User Tag List
Likes Likes:  0
Results 1 to 5 of 5
Thread: Front Stableizer
  1. #1
    Join Date
    Aug 2006
    West Branch
    MI
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Front Stableizer
    Hey all, I noticed when hitting bumps or at certain speeds, the front will shake on the RSV-Hannigan Trike.
    Does anyone have a Front Stableizer on there RSV Trike?
    If so where to buy? Thank You, Later-
    "Sometimes, it is Fun to let them slowly pass by,
    then Smile, as they wipe the Drewl off their face!"
  2. #2
    Join Date
    Aug 2006
    Reading
    PA
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Front Stableizer
    Will shake at slow speeds, its the nature of the beast. I havent seen a hannigan rsv with a stabilizer. I know when I rode Jonseys Hannigan Wing it did the same thing. If you find a solution I would really like to hear about it.
    Craig
  3. Thanks Red Ryder gave thanks for this post
  4. #3
    Join Date
    Aug 2006
    West Branch
    MI
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank You Craig!
    Yesturday road a friends 2019 Harley Tri-glide, had very little if any shaking over bumps or various speeds. Would be great to eliminate the shake on the RSV, have to do a bit of ingenuity, but maybe. Later-
  5. #4
    Join Date
    Aug 2006
    Wausaukee, WI
    WI
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Check your steering head bearings . If they are set loose the front end will shack. You can set them on the tighter side because it is 3 wheels and does not lean any.ore. my 86 tri-wing kit did the same thing and i tightened up the steering head bearing and help very much. Give it a try. Good luck
    1986 Yamaha Venture Trike
  6. #5
    Join Date
    Aug 2006
    West Branch
    MI
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by bikenut View Post
    Thank You Keith, I will check and tighten the front end. Later-
Similar Threads
  1. Front end
    By usedcyclesales in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 02-19-2012, 12:27 AM
  2. Replies: 18
    Last Post: 01-19-2012, 06:49 PM
  3. New front rim try # 2
    By dingy in forum Venture and Venture Royale Tech Talk ('83 - '93)
    Last Post: 10-02-2011, 08:34 PM
  4. Lowered Front End How to add air?
    By MikeyJ in forum Watering Hole
    Last Post: 09-10-2008, 07:41 PM
  5. front air deflecters
    By Eddie Fulmer in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 09-10-2008, 07:55 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
