DesertLawman Posted March 27, 2020 Share #1 Posted March 27, 2020 I bought a Sena Freewire to use with the 7 pin onboard communication system on the Venture TC. I tested it out before the upgrade and everything was working fine. However, after the upgrade, I no longer have any sounds coming out in my headset. I can use voice commands and the system recognizes the voice input, but the radio, CB, XM and all other media no longer can be heard in my helmet. I made sure all the helmet boxes for both rider and passenger are checked in the audio settings. Im not sure if this is a bug in the new version that has not been found yet. I wish I was able to obtain the original stock version of the system so I can revert and use the system as it was before the upgrade. Has anyone else had this situation? Link to comment Share on other sites More sharing options...
bpate4home Posted March 27, 2020 Share #2 Posted March 27, 2020 Did you look under the settings / audio output that your default is all checked? It will then auto switch when a headset is plugged in. Link to comment Share on other sites More sharing options...
