User Tag List
Thanks Thanks:  0
Results 1 to 11 of 11
Thread: Need advice on RSV leaking fork seal
  1. #1
    Join Date
    Nov 2019
    Golden Isles
    GA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Need advice on RSV leaking fork seal
    Hi All, Newbie but longtime enthusiast. I picked up a barn find 2008 Royal Star Venture. The last few months have been fun getting her cleaned and tuned. Only 2000 miles and she is a sweet
    riding and fun bike. (Wife Loves this bike) I had tried tuning up the front forks by adding just 5psi to front forks drove for a bit and noticed all my fluid leaking on front fork. I figured there may be debri in seal and was going to try the film or thin plastic trick to clean it out. My thoughts are the air pressure changed recoil travel a bit and dislodged some minute particle that may have been on fork from a long period in outdoor storage. Anyhoo i contacted 2 of my nearest yamaha dealers and they will not work on a bike that's 10 years old.. Should be spanked by their yamaha rep for not honoring an older bike. I know i can still get all parts i need from yamaha so its just a pain that I cannot go to a dealer for repair. Do you all know the easiest way to get to the seals? Thought I could just take off fork covers and check seal. But they are not removable without taking fork completely off. PS the fluid was clean a clear that leaked out. Any advice would be appreciated for sure.
  2. #2
    Join Date
    Mar 2017
    Dexter
    KY
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Need advice on RSV leaking fork seal
    Congrats on the barn find, unfortunately low mile bikes often leak fluids from setting and drying out. Do a search here on the forks, there are several threads on that. Scroll to the bottom of each thread and you'll see similar thread links. Only use OEM parts in the forks, the cheap eBay parts will not hold up.
    Once you get it done you'll love these bikes.
    Welcome to the group, you'll find it's the best $12 investment you could ever spend on the ride.
    Faded Blue is the fastest.
  3. #3
    Join Date
    Dec 2007
    Victoria
    TX
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    If it is just a little seep, I would ride it some more and see if it stops. Probably not, but free to find out.
    Hidden Content A curve is not the end of the road, unless you fail to turn!
    See my gallery of the RatRod in progress!
  4. #4
    Join Date
    May 2013
    Indianapolis
    IN
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    I always have great luck with the 35mm film.
  5. #5
    Join Date
    Apr 2014
    Wilmington, NC
    NC
    Post Thanks / Like
    Mentioned
    19 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by OutKast View Post
    unless it runs down on the brake pads
    2007 Yamaha Royal Star Venture 23k miles
    1989 Yamaha Venture Royale 6k miles
    1985 Kawasaki ZN700 4cyl shaft 5k miles
  6. #6
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    113 Post(s)
    Tagged
    0 Thread(s)
    How much total pressure di you have in the forks, the front only takes about 4-5lbs if I remember correctly.
    Did you forget? You are not forgotten!!
    When were you going to decide?
    Join a great group
    Register today
    716.778.8568
    Rally@the Shores
    July 16-19th 2020
  7. #7
    Join Date
    Nov 2019
    Golden Isles
    GA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Marcarl View Post
    How much total pressure did you have in the forks, the front only takes about 4-5lbs if I remember correctly.
    Had just under 5psi. didn't notice any real difference 2 up.
    Finally got the fork off. Pretty straight forward but not a quick job. Fork oil had leaked onto pads so will need to change those out. (That's how I first found the leak by the noise of my front pads deteriorating with fork oil.) The fork looks really good and dust cap and seal show now age or cracking. I am getting some film strip and see if we cant make magic happen. Will keep you all posted.
    And thanks for all the response and ideas
  8. #8
    Join Date
    Dec 2007
    Victoria
    TX
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I guess it is how you define a seep! If it got to the brake pads, probably more than I would call a seep!
    Quote Originally Posted by BlueSky View Post
  9. #9
    Join Date
    Sep 2010
    Sebring FL
    FL
    Post Thanks / Like
    Mentioned
    15 Post(s)
    Tagged
    0 Thread(s)
    I never had a leak on mine. But I tried different fork pressure (I think 7 psi is max aint much) didnt really seem to matter. So I had read a few posts of guys that changed fork oil and went up to next weight. It helped with the ride more than air and I didnt even run air in forks after that. Pretty easy to change fork oil if I remember right. Might be worth a try.
    Probably easier to pull forks out 1 at a time to change seals than to change on the bike.
    Hidden Content 2013 Black Victory XCT
    Trailers are for when your bike is broke, aint they?
    Hidden Content
  10. #10
    Join Date
    Nov 2019
    Golden Isles
    GA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Solved!! Took both forks out and inspected dust covers and seals. All appeared perfect but the one that had leaked oil had some mild grit around seal. cut a thin plastic sheet and made a tool. took out the littlest amount off grit and kept cleaning under seal until clear. topped off amount that had leaked out and tested fork. Worked like a charm and just cleaned up both forks and put them back on. Long ride with some hard braking and fork has zero leaks. I am thinking this was all caused by adding just a few pounds of air to forks to trigger this leak. Anyhoo thanks for all the input and advice and I am having a blast riding this bike...... PS leak was just under a 1/4 cup and it turned out it did not touch the pads. Pads are good just had some grind to them. Cleaned calipers and pads put them back on and all is just fine. Thinking I will not run air in forks and really did not notice any difference with 2 up riding with or without air in front forks...
  11. Likes SpencerPJ liked this post
  12. #11
    Join Date
    Dec 2013
    Green Valley
    AZ
    Post Thanks / Like
    Mentioned
    123 Post(s)
    Tagged
    0 Thread(s)
    Glad that worked for you.
    Thought about running air in forks. You may need some, especially running 2 up, if you run into some twisties. A little firmness goes a long way to help the old chassis zip around corners evenly.
    USAF
    AFRTS Turkey
    1970-1973
    Patriot Guard
    "Some mistakes are too much fun to only make once." - Well worn saying
    "Great ideas often receive violent opposition from mediocre minds." Albert Einstein
Similar Threads
  1. leaking front left seal
    By kapebretoner in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 05-10-2016, 12:32 AM
  2. Leaking Fork Seal - GREAT FIX
    By cabreco in forum General Tech Talk
    Last Post: 10-31-2012, 08:05 PM
  3. Shift shaft seal leaking???
    By ACE50 in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 04-22-2012, 05:11 AM
  4. fork seal leaking again !
    By 6m459 in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 04-30-2010, 01:28 AM
  5. Fork seal leaking
    By Bill Feehan in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 04-19-2008, 03:01 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
