Bodywork by Glue Bottle
Semi-retired
It probably happened a while ago.....but just now getting around to "why all the extra rattles going on?"
While doing a little management-by-walking-around, I discovered the left "lower" is nearly flapping in the breeze.
And it seems to be because the bolt that my finger is pointing at in the (hopefully) attached photograph is no longer attached to anything. (at least, not anything that it attached to anything ELSE!) (Sorry about making you twist your neck to look at it. I'll do better next time!)
Is it possible I read somewhere that ABS cement would be the best potion for dealing with this break?
(Yeah, I know the engine guard is likely the ULTIMATE culprit, and probably needs straightening in my bench vice while I have things apart....but is the ABS juice the way to go? Or is a tube of JB Weld calling me from somewhere?)
And, if it's a toss-up...I'll go with the one with the shortest cure time! :-) (cause the days are getting SHORTER!)
Edited by Semi-retired
Need the pic!!!
Carl has some "magic" stuff that you can rebuild or repair the post inside the cowl. Just make sure that you keep any plastic bits that fall out. Not uncommon for this to happen and is repairable. ABS glue will work for a while but when it becomes brittle it lets go. The stuff Carl has basically is plastic and fixes it permanently.
Do you have the braces on the engine guards (they go from the guard to the footrest mount)? Larry (CarbonOne) used to make them. If you have hiway pegs on the guards the braces are highly recommended or you will continue to break the lowers.
Hmmmm.
As with all things in life.....now that I have it taken apart, I see the plot is thickening.
Here's the good one.....
...and then, of course, the BAD one!
The bracket on the "bad one" is still about 50-ish % still there.....but would require some "artistry" to recreate.
But, I acknowledge that the engine/crash guard IS probably out of alignment (from my last tip-over) and YES, I do have highway pegs installed (although the weight exerted by my pencil legs on these things is miniscule), so I realize I've got some straightening and/or reinforcing to do (a la Larry's solution, or otherwise.)
Any tips on "faking" the missing portion? Do any of your named elixirs have better fabrication characteristics than any others, Carl?
The kit come complete with a rubber type pad that when heated can be formed to make a mould for that piece. Just make it good and warm, shape it, let it cool and the use it. Need something else, reheat and repeat. Check out their websites for vids.
Home Hardware carries the same stuff called Plastex in smaller quantities and would work perfectly for your repair....
Home Hardware "found the item" on their computer....but it's been "DELISTED".
Not enough broken fairings, apparently!!
I guess I'm off to Brantford.....to buy the "other product" from Spruce Goose or whoever they are.........OR have to convince either one of these manufacturers to ship one to my Niagara Falls NY, warehouse!
"Sorry, but this item can't be shipped to your selected address. Learn more. You may either change the shipping address or delete the item from your order."
Interestingly, although Plastex is located in Nevada, it appears they won't ship to New York. WTF?!?!
https://www.venturerider.org/forum/image/png;base64,iVBORw0KGgoAAAANSUhEUgAABUYAAAJ4CAYAAACpljkyAAAgAElEQVR4XuzdC5hV5WHv/9/McBtQGBUFEhPHRIXE2KAlBXJTc8FpGo/atHEmbR hPX9D2nok9Z Iadpx2rRgWhNS2mrs/xR8TutALkesaRzJRcwNbIjBmFS8JI7RhEGJDCAMt5n5P u61 Vdtz17z w98 U8fU6Etdda7 d919pr/fZ7aRgeHh7WWP7Zd79uaOuSOnu0/srZY3kmuY/9 O2LtKK3Uz3rr1R9nHHuoo3Cho/r9kUr1N2xQTtvusg 3r77b1Bb13Z1bNgp96/i5/HSj3T1P/ZJ71mkLe84vTLn6e5zSfsyrX5DZXY5cffyrNZ2Pq0dlayfcYrZ9 1tmvd1qftPL1P7mUmFdDxvWXC hjvOHacSFAsBBBBAAAEEEEAAAQQQQACB0RM4ePBg7GANBKPFK4BgtLiZ9wnbrrtDG3beJCcWtaNR3X9Dm7qUEjYTjJaPPiqfJBjNy0wwmleK7RBAAAEEEEAAAQQQQAABBBConMC4CEa93oU S6DnoR2xWb0Pty5TZ2uXurqtv1mqzp71sjqjhj 7VJ0blmnrii61hnoquiHd9hJ8qSdj2r9FKyq rSLn6p9vV hgfk9K69 9EHbDsq1a4W/nlmnP7Vq0wi6k/Sfe4zLn T4e3o WRgJK 9971dlzvZ5qWyH/iIbyKHVf7vm0lnqLeufu1E1rJDANmBYKRl/WpvU71TH7fO05 znN /pxd0dTSr30nnhEDZsOlA4we6723PBrmmv9Tdq/ f8udb9nQB3uvtek9Dp1gjDvHKwdBM4j4fp2PtOs7X/arLX/2Kf73O2uMvTIjO3f72XoOihQNkk7urdq6e7IOdhlHkjuxej6e dhnU64zF4wer7adz2tjn1ewWZpe9diLbH/s1Qvdi9Iv8fu dKmp3WL95FIL0n7fPfN1faFL2upqS7tz0WCWb8856j3H5P3bX0y7DdF3e2na9OmPmX2JDaYmOrH8S55OO0m0mM0sq r3jNXS77eF gx6pRP75mrHV9324Pv5PYu9duSoX1F23SsDbp149ebJHqrJlyd/DUCCCCAAAIIIIAAAggggEA9CtR9MOr0NiwFnZI7LDsQ5PnhZyS0i33WHcJvRZKlQDG Py/oC4aO2T1GTT0gnX33BqYMyFMeZxv7JN3ANBB2xsptzUjghMAmG1NZ4sPYvf0HenX6YWf875YGypO4r7SeoO6VlGlaTjC6TyoFVV7wEwjqDEPpvZCsFPoZwkUvZAqGqVkBpx8OesFkMDCMf9gP6wLHiJ bKeQMD8H2A1b/ KUQLRhseuGjHw4HT8lkHwtSTfuN2pmDUStsLZ1LfAi5HyzGLILhoikYtYLvgLNbb8HwMhYSBwLKtLC7FOoGpmFw9x9rO/vi5xAKx2PnFQgpY FnJPT0zjcQYsZ6pMbOywuDm93Q2hSg0wO4Hr/kOWcEEEAAAQQQQAABBBBAAIFkgZoORgN9JkslCPZcdIPMcO9Ou0ul3WvSCy6dcC4YENrdSI3zmEaDPONnvV6bgeHfmSGeG9gGQ9BYteQsj2noeVoZPZ98ZYmHtfZ5Rr0ixk5Zor0/43OHGvdlaJ9F5hgN9lgM7yoYGJl7Sjo9QQO9ImPBaMK8jtFg0BA0mS 7hHApx9ym5uHWkf0lhcXB85vtzM3q9360PzOgJQsO6BZ581dmhGBZvUntwpvtwsGsORiNzRsbOZ4TXkaD5Mi jD1GD0R6teY7vimAjtavOUiO7D hnYTrNqGtxjzNvqk2bk9heb2PA F8uDyEoDw4IIAAAggggAACCCCAAAIIjH Bmg5GMxdf8odzez0ivQoLh3vGIdlJnw0FfinzXEY nx2MukPg7THn0fk03fPOWR7TsbKD0ZxlkRMYx8LmaOhpPNdIMGoMT00BavhC80LRYM9T46VYTo/R2ZGFa7KC0cTA0xR4pQw7T7iXhIdUR4eihz8U7 lZCh 9BY6S56oMBl3ypxWwhq/bn9l1ujMsfdfpzvQBtu3Lak9cDCgwVDtxeLU5XDOGgF69JAXEkbpO6s0aDgWThtIHFzjKWY 5g2 3zqLD1F0jcx16UzV47ScplMwIflPCaOufQscO9II1DfW3ti 1zfSezOP/a5ISIoAAAggggAACCCCAAAIIjFeBug5Gk3pAekPGvd6ZpmA08bOhXpuGOUFDLaE0hD9PMGp/NDrfZiAkzVueEQWjxm641omF5yhNnJvUmws0LRj1hsnHyhq5jFLmI80MRa1dVSwYDfQijAZzsXkYI2XwQsFcPSidz8bmr7TCR0V6cRruOGnBqLdSeXzu0vCOvBDMC0OtELS3e6vWnr1IWxa84Iehl 12wlLjMPrALqPBbngOynKDUVMgG96XfVy/d2vphMJGBYLRUE9Kw rwOXr0eu0xPPdrOIQ29 b02rJbbrctxHrNemFlaq/e6Nyi0YZkmN81MIdoLCSNtX9C0vH6MEC5EEAAAQQQQAABBBBAAIGJKFDXwagTMloLAFW5x6hhYaBoY8kdjAY/6M9p6vYgzVmeEQWjWWVJGs5fpMdoKBg11U/ypVbIcdSC0Rw9QfMGo0nnnCN4yx MevNEptzSIgsRyV4oyl3Mp32RWrU5sWLtKWd5ye 77oh7KROTC93qzejmqyx6i3GFVSPWb2GE0a/h7u5TlaPUaj5nkq0Qu5k3qQloJfwtE8nmyDAAIIIIAAAggggAACCCBQ wL1HYwmzBNqnmM0srp5oTlG4yujR3uhFgr0Au0i1EvUHcYem0IgMiS9vGDUmibUvMp7 O9zzguap8do4ryqCfOYxuYozbiARiMYjc5T6Z9Snt6IhvNPnWPyeGT y/Dn8wSjxgWArN0kzJ2qBbN0y275q8Q7Q9Sn6Kp9ShlGn1Qv0XCw3B6jfareHKPRkDtyzgltKnuO0fS5aO8L9SyOznPq9SL2eqoWm2M0GoKmTjOwb25KL CEMgSqO3mqhtr/suMMEUAAAQQQQAABBBBAAAEEEIgK1Hcw6i ClGdV ni4mbwqffr TAs3JYWOJXBT4Bif9zP3qvS9nepZf6XsxebttZGSF5gqzRfqnoNhAatgGJt/Vfpob9B4eUyLKJkWjyrr0qxGMGoIQpNXfo uLJ6jZ6lhxfDgEOy0Vc9zBaP 3JDZC08lr x XAqs9m6sG1PAG6uP8oPR xQ4f4OZf 6B U1jq8kbF1/KCEZNfv58nJHV30Mw3qrxCUPVY cZ2M60f0Pbjpc5fSEvP4y1zjNSX8aAM7SNKSRNCmzLunr5EAIIIIAAAggggAACCCCAAAJjLlD3wWgpFCxNnhmdnzIttPSCO6cmlqpzwzJtXbFVy0LD8 Nzjcbm4PSHxUvJ82O6wWSw2oMhZSjkTC5PuT1G3QhV99/Qpq7AXKPx UQNc6FG5wPN1WPULVB0rlFDmZ0tE3qrJl0mgQVkkq8kL4CKLlzjfsIQ8BkXnYnOtRgNDvMOpbcOGztv6xzP0rbOp XNFWoqT95g1PpsbK5R0wJJbplCQ6eLhM2G VfDw7DLD0aXvGeudny9T H5OkvD r1ekd2z 9Sx29OKDvHO06vXHPbF5oFtP12bNqUtRmWdgxeOlmrPCrov27VVS3eHzy08N sUdb nWR1fj4S20XayYK669/Wpw19ALG3l 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 67d0ztq1ampuzvfBKm5Vk8Ho8Rdf1A/OPVcLvvxlTZs/X1Nf/WpZqbKGhqpIwa4RQAABBBBAAAEEEEAAAQQQQAABBBBAoOICjY32aPBjv/iFBnbv1u7f/m0tev55TTnzzIofqsgOay4YtXqKPnLmmXrrkSMaOnFCw8ePFykP2yKAAAIIIIAAAggggAACCCCAAAIIIIBAjQo0TJ2qxkmT9L2pU7Xk4EE1Tp06Zmdac8HoT2 4we5Se9qyZRoaGBgzGA6MAAIIIIAAAggggAACCCCAAAIIIIAAApUXaGxu1v4HHlD/176m161bV/kD5NxjzQWjP3j96/XGrVtLw dzFoTNEEAAAQQQQAABBBBAAAEEEEAAAQQQQKD2BaxFmI698IL u61Nv/7MM2N2wjUVjFqrz6 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 tyfPnFygpmyKAAAIIIIAAAggggAACCCCAAAIIIDC BQhGC9RvvQSjg4ODOvxAj/r/7tN26Vo 9nHN M02NTU1FSgtmyKAAAIIIIAAAggggAACCCCAAAIIIDB BQhGC9RtvQSjA3tfUv/mTer/m7 