Venture Capitalist Posted May 10, 2020 Author Share #51 Posted May 10, 2020 ok I just disconnected the cable from the relay to the starter and put battery directly to starter stud and the starter turned very slowly. so I guess I have to take the starter off and clean it up? can I get that out by just undoing those two bolts without taking the rad and header pipes off? Link to comment Share on other sites More sharing options...
Venture Capitalist Posted May 10, 2020 Author Share #52 Posted May 10, 2020 I see a starter at db electronics for 80 bucks it is for xvz1300 mine is xvz1200 anyone know if that will fit Link to comment Share on other sites More sharing options...
Patch Posted May 10, 2020 Share #53 Posted May 10, 2020 At this point Cap you are leaving my world so many can and will help you with your model You are getting good at this stuff. How is the van coming along? Link to comment Share on other sites More sharing options...
larrydr Posted May 10, 2020 Share #54 Posted May 10, 2020 I'm hoping someone can help me out. For the past couple of years my starter has been really slow but only when warm and I see by looking on here that is a pretty common problem. Yesterday I went out and it fired right up but it died because i didn't choke it in time. When i went to restart when i hit the starter button nothing happened and the neutral light and everything else electric went out. I took a multi meter and put black on neg batt post and red on the starter relay that the batt cable hooks to and had power there (still no electric anywhere) then i put the red on the other side of the relay and when i turned the key it had power. Not sure but isn't that one only supposed to have power when you hit the starter switch? And can anyone tell me what to check next if that is the way the relay is supposed to act I just finished a starting issue like that ...Ended up replacing the power cable from the the battery to the start relay and the cable to the starter ...It got better but it still poor with a warm engine ... I pulled the starter and found a bad bearing at the brush end of the starter .I set the armature in penetrating fluid ( bearing) at the brush end of the starter for about 30 minutes ... The set the starter armature bearing end in light motor oil for a hour ....Problem solved . Link to comment Share on other sites More sharing options...
Venture Capitalist Posted May 10, 2020 Author Share #55 Posted May 10, 2020 I still haven't been able to get the bike started to get over there and finish the van. I'm hoping I can get the starter out without having to take off the rad and the pipe, as you know I just recently got that cooling issue fixed hoping not to have to mess with it since it's perfect now. If I can i'll try what larry said or if a xvz1300 starter will fit a xvz1200 buy that Link to comment Share on other sites More sharing options...
Flyinfool Posted May 11, 2020 Share #56 Posted May 11, 2020 It depends on what year the XVZ1300 starter is as to whether you want it. If you are going to buy a starter make sure it is the 4 brush starter. The one you are looking at will fit but a 4 brush is a munch better starter and will cost about the same money. Most sellers will have no clue if they have a 2 or 4 brush and if they find out they may also raise their price. everything after a certain year is a 4 brush, I do not remember exactly what year the 4 brush started. But then I am cheap, I would take apart what I have and clean it out and do the ground mod and try that before I spend anything. When I did my starter I was doing a lot of other work at the same time. You do not have to remove the radiator but I think you will have to loosen the mounts so you can push it over a bit, you do not have to drain it. I believe you need to remove one of the exhaust pipes but they come off pretty easy, 2 bolts to the head and 1 clamp at the bottom. While you are cleaning the starter, make sure to clean the mounting surfaces on the starter and the block real good as they are your ground path. Link to comment Share on other sites More sharing options...
Venture Capitalist Posted May 11, 2020 Author Share #57 Posted May 11, 2020 It depends on what year the XVZ1300 starter is as to whether you want it. If you are going to buy a starter make sure it is the 4 brush starter. The one you are looking at will fit but a 4 brush is a munch better starter and will cost about the same money. Most sellers will have no clue if they have a 2 or 4 brush and if they find out they may also raise their price. everything after a certain year is a 4 brush, I do not remember exactly what year the 4 brush started. But then I am cheap, I would take apart what I have and clean it out and do the ground mod and try that before I spend anything. When I did my starter I was doing a lot of other work at the same time. You do not have to remove the radiator but I think you will have to loosen the mounts so you can push it over a bit, you do not have to drain it. I believe you need to remove one of the exhaust pipes but they come off pretty easy, 2 bolts to the head and 1 clamp at the bottom. While you are cleaning the starter, make sure to clean the mounting surfaces on the starter and the block real good as they are your ground path. I'm pretty cheap myself I went out to pull the starter and clean it. Thought I had scrounged up enough tools around here to do the job. My tools are all in my van which I just put a piston in, but yes you do have to take the pipe off the starter bolt won't get by the thermostat housing if you don't. My allen wrenches are in my van. I got this stuff called berryman's chem dip to clean the piston I got from pick and pull, that stuff did wonders, it had a lot of carbon on it and was black as could be, but it came out looking like brand new. Do you think I should dip the starter in that stuff? If cleaning everything and doing that ground mod doesn't work I will look around for a 4 brush, but after googling for starters that one at db electric for 86 dollars is going to be pretty tough to beat price wise. I'm cheap by necessity, don't make a lot of money. While I have it out I might as well do that dingy mod (if I can find that post again) and put new cable on it. Thanks for the help. Going to get to googling and see if I can find out what year the 4 brushers started Link to comment Share on other sites More sharing options...
