User Tag List
Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: Intake manifold install - ube/oil orings or RTV?
Hybrid View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Join Date
    Apr 2015
    Montreal
    Canada
    QC
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Intake manifold install - ube/oil orings or RTV?
    When installing the carb boots/manifold on you engine, do you guys recommend oiling/lubing the new orings (with ATF) for a better seal or do you recommend putting a film of RTV on the cylinder head mating surface or the boot mating surface prior to install?
  2. #2
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    114 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Intake manifold install - ube/oil orings or RTV?
    If the rubber is nice and flexable then I use a product called Fluid Film. It's made from lanolin and so has no effect on any of the rubbers or rubber type components. It is alos nice and slippery so helps to seat the boots etc in their proper location. If the materials are getting hard and old then I would replace them as no sealant will continue to work well under flexing components.
    Do it now, before you forget again.
    Register today
    716.778.8568
    Rally@the Shores
    July 16-19th 2020
  3. Thanks jfman gave thanks for this post
  4. #3
    Join Date
    Nov 2014
    San Angelo, TX.
    Texas
    TX
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jfman View Post
    I have used Rubber Lubricant before to install carb boots very easily and not pinch any orings.
    You can get a lifetime supply of bead-lubricant/rubber lubricant XTRA-SLIK from Oreillys for $12.00 gallon.
    This stuff is slipperier than gorilla snot mixed with owl S%$!.
    The good part is after a while it dries out and helps to seal whatever rubber part (tires, carb boots, etc) you were trying to install.
    Click image for larger version.
  5. Thanks jfman gave thanks for this post
  6. #4
    Join Date
    Apr 2015
    Montreal
    Canada
    QC
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Du-Rron View Post
    https://www.venturerider.org/forum/a...hmentid=118535
    I cant go to the auto store right now but I do have a tube of brake caliper sliding pin grease that is heat resistant and supposed to not iterfere with rubber.
    What do you think?
  7. #5
    Join Date
    Sep 2010
    Mount Palatine
    IL
    Post Thanks / Like
    Mentioned
    45 Post(s)
    Tagged
    0 Thread(s)
    What do you think?
    Don't worry about what kind of lube to use on the O-rings at the base of the carb joints/holders/boots.
    As long as the head surface is clean and defect free, and the O-rings are new and proper, dry assembly is OK.
    The TOPS of the joints (where the base of the carb fits) can be simply lubricated with WD-40, Vaseline, lithium grease, etc. Not that critical. Lubrication at that location just makes carb insertion easier.
    Kevin M. Campbell Hidden Content
    1974 Honda CB750, 1991 Venture Royale "the Tuxedo"
    Hidden Content
  8. Likes Patch liked this post
  9. #6
    Join Date
    Jul 2013
    Calgary
    Canada
    AB
    Post Thanks / Like
    Mentioned
    11 Post(s)
    Tagged
    0 Thread(s)
    OOOH post #9 what a pucker moment Bro! Great picture!!!!!
  10. #7
    Join Date
    Nov 2014
    San Angelo, TX.
    Texas
    TX
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    What do you think?
    Everybody has their favorite stuff. Silicone grease is OK but not my 1st choice. I would say, NEVER use WD-40 on any rubber as it will destroy it.
    Iuse XtraSlik as a rubber lubricant because I already have a lifetime supply of it for mounting tires and whatnot. It is super nasty slick when wet and when dry it does not act like a sealant, but their is a minimal surface -tack- to it.
    But, that does not seem to be the main problem now if you already broke into the heads with the use of longer bolts. Owwwwweee,
  11. #8
    Join Date
    Sep 2010
    Mount Palatine
    IL
    Post Thanks / Like
    Mentioned
    45 Post(s)
    Tagged
    0 Thread(s)
    Generally, sealant is not recommended on any O-ring. Light compatible lubricant is acceptable.
    When assembling the carburetor "joints" onto the cylinder head, please note that the mounting bolts are not all the same length. Putting the 20mm bolts into the wrong location will cause the long bolt to break through into the cam oil gallery.
    Hidden Content
  12. Thanks jfman gave thanks for this post
  13. #9
    Join Date
    Mar 2008
    Livonia, MI
    MI
    Post Thanks / Like
    Mentioned
    12 Post(s)
    Tagged
    1 Thread(s)
    I've generally used silicone spray lubricant.
    I agree with the others - no sealants.
    Hidden Content
    1989 Venture Royale (Sold)
    1982 XJ650 (Sold)
  14. Thanks jfman gave thanks for this post
  15. #10
    Join Date
    Jul 2013
    Calgary
    Canada
    AB
    Post Thanks / Like
    Mentioned
    11 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Prairiehammer View Post
    Right on Kevin.
    I'm going to add a couple things, while the carbs are off it is the best time to check compression; also when installing or removing carbs from the boots it is best to use a lube like WD which helps save the sealing ring inside the boots from chipping, also helps the seating of the carbs by reducing the friction before clamping!
  16. Thanks jfman gave thanks for this post
  17. #11
    Join Date
    Apr 2015
    Montreal
    Canada
    QC
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    I did not even notice the difference in bolt lenght when I removed the boots.
    So you are saying the two bolt holes that seep oïl require use of the shorter bolts?
  18. #12
    Join Date
    Sep 2010
    Mount Palatine
    IL
    Post Thanks / Like
    Mentioned
    45 Post(s)
    Tagged
    0 Thread(s)
    None of the bolt holes should seep oil.
    If any do, it is because the incorrect bolt was installed previously, thus breaking into the cam oil gallery.
Name:	too long bolt damage.jpg
    Hidden Content
  19. Likes Patch, Du-Rron liked this post
  20. #13
    Join Date
    Nov 2014
    San Angelo, TX.
    Texas
    TX
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Owwwee... How did you get that picture? Wait... I don't wanna know...
  21. Likes Patch liked this post
  22. #14
    Join Date
    Apr 2015
    Montreal
    Canada
    QC
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    https://www.venturerider.org/forum/a...hmentid=118536
    On both of my ventures when I first disassembled the bikes initialy to remove the boots, oïl came out of the two same holes on both bikes. So I scratched my head but marked it as normal.
    The far left front mounting hole and the rear far right mounting hole seps oil for both bikes.
    I even pulled the cams on one bike and did not seen/notice damage in these holes..
    So I am saying both of my bikes have been like this for a lo-onng time.
  23. #15
    Join Date
    Sep 2010
    Mount Palatine
    IL
    Post Thanks / Like
    Mentioned
    45 Post(s)
    Tagged
    0 Thread(s)
    Were there shorter bolts (16mm long) in those holes (upper bolt on #2 cylinder and upper bolt on #3 cylinder)?
    The rest of the bolts (quantity 6) are 20mm long.
    Hidden Content
Similar Threads
  1. Size and alternate / sftermarket source of intake boot orings
    By jfman in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 12-02-2019, 01:52 PM
  2. Will Longer Intake Manifold Bolts in Short Bolt Spots Cause Problems?
    By Bob K. in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 10-08-2018, 11:48 PM
  3. Intake manifold boots
    By wrscomncents in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 04-16-2018, 07:46 PM
  4. Problem, Intake Manifold
    By GeorgeS in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 05-17-2009, 12:59 AM
  5. Intake Manifold Boots (Question)
    By crockettrider in forum General Tech Talk
    Last Post: 10-10-2008, 11:56 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