RGhrU8ok/V8u116p5zpkFSsumCCCAAAIIIIAAAggggAACCCCAAAIIjF8BgtECdVsvwejBf/pXHdy8WYee pE0ZYpOPe9NmvmBD2jmn/xhgdKyKQIIIIAAAggggAACCCCAAAIIIIAAAuNXgGC0QN3WejA6NDSkQ4cO6cjqT rQ7t068t636azmFzT8wOOadP5infLpNZo fboaGhoKlJpNEUAAAQQQQAABBBBAAAEEEEAAAQQQGH8CBKMF6rTWg9GTrxzWi1/fpmP/8i8aOvMMNX7yJp0x Vkd7vpXHX9pWM0fvl5nvOudapo vUCp2RQBBBBAAAEEEEAAAQQQQAABBBBAAIHxJ0AwWqBOazoYHTqhk88/pz1/fIsGjx7VqVf pk6/8SM6fvy4DvzTv jIfz6opmnTNO f12jSa86RGicXKDmbIoAAAggggAACCCCAAAIIIIAAAgggML4ECEYL1GctB6PD/c/o5KP3a8///Ixm/NF1OvUPfl TXzPfLt2J55/Uof/zbzr8v /WvP/vzzTpkivV0HJegZKzKQIIIIAAAggggAACCCCAAAIIIIAAAuNLgGC0QH3WcjB6ZPtD6v XdRp ep9mffRGTX//b6lxygy7dEPHD vIV/5TBz77OTWcP1st/88qTV96eYGSV3fTn61t0J5bpKbuPVrSPre6BxuzvffqiVU9mrpupV43yudwvHeLftTTqkUrF Y4cp9 cvU89d/nbDr1gf1a1NaS8rl PbH8NL18t7XJVWrZs0UXjtcqzKHHJggggAACCCCAAAIIIIAAAgggUD8CBKMF6qpWg9HBl5/Vgc1f0Mv/sEGn/e7VOuWDH9LUN/1aqGTHfvwjvfKFe7T/i1t0 v9aoVnXflBNp59boPTV23T8B6N9eqJ9nl7evEbzhlePbjDat0X/Ne8anVizXW9bvSRHJYaDUX34Ab3pzjbNSvpk/xb912nX6IT97wSjOYDZBAEEEEAAAQQQQAABBBBAAAEEakSAYLRARdRiMDo8PKxXvrVRh /5dx1/ Oc6657Pa8obLlFjczjKGho4oONPPKoXP/RhTbn0tZrxod/TKe9cXhMr1E EYNTphTkWwegm7ZjXocHCweib1fDmxzT82Ic1e/ dmp/QafSlTVfrqY4d0py90l6C0QK3EzZFAAEEEEAAAQQQQAABBBBAAIExFiAYLVABtRaMWqHokSNHtL/rkzrx8MOaceFCnf6pv1LT3HlqaGwKlWx4aFCDfXv08if/Uod/skuTL71Up3V StOnTx/zcJRgtEAjLLppX7nB6FU65bMteuWjd2vqQwNadNk0w5Hd3qVaoxm6RYfvIxgtWj1sjwACCCCAAAIIIIAAAggggAACYydAMFrAvtaC0aGDB3Xgy19W/z3dapw1S2esulHTf/3X1djcrOO7d2vgm9 0S9f8rndpyoIFGjxyRAcfeUT96/9ROnRILR/q0KwPfECNM2cWUKj8puZgdId2NSzV4TXbtXjlND2xerUObnlQ2jtHuqJdLevW6sIF03Ro9xY9vXatBu5 RJozX03tt rsW9t1dqCHo9OrUWrZs0mn7VinF1av04kn90rzr9DUVat1zsrLdKahWMf7tumJW9fpcM99Gn5O0vxLNXn5Kr1q5dWh/VsfdcqwRnP2X6ZXlrfr8H3PSYuv08xV5 lgx19E9h7uOXpg9xb9dO06Hd32sHMcnaOGq9o0Y9WtesNlczUl8GnvOPOGV2rKplv1wrotGnzkOemcxZq8crXOXnW1XuVmmJ5r6OCZPUe9ofRXqeWHy3X44mt04saHdPG6yzQ9auSGrurerlM3LVV/QjD60o5Nev7OdU4daY50aZtm3LpWb4yUzdl9n56581bt29jjlMvdvnnlKp3TvlBnhM6hyLaBfW/apsGHn3T2lFKnUr9e2HKnfrn2Tp3wjFet1bmrpukXVtu8qlsXbGkPtZ2T/b16dtNa/cqqF6uNnbNYTVevirXJyl9F7BEBBBBAAAEEEEAAAQQQQAABBIoKEIwWEKulYHRwcFDHXnhB z/2cQ2e3KvmK5ap5Q8/pkmTJtk9QA9/5Sva/9d/bZfutL/4C814//s1NDSkY8eOqf9/36ZjX/uaJk89W6f93ac19eyz1dQU7mFagGXEm6YGo1ddp8m77taJadeqeeUSadcWDdz9sDTnWs1ct1CHOtZp Np2zVgyTSd7NunYg89JV2zQ63uWy1sDyAtGm9dM08At2yR3NbNurEw3ulS9doXs9qvS7QKfJX21bryctv07DOUdOH2zVtwVwN7bhTA5uftI/dsmOTLmwtFd0pw2I1LH5Ewy0fVnNbi4Z6WtTyuYV65YFtOr7xNp147ApN/WybJmmB5q5qs89v76Z2PdOxWTrnCk1tb9OkudLQ7h4NuCHw5Ht36TeuLq1m5BznOjXfuFsDm/o1uX2lprT26vidm5ywd/Fndc6OVTrbihh71qlv2w4duW2zhq/4sGa0LZAWXK2FbYETj9VeIBjds1GNq62FlW7UWQPrdH6k02gpcL5TWmlNFRDtMXpUveuu1i8qAdWkfPtWHNdl20eolO9c hVz9pX6L zXLrqFXq262jW9yQ8cMP6I13tuk0e/si20o6ukO7Lluqw4/MKe1bvTq aYsTei5eo3nbgm2gV08sv0wv3/2cNN9te1a9fP5B6dpr1bR5swYjwejJ3h7tav9NHbPy3yusNrBA8j5jaDMjvnDYAQIIIIAAAggggAACCCCAAAIIjEiAYLQAXy0Fo8cOHFD/o7t04M8 qpYVizTrgx/U1Lnv8UtzaONGvfSHf2j/95n/ q86dfly/99eee4 HfjCF3T4nic06zOfVcslCzV1VuLyOgWEyts0NRiVZAVoF65e4i8A1LtuoX7x0cckvVnND23Tr13WokleWHb1ueq/78065Ye79GZ3EXYnwLOWWV s5od6Atv365m1bdp7yyNq OwP9RurFjr7sRYsWmgtKBQPQP3ANBBAWh/xe2de1a3ztrRb/RwDf7ywMTLHqLdwUSyUk072btLOczs0eOkGnbttuV7l7s0/zuI1mtOzWuf5PWN79RO77HM0Y3ufFnrrLI1gKL21wvyrdizXf19jGk7vlqnlXr1x4xL90p5DNRyMHtmxVruW3qLhxTfrrJ61Oj94rm4AOvWB3f6q90e2rdIPL/ cmjY8q0XLW906dULQx9su06GjV uMLevs U6LbGvvwW4zfZrcvUOXtAf3fVTPrF6ivbc9FpoywG8z13brvE2l jzeu0m7lnToxF5rralgj1Gvjudo8oZtesPyBX7ge2jHWj1uO5RC6/KuFD6FAAIIIIAAAggggAACCCCAAAKVFCAYLaBZS8HowEPf1YF1d jgsz/WWX/xMc265ho1TCoNdk4LRo8P9OvAvfdq/9rPaea5b9KsVR9R8 VvKyBR2U3Tg1HDvJU71uq7S2 RIqGhdVa/3HiZnl3xsGZsH/bDQT/kuvkhXbw2MiT86DY92nq5BrRG8/qcFeNfWLdQz330MTV179GS9lJvTafUVpDWqr237Q0FaV4Zpj6w3w/6SkrmYHR/zyo9cesWNa7aYTiOO5WAdV6BlezT5mP1yhk67xEGoxdOc1edjw6nd/fbeO9 /cbVR UsLhWsq349sdzqbTpHzQ/16pLoHKVeKBzo3eud/2R7nwmrPbmoRbaVdunxtlU6uLtN83qdOg7 ibv16vHLztXBh6/T6fs36g2RU/HbUyAYPblrnf7r4o9qONJb2TuOF8waLSp7ObE3BBBAAAEEEEAAAQQQQAABBBDIKUAwmhPK2qxWgtGDBw/qyBe rIG/u139H/xtvebaD2r2m94UKklaMGoNqd/34x/rF1/8klq 8H/V/LGbNP2DH9DMMZprND0YNazk7gWjhvkyvdDKFIw2bx/WJV5PSl/rqJ5e1awXP3epZj67TRe19umJ9nl6efNVanl2S2i4vPeRkztW65Glt0lrfqi3rXa6pTplCPdUzQpGgxV2/Gi/Bvp69VJvrwZ2bdPAlh6dsOfBNAWjczTjh31a6PaI9ffjulQ0GJ3rBZzh4fSOc4sbHAaH32/RhVaWfHSbdjZfrmO6WXOG1 q82HXm9XC9Vqfv2aQ3WJ/Zfae 94aPONMX3HirTmtfotkLF gM07pPRbYNHfuoDvX369Du3Trcu1uHtvXoqDuHrO9m9Ried41OGOYQtXfVu0k7rN68gX/3Avmm7me1pD0 VYGpzRS49bApAggggAACCCCAAAIIIIAAAghUQYBgtABqrQSjL31nhw5v/qIavv1tHV33d5p78ULNigyFTwtGrSIfOHBAfT/cpUn/68 kty3Rqe0f1FmXXlpAo3Kbps8xGl/gRmUFo0oMOr3jO2HqLj228GK98lhSoGcFYxv1vXNXaDjQi9LZR9Kq7AlD6SUd2r1JT69arQFrblT/j7X40gLpvgc1bAxGE45TlWBU2r8lOpw OIz ap0mQzDq9VSdf5WaV16mRkNzOdnzUR17UKHevXu3LNczKWrKHq9h9rsa2rNWP5cr26fUlooaMi21oLKT2zbqX2rt0c2Lez FLT3H4NPhzoIbxrrb578S1S4kJVO/Row1INBIJRrw01XLdG0xcaktw d67XpLC1cpcTe0IAAQQQQAABBBBAAAEEEEAAgZwCBKM5oazNxjwYHR7S0NFD2vepz rYt/9L09 4QNM/eZOmzJsbWzwpKxi1F2/65R69fOsaHX3sB5px6VLN dStapx2qtRgirEKQBXcdNSC0T1ub8bI ZUdjN68XYvXLrntk0wAACAASURBVLHnwiwnGPWHX8 5VJNXr9RpSxbq9AVz1dzSoulKG0o/usGovGHvXhDcu1E7zl0hZxi9Nc48JRjN0RaCvXutzU8e7deL27aob8smdxEqdyemuVhzbduvJ1cu0L7P75WuulEzl1 t0xYu1KlzWzRrmhQbSp8SvDtnkhyMZhaXYDSTiA0QQAABBBBAAAEEEEAAAQQQGC0BgtEC0mMdjA4NHNDh79 tQ7fdo8bmOTrtr/9ck193kRqmTLNXog/ yQpGh4eHNXz8qI7/9Efa/8m/1tDRFzVz9e9rxluuU2Pz6C7ENDrB6H2hnoklKys0O037Pp9/KL238E98KH2RHqPeEH5p6gMDWtQW7WVYQ8Go3OH0PTdrTu9anbKpTT9d0arZ 0F0IyBqPeUHrjYlQFLjpJ 3f36LlVy3X4wb32wkxLlseHqnt7NG7r9fC99A6du22lv5CV95lYMOr1di1jKL15uoZi5WVrBBBAAAEEEEAAAQQQQAABBBAYHQGC0QLOYx2MnnyxT31/tUrDT/xcM972LrXc8jE1TD1FDY1NsVJYweiLf/RHGpw Q3PuvEOzfu/3YtsMDw1q Ngr6l/zdzr83W q4Q2v1dy/XKdJZ0UXHCqAVMamoxWMhlae987TW3xp7md1zq5VOrvI4kuBhZaK9xg19LIM2Pm9SWtgKL11Ws5w h41P7RNk9e QQdbH9Cb7myTE6GbyuL9nXkBo3gzOaqnV7fppS3TdGpPjy6KZJ lOTq32/O65t92idKmXrCG2DuLRCmw2JY3nYL53L2pBYKr0p/csVaPLL1FxjZWxjXBRxBAAAEEEEAAAQQQQAABBBBAoPoCBKMFjMcyGB3cu1cD3/qW9nbeqqlLFmtWe7tOXbYs8ewP/vu/af/KmGWmZr7u2f1qwPXJO47eGe 3Xgi1/U4Ud/rLl//glNf8c71DRnTgGZkW06WsGo5lyrmds26qIFXu/Mfj2ztk17b3kkvAK9tfjOwmt0QteqZcem0AJMv9q2Wk9efpuGI8O68wWjHw70siz1GLUW7FnU3moPybf nOzfoR 3LdXhR6z/Mi2 VMZQ g8Hg8y0 koIbL3h9Ndeq6bNmzUpEAqbg1Hp0LZV tHln5Ou7dbrN7UrGLcf792kXUs6dKL1Zp21ba3On1aay7Th5od04drL3NDVOtejemb1Eu297TFNdY/rhZN5tvXnhH3zzZqzY63OC3TO7dvUrp92bLZBgotWeb1IG258QPPXtekMr256N lR67ytOVBDPUp79XjbuTr44GLN2N6jNy1p8evTnt/Uamfr tW0douWLF8wsguGTyOAAAIIIIAAAggggAACCCCAQEUECEYLMI5VMGoNez/yjW o/9Of1olHH9WMNWt0yu//vpqbm5OD0a/cp71/26XJs Zo9k3/r055z7sTtx08uEcHvvgl7Vv7D5px3nlquekmTX/3u2PD8wtQFdp0tILRhsWLNfxIn5o 3K5pC47q J2bdOLJvdJ19 q8jVdby/z4f/wA1Foh3d5 roZ23KmBzU8qHrBmzTFq/ftc7bllrxquu1nTF16ms1a1qWXXWu26 BYNW0e tl0zlrRqaHePBj7/oHTdHTpFH9Erd4dD0NQA1rT4kjVX6dylOrx3sSbf3K4pl7XpTW0LAqFdtKqSerKWelZKwYDX nzSZ47qZ2vbtOeWh6VzFmvy1e2a0ioN7dqkgbut1PccTb53my652guFe/WT9iXq37xXmn tmlcuUaP6dLJnk45Zi1Nd263zNrW79VRk2z490b5QL1v7PecKTW1v06S5vU799y9Q861LdPQjt2k4tNiSYf 9O3R402apdbEaHnlEw5Gw WTvFj162TU68ZyzYFRz2wI19u3W0S1bNGi1s0vXaF7Par3OsDZToQuGjRFAAAEEEEAAAQQQQAABBBBAoCICBKMFGMcqGD169KgOfulLOnBrl6a/7ly1fOxjan73u9XYmLxI0vE9P9DAE19SQ1OTps3/bU2Ze0liSYeHTmrgG9/U/s98VoefeUYtnZ2a Tu/o2nTRifBGa1gdMb2/Zrde6teuHWTE1Qtvk7Nq1fr9VcvCPROLDEd79umJ25dp8M992nYWjR /qWavHyVXrXyap1tz61Z pPeY9TtBbpyuQ5bwaquUsuzW yeqAd2b9JPV92qgQetv3cCtVNWrVZrW6sOb7xMz654WFMfGtCiy5y6KB6MSr/asU4/Xb7WCYEz5/xMHuLvDyH3FmHyi58 LcBL2 7Uc s26th9dhdYOyRtaluuM1a369zWYM9KJ2R95s5btW9jjwYfsdDnSJe2qXnlKp3TvtDvuensqOC261brxXV3O3VpBbUrV2n28na9rmWbdjZfrmOXbtC525YH5iDtV /GW9W31m0v86/Q1FW36ty2Xj19bocGDavWn zfrafvXKv9G3s0bHn7579Sr2lfojML3G/YFAEEEEAAAQQQQAABBBBAAAEEqitAMFrAd6yC0Ve 9jX1f GLOvz97 u0m/5Msy6/XFPPtmbDTP4zdOxlDR553t6gafpr1Dj19NTtj73wgg5s26b z/2Dpl9yiVp 5wM65b3vLaBTu5t6w6Kjq5/X7hlzZrUs4M8nuuFZvTVlIahaLgPnhgACCCCAAAIIIIAAAggggAACEsFogVYw2sGoNYT xIkTOvi3f6sj39uq4YvO1umrblPzvNdo0iRvRkpzAY739urIzp32P05ftEhTWpNX8ra2OXnypAb6ntf f/yktOs5TV/yHs38xCc0efLkURtSX6AqCm1KMFqIi43tqQEWqr9/leb0rA7NSSp5Q xbdcoPd jNC FCAAEEEEAAAQQQQAABBBBAAIF6FSAYLVBzox2MDp44of7en vwJz6hhqFenfJXH9LM865T09TIOG5DGfq/9GXt fjH7X Z9 