Venture Capitalist Posted May 14, 2020 Author Share #58 Posted May 14, 2020 ok I finally got over to my van and got my tools and got the starter out all I've done so far is pull the armature out. Should I dip that in the berrymans chem dip? And what is my next step? Do I have to take the other end off? if so how is that done? Link to comment Share on other sites More sharing options...
Flyinfool Posted May 14, 2020 Share #59 Posted May 14, 2020 I would not use harsh chemicals on the armature, You do not want to damage the insulation on windings. The brush dust is not hard to get off, simple alcohol or electronics cleaner will clean it fine. It has been a while since I was into a starter, I dont remember the order it comes apart, but you do want to take out the brush plate for cleaning. Link to comment Share on other sites More sharing options...
cowpuc Posted May 14, 2020 Share #60 Posted May 14, 2020 Yep.. I am in agreement with Fool on this one.. I would definitely not use Chem Dip on the starter,, I tested a bunch of carb cleaners and found Chem Dip absolutely second to none for that purpose (and like you Cappy,, also use for carbon clean up when other methods just dont work = stuff rocks) but I would strongly suggest not getting that chemical anywhere near those windings - it would probably not be real friendly to the varnish coating therein.. I always like to just blow out the amature, inner starter, brush plate really well with compressed air first as that entire area is always extremely dry any way and the removes fairly easily. For further cleaning IMHO, a nylon cleaning brush (even a clean/dry tooth brush works great) is the best route cause you really do not want to scratch the coils, again forced air to assist.. Electronic cleaner is good assist too.. I like to double check the bearings and brushes before closing it and always sneak/work some synthetic bicycle chain lube into the bearings. Also, best to replace the oring seal found on the mount nose too.. Link to comment Share on other sites More sharing options...
Venture Capitalist Posted May 14, 2020 Author Share #61 Posted May 14, 2020 ok thanks fool and puc. glad I waited for a reply. was thinking might as well drop it in the dip, what can it hurt, then thought better wait for a reply it might hurt something, that stuff is pretty strong. i'll get on that I happen to have some old toothbrushes. thanks guys Link to comment Share on other sites More sharing options...
Venture Capitalist Posted May 21, 2020 Author Share #62 Posted May 21, 2020 in case you guys are wondering what happened. cleaning the starter didn't work, it was shot so I ordered the one from dgelectrics cause there web page always says free same day shipping if ordered by 3:00pm, so I ordered it like around 6:00pm thinking ok it will be same day on tomorrows before 3 list, but it didn't work that way it should finally be here later today or tomorrow. it is at least in Sacramento now, they should add that to their website huh. order before 3pm free same day shipping, order after 3pm free 1 week shipping. Link to comment Share on other sites More sharing options...
Patch Posted May 21, 2020 Share #63 Posted May 21, 2020 Hmm, did you guys here a squeak too? Link to comment Share on other sites More sharing options...
Flyinfool Posted May 21, 2020 Share #64 Posted May 21, 2020 That free one day shipping only means that if ordered by 3 they will ship it out within one day, not that it will arrive in one day. Link to comment Share on other sites More sharing options...
Venture Capitalist Posted May 23, 2020 Author Share #65 Posted May 23, 2020 oh yeah, thanks for all the help guys, just got the new starter in and she fired right up. I think Neil Diamond must have had a bike that had been broken down for a week when he wrote that song "What a beautiful noise" Link to comment Share on other sites More sharing options...
SpencerPJ Posted May 23, 2020 Share #66 Posted May 23, 2020 Glad to hear, Get out and ride. Link to comment Share on other sites More sharing options...
