User Tag List
Page 1 of 5 123 ... LastLast
Results 1 to 15 of 75
Thread: coolant blowout
Hybrid View
Previous Post Previous Post   Next Post Next Post
  1. #1
    Join Date
    Feb 2020
    Sacramento
    CA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default coolant blowout
    Hello Everyone. I am new to this site. I purchased a 83 royale a couple of years ago and aside from having to put a new stater in it I haven't had any problems until now. I was sitting at a stop light the other day and all the coolant blew out of the right side onto my leg. It couldn't have been all that hot it didn't do any permanent damage to my leg. Just burned a bit the rest of the day and left a red mark. I am just wondering if this has ever happened to anyone else and if so, what caused it. Where should I start looking to make the repair? I would appreciate any advice anyone can give me
  2. #2
    Join Date
    May 2013
    Indianapolis
    IN
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: coolant blowout
    Now that it has cooled, I would rinse off with water, let dry, fire it up, and detect where the leak is coming from. If all coolant gone, I would add distilled water or coolant first.
  3. #3
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    113 Post(s)
    Tagged
    0 Thread(s)
    In order to answer your question, I have some in return:
    How long was the bike running before this happened?
    Did you ride it easy or hard?
    What was the outside temp approx?
    Wear did the coolant come from, appprox area if you know?
    Did you notice where the temp was on the gauge?
    Could be that the thermostat got stuck, heated up the coolant in the engine to the boiling point, created steam which then was forced into the rad and blew out the cap or overflow. Solution? replace the thermostat.
    Did you forget? You are not forgotten!!
    When were you going to decide?
    Join a great group
    Register today
    716.778.8568
    Rally@the Shores
    July 16-19th 2020
  4. Thanks Venture Capitalist gave thanks for this post
  5. #4
    Join Date
    Feb 2020
    Sacramento
    CA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Marcarl View Post
    First I want to say thanks for the reply. In answer to your questions. I had just ridden it to the store about 3 miles away. The outside temp was really cold. I had to be all bundled up. It came from somewhere on the right side. It shot through that gap in the right side panel onto my right thigh. The temp guage approx. 5 mins before it happened was a little below normal running temp. I always keep an eye on it when riding cause since I got it, it has always had a tendency to run a little hot. Normal for it is about halfway between the halfway point and the red and in the summer at a stoplight sometimes it gets almost all the way up to the red and it has always leaked a little bit of coolant where from I don't know. I just have to add about a cup every month. Once again thanks for the reply Marcarl and hopefully this added info tells you something
  6. #5
    Join Date
    Mar 2008
    Livonia, MI
    MI
    Post Thanks / Like
    Mentioned
    12 Post(s)
    Tagged
    1 Thread(s)
    It sounds like your temperature is pretty much normal. The fan doesn't kick on until the temp is at the red.
    It sounds like the coolant may have come from the overflow, although I think the hose should go low enough it doesn't get on you. Any chance it was over filled? What's the level in the recovery bottle cold?
    Hidden Content
    1989 Venture Royale (Sold)
    1982 XJ650 (Sold)
  7. #6
    Join Date
    May 2013
    Indianapolis
    IN
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Pull the plastics and have a look see . An 83 like mine as well, the question really is: What hose or seal didn't blow . Mine is very temperamental in the cold, the couple times I've had it out below 45, the thermostat housing oring leaked.
  8. #7
    Join Date
    Mar 2007
    West Coast
    MI
    Post Thanks / Like
    Mentioned
    630 Post(s)
    Tagged
    0 Thread(s)
    All good advice IMHO.. Personally, if it were my 83 I would check the water pump impellar.. 4 of the 6 84/83's that I have retired still had the OEM plastic impellars in them and 3 of those impellars were scalped clean of the plastic edges that push the water. It is pretty hard for them to cool properly if the water pump is not flowing anti freeze. If it were mine and unless it showed that someone had changed the impellar, I would rebuild the pump completely so I didnt end up with an iffy shaft/seals when replacing the impellar.. Make sense?
    Remembering my brother and friend:
    "I'm not Yammer Dan" - Yammer Dan
    Proverbs 18:24 - "There is a friend that sticketh closer than a brother"..
    Miss you bro - Puc
    Life is just one step after another..on a rocky hill side-Sly
  9. Likes Patch, mm482 liked this post
  10. #8
    Join Date
    Feb 2020
    Sacramento
    CA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by cowpuc View Post
    yah all good advice. I should look at the water pump, but would that cause it to explode out of there. I mean it literally xploded all the coolant onto my leg. In looking at the manual it showed a little rubber plug on the side of the head, would water shoot out of there if the plug popped out? Now the overflow bottle up in the fairing, does that have a hose coming out of the bottom other than the one to the radiator? If so, would it all blow out of there all at once? Sorry if I'm asking stupid questions, this is my first water cooled bike. I have changed water pumps and thermostats on my cars before but that's about it
  11. #9
    Join Date
    Mar 2007
    West Coast
    MI
    Post Thanks / Like
    Mentioned
    630 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Venture Capitalist View Post
    IMHO, DEFINITELY!!! But consider the source here brother,, I am as backyard of grease monkey as they come!! My logic (and it often gets me in trouble) is that if the impellar cannot move water (anti freeze) the coolant in the cooling jackets in the jugs will quickly turn to steam and POOF = high pressure on the entire system and then POOF again - something somewhere is gonna pop.. Also,, (and again,, take this with a grain of back yard wrench spinning thought) I would probably implore a pressure tester on the system (like used on cars) to see if I could detect what blew... Remove the cap, fill the system with water (no since in using anti freeze just for testing), attach the pump, run up to 13 pounds or so and watch for leaks.. Among other obvious places to check, I would look the head coolant bypasses over carefully.. They are located behind the plugs and you hav,, wait a sec,, watch this (with another grain of salt of course LOL):
    Miss you bro - Puc
  12. Thanks Venture Capitalist, mohamed samy gave thanks for this post
  13. #10
    Join Date
    May 2013
    Indianapolis
    IN
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    I agree with Cowpuc, and he is one of the master mechanics of these machines, rides them to 250k miles before retiring them. But personally I would still simply top off radiator, fire up, and watch as it gets hot. The cap is easy to get at, and I'm not sure the overfill will be enough to get you started. Next I would pressure test, Autozone rents these simple kits. My extreme limited mechanical knowledge has me thinking a stuck thermostat and the system built up pressure. But in reality, it could be as simple as a split in a hose.