lP2z1As/4MHuvXwWfu1it/8W8abmzVjDVr1dL6WjVNnpz10Zr d4LRmq6emjy5l7a066lrNofmRlXvLh3ZYg3Fn6Omz/bowlULdWpNnj0nhQACCCCAAAIIIIAAAggggAACeQQIRvMouduMdjB68sV96vvzT nEE7s17R1vUcsnbtDUGaersTG9t6h1uv333qs9t3zCCUbX/K1arkleld4jGBo6qWOHX9a v/yUjn5np5oX/obm/s0nNems2QWUam9TgtHaq5N6OKOXdmzS83feqYGehyV7utD5amhbrlkrl v8JXM1pR4KwTkigAACCCCAAAIIIIAAAggggECiAMFogcYxqsHo4T06 ZNv6ZfXr9Hht7xVM679Xb368nfaCy41NDRknvXx536ugUcftbdrvuQSTTnntZmfsYbuDw0N6bkHH9ThzV/UrMd qFfddYsmXfhOaca8zM zAQIIIIAAAggggAACCCCAAAIIIIAAAvUiQDBaoKZGMxg98eQPdOTeDTp09zd14o//xA5GzzrrrAJnW/6me/futYPRKXf8s0697l2afs0KTZ7/6 XvkE8igAACCCCAAAIIIIAAAggggAACCCBQYwIEowUqZLSC0eHjh3XoPx7Qr277J8141as0/U//p6Ze9nZ7IaTR nP0oW/r4Lo7dbhvr874 Ed06pVtapgyY7QOz3EQQAABBBBAAAEEEEAAAQQQQAABBBCoqgDBaAHe0QpGB378Hzr0f/5NA1/4vmbf8WlN/Y13qOm0ObmG0BcoTuqmgy/3aeAH31Xfx/9Gp1x5oWZ98HfV/Kb/Uandsx8EEEAAAQQQQAABBBBAAAEEEEAAAQTGVIBgtAD/aAWj 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 fjtWrSiN3Au 3S/U6Hxcxs9qIwjWefYpq7WDdp5k90K ZMlZl 3Mre5iuo5bVz291hFd1zGzip5LxrbNufcd92nh46J3e5j30F5W4Z9r3Puvlqa9d2cd6dV2m40vwcsl7suyHhWqVI52S0CCCCAAAIIjIkAwWgBdoLRAljlbOoGpa3GF8hKvtCVc3J8ZqQC4zUYjbrEy0nbTWo7eV7ox9wzFpSO9Erg87Ug4LS96gejdvtVrQR3lbwXjWUwWsly1EJrHItzGMv6K17efM8Pxfeb9Inaum4rVy72hAACCCCAAAJmAYLRAi2DYLQAVjmbEoyWo1Y3n8n3YlP/L7xjHuTVTYuQ8rSJMfckGK2jFpX/VEclGLXbjtVZ1O1Nnv/0qrRlJe vYxispT4rVIlu3O22km2h jh5visqehZ2G9uqZaZRDBU9EDtDAAEEEEAAgVoQIBgtUAsEowWwytk0VzC6Qcu2rpA3gk7qiL90BoeHWecRHSLmvqx2dvaqy92RM1zf2jg4tNf cPpQS/dYpc 7Q6mtKQJCw/viL5H2g747is3hipbF/UxwroFcQwajZbB2ndFjybffIK3whjZHP ecz9ZlnWrt6nKGPwdsQ0Mb7eKEj m92HS2dqnLL3fU1/SyFncIebt11tsZaRvuue0JORvai99WXTdTvW0Pfy7Y03GeP5T OvVaw5kD9RWeBiJH241eN9G2bGyPGW02tW7nOUOwvXM2DafMup4Sr/W088rTRpPq3WsjeTwLXs/2LaA0lH7p9sBw3WibznDx24h9SZUudLtNzAtPI7I0OkVIrnoPwkfvL6Xr6Pqn2gL3mbT27wbV3fFt4qFE3msyPPVJNIy0/3vrMpXuCen326x7TNr wvfbDjn3/2iP0az24g6L7 xUb5c7DUzivTUhOMxVt1nn4dR9lkf80vTaReAebvqOdPYevjfYt/TgdADm8qWdkzGMdj3C10ByaBfbf/CemHWvSv3uD2hV 56Zdh5ZZTDcb8M970v10nPBXaXpBtKcQnWb1fbM14BzrFZtKOd F3vuCj4/ZH0PBO8x dtsok3AN9Zr1G0XYkqncp7w QwCCCCAAAI1LUAwWqB6CEYLYJWzaY5g1IoXSi9n7kOwSnNjeS9Nads4wUd3PDD15jwNvOhm9yqKv8D5L27BkClStsSgwS9LvGxeaJs z6rhhTLPw3xgvtdYSOx7lF46wi/IXqASDDXcl6uAgR9MxMLUYDgRPf/4frz6M4XZ/t8FylN64TaZhhtqrF78/QTLFg4EosPBk3o4ZrXd2CVjCN2N85lGQvjYNWAqQ DlO7m S8FL6vVkutYTr6XtoXAlTy gsj3Lup7Dwag936mhx2ie 4zpPlAK5wLhY7Se89R7zNwcjIbbnOFaSgjizT88eAFE8jVZutbMwZYxGLVS awfbuxqsH5ISr/H OZZP2747T wv1ztxQuNMn4wc1JLew7t0NQweeo213mkeKRalkKv9Ptinvtu0o99KXVkMPGvieB5Z/XSNuwn8ZoM/qiV9N0fvQ6qcc/McR557ivm221wnuvS93SsjkM/8CU/KwR/1I2fk/kaKPt 5/ wGQg4Dc8s2SMH8tyX8tq4ylntsJznXD6DAAIIIIAAAjUpQDBaoFoIRgtglbNpnmA08tIXDopMPf5KL6j r/ymXp7 i3dCr81A BrPEsKLClkP8HepQ ru9Ydhhc4zqZyhh/DkHjNptElzNmYGUEnhaeicEoLF1PJ0 0GY8wKc4OsvGhMud1IwHd5XSk/PSL0l fim0Rch67/vsvrydqt3mfviFilv7mA0te3GazXzXL02G1vQKlJPxro1XyvhdpLzejI0SHN7i7efzHZpLKP5vIz1kNTeUq7nWBAaeznO55LWOy4teMxT74bWEll8KZ9RfD Gz0XKn3qP8b2LBKM55vnMeY/Jb 6F/qVjp96f/PaSUPemm3JioB5YqC3p2slqt6n369I9N1f9GkLcfPfdSDCaq46iYarz30 1dqi7uzTlQOZ9IXashO/LqFPCd3/8dwYn1A73DMx/z4z9eJnrPPLdV3IHo9F7XMJ9LHiu e7bafeWyLVs9DZ9x8eviei5ZAWj e5LCc8wSQFo6jNpOQ 5fAYBBBBAAAEEalWAYLRAzRCMFsAqZ9McwWj0hSP0ArfH6Qka7c3oDwn0wjfjQ3DyC29mUGEINN3xZP5KxLEhWb5PdOhXqbeNsXdZEddAr0n7Y2mrzibZh17oZF75OrFXRfgFKOll1xRuO/XsHs8UYmWGyOYXoMy6jPRe8eptg1aUFlBxh0F68wbmDUZT267VMzH6x9jrNbhR8hx/2UF8jpf8xBAh bjO2eU8r8RgNwyR9ULsbR0Ocyp1PSf1IM2 zxjbWo6gwOtpaM1uEBtin3j9Jw lX293e3Vrxp/2IXnOy6z2nBhaZV6T8TAy 3p0TzznPca0v8RjGM6329DbMvn ZLpoSxVkPG7mNZ2v3TrTd5gC5awf1JL Pdh 3Ok1Mu 7kTZXTh3ZHlu1bMMybV3hzefo7Her90OUqc1Hv68Snx3ynmPkIMb95bhnjuQ8yr7feteVFy6mTeHQG5gaKNoW8t630370iAScee53oa 08BQjwWeWrO BfPelvDbeSWVdT0UeyNgWAQQQQAABBGpZgGC0QO0QjBbAKmfTCgWjiYf2XnrTgtHkD6csoOE8PMufO/ApXb/zJslfjdj6n 6/2/OYesMgvYO5vShN5 UP Yxsm3ie3jA3dwO3zPl64JgWGgi GJiD0aTeRdGh/0nhcGYwGpxjNVRuL0Q2vbyUG4y6dWOvIu0EBE9dv1M3qbSISqlencrMCpKSpkBIdgu9Kcbm YsOV84Mc8p9yY 1vUijSxyymy/csfQy22VKj9H0oDlyHcSul5S5Nk29hlcEAoWcLmUHo06rSql308VfJBjN6KEZai8J4UlmaFakx2h6D8rSNZYdBJrMzT1BvZEE3j0vb3vJH5QkHje1bvOdhxOMJt4YUwL1wHeV 13ktCZDMJp53zVNKZJdR07w77pbP2bedYF61i/Vdi8MXbo9e9Gb6D0tb6iYGN5GrqkR3jPL nE2533FePWHfvBIC/ CP hE23Le 3alg9F8zyzpwWjeH1Hz2njK a/3ch55 QwCCCCAAAII1I4AwWiBuiAYLYBVzqYVCUaDPSISTiIlGE2fvzOpUKWHbXtC/63L1ON0d3T 9/VPqS24MnHSS1zWS5vf2yg51El6Gc8MoGq5x6g/zD7Jv7LBqB u9Fygu7wXeHkv89frKacy3cW6qh2Mhsvs9SJ2wtGEHrzRsHZEL/k5rqdYteTteVT9YLSs6zlXMJrtMrJgNK3ejd2LjUPpC/dSjoZky7ZqUTAUTguzx0GP0ez2kj8oydsbNnxN77F/RMs6j7z7jt8xC/QYzbzv5u2NaQ7grDLaC4PZP0Jd5PxIog0Kfocm9skdtz1Gs 8r1QtG8963KxuM5n1mqX6PUdMogPzXezmPvHwGAQQQQAABBGpHgGC0QF0QjBbAKmfTkQajs5MeYiN/nxBAJoWHmaGiF0RtbTXMRblVWrpd2wMvmenzt VZlTmpx1fC/Fneiq85htLHVlsNWSW8OOWc7y51Dr/UOUbjPcqyh7eW32PU69HUak8T64Tcs90eVVu1VNu3h8 nuj1GoxdSuFdPrnkRyw1GTYti2KeT/bKY67yq2mM0OXTNvJ6zgtGcLpUMRj1zU 9gp4VUsMdoIFjv6OhWtxtceS0x3/yT5jbitIvSPS53wJfzHpPfPGGO0dh8vdF2lN32/Ss264eu0oZ2GOrVba7voYwfskILPoVuIQm9AiP7S6qX8N b5xg1f4eEQycnBO1QhzOxqPMjk u1dOl2KW0Yvd3cowtbpZcrPL94jvBxhPfM2HVqnGM0eh45n18Mz1ap9eJtH/tBNn68fPftSgajST093fqMLt4Yuj7D55HvvlSwxyhzjJbzJM9nEEAAAQQQqEsBgtEC1UYwWgCrnE1HHIyaVtH2hq1HV4E2vBx5PTJjq OmLWbhFjQwd1zqaul2ruTMhRqaP9AfRhceHh5 wUoKPkvY0eDBOZwVRuSbY3S70lZpTu5REj9uwouNs0y23UOodG7xVYxLPabi /Feiksv4JXtMRoaxhw71/D5O /owRWB4/9d7lB644te9OXW0GadzwVWfy/7JT/n9WS61vOcV85gNB7S5Bum7c/VWfR6jgZaBr YsWHxtvwhXY4X/MShwn5cWcEeo6XwO7yqvZ wOEFe8IcWwz0tFrLE7nGmayX5iyPPPSYp0Iudi3 /Tl V3rtXR /pWT06naw6vip9udd0/DxMq9Jnfz/4Abt9G/N6vRvusaYf02LhdPz7IE8duTdztQpu b4N8lNYdc16Q3HUWO7/7ocSp6z8x/HnnuK bbrWFV miP3xzBqOmeGT nSgajs93nk/APwqZnluzvAUM7jt2XCgajuX/cKOeBl88ggAACCCCAQC0JEIwWqA2C0QJY5WxagWA0/NLlnkS0p2Tqw25kvqs8L2nOW7A7J2B4mHviPHPR cSsc yUukIr4UbPJSPcdIvrv1T4xe9Rp7oSFutwN/LsOzvV29Ulb3q58OIvycFoKSAsTUwXXTjG6wnV2dqlLuud2P4TnRYgJeQMzHmXtqq3s98R9Bj1w85AuGjtMiGcir2wBUJyx8A8PDbPHKPeS2nwcorPXxdtJxHTEbzk57qeEq/1jPPKGYzGFyMq4lnG9Ry7PwTm zSEgX7xI/eZcoNR07VkXymB6Rvi5JXtMeo0d sHlaRpO6JzoJp6uke2sXzsaUVKP0rl7jHq36bCc2tG7zFp wvfF5eqs7NVXV3mXnv 7Sl2/y/QY9QzNPa4DU/gmX1Nm0cSxO4PifP ei3GO/9OtXZ1qXQbLv1YVWpb8Xluw dp/j6InpN5ATFTGJsn2I18X0Wviej3atQjb9BV6XtmkfMwPRvYoxaS/1Sqx6hzhKz7dmWD0dK9plQ q83Enllyfa9m3ZeKBaPe9A7eD7nxH2VTKoV/QgABBBBAAIG6EiAYLVBdBKMFsNi0vgQYMlZf9cXZIlBVgfQfQap66PG087xB3HgqM2VBYDwI2M9EpgUpx0PhKAMCCCCAAAIIRAUIRgu0CYLRAlhsWl8CBKP1VV 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 D2rpatWHnTfIYKlLyfffLKbJ3rMd1 6IV6u3s0fqycTPKJilUnxUpSLGdlO1pebVZYCYfx85qxUvtf5dTx60btNNrvFbb3bqs9N/FTju8tXsuSU3I3rgjcOyRHMv/bLR9VKK95Dkxt00FLfN8bBxuU3bbHYcWSUV6/PZFWtEbvodWpPjuNdca/D6qyI5LO6mP q3i9Ri9R1bt 94zd 5hCtWp Tss/r01ms8Mweef7ip h7plV9r1k/4dH3WqTpsu87vHfdY0PoMEvlPtf1f0WTNa347DU9cHnk8rfD9gdwgggAACCCAQFyAYLdAqCEYLYNXCpikPq85D9XY3bJotVetFqVr7NfqmvXx4AVuHH4RW58XCoqxGgJD YmUfs3tpFYLtUWjIicGoV2dp5apwmJAa0o6ChX2IMl9OC59ehe0KH58P1JNAde5rkghG3WZQreuxWvtNbr12W1HwByT3Xh79Ucn78Tb496P6zFCDwagpPDU8y1Xn aXM756kZ00/FC09d8Vajam 7c9t1bKK/1BfT3dczhUBBBBAAIHRFSAYLeBNMFoAqxY2TfsVX5GgrVovI9Xab Fg1MqbnB60Xq G6rxYjE0w6oVp3RXvzTgKDdkYRuYJRa1zq/BLP8HoKFQ4h6hHAYLRatdaoMibBAAAIABJREFUhe9l/ulWa78JHvb3rNVZtDQSI 27NvZvo/rMUCfBaPR5zf49oRojXioYjOYJRe3fAc2jleLherWvP/aPAAIIIIDAxBYgGC1Q/wSjBbBqYdPUYNQN8LrdX/KND6elYcx cZJ6fPgblHr3eb1SjZ NDvMPDXOP9 50np tXpFpQ8YzhqtFQi/Ti0XsnBXvreidR6nI3vC4 FA4J4Q1vWxEt83q7Zk1FM81i0wX4IXB8XN1/sY32CCtCEy7YBoSl2UT9bT/e sydbZ2qcue0SGhjLEw0lz/7hkHhtLLH2bv/FuWYY6LsoxgNNYeFO0dYxgiGbqO0obS73HKGAu8873Ahs tQxvsevamzIgGJgkBivE Er03lGef2kZS7xE10nadqyg2hUf4 nH feuyTrV2ddnTQih6nXpN0w2VOjt71eXOCeLvayQe85zpKrwpIpxpKcJzpmS143gwWmoDwfKm3vdNl6DXY7SzU71dpXOMTllRkbbih3WlOgtZZBiXQpzr9VSbM8WH/SfrBym/V6x9ASZ8znz9Zd13Te2vdD4J1 keUxgV3Tall1/irTStDNZsKelT6qS1nUwH/xkmu27C 1qqzs5WdXVFh9JnPf kXdeRz3Z0qrO3S115htIbt4m7lvv8Em8vwXu34XvFvyayen0G/LxQ1HSfCzxrLt3ujFwyPiPSazTHAwubIIAAAgggUDkBgtEClgSjBbBybLpz50595jOf0VNPPaV58 bp7// 7zV//vwcn8y5yYh6jBoekKOhUZ7hXYbA1XspKb1MG0I/78Hae F0j2V6oS9pZISHGT1GTS8aTlhQeiGI/repx2JSgFCaYzQeYjrHTntxzBf6bg 8oOdxLr0gBl568tSrH1QnT03g7ztnaODMMeoGgbFw0avlnGFezksktlnBYDRe19F6MtVb1pyi4X