User Tag List
Results 1 to 7 of 7
Thread: Nexen car tite
  1. #1
    Join Date
    Aug 2006
    Gassaway WV
    WV
    Post Thanks / Like
    Mentioned
    8 Post(s)
    Tagged
    0 Thread(s)
    Default Nexen car tite
    I am looking to upgrade my rear tire to either the E4 or move into the Nexen car tire. Just wondering the pros and cons.
    Skid
    Second Generation!
    Hidden Content
  2. #2
    Join Date
    Aug 2006
    Rock Bridge
    WI
    Post Thanks / Like
    Mentioned
    22 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Nexen car tite
    My first car tire was a nexen CT. I ran it at 40psi because it wanted to wander at higher speeds, other than that I had no issues with it. The 40 psi was a suggestion from another VR member. Stuck amazingly good in the corners, worked well in the rain and held air.
    I ended up taking it off at just over 30K. I took it off to lube the rear splines and realized it didn't have enough tread to put it back on so I switched it out to a MC tire. Then put on a BFG CT. That one is still on. The BFG sits a bit lower.
  3. #3
    Join Date
    Mar 2017
    Dexter
    KY
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Jeff I installed the Nexen last spring. The ride is much smoother and braking is improved, even my wife commented on the ride the first time she was on it. I rode solo locally a few times before I let her on it just to be sure it was safe. I did an 1100 mile saddlesore, 2200 miles to Niagara and back, 1700 on WNY trip, and several shorter trips. The only difference I feel is on a crowned road if I let go of the bars it will sometimes want to migrate down the crown and if I shift in a low speed corner it will try to stand up a little while the clutch is pulled. The only place I really notice it is a wide sweeping turn from a stop sign nearby, if I shift from first mid turn it tries to stand up a little. It's not a violent jump or anything that bothers me, it doesn't take me out of my line, I just feel it. When this tire is worn out I will install another just like it. My local tire shop mounted it, like everybody else said it took nearly 100'psi to seat it. I just walked out to check and I have 12,200 miles on it with 6/32 tread left. I was running through back MC tires every 6-7000 miles. I tried Commander II and Shinko 777 before I went this route. I went with the Nexen because it was taller than the BFG, some say the BFG is a better ride though. I ride just as hard in the twisties as I ever did with no problems.
    Faded Blue is the fastest.
  4. Likes Patch liked this post
  5. #4
    Join Date
    May 2013
    Munster
    IN
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by eagleeye View Post
    I had the same issue with the Nexan and tried everything from 30-45psi and couldn't get rid of the vague wandering feeling at highway speeds. I also have a Hagon HD rear shock, 130-18" front wheel from a Stratoliner, and beefed up front springs. I assumed my issues of wander were due to the higher suspension setup and narrower front tire. I did a December Toys For Tots run in 2" of snow and the CT stuck like hell. Braking was greatly improved, handling was great solo or two-up for anything under 65mph.
    I ended up with a Dunlop E4 for my next tire, I still have a 2nd rim sitting in the shed and will probably try the BFG CT next go round. As noted, it sits lower than the Nexan and that might change the rake/trail geometry of my bike back to something stable at highway speeds.
    1999 Royal Star Venture
    2007 Ural Tourist
    1984 Suzuki QuadRunner 125 rescued from the scrap pile
    Honda Trail CT70
  6. #5
    Join Date
    Mar 2017
    Dexter
    KY
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by BratmanXj View Post
    Out of curiosity did you check swingarm bearings and steering neck bearings? Reason I ask I did the swingarm when I installed the CT but not the neck bearings. I had it on the jack getting ready for the WNY rally and the neck bearings seemed a little loose, I tightened it up by the instructions here and it wanted to go into a death wobble at 90 mph and big truck turbulence was terrible. I backed them back off and it settled down. I'm going to replace the neck bearings this year before I really get into riding season. It rode great before I messed with the neck bearings, I had it above 90 two up pulling a trailer to get away from some trucks with no issue. I do run the 150 front, haven't been into the forks to see if PO changed springs, and have leveling links installed.
  7. #6
    Join Date
    May 2013
    Munster
    IN
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by RDawson View Post
    I bought the bike in '13 with a few maintenance issues. I rehab'd the back end in Sept '13 with the Hagon shock to replace the blown factory, pulled the swing arm for a full grease and torque. It's checked every year as part of spring maintenance.
    The Straoliner front wheel went on in the Spring '14 with a new Michelin tire.
    Front end was rebuilt Winter '15 with new bearings, up-rated spring and fresh fork oil. Previous owner had the neck WAY to loose and there was a noticeable "detente" in the steering.
    CT went on in 2016.
    The Hagon shock raised the back end 1/2" higher than stock, the front end sits about 1/2" lower than stock, plus the narrow tire just didn't site well with THIS SPECIFIC tire. From what I understood in my reserch the Nexan is slightly taller than stock and I think I just pushed my rake/trail numbers to far with ALL the modifications. I do plan on trying the BFG at some point as it's slightly shorter than stock.
    2007 Ural Tourist
    Honda Trail CT70
  8. Thanks RDawson gave thanks for this post
    Likes RDawson liked this post
  9. #7
    Join Date
    Apr 2019
    Katy
    TX
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I ran the Nexan on my '06 for 18K miles. I had a wobble at 95, adjusted the tire to 36 lbs and things smoothed out, I never had any roaming issues with the bike. The tire was great in the rain and had excellent stopping power. If I still had the 06 I'd be running another one.
    Hidden Content
    Don't end up in pieces. Riding should be your Peace.
Similar Threads
  1. Loc-tite
    By yamagrl in forum General Tech Talk
    Last Post: 07-13-2014, 08:50 PM
  2. Vibra Tite
    By JohnMidnight in forum Watering Hole
    Last Post: 11-26-2012, 07:06 PM
  3. Problem With Loc-Tite Blue
    By Bobby G in forum Watering Hole
    Last Post: 01-03-2011, 04:57 PM
  4. nexen tire
    By wild hair 39 in forum The Darksiders
    Last Post: 03-26-2009, 11:30 AM
  5. Time for the lock-tite
    By Jethroish in forum General Tech Talk
    Last Post: 04-21-2007, 08:21 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
