User Tag List
Likes Likes:  0
Results 1 to 7 of 7
Thread: Code 90
  1. #1
    Join Date
    Feb 2018
    Germantown
    MD
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Default Code 90
    Noticed code 90 showing up where milage usually does when turning bike off via kill switch after ride into work this morning.
    Powering off and on made it go away.
    Any idea what this means?
    Sent from my SM-G975U1 using Tapatalk
  2. #2
    Join Date
    Apr 2019
    Katy
    TX
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Code 90
    You can check the Service manual page 7-84. The manual is here. https://www.venturerider.org/manuals...vicemanual.pdf. 'No Normal signals from the switch are received by the ECU.'
    Don't end up in pieces. Riding should be your Peace.
  3. Thanks DanielM gave thanks for this post
  4. #3
    Join Date
    Aug 2006
    Wadena
    MN
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Code 90
    I believe that is the code that some people are getting when one of the cruise switches start to fail. Your dealer should be able to fix you up
  5. Thanks DanielM gave thanks for this post
  6. #4
    Join Date
    Feb 2018
    Germantown
    MD
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Code 90
    Quote Originally Posted by sldunker View Post
    Is this becoming a known thing with this bike?
  7. #5
    Join Date
    Aug 2006
    Wadena
    MN
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Code 90
    I have 14,000 miles on my Star Venture and have had zero issues. Some guys may be washing their bikes with a pressure washer and getting water into the switches. Not a known issue.......yet.
  8. #6
    Join Date
    Feb 2018
    Germantown
    MD
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Code 90
    I'm at about 23k miles. Bike has not been anywhere near a pressure washer.
    ABS light is also coming on. Will give the warranty a test drive with the dealer.
  9. #7
    Join Date
    Nov 2012
    bethlehem pa
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Code 90
    Code 90 is one of the cruise control switches. This is a common issue. Dealer will replace the front or back or both brake switches.Yamaha knows about this.
  10. Thanks DanielM, N3FOL gave thanks for this post
Similar Threads
  1. p code
    By yooper in forum Watering Hole
    Last Post: 04-23-2013, 01:49 AM
  2. Dress code
    By Hummingbird in forum Watering Hole
    Last Post: 02-08-2013, 10:47 AM
  3. E6 code
    By stevey30 in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 04-01-2012, 06:52 PM
  4. Promo Code
    By N3FOL in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 10-09-2010, 12:11 PM
  5. E1 Code
    By steve in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 08-17-2008, 08:06 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
