02:56 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
