User Tag List
Likes Likes:  0
Results 1 to 7 of 7
Thread: Rear brake bleed question
  1. #1
    Join Date
    Dec 2019
    Leeds
    United Kingdom
    WY
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Rear brake bleed question
    Hi guys,
    Going to bleeding rear brake on 92 VR shortly. I have the service manual and know the sequence to bleed (front right on it's own/ front left linked/rear brake and then proportioning valve). On the rear brake, the book says to undo caliper bolt and whilst caliper is still connected to front locating pin. rotate up 1.5 inches away from the disc and bleed as normal.
    My question is that if the brake pads are away from the disc, the pistons will be forced too far out and might be difficult to force back in?
    Is this correct as it is different to the way I've bled brakes on my other bikes. The others have all been bled whilst the pads have been in contact with the disc.
    Advise would be gratefully received from an English cousin.
    Thanks.
    Blake
  2. #2
    Join Date
    May 2013
    Indianapolis
    IN
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Rear brake bleed question
    I've never bled the way the manual says to on my 83 (never read into it tho) ?? I'm like you, bleed it as sits on the bike. If you were to take it off and rotate it up 1.5 inches, I would slide a shim in between the pads. If it compresses too much, the piston is rather simple to compress with a 'c' clamp, even a large pair of channel lock pliers. Seems I started with the proportioning valve, front, than rear.
  3. #3
    Join Date
    Apr 2014
    Wilmington, NC
    NC
    Post Thanks / Like
    Mentioned
    19 Post(s)
    Tagged
    0 Thread(s)
    If there is no air in the system and you are just bleeding the lines to refresh the fluid, does it really matter how you do it if you are bleeding from the farthest point from the MC?
    2007 Yamaha Royal Star Venture 23k miles
    1989 Yamaha Venture Royale 6k miles
    1985 Kawasaki ZN700 4cyl shaft 5k miles
  4. #4
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    113 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by BlueSky View Post
    Nope, don't matter, don't even really matter which you do first and you really wouldn't have to worry over the valves either....JMHO
    Did you forget? You are not forgotten!!
    When were you going to decide?
    Join a great group
    Register today
    716.778.8568
    Rally@the Shores
    July 16-19th 2020
  5. #5
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    113 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Dales venture View Post
    Hi guys,
    Thanks.
    Blake
    The only reason to rotate the caliper would be to get the bleeder port to a higher position, so to easier bleed out the air. Pads would be left in place and should nicely slide back to working position. You won't be putting much pressure on them if any during the bleeding process.
    Join a great group
    Register today
    716.778.8568
    Rally@the Shores
    July 16-19th 2020
  6. Thanks Dales venture gave thanks for this post
  7. #6
    Join Date
    Dec 2019
    Leeds
    United Kingdom
    WY
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks for the advice.
  8. #7
    Join Date
    Sep 2006
    Burlington, ON
    Canada
    ON
    Post Thanks / Like
    Mentioned
    56 Post(s)
    Tagged
    0 Thread(s)
    I would still bleed as thought there is air in the system. As brake fluid ages it absorbs moisture, this reduces its wet boiling point. When brake fluid reaches or exceeds its boiling point it devolps gas bubbles that act similar to air bubbles and so you want to bleed these out when replacing fluid.
    Quote Originally Posted by Marcarl View Post
    On the contrary the rule of thumb when bleeding any hydraulic system is to bleed the the furthest point from the master first and work your way back.
    I also do not pump up the brakes. I start by 1st opening the bleeder screw and then slowly depress the brake until it bottoms out. I then close the screw while the brake is depressed. From that point on I simply depress the brake once to pressurize the system then open and quickly close the screw while under pressure and before all the pressure is gone. I continue until there is no more air coming out.
    Hi guys,
    Thanks.
    Blake
    The only purpose for tipping up the caliper would be because in its mounted position the bleed screw is not the highest point so to ensure that the bleeder screw is the highest point for the air to go to you would have to tip it up in order to ensure you get all the air out.
    I AM A DRINKER OF THE WIND Hidden Content
Similar Threads
  1. Rear brake bleed order. Just confirming...
    By Banks412 in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 10-28-2018, 04:03 AM
  2. Bracket for '86 up brake bleed line
    By flyday58 in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 12-30-2014, 02:46 AM
  3. Brake Bleed Screw Covers
    By Donvito in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 08-06-2013, 09:53 AM
  4. brake bleed - 07 RSTD
    By naturbar in forum Watering Hole
    Last Post: 10-26-2010, 01:00 PM
  5. Need help with brake bleed on 05 V-Star
    By duke in forum General Tech Talk
    Last Post: 09-05-2007, 08:35 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