Pt7nkXjaxa2F7vF5LAXJOy2h7iF6bfsCeHXxEvZPaSN20XXfag 5gABC7V5VCuMx5gL0Qwjgf8vbAHIjxduVbBj5bCjvTr /sdhztCZ/241U8aEntyR6dg9Ce8Dk 9LpwWwm0/fC93auPcJifp82VfmiKe6Z N UqY77wK3w/yHN/MYSV0e9lwzVtvO9k3VeTpkUIlD/9O9x8b8vz3Zy3bmLTzqTUTWhe8Nh3Q8J1nWiZ8oOI7ZryHZ jF24uI8P9KvzsEflu8u5HWd/hwe8I70eY1B9/AvPZJ/YQHuWezlltm39HAAEEEEBgnAsQjBaoYILRAlg5Nu3o6NDTTz/tb3nBBRfonnvuyfHJnJukBKOxl8DIw2nSMK3gC7TyDOWKPfQmzDVmCKRK5 j2skl60PY50sLDpDDSW3wpoQde6EUv34N6VjBqtvV6nyQt0JRWNtOLfj7npEA2XIY8NvGhfdlhr1txft0HetSNcTCavPhSIExJCgFCbT5Pz86MoNRwHWcOa0649sOhQHnBqDkwyQjuE25Z5jZSP2039T7p/6BSwCatd240nDD2gI E0yn780OfXO04GIy26m57QbRID7KkHxVSf6ArzTEaW3zN J0UDd/T703ePkv1dJ167QX6oj2c87W56HQsTrPO8b2QapPUgzvPfTfP/SU7GDXfT5x9hxdQynj2SAy5SlPZhPdg6IWY8MwQW7ww2m6N7SxS9pxtNM/zz yEILP8 2MpaDUrh63C55inrSQNvw8 ezg/TNrWrXc7i3dmhaL27xjuNEXBXt8jDkarNS1RzudnNkMAAQQQQGCCCRCMFqhwgtECWDk2XbRoUWwrqxdpxf5EhwWGdhx5MUx7oQn0qLB34T3w5ukFEt1v4kuy6eUy KKQZ6huxotF5AE/6eXHec53hu17f8LzklqxWfL5ZAWjmaGWsQEUe2kyv8DHX KTDNJCzXQbL2guMAdaqH11aEPPBbrLGvZrfLHKGeaVexEV7DFaOky0fkrtw9hrL3R WT1Io2XODkPy1WtOy9A1mxAglTnnnfE8c94j8pUx3BAq3XYTr XQfS9HcOadpuk PBKPPMFoiCijHfd2qEPd6o4Fi971buo1nNFek4LZyCJkxvpO/GzY3PtsR0e3uk3TseQ0Ns HmKN M3pSOgGuAtOE2N1mw3eJhO k7PtLVjCa4/xz3k/TvlODuyiNVHD/tsDiS0nXcK66SXrOSWxHpeDe/7HM/15KeWZpDS485ZQx 3s/5QcUw9D0cp5fss/BvVY7OmRdKObvYENjCD5rWj7XP6W2pFDV EwY6EEa2H3e9pSzebIZAggggAACCKQIEIwWaB4EowWwcmz6/ve/X319ff6W559/vrqtt7ZK/cnqqRM8TlLPTm8b98UlcchloItdfM626LCplDLmWbU20adAzyxDkBN WXODLTlz87Xac4W6B44GxZGQND0YdV9 U caMxXQXDbvJTE2RDc1FC/NiWeXeesy9ay/UqEZB429tfwZCp254iI20ZeY3C81vmd0WP52xYdd5gzzYi9XwT6gKSF7wWA0/JKeMl9vrD6CvX ygtFIyJz2I4Zb7sRhsKmBXUJAYgpGE6/BYvMSpgWjyYdwQoexb7sp95sqBKO5PLpKP0y4aUxowTk3oin1CnPnGc3TjqOBVHSe1FjYFTnhxCHU9jVnWoE6fF2MPEQP3gMi7TTn/TI1fEu7p cqYzwYzf2dlHp/yQpGk3/sKPooUnz4fSmID8 lGw7KcjkY74vha9QZ5ZIc3pd6x0bnCHXuOeHvdtP9MuOHI9N3rY c/vwSnQLA/H2b9h2d5/koUm77d/CkUSyB1uG1P8M0HuZnkzxD6Qv8uFq0obI9AggggAACCMQECEYLNAqC0QJYOTa1eofefvvt9nD6uXPn2v979OYYjZxg5KUi6QUnq8eB9/LsP0wX6B0QJws/pGfOz5c2R5ehPkIvFkmBWFpPEid5cBcAivQQ7PUWZCpt4wwFrGwwau/dtChVjvDM myuXnduABob6hqxGWkwGt2/OfQtHozmuBRLmxQJRpN eMiyjwXB2cGoAtbLti7SilD7ipcwV73OzmlpCEZjw1oLIQe5DSsrZ/m5H89Vxiq33dHrMWruURVkzx8cmucRzAowQmV120QwNMn9Q0i0rYxij1F7pXTDHJBJK2PHmnWO8C28pJXfWOM/sDk3YPvvjT1Gy/1Oit1fRi8YNbeBfD2G/ft/1DivQ566ydljNN/zzyj2GDXM41z8 SV/MOrd36NhbOJt3vhd6IXeGaOTUu73Zd9Tyvw 4mMIIIAAAghMZAGC0QK1TzBaAKsWNi27x2jSA3R8ns7EMDO0aFLwpT7pJSn 98GH8ta7w4sgmXnzPPgnhDIJVl5PldRQNvLZrKH0SQ/76aFzWtni4awX2MYDLFMvrHgPGlMIEjWI2lQ6GC2FzsHeXTnDvHKvvwLBqFPeBLvu9Kkfwp/NEYz68xh2qMPqVR7swWwqa0J7Dr/o5rOM1nNSO8360cR0msWClNpru ltwGu3BYYqG0OCfPfMcoPRvO04Wr x8ChjuHio13040Q2Eg4FY0dhrPdIj1rBIk73ryHVsvjcFr918xiPrMeoFoElljLSTEXwnhes0KxhNGuZdoN169ZkQcqX2JDXOFRofZZL1/ZOrbnLNMZr3 cfsYy5rnmeTPD1GExY7zNlWsp89nPmDYwtFZs0zmvSsaZgCIFZPKcFoOd8p5X718zkEEEAAAQQmugDBaIEWQDBaAKsWNi07GPV6IYbDHX8opTtcyjgsLXpMw8uyKWyMvUzEeiTlGe6X5 UjIRg19SIKDJl3XsrShrMnr84eDykNAXNmXWWUzTCULY zP0QxMAQu9rlcNkmLL0WDDMOFkRZGxsoVfxmt6MtTgWDUm8c1PnWENVWEd 2Y2m20LvMEo8HFS/IMV/d665hWpU8O7GIhWewaCMy5F5sXsDuwanq G2B6r8/gKuzePSk 3UJwSPeot90iq9Ib5h2MKSWEBPmv5TKG0ht6f5ZW E7pCW 4L8R7mOW4J/ttLL6w2fZAG8vfVuJtP/7Z D04j3Gu8M38C4Ad/m4PTrsS84vc23Ldd/PcXwzBZ0KvzLi3adh5yrWd0fs3tmCXKdiO7iOXg3k1e9NK7/EfAkojU7zw1dRTMvr84yFLuu43Vi p6NK6ZcK1k9tPMapdyvnLLHfyAo58fh8O8e1g I20uLOCW0vfgPJ2UE8/m dtgKAQQQQAABBAwCBKMFmgXBaAGsWtg0M2wLnKThhTw6p5wVAHWqK9RLzn/gD wq3LPDe0kNLNpkbesFXt7nggvtmHoZBD T2Hshx0t44DxjL8uBEMjZzAphlmmrtQKzf8xAefx9mVdntpdosofPB1Z6def081/YSis6OPN2GsdhWgfKLptfF4bAyj/VyIJGnkFnZ6 6rJcX 4 ht2MOm8r3GHXOJvxSuVTbrVWlgy jgbaUPd1CxoUZK6dpe1PY6NF1qqdT6vKHx1oVGp 3LTw/Y85gNKl3XEqRwtdwhzZskFbYC03fpIsSVtOOfcZdDCv84hotU7zNpPYSc885Keyy/zntHhGYBmJM267TQp1FcxKv5QIv Cm9p/J6OHXr/jF Bxh6R5qsI 3Y9AOEd23Gh9QH5vPM6m3mBWHBFa0NcxsWait5FtrzylzgfjnSYLQ1tYyGdpLjvpt9fwlfS/Y9UtYq4tHpGaLXtGkV9Oyg1G4nii8 5FzS4UUN7W/ZWO93wzNDHgfjtWP 3ow t3S49RK8x2U//6Rd1xHLpZ3qbO1SV oUKKZni9LN3dxjNvBDSB6jzPuVqee0d14poyAynjV9S taW7Y10vYSnhHt8pjmHs74DuefEUAAAQQQQKAsAYLRAmwEowWw2BSBOhBIDRvq4Pwn1Ckm9sbKr2DXd oCIPn3lb2l9cJ7t1rXB4K67A/l3oK2m5uKDcdaoALX7lgXIffx08L93Dthw4kukBawT3Qbyo8AAggggEA1BAhGC6gSjBbAYlME6kCAcKkOKsk9xUKhpqkHT5FpAirBYh3PmlZx/ZVK7Ag9guPQdkeAx0dHV2AiBaNez9CEXqOjC8/R6lKA3qJ1WW2cNAIIIIBAfQsQjBaoP4LRAlhsikAdCBAu1X4llYZ95plbtFSe7Gkuqlt26/h3t67XTf647soej7ZbWU/2VkWBCRaMesP7MxeJqyI5u65XAWdo/VPXW3Oe1msZOG8EEEAAAQTqT4BgtECdEYwWwGJTBBBAAAEEEEAAAQQQQAABBBBAAAEEaliAYLRA5RCMFsBiUwQQQAABBBBAAAEEEEAAAQQQQAABBGpYgGC0QOUQjBbAYlMEEEAAAQQQQAABBBBAAAEEEEAAAQRqWIBgtEDlEIwWwGJTBBBAAAEEEEAAAQQQQAABBBBAAAEEaliAYLRA5RCMFsBiUwQQQAABBBBAAAEEEEAAAQQQQAABBGpYgGC0QOUQjBbAYlMEEEAAAQQQQAABBBBAAAEEEEAAAQRqWIBgtEDlEIwWwGJTBBBAAAEEEEAAAQQQQAABBBBAAAEEaliAYLRA5RCMFsBiUwQQQAABBBBAAAEEEEAAAQQQQAABBGpYgGC0QOUQjBbAYlMEEEAAAQQQQAABBBBAAAEEEEAAAQRqWIBgtEDlEIwWwGJTBBBAAAEEEEAAAQQQQAABBBBAAAEEaliAYLRA5RCMFsBiUwQQQAABBBBAAAEEEEAAAQQQQAABBGpYgGC0QOUQjBbAYlMEEEAAAQQQQAABBBBAAAEEEEAAAQRqWIBgtEDlEIwWwGJTBBBAAAEEEEAAAQQQQAABBBBAAAEEaliAYLRA5RCMFsBiUwQQQAABBBBAAAEEEEAAAQQQQAABBGpYgGC0QOUQjBbAYlMEEEAAAQQQQAABBBBAAAEEEEAAAQRqWIBgtEDlEIwWwGJTBBBAAAEEEEAAAQQQQAABBBBAAAEEaliAYLRA5aQFow1TpqihsbHA3tgUAQQQQAABBBBAAAEEEEAAAQQQQAABBMZKYHhoSMPHj8cO3zRjhrwccKzO7eDBg7FDNwwPDw PxQlZCfJjb3mLFj76qAaPHJHG5jTGougcEwEEEEAAAQQQQAABBBBAAAEEEEAAgYkh0NCgpunTteuSS/Tm739fDU1NY1LumgpGLYEfnHee3tjTo6lnny0rKOUPAggggAACCCCAAAIIIIAAAggggAACCIwfASsIPfb88/rv971Pv/7002NWsJoLRn92441qaWvTacuWaejo0TGD4cAIIIAAAggggAACCCCAAAIIIIAAAgggUHmBxmnTtP BB9T/zW/qdZ/5TOUPkHOPNReMDg4M6JHTT9dbBwY0dPy4hk cyFkUNkMAAQQQQAABBBBAAAEEEEAAAQQQQACBWhaw1hBqnDxZ3500SUsHBuz/PVZ/ai4YtSCOv/SSvv/qV sN996r6RddpMlnnunMN8qco2PVTjguAggggAACCCCAAAIIIIAAAggggAAC5Qk0NEgNDTrx4os68vjj2n3NNXrL3r2afPrp5e2vQp 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 rJ3BBBAAAEEEEAAAQQQQAABBBBAAAEEEKhBAYLRGqwUTgkBBBBAAAEEEEAAAQQQQAABBBBAAAEEqitAMFpdX/aOAAIIIIAAAggggAACCCCAAAIIIIAAAjUoQDBag5XCKSGAAAIIIIAAAggggAACCCCAAAIIIIBAdQUIRqvry94RQAABBBBAAAEEEEAAAQQQQAABBBBAoAYFCEZrsFI4JQQQQAABBBBAAAEEEEAAAQQQQAABBBCorgDBaHV92TsCCCCAAAIIIIAAAggggAACCCCAAAII1KAAwWgNVgqnhAACCCCAAAIIIIAAAggggAACCCCAAALVFSAYra4ve0cAAQQQQAABBBBAAAEEEEAAAQQQQACBGhQgGK3BSuGUEEAAAQQQQAABBBBAAAEEEEAAAQQQQKC6AgSj1fVl7wgggAACCCCAAAIIIIAAAggggAACCCBQgwIEozVYKZwSAggggAACCCCAAAIIIIAAAggggAACCFRXgGC0ur7sHQEEEEAAAQQQQAABBBBAAAEEEEAAAQRqUIBgtAYrhVNCAAEEEEAAAQQQQAABBBBAAAEEEEAAgeoKEIxW15e9I4AAAggggAACCCCAAAIIIIAAAggggEANChCM1mClcEoIIIAAAggggAACCCCAAAIIIIAAAgggUF0BgtHq rJ3BBBAAAEEEEAAAQQQQAABBBBAAAEEEKhBAYLRGqwUTgkBBBBAAAEEEEAAAQQQQAABBBBAAAEEqitAMFpdX/aOAAIIIIAAAggggAACCCCAAAIIIIAAAjUoUJvB6OP36LavPi/pNXrfzR/SRT7c47rntu/ojOUf0RVzalCTU0IAAQQQQACB8Smw90HdsXGXDoZKN1MLk55JrGeZ75yh5R 5QjyyjIMm4T bemVJqfsqF/fxe26T85j8Pt38odJTcvywPDdXuSrYPQIIIIAAAgiMA4H6CUb9F5KxexAdB/VNERBAAAEEEECgkMBePXjHRu0KJ6LhPUQCqr0P3qGN1gdmLiQYLWRdmxv79Wk4vde872alZpNVKFKuYJTn5irIs0sEEEAAAQQQGI8CBKPjsVYpEwIIIIAAAghURCAYis1cuFwfCQxZ8QMqu/NeKSAjGK0IfY3sJBCM wF44O/GIPwmGK2RpsFpIIAAAggggMC4EKiPYDQ2fEmhXhjRX/ITX1xe8z4tP M7Ti8O 487VD8yPC7667 pp8BY9BAYFy2OQiCAAAIIIFA3AtZQ5K/KGrUcfbbwiuCHVG5A9qI3zDlQxpnz50tPPmkPw098xhiDgK1uqmFMTzShDaROS0mdCzpvefoZ6cvy3932Bv5OgUUpIiz6hWO3z7rzamD6XPeG6WSmXyTivevkvb8Mw7pg2QgyOAAAIIIIBAlQXqPhg1vYA4mWdp3qVgj46Y58yZmnnwYGTOsNKDafLwKYb0V7ltsnsEEEAAAQTGVsAPmFK 8yNDll/1DXf x2AwmhhmlXoeJgWvYwvA0S2B8HNknrYQdQt8xjhXbaixlKZfyNo2aY7RtGDU9G9 hhucs5RglNaPAAIIIIAAAhNDoD6CUasuTHMlGX t9x7kSg hpQfa0t8Zh8YFHha9X8fjw5VMQ6omRmOhlAgggAACCEwogcRegUGFeIBkHEpv2pf/bGPoKTihoGu9sPEeltYZh8Nsc8jttwUvxAyGnYFewqXnUtPza6B9BIPNtMWXjHOMJkwBYHj rfUa4fwQQAABBBBAAIFKCdR1MJo2GX7wgTU6zM1eHdbYCyTl5cYTz1wBtFJVw34QQAABBBBAYEwFKhmMBoYvJ//4Oqal5eAZAsbnTj/cNIenpV3Gp28KDVGPBZnJ0ziUPcdo4oJM/OhP40cAAQQQQACBiStQ18Fo6hD5wC/5xgfI1N6m4TnAko7DsLeJe FQcgQQQACBCSBQaCh96dkhafGlcO9BufOXMjVPPbak2MJbZz2oOzbuikzNFCxZNBiN1HtKMBqd47PsYDQl6M 1z3qsKM4ZAQQQQAABBBDIEKjrYDTvqq8jDUZDhqG5mRj6xhWGAAIIIIDA