User Tag List
Likes Likes:  0
Results 1 to 4 of 4
Thread: '96 Royal Star front right brake assembly
  1. #1
    Join Date
    Sep 2019
    Valdosta
    GA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default '96 Royal Star front right brake assembly
    I just bought a used '96 Royal Star Tour and the front brake was messed up and I messed it up further trying to fix it :-( Does anyone have either one or a set of front brake calipers (everything but the disk) for reasonable? Thanks!
  2. #2
    Join Date
    Mar 2017
    Dexter
    KY
    Post Thanks / Like
    Mentioned
    7 Post(s)
    Tagged
    0 Thread(s)
    Default Re: '96 Royal Star front right brake assembly
    Check with Mike Eykamp- the diamond cut guy.
    Faded Blue is the fastest.
  3. Thanks revpat gave thanks for this post
  4. #3
    Join Date
    May 2013
    Munster
    IN
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    I have a stock master & front caliper set off my '99 RSV sitting on the shelf in the garage. I'll try and get a few photos tonight when I get home from work.
    1999 Royal Star Venture
    2007 Ural Tourist
    1984 Suzuki QuadRunner 125 rescued from the scrap pile
    Honda Trail CT70
  5. #4
    Join Date
    May 2017
    Biglerville
    PA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hello,
    I was wondering if you got the front brakes completed. I have a 97 RS and had the front rotors replaced and bothe calipers rebuilt. When I got the bike back it felt like the front brakes were a little spongy. I called back to the Yamaha service center and they said it could be some air in the system. They said they sometimes will tape the brake lever filly back to keep pressure on the system and let it at least overnight. I just untaped it and it felt much better.
    Just wanted to let you know of a quick and easy routine that might cure spongy brakes.
Similar Threads
  1. Replies: 0
    Last Post: 09-30-2019, 01:21 PM
  2. Replies: 0
    Last Post: 09-23-2019, 09:00 PM
  3. Replies: 0
    Last Post: 09-13-2019, 12:30 PM
  4. Replies: 0
  5. Replies: 0
    Last Post: 08-20-2019, 03:50 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
