Venturezach Posted August 25, 2019 Share #1 Posted August 25, 2019 Hey all, so I’ve been wondering about the possibility of a single throttle cable setup as I am now running the single solex pict 3 conversion. When I installed this, I used the pull cable to work the carb and I just tucked the push cable out of the way and it’s been working just fine up until the push cable came apart and the throttle got some play on the handle. If I have to just replace the pull cable I am okay with that too, just trying to see what’s out there and get some ideas. I’d like to get this replaced before I lose throttle on the highway . Thanks guys, I appreciate you all! Link to comment Share on other sites More sharing options...
MiCarl Posted August 26, 2019 Share #2 Posted August 26, 2019 The motorcycle will go just fine with only a pull cable. The purpose of the push cable is so you can force the throttle closed with your hand if something hangs up. It's a safety thing. Personally, I'd hook up a push cable if at all possible. Link to comment Share on other sites More sharing options...
Venturezach Posted August 26, 2019 Author Share #3 Posted August 26, 2019 I don’t think a push cable setup is possible with the solex, it has a good spring return when you let off the throttle and worse case I could always hit the kill switch if I needed to Link to comment Share on other sites More sharing options...
Venturezach Posted September 13, 2019 Author Share #4 Posted September 13, 2019 Good ‘ol eBay for the win! Found a universal 7/8” throttle kit that worked perfectly! Thankfully I changed it out before the 36 year old handle and cable took a dive as they were looking a bit worse for wear upon disassembly. Just thought I’d share for anyone in the same predicament as I was. Cheers! Link to comment Share on other sites More sharing options...