BUw9dpze9dpoT0XZGmuc8N0PdEFlYJD598nffWrz4cWkxy/jnVcssRwPDp0/kV/oa7UxYqSem3G/j55/tlcIabpOPQYreOGyKkjgAACCCCAQLUE6joYLQ2HD/TwNDz0lR MJgwtytODpFo1xn4RQAABBBBAYNQEjHOSmxbFCUy1k/zDbeC5wi0BK36PWlWWeaDAEPngdEqxeTnN83fGnkFzB6PBRZ8qNcdooCzB0J45RstsG3wMAQQQQAABBMaDQB0Gox679ZD4bv3yjo3addBQFaZV6Y0PtMFen4YVOHOv3jkemgNlQAABBBBAAIGwQDzMjAuFh0XH5qJMCNQkRp7UQ2tLndM IWAMl8u0Kn3WUPrgwqMJSrkWXwo N39IF V rmVV npom5wjAggggAACCIxcoH6CUfv58A5t9FPQ0stEbA7QyINi T1GXeCMniEjrwb2gAACCCCAAAI1LWB6FgiecOjZIxKmhv4toQdiTReekwuOUvI1TMFkrJ3kCECtHWb2JHWOas1v//ZfbZQ1C4MyFgRNem5WYCEwPzZ938360EXBeiYYpdUjgAACCCCAwMQQqM1gdGLYU0oEEEAAAQQQGA8Cbi 8XMPiE 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 55W/ /9X N9n f9P/W rshNbj/0mD/b 8z1kZNfrlP2ls1qEGN/vZ1isJpI4AAAgggUGGBfS/369nnfqHDRwY0ODhY4b2zO/uZpKlJM6Y369xzXq3Zp7fUFMqJn/1MBz//eR158EGdeOyxmjo3TgYBBBBAAAEEECgqMOmiX9OM9/2mZq5cqcmtrUU/Pi63Jxit02o1B6PWC9uw / csHPIjkytUNSKP0t/Sv9FMFqnTYDTRgABBBCossCLL76on7/Qp8lTZ2jK1GlqbHR huRPZQWGhoZ0/NhRnTj2il579jydddZZlT1AmXuzQtFffuj3dOLSd2vwt/6HdPZrytwTH0MAAQQQQAABBGpE4Pmfq k//0NTvvUNzdu0iXBUEsFojbTNck7D6y1qfdYJSofc/7P y4pFvR6j1gZuFOr8k/OnwfqcE6bSY7ScGuAzCCCAAALjWeCRRx7R1OktmjPnLLXMmqFJTU1qbAj/0Dieyz8aZRsaHtbJwUH1Hzisvr69Oj5wQIsXLx6NQ2ce46WPf1z9DVN0yk03Uf ZWmyAAAIIIIAAArUsEHzmOvjKUTXesV6nNQ1p9tq1tXzao3JuBKOjwlydg0R7jTq9Ra1w1A06h5240/4TTFG9nLTR ush 1OlYJQXvurUFntFAAEEEKg3gW9 85uaf FCzTljlgaHhjU8HJyUpt5KU7vn29DQoKbGBu391QE9 ZPH9K53XV4TJ/vzNy/UpC/eq7Ne91rqvyZqhJNAAAEEEEAAgZEIeM9cL 0/pIP//aSab1yp1 764Uh2OS4 SzBax9XovZ9ZnUFLuafzv y osNSw7CdfoaD0dLUo3YwOtQQnGO0jkE4dQQQQAABBCoo8LWvfU1vffs7ZT1E8mcUBIaH9d3vfEvvfe97R Fg2Yf4WUOD5hw5Sv1nU7EFAggggAACCNSTwPCwnt/zsia//lV6HT/8M5S ntpu7FyHA5mnG45621j9RK1g1O1Aag5G3czUCUa9BZyqJ/L47Yu0ojt5/x0bduqmi9x/33e/bmjr0nYtVWfPel05uxrn9bhuX3SXLqja/iPn7JcpoSxLO9Wz/ko5RbXObYUsrpBLhRn23X D2p66XjtdeL OOjb4f1fuIe19d21P XiHNuy8SV6Vl3uckX1upM77dP8NbbKLGTML/JukpZ09Wn/lbCUaP367Ft11QaANjKBkWW3N3nU1ri2D56hcy1GrkdbrCOxr qO4FK0eKxh929vfEZiDpuge2L6YgBWMfrumgtG5Rwao/2KVyNYIIIAAAgggUPMCVjC6n2DUrSd6jNZ8g005QXdEn51/RjqzeD1GE4NRa4Mmd25S97PV7g TFYxaJfVDwGqHKdXev6na8oRVfjha/QDDFNCNbjBq1/gYh6MjdU4KRs2hqB15ez8QBIJUP0QOheMjuDnlaWsEoyMArtePjrS912u5yz9vJxh9Z/k74JOFBWqtx jcI0cLl4EPIIAAAggggAACtS5Aj9FSDRGM1nprTTu/QDBqbWb/pxdyWsPovb MzC9q79LtIhr6TJUtkkO3QIjkBUPVDi6rvf/UYNTQU8/qLeh2p3XC4eoHGJUMQc3F9XqMGsLPQHDn9aSscvOr0u5NwWhyKJp0EtULRqvRK7Qg5Vhca6PU47qgBJvXoYA9lP5tVo9R/oyWwPe W1s9RucctnqM8gcBBBBAAAEEEBhfAi/00WPUq1GC0Xpu25E1IKJLQljZZ jvvLDUK3Nw L07nL6aHGlBXGnYtRuiJYYppcDQP9foEGZTb7ngNoEQ0t9HsKde9N8j y/1fC0FfqXzTwmiUgOiUrmcoHBP4lD6eM/bePAY3yZ4XuHgzjOwAtllW93pDqKmMbPswC1Wp6HGVTqHcDAaPbfocYKBcY8uuMsdxm7t29jbMqu9xAPoYEi5YdlWrXCnAzBPaRAPRoP2ptA3eh2YelKPOCwuJ4w0XDfR8zBNjxB2yR5Kv3R7UmCe1Cbid6WQmVXvnVJXaOqN7PPwp fIfa8pr3dzsL43aIU7nUipXUdNo bBz/dccFdgegrzNZh f8hw2bBMW1dYU5iYpoYI10PsOJHrr9h1VM1vnpHtm2B0ZH7lfJpgtBw1PoMAAggggAACCBQTIBgteRGMFms7tbV1xuK4TkfRYR0/OajGpiY1NjRoeHjIXlV3UmOjhoecjqMNjQ0ajXUlkoPRQHiV2mPUEHKVUj1nTsyUIcR 4JASjCppXsyE T/teSWv63XnQy3NI2lsKClhVTAcSesxmjwdQSm0yd6mWDCaPFdoejiaGowG6qkUrCXXb55tHPNgeJWjvRh6FprLmxSKhYPRUvCV3BZqMhjNcd3kawd5AsmE3tA5w9z0KTm8NpnnPNyr1HTcRI/sHwSi177xfN37yZ6keZcDP0xkTUESDKazr/00l/CZJ89tnHJdBa6/YtdRbX21Bs/GCkaX0mN0VCtoe431GD2LHqOjWv8cDAEEEEAAAQRGR AX9Bj1oQlGR6fNVecoXjBqCkjd3qCDGtbREyfVNKlJjY2NGhoatLuRTm5slIas1eudfqVWaGoFpNX8k/WCb8da3gJMhrDCf9E2hQZecOmHnqbenIFwKzUMMfeuDAUFWb1OTZB55n1Mm2PU/3ygHP55eOds6nUX7Y3qLu9kmOsyHl4HQhDfPW3BoVLBsxdfCvfyNAbnXvkMLqEQNFAfXgCeq71kBKPZPTfNIXM8pC251Mwco4brqFTelJ6wqe0gXyCZapC28JdxCoZgHVQiGDX3XDW1pzz3y B9z3wPMYX5pXuQ fNpPyal3R8ygtEcc9yae8fH7xPB6z/7OsojOTbb2MHoW98 NgefoEfd/r3v1NTiS2e9cmSC1gTFRgABBBBAAIHxLPCLvf0svuRWMMFoPbf04UAiOhxffclZlH5YJ63trC6h3ibDw2oYHlaTGuxAdPDkkB2KNjVZa9lX7096MBrpkZfReywWusV6mnrlSOjpZ9q/KewMciQOqbcj3exFhDKC0XB4kDHHaGxf5iDFOrOkUMIUTsX LmcvPnMOnLYqfbTnXVrAaJdCnT3rdeXsZJd8UzW4Z5oSQKdPARAtafy8l3Z0SN3dicORazEYDZYqdp267T52zRkDzHzBqGI/YOScU9fww4d97rF2mvM8Mj5rvhvmuNYDH/Q9k4aaJ9xyves2sV0nWYTK5O08T2Ac GEq8WsgebqD6HUzz 99X8yret9A5e2ZYLQ8t5F8imB0JHp8FgEEEEAAAQQQyCdAMFpyIhjN12ZqcCsvFB2S/n/23gTOrqrO9/3t6Qw1J6kkVAwQEgxggAxkBBRQiWg3ARSv5F5b5akIrTjLoK fH28/G9TX79M2Kkj3fXTfT9 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 cx6gZJXnhT0Sxp4R12WgCyau96WvDU3U5hpih7idA5QVgxEJZWwG0fXpA2/cAoIyw7dF0u /L8AsJZY1IwSpw8bY/izY/Byc0aG3I9IR6jPs/IwBlK6L2a8FYP 4VQKOT19RsGVv33VQVEutaXZG1V3Utj8BhNdI4SinkamhGP0fUbrjoNI5 9Q27f9tK0CqWfOzx69m4GXzlXgCvAFeAKcAW4AjNWgZNdgzyU3t5dDkbPWDMnsNP6Y FOEaZpwVHrf QtAkXJHx3QNQuMkq RN4mnqCCgkC9CTqdpDtLp7THKAmJBoFMpnsQuwlMGLzEeqZEecG4Ih83YvHkLiZyOD6evCkAE4QwLkFS8zoIelW7IFOm9GeUx6srBSQtNkQJX7vVHQI/wkHQ2NKyshZEftuocox3469W3g2wLay8rFewnC4z6vDAjNXZBwomCSNXYGqsQltvbls7dBZrdv9gYD3gLePQm8MSckByjbptg5Sd1fS3mFwlJvn3Eh8JH51ZOmmO0XMiJNecoj tqbMVz97m91CNyjE6UTScRexLaEDC6bgLBaPdvPos1v9mEV/7 JsydhPnOhC53TDMw2jwuMLoHD5 3CT/Ah/DQrv BG eF7ZDd7r7foO3PVwGw/t36kz14dFPoQ67OuvDU51bh7lXO81NgCXt ikU374lZF5mHPbet3jnd 0Q77iJLnfAXGe9 4K9cenc9iTu DXx/nOeu9WcLcQvYGtOz/aVnyquJW19UX6DaPlBRZuNPY 6MsdqZV3w6pwcBhI1HdFz9RcBll84zYeu13r8fvz7 RayM3OskduKsM9poNsadG7pDvfmv37yR7RXherP98DsXOyta0ck2R3BpjnyK8TW//yfttzZe6hf16xthiyN45G5TvO185 vzIH/53Ibo/Yu5VcQZbdeq gOH1d9hgz51BrjNLKNae4u6LcP3MdrtEZ48We6YDurNXYWiDuHrKeZZ6dMA0n/P7nHVarQEcCMPrII4/Qbi 66CJcd911oUO8/PLL2LdvH33/zjvvrHYqp709B6OnfQvGOgEHiuoUeBqQYFAgKoIEzAuEf oEhBokdh4DbcdQHBlBoViAks1iwYVLgGwW UIBqUwGkqKMdSKJnxtvKH1k6CkTnPmnxiq 5LSx3kNYlWj3h3uXp5y/gnwFuDFkqQpAMLzWInOgViBFVNEjNyz160neu PgDbid0EQX/IrqL8pLNjJXJ6NYUiVPZFC7xFXpmVCIsRdJQukTAZ2oQlRs79hIj9GyOVYgdOID5m6YpNBX2fM4Jr9rIK0CY0Zle0nuMUp68dhgEk9y/zPOVDZswIZt27AtMuVC0jy2UakF2DAwytM1/N6LmE C9AXW0l3zSXQ/VLc/bNuLSnsR9UuNMVnyaX IgtH1E QxSj6A3PKA9QH87zgYDdvcHdunl8do89B4PEb34OHzN EHGz EjVtX4a5jLDhktyGC3DtWsNmFpz6/CnevHOvzYzhq1J734KFXYoAvWb9/Xc5ZGPN6I bLmBeFA63jO3f0w/7dzzD3iPb/gw9VtCAAY80XgYfYYDuqL e9e3/tgGPHhqLmPxF2ZvXRuvFD2Lr1GVTGd2nNWJe1dtLmfvyaYd/Wz3Kj3b86/aTuw5h jMshJLX/js1j4/W1176HvYem4Vc40UZN/yAFuzJEfLfn6jax1BO3B35MwXjDGDWrL2IPA1xhwoUPTYsTNu3H4yFu2ceXLNlW3b1S6gYYhN2I9YZ5rcq89ga g9Eq5T1BmkQzhrp fBby/2JKL23X4 bG6OHW7c Ay2EuCY5GeCmHslqHqCM53Idm0dE8yTfd6d73FjsJsk54e3GZcCHd3xHqNtbW3Yv38/BgcHsXjxYqxduxayLHvGfeWVV3Do0CFkMhmsWrUKixYtGte8TsfDHIyeDtUnZExaVgmATn1GdciwaswTMCpCNABRNwBdBwYGsfVf/hUnDh9BLp/H/PPPxcZbP4qGCxZBI96kkgxRkmgO0sl8jReMesKWyUQJPPh0m50PMC7HZtAbzQv8WFXsbTU8gCzoGUVbsUCfX8zxglFaY8Zd0IjM dNos0PGPXCGAUmC8MYLOMLAKF1GRLGnMJuJK2IU9HalQpY9PZ1 vfDVC3Y2bl1tgVzyCoBMH3hi2sskeoz6dbPnV/bs84BAxlxt79wxncmqwGhQd2ori/4Rqy1KXiksxurXs44qwVvglwzJVhsAqoF7ICwc3m9fm/HY00vx6A3fc0FVew6xNh e1sG9irh7L6zYldOH5/mNW 09oQZvFySrjBZ/P1Q8qSPTiiTYhrh5J00VkGCo09qEgNG1668c9xxaf3YuPkrhAfFM gl2JvkQNO5Rz8wOdm5/eVqF0s8ZGhmHkOQD4U344b0/wd 2fgntd70T9JLc81NcsB245wcP4of3Pomj1GO02hf54HoFvrxyrM9XOx5xav0pLrhlD/42AoySD/9r716FXzGAWdR7Y5hN5RHGvOj5ax3rubO1ddzN/HtEYcWXgId2e7x72euL6Yt4Cp9/E1p9fcVrPQF2Vtbti2hfQ2yWYUuMtXruNsYz1vv3MW3A2bSx20mIXqEGFNU uq9Ie6XaPYh7fs043wmMmW2fIWfa3oNn7X79Y1rzhPdc vfN/vdK33z982DOK TZ2GXaGlntGPYQ0NCxadadVtmru9qvCLUvphauiUa9X97vVxbiYcb5pt3E7Ht4/5W93bnwp8H9ChMz5K4JN3fnjo4404ls154vYu7QKNsYq93EGhZvMF4FOruHEoXSEzj61ltv4dSpU9Rz9OKLL0ZjYyNGRkbw5ptv0veampro15csWTLeaZ2W5zkYPS2yT8SgOsWh5I8FRonHqERD6km1eZmAUU0HVA04egx/8fVvYP u3ShpGi5euRxf/D/vw5Ir1wOZNEqmAVGUIIlyuXD9RMyQ98EVmHgFJjb/48TPj/dYjQJVw7NAiL V2iEOwlczp raWkB768an8dCNzdU9mrB1HFhN2A1vNkYFKBhdNz4w2vowAQMb6QfVhb 0Ac2j3GM0bEt27phmYHRwnGB0kQWZ6Afg9i/iqC9 vPXhz6L9VtcHV/r Hjy8yAZk5fj7Ljx1xxX4cjke1LKpG2lOBvu9lU/iV7ipAuHhbuMobvX9Q/cGEKDlj2tvtWBP UWAvttu6fs2GA3JC9H9lAvSJMod4Z/bffhVm9fL1urTFRTrmnvwvX/A37Z xqUZLHgVHdPtUsbRnMzj42gn hP47NYqTIduC5hS ETHS9oXAmuOv75s3aq2M6dne24EfDx6E0A1XhWch70mCoFtu7Tut/vwq18DH3XgoEvf8vu fXSvqXo78doyBcnheSpcQ1V0Cth7jMjWHBmakOfss1KdbcXtqndP6PGx9X W2Pyt7/jsy qPqSVj31ij070iv0CI v4UsOu4ddjvlzV6ErjFBu Bc2TDZWo/4XvlWSP858x3z7HutvKU9 DhO7Zh/fe/iJWe 8k7dqguMfvu3EcBu/A8x7rrQzRNuI/W0wnPdCLbZdgia4pVzS h3fBmk65AZ08yMEomcvLkSezevRsdHR1YsWIF5s2bh76 PuzcuRMtLS30a eff/6kz3myBuBgdLKUnfR LRxK/pBgegJFdRCPTwuMKoZBwahZUmG