jfman Posted November 12, 2019 Share #1 Posted November 12, 2019 Hello Guyz! What is the tallest tire you can fit on the back of a 1st gen venture(stock Wheel of course)? What sizes are workeable? Link to comment Share on other sites More sharing options...
Venturous Randy Posted November 14, 2019 Share #2 Posted November 14, 2019 There is probably very little variation on tire size as far as width versus height ratio unlike car tires. The problem with a 1st gen, and probably all, is that you can not just put a bigger tire on the bike because the tire is so close to the driveshaft housing to begin with. What are you trying to accomplish? Randy Link to comment Share on other sites More sharing options...
jfman Posted November 14, 2019 Author Share #3 Posted November 14, 2019 There is probably very little variation on tire size as far as width versus height ratio unlike car tires. The problem with a 1st gen, and probably all, is that you can not just put a bigger tire on the bike because the tire is so close to the driveshaft housing to begin with. What are you trying to accomplish? Randy Simply I want the rear of the bike to be a little higher to scrape less. Link to comment Share on other sites More sharing options...
Venturous Randy Posted November 14, 2019 Share #4 Posted November 14, 2019 What year bike and how much have you aired up the rear shock? Randy Link to comment Share on other sites More sharing options...
jfman Posted November 15, 2019 Author Share #5 Posted November 15, 2019 (edited) Well I own both a 1985 and a 1988. The 1988 seems a little bit lower than the 1985. I have yet to mess witht the suspension. I plan to mount new tires and then ride it and mess with it as I start riding it. If there is an issue with the air suspension. Is there a way to have the rear at the max setting permanently? Edited November 15, 2019 by jfman Link to comment Share on other sites More sharing options...
Prairiehammer Posted November 16, 2019 Share #6 Posted November 16, 2019 I have yet to mess witht the suspension. Is there a way to have the rear at the max setting permanently? "Messing" with the suspension on a Royale is as simple as pushing a button. If you select the maximum (HIGH) setting on the CLASS, it should remain at that setting "permanently". (Provided there are no leaks). Link to comment Share on other sites More sharing options...
