hemihead Posted September 11, 2019 Share #1 Posted September 11, 2019 have a 2000 royal star venture. Just bought it. I can rev it up and hold it around 2 grand and it starts popping thru exhaust. Now i think it has aftermarket pipes, seems louder than my other Ventures. Just synced the carbs, came out fine , sprayed carb cleaner around the intake boots looking for any leaks. Nothing found. It seems to me like a lean popping. Can the aftermarket exhaust cause this?? Or what else could cause this Thanks Link to comment Share on other sites More sharing options...
grubsie Posted September 11, 2019 Share #2 Posted September 11, 2019 have a 2000 royal star venture. Just bought it. I can rev it up and hold it around 2 grand and it starts popping thru exhaust. Now i think it has aftermarket pipes, seems louder than my other Ventures. Just synced the carbs, came out fine , sprayed carb cleaner around the intake boots looking for any leaks. Nothing found. It seems to me like a lean popping. Can the aftermarket exhaust cause this?? Or what else could cause this Thanks Popping is much more noticeable with a working AIS after going to aftermarket mufflers. First thing I would do is check to see if the AIS has been plugged. If it isn't, go ahead and plug it. That should eliminate the popping. Here's a write-up on how to do it. https://www.venturerider.org/forum/showthread.php?485-Plugging-the-AIS Link to comment Share on other sites More sharing options...
hemihead Posted September 11, 2019 Author Share #3 Posted September 11, 2019 Thanks Looks like all that stuff was removed when the did the exhaust They plugged the 2 small pipes by the rear shock with vacuum plugs Both of them were rotted and i assume leaking . So i replaced them..we will see if that fixed it or not. I dont see anything up front. Could there be something there also they could of plugged that i cant see ? ? Just tried it and it still pops Link to comment Share on other sites More sharing options...