fRTf tzncWj/a3RWi5ddgtu/9Q0s/ D7gVkNKJCnRAmKSJ7kL67AdFaAg9HpvDtJ58ZK45AMLCYM 086kfG2ox6vbQHPzfF2636eg9GJVLP6viwwuqH6B0OeaH34PPuD56YZkWP085/7P2K1 bu///9i27gb7NyxbXp5jA4OVzV/b2Pyofdm/PDeJ3B0/XZccAuBXn/uyrVIPpi349ZHF KXTrsyGL0ZrQ/tsoGP3Q Fk5btdD/1OdvT6O9x41zywXU1BYDXl58BqL0RaFUe0 qn0i9NCGd7PDpjOX1vxT2/Pu6CeqvxZQrObNtt/ZkNRsn4IRLZfRPvNve8mK2dtkQrG5j452/9m8BeZ8ygLmDMa2LOna3xysr86DrCdGDoWlk3uy 6p09twk7HHpwHXJqwlR6rndm9 ecaNnfG1917hIC9sWyQsYJq7MTzOMOeY06rNV/SyH0u4o 4dd4IGHWfX/s5agME6jnnJb6/ BauPWUl47U1WxkYM/hc8NwER7fW5z7zrBkyzlv8QqwWbo3A0CugYdj67bNTvov8/56APfHPJWx/Y/Y9THf2vZbAHiPvFN9GJD3TiWw3ROPA3le D9HIGOd7RVIb4e0SKTDRP3d19gwn8hh1JjcwMADyszEJq9c0DZIkoaamhv7cRkDpmfziYPSM3T0CRq3/WWBUpn TF/EblQ0Dkq7BzBeRe2UXvn/PvXirdS/S6TQWLl2K6zZ/Ah/ yt1AOgVVtIo2Wf6m/MUVmM4KcDA6nXcn6dzGklu00ncIHE2YozTpHOPbWfM4eMcujCfrQdw4HIzGKTS575Mf/tZMMBj9WOtPsGOGfGDY29qKl156AW8fOhTYiPPOOx/Xvf8DWLEysXse7eOVaQZGZ08AGP3RvU/gyF2gUBJukNH6M3yh/Vb8/MZ2 p7VzvEYvRl7H9qFn984j0LQdXevwuMeKGN9CP3tjaQN6H9/BT7bav0ZFt yBz 2QSK7HwteVezSAhKVudhb2/0bfIGGlFpzIqDD3XfoSaTtXJ6ntOF9vrX45 D0Zs2FarbQGn FHwTZ/X/L TpjXt71jfXOsPT ykpnj7y6hM2LAGGql fF7ovOk0K7jeU9szznbsaPNkbdG 49q8bOrEkF7cKen9 e/DZAeBeds7OfQdvxvh hfUI78fZgjeeck2Q7a6/NVwyMvU VHsPODm3BnLt7NkF7j5urpZvbDnxP2HsRsDu7WcWWrPQtod9z3HMv3z/ 2bk1i5hT1KJ85zRgF/5z7Ni9f06MdVt7A9eZcWza 7U4zZ33g/dFyJ0YmLNrBEfXgKYMm43qxz1pe 1OGgXPenx7nPhMJxo75D5gCmpr5XuvfD8n3QTeLlSBif6561SVYNSZ2DPPPIOjR49iwYIF2LRp04zYMQ5Gz9htdLAogaICdAi0Rj2pUE/BqGmBUSOXw8k/PIef/tVfoe2NN6DrBpoXnocPfeqTuOmb36RgtGSDUZJCl4PRM9Yg MS5AlwBrgBXYIIVoGB07cR6jM4kMErkfv2117Bjxza89dabZfUXL16C9RuuxPLlK6rekVd2Ti P0dkD4/QYveBm/OgeC6bRD9xwwBr5sElLpePGuXvwsKsdhWEX3Iy9f2tBtXiwFwLtyIfejz6Ib/2K4clGPmSv/RLKH7Kvt FJ6DO MWi7PfjxzgiPUT/LIQCjkgsAsHWxwj4Z0NH9fOh4Xq0opPLNK16/JGYaPkfa/w83VrRwaXu9vYfeESLA6A8R3K ofaQde 0nuZ0Fn3XmScHKl7d652KvC641WWu/D48ftT0pfXMNvJ9AamfsctOynfgf9u19gr69TWzdyl907SHTdldV1hmwzZBzVvWcbKj35a1g247dob0XK/xn29bf/SxzLwPzsm3yWddesubO6D/REgM27Lvz4t63B2Hak3PeXHZirRmB ylgW6Rft30xbJw0CZxx kXrfg17sfaPPS9bC cODuswZG7B5v7vJ1YLph3E3i3kyWrAqGs2/u8x5Bdizj2RyGh4ozAFJvLnrlO91XmMEk/R559/Hr29vSiVSlAUheYavfbaa9HcPDlpxabKEjgYnSqlnXEIuZyglylYcNQComIZjBK4KREwamhQR0fw8j//E/7nz36K3vYT0DUds1oW4KZPfwYfu vPYTY0okC8RQUBskjKNvEXV4ArwBXgCnAFuAJEAQJGV69dP2FitD58Pm5tfQjbZ4jHqCPM/v378MfnnkN7 ztoaVmAq9/7PlyxevWYdNu1c/u0CqWfNTA0pnVYD 3BIxfcgh/d82scJp6grT/Dko8CvyQfDrt/gzu/A/wltQVfO/vfe//2FTxyI/DbO9bgK4iymy6rzUp7HGfGdLwf4Fu/OoY77bx9dD7O /a8PHZpPxO6aM9aWvHjnX HP02UP9Tdoz3fZwkEJHPzrz84evdTn8d6Cjr841nPWlpZnqxLPuqd18ScuxCN7anSMZzErdeTvVqIx93z8iyJ3ZfVB4FzMWsMyDNWO7PgDrGR2P0mDYjNWpV9LK0pMCJzvteyaY8W1tfAeD/5gfLbif9J394n7zjY0tGB7l0w1Yllfys96yx3EjhnY5 INQ6BohWNmb3Ze7GifLZJK1svxl2R6Aww9pc1NmvPY1fM0sj9NYTcVc59475PQwdz2WGiPQmeQ0f/sCE8 8Iaw9bwWaYdVeyZ3T/r7LtaJtyfqs50NTpFfg KtoCyrp79jLUa3iBCAefnrpMnT2D /HPG/HNXV 9I4lD6zs5O7N27F8ePH8eyZcswd 5c9Pf3o7W1Feeeey6WL1 OhQsXnrH7xsHoVG/dhIJRK5yeeIwSX0 na5pp1DQgmBr0Yg5vvfg8Hv nf8RIby91KW2aew6uv/ljWH39h2Bm6qEKAkTBgqM8x hUGwQfjyvAFeAKcAWmqwIUjK6ZYDC69yFs//nMyDHq3reOjpP48d/8v7jjC3eBeIyO9bXrlT5m8MgAACAASURBVGkGRvvHCUYX34IffcsBlnvwyOJbgMeP4WPtn8df4Ps2YLK 7m 398c2GP2CDUZD7aYLvyVtVjDA6Md gG89boFRCjR dC9 ecSbJ5F 3bFL8kH5Y6348Y4Y4BnbzlqTtQZG3jHyId Kf8UjN7b71s wntDxfOMw2nnWN1bDJNCJpXFYf3R9T FPmTqy 6Lw4CtgaB jJQHpY7Izex4EeDBsK2Avnj1zgdGATVXm80vcwrS5imzV2InfjuJ08W6Ope/KgP07rcLOB3k/8llqc5VzNlYTs8YHrg87M 6O7b1YYZ9t661wG41bO32csb stUTpFLr2EI3KfT0O3OrR0G/Tzh6wzocN GOeD87Nr1dwzMozjLMStu 2jhSOus9VlJ0k0T5JG8cGkp7pRLYbfU94zk/ozzfJ hjr2TlbnyM/d/38kYfxqU9/Zsw/d3X1JQOj7e3ttPI8 Xvx4sUUjM6ePRsEJr722ms4fPgwzTFKqtKfqQWYOBid6pNE6OVEwFGBdGPAEIi/KAGaUrlfAjdpYL2pwTQKGOk8jn9/8nEURoYhixIaZ83Fmquvw/x3vwcmUjBJKL0NRTkYnWqD4ONxBbgCXAGuwHRVgIDRKyYYjH5870PYNgPB6ETt4e5pBkabJgCM/j/f jXeLhcUOh8fx0P4m71PAf 3Ax tD SVdl7gQ6DGhq sxL8ygKZlT ux4wtr8NUVlXHofrT DBd 7Af4JoUn1gfTr8Jvf/bY1ztfD4NNQQB54cda8TcRAJVAj4//6N7AvN0QxgE7tG3gbNhzJuu6td0FUl2AzLNGZ83eebH7rtZiXXNxF8NhAioL4rD2zA2wAvsVBj7oGqO09tuPBcFj7SwOtNjaftABdSFglLnH9rPWekNswN6CauzEu2vVgdE48BdlJ5H76bfBak3L9rz9 I9gn9UEHUSA0eAZt 3BOV9h9sS6L/x3ig3eWGNEzjpUI9t27Yetu4r8w2/TYfeXM6r/HnPOICLuKN ZjtlHywa2VvYoor3TFv67P w dHR9NuKsxJ1XIkVcG/ ZTmS7cdo7B9n9/cZvDSH3ZwJT500mV4HuBGCUVKHfs2cPDZ8n0POqq66CLJMkjJXXyy /TOFoQ0MD1q5dS6vUn2kvDkanescmCoySgkuCAVPQAZNgUbkCXMkYBJgKGgyzgP7edrz44h gl4pQJBm1tY14z7JVmL9wCQxdgUCq0YsiBIFj0ak2Bz4eV4ArwBXgCkxfBSwwum7CJtj68CIb/tw4I6rST5gwro52v7JjWoXSN/UPjmOZrS7gaQcatz5MYSUoiHTswN/O rflbUni1O333c/Y/Xzz8TbcubLbgp4UYriKXXnaEDiyCB//0Ub8zY5Hy Hv1tdo2fjyfLqfusMGAKRva/lWO/Kh/S4rZJr2TWBdpa gUPa8KRizn7N6C rS/RQFn7 jIMEa1JoHARvWGMH5M3Sx 1lBdbFmZPVDwLJ7DtVua4jGjjYUOtn76dM9OFJMX549YmgV6HBsdubXN3T/HNuwtbW8fK38CQG7cHVStq3A/vtHqsJOPI/6z0n8njq2bcHeSg6IOC0ibSh2v6PnxTpvsSth2Lm9IfR ca8v2L9tf/SXJLbNOucv9I5x3wME4FbOV xcy/cF SUN4znnToS7X59NM2wvYEUR95t/v637y0oh4cwpypbti8R7R0Xuu63xs07/8ec41g4SaBBnx4HvJYlsl2EvIZvunHn/Psdqm8iIeKPJUKC7bzQ2lP6RRx6hQ1900UW47rrrQqdB4Oi ffvo 3feeedkTHdSRgdFLlZXQ KWCUFFxSLDDqeKMSaCqqMPQ8Dh17Ha / SoMQwN0E5KYwgXnXYTLlq2CrikQBAWSLEOSeIbRqTYHPh5XgCvAFeAKTF8FKBhdPYFg9BEbjD7CwWjYru/eNc3AaN84wegS2xO0Qulw53o7hLycnLMVj3jaWf mYLTcphu/vXMNvlqulrQRf7PdgZL2ewSMOuM4MOLWH Cbv3QBTmKD5SSjoADlL/EdC0CW 7PB562u3JMEmLjtlnygvrXV 0zYh2XfmBRGuOZUeczWofyFe/Gvh70ws/u3FrR1XhR4eJKcunRy5kyAwvq78TtY6yXtW mcgv2H30YhGtsPWP05T7v3htVjdF/ NVKvM/e Brr02w lwTF2Bp/NsVfuzIXu18Jgn9E6OvuZTGevhtZ82HbizJV1ThJ8P3HZQ7m137593Vg6rAzYI21Gz0JEnlbSJrR/v8375x inb2GFaxzFFgf2x79egfPUsWOyNmxXsH5JDpLtkZhnMpfK 16YTjeGsO3Be2Bp75sI8L0FbsuZh69lu7Xu4jTrjbsR//0vg//oL3x0bdo7DbCV2jox7gHEcPGcaUbbr2I3/e4 vU7/erPMQe4clOLe8yaQo0N0fD0YnZeBp2CkHo1O9KVMMRkt6Hrvf2I72jqNW6L1hkAh7tMw5F9es/yAEZABTIrH33GN0qm2Bj8cV4ApwBbgC01oBAkZXrV47rec40ya3Z9fOaeUx2tg3MNMk5uuhCpAP 7/EwkfuwgquCFeAKzAOBfhZGod4/FGuwGlVoKc/F sxelonOIWDczA6hWLToSYYjBo0lB6QaY5RkniUEE4SSq/DFEooajm8sPt5dHS309B7WZIgGBJm183F9e/7MCQzDYGE4ZN69DySfqqtgY/HFeAKcAW4AtNYAQpGr BgdCq3aM/uaQZGezkYncr9n7Kxup/CXX8B/HfuvT1lkvOBZqgC/CzN0I3lyzobFOgZ4GDU2WcORqfY4k3DhKkDouSlkOTrFJqKAkjdJMuD0/rbCY83TROknSAJ1LuTgE4KRkFC6W0wapgwTB2CYECQdJTUHP79 d9iODcAQRasRLmGiMaaOdh4jQVGdTIfQYIoSVOsBh OK8AV4ApwBbgC01cBAkZXcjA6pRvUOs3AaAMHo1O6/1M1GAkn/dW7HsUXXClZp2psPg5XYCYpwM/STNpNvpazTYFeDkbLW87B6BRbPwWgpC6SDUA1XaOFj2CaMAwTsuIqouSCogSSUjBqkmctVmpAt/5n6pAFGRIpoET4KgWjOvUazRWH8dutT6KkFSApEgRJhK4B9dkmXH/Nh5BV6mAapPCSBFEkYPRsdhvdj79efTu2ANj82C5847IJNo6ep3D3Dd/DNmzAd59 CDc2T3D/nu4meS2TMPWep 7GDd/bBmz4Lp5 6EZMjjxEl0ex1NF/ivZk/1 vxu1bWPte2SdH0g3ffRoPBYyjB0/dfQMO3jEJdhm5l1NnR8n2P6iXf/reszvJ8x z/VTmFdxv7xqt9YSvg 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 5vUsnGe5FLm/qxk62/1GelpZXLXE6rngdT/L8x2xTrHWEQdHwDWKCUVR04F6j4zu75GkCRldwMDp IavoYe80A6P1HIxWsXu8KVeAK8AV4ApwBbgCZ4oCfRyMlreKg9HTYLUEjOqmBkmQoeoq9RYlYewS8RwtJxW14uh13YBBk4CS/yN5QAUYukFD6YmHJwGdBIySsHoTOrr6OnCi4zgGB3pRzI8iNzICU9OhES9UWaYgNZcvYDSfx7zmudRrNS1nseLSK7DkgqUQSK7SSXq5P8Q/htstTyd3WPn v8Zq64vWy M1B3jAyR0HcUO5rQORvGAhLkQ1OAYDori9 jzzcUEY2lGC8HgPRLkDB2 wwvaj5/EYcLvdzu1xyPA2jA0hHvNavLps3Gp7qSVct3vfn176qBUuz3g2FIwx1hrYW5b3pXu//LZFt y7ePq7wPeY6Q38 xu0x2THxNEuaB9lXTyepD4bbHHSL7hHc3kCxmnjsTm6WAscWkYX8CisgFnHpit2GmZf7PPqXgfLhn2en5sfQ9k2IlMpRIFR1x1RXls4GC3rX1kAw8MyJtUBC4y6bI2dFoEM6F8HKlCXmcrDvw6GfbqeSwaZk1nw2d6KgtGVq892GaZ0/Xtbd02rUPr67r4pXT8fjCvAFeAKcAW4AlwBrsBUKNA3VOCh9LbQHIxOhcW5xjBMwwp9J/lAIVA/T10nOUEFGlJPPDYJ5tRUzS4UT1oJvvYEb9oFk0QJhg1GDWg41fsODh15E729XRRxyoKIuvoGaLoOAyIMCMiXihgdGYEsisiPDMNQgQ2r34vL3rNyasCoW3MbgsDJL nfDxck8UIbX8MNG7Bh2zaUmQ99m 11F9jyMkDzwwcXFAkJbfb3FemhFRU6TTmVEw7LDhd2IEuUDuEhxONZS1z4cnTIbhBAeVVzNGPCnAjNymtN0qYqMBqxXh sj70 yuMyNPLNiQnRmGuz 0qy7jibS3q PLAuiT5RNtxRzuXL1G/MYNQFC0PPtDViuE1GQ2dnvkHbs 8aVEB2OBSlMyhrsOG7j2Hj1tvLwJp9h1QHRhFld7FGyxu4FSBgdDkHo1NqFK9OMzBax8HolO4/H4wrwBXgCnAFuAJcgalRoJ D0bLQHIxOjc3RUSgENUixJAuMDg8PY2BwAP39/SAbkcvlUCqWQAoySZKEpqYmNDQ0YP7c WhZ0EJD8Ml7JAye5BQVTAmmKdDiS6pQhCwBJ3uP4Y239qG7 xTSsoJ0KoVUqgaqRrCpAFMQKSTV1RLFssWRIehFHRtWvw Xv eKKQOjng//zHDUYDioGwiWn3fDJQeGuGBQACa6wFbQYy/Oy80HVVgeiVFQxw2pmECK5fnqB2pswBkMwZ7Itbghl2s