84 venture royal
Have you checked the available threads describing what needs to be done?
Some of the boys have a good handle on where and which ones to read,, so hang in there,,, replies on the way.
Edited by Marcarl
You will need:
A set of R6 calipers, '03'04 fit but there may be other years that fit as well.
Either an R6 front master cylinder or a Gen1 Mk2 front master cylinder.
I highly recommend Skydoc_17's delinking brake line kt but it may not be an absolute necessity.
The calipers bolt right on. the rest of the job is self explanatory.
Au contraire. The R6 calipers will not bolt onto his 1984 forks.
To use the R6/R1 calipers one must have 1986 or newer forks.
I stand corrected. For some reason I thought it was only the 83 that needed different forks.
