Jthomas Posted September 15, 2019 Share #1 Posted September 15, 2019 Here i go again, noob question. Freebird is probably rolling his eyes by now. What is good idle speed? Without having a tach its hard to tell if my bike is idling high or just sounds bad ass. I roll through my apartment complex at idle doing about 11 mph. Also, is it normal for it to have a weak idle at first but then sound like it racing after riding on the highway for a bit? Link to comment Share on other sites More sharing options...
Marcarl Posted September 15, 2019 Share #2 Posted September 15, 2019 Sounds to me like your throttle linkage may need a bit of lube. Also to make sure things are in good order, you should do a cab sync which might also define and/or fix your issue. Once you've done that, let us know if we can be of more help. Link to comment Share on other sites More sharing options...
Freebird Posted September 16, 2019 Share #3 Posted September 16, 2019 RSV should b e 950-1050 according to the manual. I usually kept mine on the low side of that. Usually around 900-950. I just do it by ear. ut there are inexpensive hand held tachometers if you need one,. Link to comment Share on other sites More sharing options...