Lu2jgLAbQlXaufr0w3GXNsEwdAb8YkAgVpg6EuYYZYazl8dI4BnsulPiPPeYgC5gQ2yvx0TajMXmWGeE5Y2Y8Cz5PVOZ obMM3g9x0F6dxi9F0CWbY Vg5Oxv5W9YaU68MPpDfjuYxux9XZSXC2Jd3HEOph3SLQN L3rmbY hd/rZtJQHIxO/W5yMDr1mvMRuQJcAa4AV4ArwBU4 xTgYLSy5xyMTqH9UzBqalANFSO5Ebz80ss4eOggenp6MDIyAlVVaZg8Ca83NAPZmiyymSyWLVuGjddvxLta3gXN0GhuUuJZSsAoCYUnvqAlFCGJBk70tGH/m60WGFVSkJUUBDEF3RCgmSI0gxR50iEYBgRTg57PQS9quGr1NVi bDUEyJOmCDt0mLpveUPo/TOwAUw07HJXkq/AM5bXVsDjsgwiWLDCD8LYIayVKUeAs9B8hP6w2opHXWD oZ5g4X2Ezy3pWsLCl8PDlN1byM6D6N53CzK1xFSlD0BEBgi3xg3xYE0IRkPnO4aTkagvpldndTlGk2gT cuIDucM u03eo TnCWvDbO8Oi1h4yCy/WuJaG9Te48SF18KaO sP/oOKZtClEdvpL0E75rNmzdjyxYruUZUGhD3PobbV7KzOQaTPuseIWD08hVXnHXrPp0L3rd397QKpa/t6j2dcvCxuQJcAa4AV4ArwBXgCkyKAgPDRR5KbyvLwehYTYwk fS/rPpJgVelqZULNK8W0Hb8KB7 6cPY09qKocEhWoQplUpBkRUU1SIK YIVTm8Ca9etxR1fuAMb1l1JvU4l4i1K8osaAgST5BkFiigC0PBO19vYd8ACo0oqBVGUoZsyBFGBIUhQSb5RXYNg6oBWgqAWYBR1vHftB7DysrWnBYxGhsgTNf1glJlr0w10GFAjKqQ4EoyGe6Cxd3ssYNQ/33AwGg6PwvvwzDMkn2X0WsIgSzL4Mi4wGgXN43KIWoQJTz90I5rJfycCowmBWMJ7IxEYdffF8oAOq0qfRJswGO//ehmMhnsoBz0uGSIwzlIYGA0tRjXmUHp3jtGg93UFKEb9QiDqOcZ6w 6V2JQLbjBauTMqgDsZoOZgNOFBHEczAkYvW76Kprvhr8lXgETG7H91z7QCozWnevj T/7W8xG4AlwBrgBXgCvAFZhCBcjPXIMjJQ5Gbc05GE1kfAwKSr9kf1CilZDCgagpOG8TMGpgNJ/Dq/texb333ou9u1uRLxSQzqSQzWYgKzJKxSJKJRWlQgmGbmL9hvX4yte/ik2bboRhmEjJKUiiCEMTKDiVZEClYFTH0RNv4dU39uBUdycUJQVRklFSTUhyChAVGkavkTB6U4eplyAaKoySiWvWX49Vl20AQLxRrReBsHSVgkDD MkfUWR9OEz2gTEpILssZE ic1BGgVF3YZMK IkKpadeh08vxaO0ME9yb9RIc3JBlLBCNhYsqoDRQIj6mDxGx7uWCQKjfuDlW0vQYzQYbt/sqrgdCB8ui /1xgsCPZetMMBh1TAzYtOTgKt4QMjSP6E2ScFoOTdmHJBzQ8VkZ8lvw2GaVOsxys7h6dcqqF10So5xeIwS y4XhYtLuRDihR2aUqDKUPowmJ7o x1v5FbgD394DksvXgaF5Krhr0lXgPzy9uCbr P9779u0sdKMsDxyy H OS/QamtSdKct EKcAW4AlwBrgBXgCtwRiig6QZG3jqM7Fe gPNeffWMmPNkTpKD0UTqEkBoFTyyWCEBgfYfHzP1/NPilnDAKP1v00SxUMRrb7yBr3/lq2jdsweFQhGCQMCjQSGkokhQVY0Uq6d/VqxYgbvuuguf /znUCyqkFMyJEGk71nzMgCRVKXXcOSdg3j19VZ0dnVAlmWk0xn6DB3bAAxDp38E04AomhSQ6irw3nUbseLSdTBNCaJoLZUcFgJCyR9SIErXNaRSCkMx 4EYLUMhESMnqLs4SbLiPFFglOWByQJLERCFkffSHbKdCOqMId9jAIy6 3B5pUXnGN2Fb1zGDlWOzKPI8P4LA7qTkmOUBZIZ62emWAhU/W5O6DHK8jp0e5u6IXn85RFlFyzt3XbPKsbF8tpkenIG0gz4QF0AmLJz1wbzw7KAXrKz5Kg1UTlGmWA0kPc2eKZZKT1YnprM/fHnImUA5WRgPSw9hdv 3CH1VYLR0LQd8TbLW3gV2LFjB oamjFnThOXZgoU6Onpx hwL9atWzcFo8UP0XPvvRhsOQ 1//W2 Ma8BVeAK8AV4ApwBbgCXIEzRIHRvArjoR9jlgI0P/DAGTLryZsmB6OJtHXAKCGVLihK4KibhJK3bW7qAFHn345PJckhmhvNYd1yyP0dZW5PN5SJJIoSMpyjSaG6Z5RAnYJPDzkkveg89 9rP44pf vDxbw7B6NE0NJbWATDZFwejrb 7D/gN70T/YDyWlQNM0GnavKAqdnKGp0DUVJgWkGvkCYCp435UfwvLL1gEkb6k9WVWzikSRuRGgS5cmsHIIjBOMRlWJZhUpiguPdnkVOvAksjJ6JABkAIyIsPyJrkrP6m9sVenJ7o11LRPkMco8axVgF4SIMTlQGZXHg0NEVRl3e9Kyc3oG ivbSniuTM8zUdXBIyvGR82HvPdd4Hs3lCuZB ZZNRj1AjnWVjm2OPaz5PTKyuXrGjFhKH3k1R11piNzGrO8iRkjRekb6hnu7iccjHrgOKJD /17UYbFvCp9ou/sSRp1dXXhaFs7MrUNmNXUAEUWeVh1EuGqaEN viAFIvsHhlAYHcIFixZi3rx5VfQweU3Vtjac/MRt0P/LbVBu Sjk2hq /5MnNZK8AV4ApwBbgCXIFJVID8zKUbJortHTD/ZQtSLzyPBf/yvyGfd94kjnpmdM3BaKJ9IsTT9hi18GCox6hhe3nSQHTCTUU7jJ6G01sh6cRD9I0Db E73/42du7cgeGhQeotKsky5FQKxVIB0HUIokD/vOc9y/CZz3wGX777K6TkEqGT5G06C1EwaKV7Ek5vQsWbh97A/gP70NPXTUPhiZcnqVxPICvo5AzIoghZlqCWilCLBUhiCu 7aiMuv3SNJ5SeeIySXi2vUQI/Ke5lKDZ MEo6DS/kYg059lB6kmHSB9kI2Ph0G 6mofIxeQWZkIFRPOUxyzMz9OXx4roDB2 4HVapFX8V6wS5O0OLxjgdhvQxprVMEBglmm/c6iq05fViZHtXenWm4GfRP9p9uPNhsiBqsAiT18bCwKilYWhBI8sa8dTdNpiMzCfpzD8stJoFCRnFozwwL2ivZEZMbZKG0tMkrP4zSMap2Glojs5qzlL5cPjWvfkxPL30UdzwvW3evLCBwxQDVROepYAd7Po02uz9DC0WZc/F836IvvEe5FFg1FeQjtoXykWnwry2yzZwY3PlrozNdZroG BZ36jzVA/ePHQUQ8Mj0DT9rNdjMgQgP5M01Nfh4ndfgHPm2xfSZAw0hj4JHB3c8x vTTUPfuHUMP/BGuAFeAK8AV4ApwBbgC00cB5fLlqP2Tj6Dhzjs5FLW3hYPRJPZJvSX9QNCBo94OnHB56wk7SydlmQSLWq6YmqriSNtxfP3rX8NLL76AkZFhq6UJiJIIQ7TH060xL77kInzqU3 Gb379HgiQqNeqYTFLiJJpeXEKJH9pCT0DXXjr0AEcOXoYff39FGoSj1FZVmDoOq16L0si/ZPPjUIWgDlz5mHd6vdh8aKLYZJiTqSwE4G6dl5Rx4OUrmEcHqNJpOZtZp4CyUKLZ966nRU562fnxJy56 YrO30KODYX6cFqbHR YKcAW4AlwBrgBXgCvAFeAKcAW4AtNGAQ5Gk2xFAIw6gfHuokMETjo lRbkdPuYEtJIwahhQNNKONXdje985378x3/8O/r6B6x8oXa4OiS7WpNpQpZFXHrpxfhv/ 2/4mtf/gYABaYu2iH9luOqIJpQdZVCUs0o4Vj7Eex/Yx8OHz5sw00glcpQLEvzmJLHDAOFQg4t8 bismXLsfTCS9FQP4d6lwqCVWTCDUcJJCVgNLz4EgscJxGXt5npCpztYBSOV2FkiPhMtwK vqlTwPFGZXgeT90k EhcAa4AV4ArwBXgCnAFuAJcAa4AV CMUICD0STb5AGjbk9RGwZSIGphUF/KUVfvdri5oaNYzKOjsx2P/t2j2PrsM jo7EKhWKIFjgRRpGHriiIjlVFQW5fCxRctwUc /BH82eZPI6XUQjDTECm8FGAQr04SRK rkGUBBTWHtneO4PUD 3Hw0FtQVZUE3COdTkOynyHI1lBVFIsFLLlgEdZesQ6LzrsQ2UwdhaIEjlovAkkJy7Uq0ltgNCxs3u1Vy/amTSI1bzPzFDjrwWg5LD uUvnM23u oqlXwAnj5x7KU689H5ErwBXgCnAFuAJcAa4AV4ArwBU48xTgYDTJnjHBqBMm7wBRg3pjOnjQCj 3AKEAAhNFO1xex8joAHa3bse2HdvwzjvHMDA0SHOXFUrE61NCKpVCbW0W9Q1ZZLMKZjXV48LFS/C q9 PuXMWICM30bygJIEpmZpO8pNKQKlUwLGTR3Hg4OtoO3YUPT3dMAwD2WwtJNKAJj21ytOTAkzEY3RWYxMWnbcIl1 6Aue axEy6RoKP0m/Vki9A0Ld3rFu0VgomIPRJGbF23AFuAJcAa4AV4ArwBXgCnAFuAJcAa4AV4ArwBXgCpw BTgYTaI9q94QLa7kYFCD GCipBep5yiBiaIoQYJsg1ECCiUKRotaDie62vBv//EETnV1oK6 Fs1zm9HYNAuynIaum9S7s7evC6OjgxjNDaBUyqGpsRHr1r4XF124DFlpFgSQ0HgZZBSLdho0hH7Pq7tx OghDA0P0lj4VDoFWU5RMEqD WlTEuqvQ9NUqMUSxbZLL7wYly5bgXMXno/GhkZbFfKOq9AUU6vk VeTSM3bcAW4AlwBrgBXgCvAFeAKcAW4AlwBrgBXgCvAFeAKcAWmQgEORuNUZkJRu7CSQDxEiceo9fdIYQgGqfouS5AlBZJIwKViFUyywahq5jFSGkBnVzuKhVG0t79Dw93r6xtRk62Hquqor69Hb98ppNICGptqUVeXgSIraKhvhiAokKV6iMhAFtKQoaCkFvBO 1Hs3b8HJztP0Dyjlj rgUymloJa0n8mnUaxUMTQ4BByoyPUh5V4j5aKJaTkNM5beAFWr1qDCy5YTOdueYsSMOr8zRKLg9E4E LvcwW4AlwBrgBXgCvAFeAKcAW4AlwBrgBXgCvAFeAKTD8FOBiN2xMf96NR9ZQTWl6iBnSS6RND SF093RA01XU1GTRUN AumwDJKRowSQLjgpQ9QIK ggEQYdgmMjnR2m4uyKloEhpGKYASZZQLOYgySZSCqkob4Wx6 SPIUKUshCQggiZVrjv6unEzp0v40RnOyAZkGSRAlpBFJDJZjGraTZqa sp7MyNjGJwYACjwyMwDA26VkKpUIJWMlCTrsEF5y/GmjXr8K4F59LcoqJE5m6BUXZ UUegchKBGJAaJzh/nyvAFeAKcAW4AlwBrgBXgCvAFeAKcAW4AlwBrgBXgCsw QpwMBqnsR MEgdRmjKUetzNVQAAIABJREFUIFGdglGCLPtGenDs BGa57O vhZz5jSjuWkeZBrynoJgklB2EZpZgqrnkFLIvwQYhg7TMOl7kkC8NGUaAq rJQiyCVG0wt51U4OqayipgCSnIUtpGq4/kh9F2/GjeOmlFzA0OoCa2gzkFMkRakKQJGSyGTQ2NKG voF6heZzefT39WOgrw lUhGmrkLXdOhFA4YONDU0UTC6csVKiGIKIp2TYFerJzlH/blG/WCUCOoOwY8TmL/PFeAKcAW4AlwBrgBXgCvAFeAKcAW4AlwBrgBXgCvAFZh6BTgYjdPcHylug1HDBqM6VBhQ0Tt4Cm3HDqNQzNHCSc2z5 Kc5gXISvXUY9Q0JIgkNF1QoZujkETiaWoBTAJGSSV4ERJEUaYV53VVhSAJEEnNJFODYWrQDR25UpGGuGeUWohyCv1Dwzhw8ABeeWUnNKOImvoslJREq8mLsgxFUaCkMmhqmIXabC1KRRV9vX3o7elGPp8jJechkDloJkr5EiRRwqWXLse1116HmmwDnQuZm1Wp3vYaddILlBmpFbZv5Tolr7jw zjR ftcAa4AV4ArwBXgCnAFuAJcAa4AV4ArwBXgCnAFuAJcgclVgIPROH39YNQOpTcEy2OUeIAWjRx6B06hq cELZSUUhTU1zagefZ8NGTmQBBSEHSSc1SCIKrQMQwDBRpeT2AoBBGmQeAj U/iOarA1EkoPPHQJLjR8kol UDz2ih0Q0NKzkCWatDTO4Tdr7Zi/2uvQknLqCVgVJEAyQrJFwhZhYSGugbUZGqhqTqGh4YwNDCAQrEAU7f6NVUdhdE89R5d u5L8OEP/wnqakgRJvI8mQcBpLDgrvPiYDTOevj7XAGuAFeAK8AV4ArMIAXyzz6LkX/ Z7qihq9/FalL3gNBVmbQCvlSuAJcAa4AV4ArwBXgCpxdCnAwGrffjNpCxHmSFDfSBA0lI4 RQj96h7pJzXmYpkqrvcMQkFXq0NQwF3XZOUgJNeVQ qIxgrw5SivQy0IGopACCabXqGeoScPXJVMBTCtXqAkNAkzIogFFJiHyGkQRkJFCV2c/Xtr Eg4ePoDGxgbU1mVBovGJ06Yg2SH1UCDLBMwq1DNUV0luUY0CV/LfWqkIvVRCKV kaly45CLcsPEjyGbqUVJ16jWqKGk6H8/LA0YJvHUT06iCTXGi8/e5AlwBrgBXgCvAFeAKTD8FBn/8Y/R 7Wt0Yuds/Q9kr30/B6PTb5v4jLgCXAGuAFeAK8AV4AokVoCD0TipGGCU1qEXTOiChoI2iv7hLvQPd6O2ToYomSgW8siN5KGVTMxqaMHCeYuRletQ0Ex0jwyiY6gbPcODGBktEtwJQVRg0MJMOv1DwtYNXUCxSKClDkPTIYkm6mslLL6gBecvmIemTIqWdTp14gT 84U/4OixI5g9pwmZmjRM4s1qGhSq6jp5NkU9UkkOURLxLoki0kqKhtmbhg6tVIBWLNC8pulUGksWL8W17/sAFDljg1ESkj/zwWjPrz Glw/cg03fXhdnFfx9rgBXgCvAFeAKcAXONgVMExSMfv3rdOULnnsOmWuuqVqFIw8K6Ljf 1jtNhMr1lfd1eQ/0PkLbG/ZjMwEzO/Igzcj/5knsOyckGmTsf5hEdbfZwnR/YubcfAXt2HpE7dhLvORTrx cwuGb vA tvCOo2SaDv2ChsA19pi5zj5ik/OCNsfxEsbtqOpw9F/O/be3IZ3hWk7gfte1YLoPIEW8z4sDnkw3i6qGnFcjelZ3r4lwkZjdB7X6Gfiw M9s6w1T5DGgTMyMfrG24ilycD6bbjKvvsmZuSJ72X7lq3Y0HMOOu6 HGO5cSd RjOpR9sOnrzJdU9712f97BD /kxS43SshYPRONUZYJRCRwEwRA05dRinetoxMNqDVAaQJBOqWkRuJIfiiIbZjS1Yev5lqM00oqt3CC 9uhd/3PMK nJ55PIaTFGBkq1FurYOSiYLUSFwVUaxoGNkKI h/hEM9vYjNzKAtKxh2SXnYu2aS3DZRRdg0dz5KPQO4A9/eIYWYGqc1QAlLcGEAU3XoGoaNI3kMpWtPKG6lQdAJkWZlDQyGQWKJJNMpzC0IgythJpMBkuXXoL1a66ComRhkIUSF1STeJ8SqEpC6 