sldunker Posted August 22, 2019 Share #1 Posted August 22, 2019 (edited) So I have been having this plastic rattle just off idle for quite some time. Last night it finally got pretty loud. I messed around with it today and isolated it to the upper wind wind on the right side. It was the top fitting. I remove the entire wind wing. Future warning- the lower mount for the wind wing is a bugger. There are two screws that hold it to a bracket that is in the inside of the fairing. The bracket is just hanging inside of the fairing so when you take the screws out it falls down into a place that it is a ***** to find. So if your wind wing is rattling just take a small screwdriver and pop the upper pin out. Find a oring that fits the pin and reassemble. Takes care of the rattle. After driving the bike for a few days the fuel door cover started rattling a little bit. This is the piece that I always thought would rattle. Easy fix. Took a small piece of foam and it just sits in groove in front of gas cap. All is well. Edited August 26, 2019 by sldunker Link to comment Share on other sites More sharing options...
