Removing air/fuel mixture screw to back access the pilot circuit and jet for cleaning
Hello venturers :)
Sorry for yet another carb thread/question.
Say you suspect you have a clogged pilot jet on one carb and that makes one of your cylinders unhappy at idle.
Say you also happen to be a lazy person and you would like to avoid pulling and dissasembling the carbs.
Could you remove the air/fuel mixture screw on that one carb and then inject cleaner into the circuit with a straw or syringe. Then you would let it sit for a few days to let your cleaner work its magic. Afterwards you would blow a little bit of compressed air into the circuit by way of the exposed hole from the missing a/f mixture screw to hopefully dislodge the crud in the actual pilot jet.
Finaly you would flush out the carb bowl.
All of this while the carbs are on the bike.
What do you guyz think of this idea?
I plan to try it on my 1988 venture and flush the bowls also.
Edited by jfman
I think I would try removing the idle mix screws and spraying carb cleaner in the hole. Be careful because it's really hard to get the o-ring out. you will think it isn't there but it is and carb cleaner might ruin it. Your best try might be to use cowpuc's method. Do a search and read about his method. An animal syringe injecting carb cleaner through the drain. You need to get the details from him because he explains how much to inject.
My mechanic did that to save me from a complete rebuild when I got my 89. It was running on 3 until then. I put new diaphragms on afterward, gave it sync, and it ran like the sweet beast these bikes are.
See post 24 in this link.
https://www.venturerider.org/forum/showthread.php?128318-How-to-use-Seafoam/page2&highlight=cleaning+carb
Injecting cleaner into the pilot screw (air/fuel mixture) orifice won't get cleaner to pilot JET. The path of least resistance would send the cleaner straight into the carb bore.
What you CAN try is to inject cleaner into Pilot Air jet #1 . That path is a relatively straight shot to the pilot jet.
Edited by Prairiehammer
Added carb schematic
  • 2 weeks later...
https://www.venturerider.org/forum/attachment.php?attachmentid=118087https://www.venturerider.org/forum/attachment.php?attachmentid=118088
when looking at the mouth of the carb after removing the airbox, is it the orifice with the large brass jet or is it the other orifice close to it?
