Beardyspice Posted November 11, 2019 Share #1 Posted November 11, 2019 Hi guys, So I have scoured the forum and can’t find anyone with this specific issue, but I also have trouble using the search function sometimes. So here goes: this weekend I took the bike for a weekend camping trip and probably put about 600miles on it. Over the trip, I noticed that it got more and more difficult for the heel-toe shifter to bounce back after downshifting. I can downshift once fine, but if I have to downshift multiple times (for example to come to a stop at a stoplight) I have to pull up slightly on the toe, or pressed down slightly on the heel each time. When I stopped at a gas station, I use my hand to press down the toe and it did not return up, but when I press down the heel, raising up the toe, it bounced right back. I’m Not super tech savvy on this thing yet, is this a common problem? Is there a spring or something that I’m not seeing? Help! Link to comment Share on other sites More sharing options...
P-roy Posted November 12, 2019 Share #2 Posted November 12, 2019 I had the same issue a few years ago. The issue on my bike was a bad seal where the shift shaft goes through the trans. The seal was binding on the shift shaft. I was leaking small amounts of oil also from that bad seal. My shifter got to the point I had to manually pull it back between shifts. Might want to check that out. Sent from my moto g(7) using Tapatalk Link to comment Share on other sites More sharing options...
