chocking Posted August 19, 2019 Share #1 Posted August 19, 2019 Picked up an 01 RSV the other day..Beautuful bike, and since I've ridden First Gens my whole life, the brakes are a bit different.The right front seems very grabby and catchy...any advice? Link to comment Share on other sites More sharing options...
OutKast Posted August 19, 2019 Share #2 Posted August 19, 2019 (edited) Start with flushing the fluid. fixes it 9 out of 10 times. Then get back to us! But the front is definately way more powerful than a stock first gen. Both calipers come in together. So unless you first gen is "delinked" it does not compare. A good advantage. The back of a second gen is "overpowered" and will lock easily if you hit the pedal hard. A definate negative. I have owned both. Picked up an 01 RSV the other day..Beautuful bike, and since I've ridden First Gens my whole life, the brakes are a bit different.The right front seems very grabby and catchy...any advice? Edited August 28, 2019 by OutKast Link to comment Share on other sites More sharing options...
cowpuc Posted August 19, 2019 Share #3 Posted August 19, 2019 I would do this: Link to comment Share on other sites More sharing options...
chocking Posted August 27, 2019 Author Share #4 Posted August 27, 2019 Flushing the front brake reservoir and lines until fluid was clear did the trick..amazing how crappy brown the fluid was... No more grabby.. Thanks Link to comment Share on other sites More sharing options...
OutKast Posted August 27, 2019 Share #5 Posted August 27, 2019 Might as well do the clutch and back brake also. When on a hot ride far from home is when old clutch fluid will boil on you leaving you without a clutch! Flushing the front brake reservoir and lines until fluid was clear did the trick..amazing how crappy brown the fluid was... No more grabby.. Thanks Link to comment Share on other sites More sharing options...
chocking Posted August 27, 2019 Author Share #6 Posted August 27, 2019 That's my plan..Its been years since I did my clutch..Bleed that right at the slave cylinder bleeder? Link to comment Share on other sites More sharing options...
Rafterd Posted August 27, 2019 Share #7 Posted August 27, 2019 That's my plan..Its been years since I did my clutch..Bleed that right at the slave cylinder bleeder? Yep. Link to comment Share on other sites More sharing options...
uhfradarwill Posted August 28, 2019 Share #8 Posted August 28, 2019 Man, Puc sure looks good in those hip eye glasses!! Link to comment Share on other sites More sharing options...
