jfman Posted March 16, 2020 Share #1 Posted March 16, 2020 I unexpectedly had to remove the cams from the front of the motor on my 1988 Venture. I dont have a Clymer manual but befor I pulled the cams I marked the the chains and sprocket with a sharpie. I put everything back like it was and now I am at the point where I want to put the valve covers back on. before I do, I want to be certain that timing is correct. I found two marks on the flywheel thru the sight. T1 and T2 Anyway Without a book I can't figure it out. Maybe I have it wrong. When timing the front cylinders, which marks to use? Any help is appreciated. JF Link to comment Share on other sites More sharing options...
cowpuc Posted March 16, 2020 Share #2 Posted March 16, 2020 Jf, according to the club's manual you will be using T-2 for the front pot... Here is where I am reading from = start at page 158 = https://www.venturerider.org/manuals/1986-1993%20Yamaha%20Venture%20Service%20Manual.pdf.. There is a fair amount of checking cam sprockets and stuff here too,,, just normal OHC cam stuff.. Also beware of rotational protocol on the crank,, I believe its counter clockwise only but its all in there... I know on ANY of the scoots I went thru in the past when it involved valve timing, I ALWAYS double checked my alignment marks and the like but I also ALWAYS, with plugs pulled and rotating in the right direction bias,, stuck a breaker bar on the crank and slowly rotated her thru a couple times to make sure I wasnt about to bend a valve = dont take much of a bump on a piston... I know and am sure you know all that but thought I would toss it out there... Best of the best brother,, get er done Puc Link to comment Share on other sites More sharing options...
Bob K. Posted March 16, 2020 Share #3 Posted March 16, 2020 Here are some pics you can use for confirmation. https://www.venturerider.org/forum/showthread.php?33290-Proper-way-to-measure-valve-clearances&p=1046013#post1046013 Link to comment Share on other sites More sharing options...
jfman Posted March 16, 2020 Author Share #4 Posted March 16, 2020 Thank you for this link. Did not even know it was avail. I just read thru this manual and I am amazed that there are no actual marks tu line up like 95% of bikes. Most bikes you line a few lines/marks and you are done. On this one it's more vague. but no big deal, my bike matches what this manual says and also since I have a second venture with covers off. I compared both bikes with the same reference points and there are 100% identical. thanks guys! Link to comment Share on other sites More sharing options...
