User Tag List
Results 1 to 5 of 5
Thread: What is the name and purpose of this carburetor part?
  1. #1
    Join Date
    Apr 2015
    Montreal
    Canada
    QC
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Default What is the name and purpose of this carburetor part?
    Click image for larger version.
    What is the purpose of the little diaphragm on the side of the carb body? What is its correct name (Yamaha parts fiche calls it a diaphragm set)
    Also if it fails or if the holes leading to it are plugged, what will be the symptoms?
    Has this part been known to fail on ventures.
  2. #2
    Join Date
    Apr 2014
    Wilmington, NC
    NC
    Post Thanks / Like
    Mentioned
    20 Post(s)
    Tagged
    0 Thread(s)
    Default Re: What is the name and purpose of this carburetor part?
    Yes, they somtimes fail. Some have used stuff like Yamabond to repair holes in the diaphragms. Vacuum against this diaphragm moves a fuel metering rod in and out of the jet that feeds the engine above idle. If there is a hole in the diaphragm or the metering rod is stuck, the engine will not run right above idle speed. #not a mechanic
    2007 Yamaha Royal Star Venture
    1989 Yamaha Venture Royale
    1985 Kawasaki ZN700 4cyl shaft
  3. #3
    Join Date
    Sep 2010
    Mount Palatine
    IL
    Post Thanks / Like
    Mentioned
    45 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by jfman View Post
    https://www.venturerider.org/forum/a...hmentid=118151
    It is variously called the "coasting enrichment valve" or "air cut-off valve" or "transient enrichment valve".
    When the throttle is closed, there would a transient lean condition, causing popping upon deceleration (coasting). This device enrichens the circuit to prevent popping.
    The diaphragm can be damaged by aggressive carb cleaners and the diaphragm can also develop holes. The result will be a vacuum leak and popping.
Name:	air cut off BAD greef.JPG
ID:	118152Click image for larger version.
Name:	air cut off BAD.JPG
ID:	118153Click image for larger version.
Name:	air cut off Trans_Enrich_System.jpg
ID:	118154Air Cut-off how it works.docx
    Kevin M. Campbell https://www.facebook.com/Prairiehammer
    1974 Honda CB750, 1991 Venture Royale "the Tuxedo"
  4. Thanks jfman, videoarizona gave thanks for this post
  5. #4
    Join Date
    Apr 2015
    Montreal
    Canada
    QC
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by BlueSky View Post
    I think you have it mixed up with the diaphragm from the main slide/needle.
  6. Thanks BlueSky gave thanks for this post
  7. #5
    Join Date
    Sep 2014
    HANCOCK
    MD
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    If you pull the carbs apart to clean them, the only way to get cleaner and air through the passages leading to the air cutoff circuit is to depress the small ball that the rod on the diaphragm presses on. I just used the old cutoff diaphragm that I was replacing to depress it when I cleaned mine.
    Ron
  8. Likes jfman liked this post
Similar Threads
  1. The purpose of this area
    By Freebird in forum Paying it Forward
    Last Post: 11-25-2014, 11:51 PM
  2. Dual Purpose bike
    By Mikealiasmike in forum Watering Hole
    Last Post: 04-24-2014, 04:46 PM
  3. 2000 Venture carburetor problems, part II
    By Groatski in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 04-13-2014, 05:30 PM
  4. Replies: 14
    Last Post: 09-06-2009, 08:04 PM
  5. dual purpose
    By eagleeye in forum Watering Hole
    Last Post: 03-29-2008, 11:21 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