  14. Thanks Venture Capitalist gave thanks for this post
  15. #11
    Join Date
    Jul 2013
    Calgary
    Canada
    AB
    Post Thanks / Like
    Mentioned
    8 Post(s)
    Tagged
    0 Thread(s)
    All good advice IMHO.. Personally, if it were my 83 I would check the water pump impellar.. 4 of the 6 84/83's that I have retired still had the OEM plastic impellars in themand 3 of those impellars were scalped clean of the plastic edges that push the water. It is pretty hard for them to cool properly if the water pump is not flowing anti freeze. If it were mine and unless it showed that someone had changed the impellar, I would rebuild the pump completely so I didnt end up with an iffy shaft/seals when replacing the impellar.. Make sense?
    Puc is 100% correct! In order for a pump to cycle it must fall within design spec - or - it will only serve to stir! That is the starting point, period
    yah all good advice. I should look at the water pump, MUST
    but would that cause it to explode out of there. I mean it literally xploded all the coolant onto my leg. In looking at the manual it showed a little rubber plug on the side of the head, would water shoot out of there if the plug popped out? Now the overflow bottle up in the fairing, does that have a hose coming out of the bottom other than the one to the radiator? If so, would it all blow out of there all at once? Sorry if I'm asking stupid questions, this is my first water cooled bike. Not water cooled liquid cooled!
    In addition, this water is the incorrect fluid to use outside of emergencies.
    You mentioned that you add a cup of water every other... OK well water can not handle the BTUs resulting from combustion heat, for one it hasn't the density and will by it nature generate hot spots.
    The fact that it requires constant topping off mean that the system is open somewhere.
    note: we see this model at times with over limit compression readings, this in and of its self causes over heating problems, such as slow to warm then over heating, then misfires.
    Like puc said then again like Puc said, "always start with a compression test" cept in this case pump first
  16. Thanks Venture Capitalist gave thanks for this post
  17. #12
    Join Date
    Feb 2020
    Sacramento
    CA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Patch View Post
    ok I found the problem, the main hose going into the top of the head has a big crack in it, I just poured water into the radiator and it came gushing out without even firing it up. Anyone know what that hose is called. Since i'm going to be working on it I think I will get a new thermostat too, since apparently from what you guys are telling me that is probably what caused the pressure build up in the first place. And with summer right around the corner I might as well take a look at the water pump too. btw when I top it off I always use 50/50, I never put straight water in it accept just now to see what was going on with it. I just wanted to say thanks to all the guys here that helped me with the good advice. Time to call the parts store now. THANKS EVERYONE!!!
  18. #13
    Join Date
    Jul 2016
    Youngstown
    OH
    Post Thanks / Like
    Mentioned
    10 Post(s)
    Tagged
    0 Thread(s)
    I'd venture to say the problem is 37 year old rubber heater hose. You said your temp gauge was in the normal range and the blowout did not burn you severely. I'd replace the T-stat just because and all the rubber hoses, cause they're old, ya' know.
    $0.02 YMMV
    TANSTAAFL
  19. #14
    Join Date
    May 2013
    Indianapolis
    IN
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Here's a part breakdown. Find the p/n, google it. You'll find what you are looking for.
    https://www.yamahasportsplaza.com/oe.../radiator-hose
    or the Master Part Breakdown
    https://www.yamahasportsplaza.com/oe...-xvz12tk-parts
  20. Likes Patch liked this post
  21. #15
    Join Date
    Feb 2020
    Sacramento
    CA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by luvmy40 View Post
    $0.02 YMMV
    well I got the old hose off, but I think I have a problem. I was working the hose clamp up using a pair of needle nose while a friend was holding the light for me, he reached down and pulled up on the hose and if came off with a really thin piece of either aluminum or copper where the hose was clamped still attached to the hose. Now there is just a hole in the top of the head with no place to clamp the new hose. Did I break off a piece? Capital Yamaha didn't have that particular hose and said they couldn't order one. Nobody has it anymore and they told me to just take the old on down to an auto parts store and have them cut me one. Are you familiar with that part of the bike or that piece.
Similar Threads
  1. 4th of July Blowout Sale
    By BaggerShield in forum VentureRider Gold Star Vendors
    Last Post: 07-02-2014, 03:48 PM
  2. coolant
    By Rodburner in forum Watering Hole
    Last Post: 02-16-2014, 11:07 AM
  3. I have oil in my coolant!
    By mbelik in forum Royal Star and Royal Star Tour Deluxe Tech Talk
    Last Post: 08-27-2013, 08:00 PM
  4. Oil in coolant
    By BigBear in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 05-09-2011, 02:38 PM
  5. GPS Blowout sale
    By Flyinfool in forum GPS, Audio, Electronics
    Last Post: 03-04-2011, 02:30 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