3XmD1GO7Hrc fi5Ite8Wf9QsV7V1S RkHl/b8J3SF/e8Dd7/dxyZv34N2upyv9 d7r/t945r2fhOUvS16bsOCFx7Ga/VO4q8cdeOHiq9Ef89yhv1Jw4H9WHgvOO2SJe3 I39z2ncqbn3qRAW39Wiade5zh8/e5AlwBrgBXgCvAFXArYJTyFIz23/tt uXqwaj9wQc kGJDKGwZK CbxH2aKEAWCx2CcGDKAVjsHCdR58nu2re2WFgzUfte7boSgNFqu5zM9nE6xr0/mXObnn1PPBidMI0n6fzHz4 D0elpq6djVtYv60ZvYvyyhdrn/Zi2v0Q9HXJN8JgcjMYJygCjGimWJJgwJA0jpSG0dx7BUK4XEEsQBAIjVVrIqJjTMadxAS69cBVqM0043HYCv3v5JWzbvxd5EyhqEjRIMOUUhHQaUjoNIWWBUV2TUCroGO4bRX9XL3JDA8jIRSxsqcWqFRfgyjWX4bIlS2EMFfG73z DI22HkK3NQlII5tTLYJSE6xPvU5onlOYAECGKIlKyTL1Gs8TzVJEgGioMvYiabBaXXboca67YAEXOwiQ5Rk2nANMEgFE/7PPrf/U/4cq//wSaAcSBUfqoBxb6IKEPJDLBaOh84gCjH4o6C/E 54eiTqtYOBo2r6j1lrWMm3uc0fP3uQJcAa4AV4ArwBXwK2AUcxYYvc/6pWXVYJTCpl gvuy1VxmBQsDN6yM95U7LjkwUIIuFDhyMTurmwvFtZM1L5XuygORqtV7Axrz8FocMM4GD3DjHhyp2sDUMnzi9KQX6pO7kzOut5nMBh1KqSTPS27Nvo2OFBe3fW TUSdJrQqu9WXapAqSQSM6hguDuDYiYMYzvfBEArQ9BJ0TYVW0qAWTMyub8GKi9cim27E/jcO4T93bEdb1wnItTUQ5BoUdSCvGSjoBlTihSoIMEwBqgakpCzUvIb84CgEvYTGGgGiOYQF52SwYc1lWHXx5dBHdTz7u604ePhNSLJInTsFMjeDeI0aAO2LBP8LEAyB/H qBvH8VGQZmUwa6bQMWTBgaiXU1dVi7RXrsHrVOshyGiSTqVUYSqAFmILFlxxyTMZwXmFV6V0w0QVAyVNugJh 4B186JZzKmDU19bfvgIZg56obgAZBKOV9mTMK/BFGkp/Ca62PDyZHprWGuP6IvNH2RO1Aior6wx6tFb0c63DmUMZlLqgZ BrjOfOuiuNL5grwBXgCnAFuAKTo4DasR DD/0UI3//OOo 8XE0fvlrUN7tjk2JGTcWDnqft2Dpk Uvej8oEc SB6FsWY BzSQun4TXPQLc2QL1ti0obN5MS3fW/nYLCn8aDIVPDGIdQLal0ieZkMdrhQWzXGDtXW1R6yC92V4y5ZU QAFxvR1K33LbL9BR1sEdRhiELP40BV7N/PtTCaUPn6Nvbj5PHjoetqEFG1zpEaz5w50y4YH4MFn/3D0a23q6M/q733e8a8O1Iut4Hg3mZ5AnYbtlswoJy0yy71TOaH1YJyJyjxxb2gZ0bKjkm2CtlaZYcIDvttswvMGyeb99srWx9sgTru/XmLFnnrnftAVN6zdjgBlK74TFOgq4dWbbOzt1gNW24Pcm998l/rl77JQNI71wnHWfsNNexJ6xSB1Zc0lgQ8z1XYuuUFtO0KcNoKwduglN9C51p5tgWK/nGfs53y 64m3EZxsPbEHT9s2VUHoyxoOLLNuiV3vFe9CrffDsRu N3yZ993iCb5tJQ lpuzedDlPY8qVrcZs7EvPADgi/GHSN6G7Th188tAttK87B9t91glxVD9y2EZ/peR4te2dj24o bPhdyX6W0ber184Xwp 59s3n0eL00 xPD3AUD373ECo3UCO2fW8dnGw3tN/22djS04nNPQAufjfMzRcA8D0X6DeByACsfazcUdb3a3hC7ON/PvCmiSGRtWdKyoZkKk18qxkKRklpJPIyaPg39Za0gaD1dQfmucEorahEiyoJAmlN3tPstuQvy9uSVGknEenkn4aoY7jUj3c6DtEcoxqKFIyqaonmBjU1CfU1c3DFsiuRSTfizYNHsHPvHpzoOwkxIyKTqYEop1FUdeRLJDyfUE0JA4NDMAUBaTltAUxBQlaRkRJ05Ee6IQmjWLPqcix/z3IURjT8/rnf48DB16gXKynKROZPJqhrBJCa0E2dglIYBq0xT7CloRtIZ9JQ0hnIigSBpAfQSmhqaMA1V1 DNSvXQSFglITQEzAKEZJI5mepV3lZWlp6ufUMFl8KDWWnnVlQr/dPLChKXuX2DDDqCZsvA0xGiD7TA9WBkk57CzYuenE8OUYr0NeBscz1MmBp4Fgz21TW5vRfhqxugOvAUqZmE3 B8B65AlwBrgBXgCtwtigwsvVRDD38dzCOltCy7UWI6RoI7hRDsUJUPqxHAzvng5Hrg28g3N7pyw14WDnKWB GqviAVAYSrrn4Q/piwCjNnRoLhUM8RgkQLQMqv9eMF7IEvCBjvR59OUZZeThJWKMLkPk/sDogoryfLoDj/1p4qgSGN5B77ouCeV79H5TLH5JDtfIaZ1KPUZ0CdxuQBUI5bRuM0Md/JGL3yAFPARjkgwRO7tkE9lnWJqJPBM5XcE/YsOJJD7hKul59PJo54MQBsgEPs hz4swxCEY3YBQMYOxaVOz xeroB6MJbIgRQuyex3Agz sY mTZkX8zGXcY z7wAy23jYTZFaF/9i9PnDPgA/P saw7tRJaHb03jDs/9k4OfkNLAkYtKOoCiTYEJXDzvksA0H/nPbDU 4wFRjf3eKEnhZEEZJYhpN0O4TlPg8 4wKUfZjr/7t6Hm3/SiSfL7wP NTn93vTB1XjivbNtoey I56L/RGh3MBlw59po3m 3d8/ArlGQ34 cOfP5mA0Xv0ZDEaJB6MJ3SDQzvF0pOST4jtBsCoRmdT7k3hDkuJEplWsSCb4kHhbktB4HYJIwCr5Esm1mYEpiBRC6tAxog3iVE8bOnvaUdKLMKCjpKoolXRaNT6dbsAVy65CbbYJJ0/1Ys9re7HvUCv1MFUkoKmpCYIhAYaCbKYR6XQdjh07hvqmGhRLeSiKjFmzGpFNpTHQ3QtDzaOUH8aGdWtx6aUrMTJcxAsvv4j9b70KiAZxZKVQVDBEGCpQLJRIJDx0vUTziCqSBX2L QLqGushKBkIskTXbagampvm4PprP4DVK1YjJaet8Hu6egI6CXWtYGXLvNxQlPw3ebE8Rqv3ZowGo9Fem7h6E9Iv/obmDQ14oKLirVnx4NyEWZ8C lF98SVPyL8LUkaDUSA0nD4GjDrriQSjrjXGXwO8BVeAK8AV4ApwBbgCcQp03347hv/xH5FavhwLW1vjmoe87/cWI818MCIE6Hm9PFmeZGzgGfAOjQWGrqmH5D/1fAifVDDqSy/g TDvhiwYgzdMNBhle9V6dQ/ACscrx5NHNgZER6RYIDvBzLXq20PmXCPAR1Iw6oe57ufATP8Q4uFITSoBkGfNmbVWHxiNn6fX28rxdHU8MZl6xMDp8nr8OYMjQCJb9yjNWL9UcLcPsXuPZkk9RhmeqZ5bLH7/YnVc751L4jOGcI9r/5jxfbI1Y3nluZfveId7CiS57RWsQnU EMo8kz6Qm AMOPOqrN32ng0t4BRjYwm/m8WCURsqrncgqN2v 7k2Ak7heFjaDTyw1Aaezd42FozMejw3WZDVvRTrGURAWKt1YH6BAlMW9Nxug1DWXJjzsz1InecSymxPygLf9OX2AK/i5wMORqtSHDMXjFJXUYpArT8mQBioaRoQCUAUVACkArxGvURN06TFioqlIiSJhI5rMFCixZTSigJZSEEQMgDqoaui5TUq6Sgao gZPIGTp9pQIgWMBAOapkEt6RDFDLKpelx 0VrUZWehq3cQu994FXve2IWRfC9gFJCSBEAlDFaEhAxkKYvh3CjqGtPo6T8Fw9Qwb948zJ83D4WRPAojoyiMjuKaq9 HK1auRalo4OXdO7Dv7dcoqFVLReglg4JRaAIKuSJMSaQFodRiDooIEO5r6BpqG ugiwL1i00paWTTNZg/dz6uXnsllr37YqREsmYrjJ56y5I6TOTfFja2X8SXtOKBa4FRG6L6vpk6BZccsBdnqnFgFOVQcr8HqBUGf UlP7SLN7k8QmkxJ3cYOytXaHU5Or25UF19u/KEBr1IK8A2oENgXdYPk WCVRS nl/ t0dPVsh9nND8fa4AV4ArwBXgCnAFYhWYGDDqGsYflunxGGKEdHo EAUrqjugJlClPQlEC1t9GLRzw9DJBKP qvShYPQcCyDSkPtor7fKUqPAaDgEcgMSFggKApRooJQ4rYEDSV3pFZwQcyY8HTcYZeTDLe 1HZLPADFMgGSLHrtHCWzJs9YE9umkZKCh9y47r8wT7HB1G TS87ToH/DSBgTC7 MAs/f9GJsKrW7vg1qefQ0DXu6xFtFfGvjvBZbHqBekBC F6P2Lnos1vgUl3f/NqsYevzeVuVWlMQWs1n4H1lqFB6XjKW5TK8uruo2ArGgbob9M8N9p/l8YMM5A6B3hakvtPOL K8 ZVdgn9rufzepiqtKz4aDjJQov1HSAZCDk3gKjv1jh9sYEnLD4jrsvhxVbyvY dS8lFGDunQ13PxUwuhDPE29VH5QlfbrhKewQ/UofbJhbfs4PghPpzYoAiYi SPjzAeu8JZrOWdBoBoNRUEApy1bhIOINCsGAJBGkR6BoAQVzGH0DHSgURyn0M0wSem9AJvQQBgyoEAVSfkiCZKQxq64F2UwLDCMFU5AgiEBJz6N3pB1t7QehakUIIhnLgKaSsTLIKHVYeuHlaMg2o38gh32HDuK1I2/BEEqQQQo0jaA4kkMpV0KpZKJUMihmbDm3Bf1DvSiWcqirrUV9bR0GewcwOjQMoaThIxtvwLq1G1AolLBt5w4c7DgOMS2hpJEcpxokkk9UE5EbyUPVBKqFbui00FJaESEJBmobshAkEzpxMxUlpNNZtMxrwerLVmHB/PlIi2maU9TQTJgGifIXIUqk6v2ZAUY3fRuVqvEeUBpVsb5y6pMCXOeJsgdnOYydEdrvulRCdg9Cy4evkSuQJcAa4AV BMU4CA0dKB11H3yU i8UtfntDpe0LjQj5gO G mW0mVqyvAow6obcUCliQJPGHowTgaXECmDXmUPoqwCjdED9sjoQACcBoJcWrd79tiD1hYDQAS1zD fIrUhjqC68/bWA0Rh/mIYnaowS2NFlgdDTkRJOUCEtwJ7M4GlN3Vz8saBf4xYU/NJ4xD/c43tBx1j1AOpgcMBp9xlje8JXFWKklGGA00oZCIGaMxpUcuj4xybm1Q5Ote9R/ztjF8YLrtlNM0Lva iXWvOfZBfTC964ytueXCaFgNFSoCrCPuf/8eSkraUqSfTuL8xgth64zu7PD6z35Re1w R53eP3pB6N KEu/tbigcCgYJflGWS9XeH0ypa1W4ZEAQQCf9OeDxN/7q5noDGk7Q8Eo8Qy1vECdfJtW7lBC90owzRz6hk9gcLQTw7keGGYRkixAlCVIokhD6Ul7g8SimyRXqACjIKCxZj5mz7oQ6dRsSFKa5gEtaaPoHjqO4ycOkyB6SAQc0vyeBiQhhZRUi4ULFqOhthnDOR2vHWnDa0ffhimbqMsqyI8MID8yTMPYTUNEqaRBUlKYPXcOhbQkNN80NIwODOPY4SPQ80XUyCnc8iebsG7NevT2DeCpZ57BtgP7oUpAvjQK01BRIyuoS2Wga4CmSjAFBZKkQFEUa62CjnRGpFXsyb8zqRTqMlmc2/IuXLlmA85pnlsGoyTHKE2qSlIOiOP3GI0qauQ V3Eeo1EFkMpjuLw201dvQvFFv8doZUTa34F7Kp6m1ebpZHpreuFo oF/Qs39n0Q/eCj9DLlD TK4AlwBrgBX4CxRoP Bv4KQTaP rrsgpWsmdtVubw9UPmwvK7vGENbhrmpfHRi1gCHQ0rEIXS3BYkyhiwkBo54PbAlg1pSBUfdCQnL1VZokAKOhoalWLxMGRjf7Uga41hEfnhwSbj8JHqOVfQ/3GK3qYPj3KIEtJQGjbvtke4y6wWGYx6hrJax5JQCa1Xszukmda/zyObwPaos75L1aL83KhTIWj9HA3nr2L4GObi9cG5JGg5r4EPCkGoeee eNSI/REG9f9zOnw2M06rDF3H8OJI3Ld 25UsfqMVruJMSzkhFKPy09Rm3Pz6D3arjHaFX3oa9xVSlSEv58wMFo I7MWDBaXrKnOL0O3cghV hFR88hjOROQZRLUFImDZmXZBmSJEMkifTtvKIEA qajtJICYKeQVPjhairbaG5Q4nLaF4dRkfPYfQPdwGiDlmRIUCEppHYfZmGxjfWN6Ohbi6Kuog9bx/GH/fsRtdQH7JpCaZRhK4VQSLqZVmhUDWdyqK2rh41mRpkUymYuoqBrm4ce/sQFB1oSNfgphtvwhUr1 D4iVP4X088id/v3QVkFOhiCaZRQFrQUSvLNEeorqYAiXiHZgBRtmpIkSr0JIheFCALJubWZDG3pgZL3rUQH7n w1g4rwWKqFiFqEiSUhoeX85KMIZQelZOULdh2gBxMQkTX0ffiAOjwRyb7Dym7or31oiOx6i3YNIlR 3iS59vwzPv/SSKoXk6Q/KlJgljH3PxpWBxJ1aO0TjNxnM582e5AlwBrgBXgCtwNitgFHP0l8RiKjsmGSLDbt0fapi56vzeI1WCUbt6OB54AKP3M7xNwlYUks8smGPUF/pvfygvVxOPDVMNKb5Urcco64NlqDdmdI5R9n7FFHzyeOeWaxhHe kmADJ L0MHakxuKH0QoLs1CRa9IeKz81lGHRgP6BwTGPUWJiFjuT3w2Lkj3XsfFuLuasMogDVlOUapeLau6x8A7t O nIl9JC5M3KMeoGIvwhQmOdp/FVX2b wPJdBrR17jj9j8bmD/X2Mtc/oHKNsfTye/hOaY9R3R4fcEXEey3HvR6W9YO18nMdoWM7PCkisxz989xDAykH6plNs6XR6jF4OmgM1SY7R0HB8V6g/2GuJP1VWCyYYrSLHqJND2eotWJQs6TzOlnYzFowSb1GNFFISJctrlAaAk8JIw gbPIFTPQdhYAh1DRIyWVJ8yYAipyDLKZimCEEgBZtk pyqFjA6NIThgRIa6pdgVuP5qK1tpuHnw4V nOx G5BUiLKOVIrARBmqSgo5kaJNJBw9hYb6ZhhSFrsPHcITf3wOrQdeh2YUUVefQSpFvDYJiyWenBIySg1kMYOMlEFdKo2sJEEvjGKouws1kow6JYObbrwZy5evxtttJ/A/fvlL/NuOHVAaapBukCHLRaSEEmplE4ooQVNT0Mw0dKSgmiIM4hWryCiqKgokH2mxiPmyiAUZBZecfz4fHNWDh/AWSyfpKBgEJR4glrjCOUnhwpVz5PnzemG14GiiUxPDfdeT0rRYxCgGUZRjrHmlF86ep/wiV/8i84cOAebPrIH/Gb274DRHiMVsZ38pG6xnaec40bqCQf6Y3KWAcLuga Vn2Bq7PlouPr5ApwBbgCXAGuwHgUaF 5EiSvUM0nPo7Gr30NUqa2 u6ckGhftWE/yCn/ /74qvSs4gqsUN1Kn67qx0lWkKDqd7CidyWkdurAKAugxHmbRYNR1gdJ/wfVifAYZQO2ytzntbWg435X3lRXaL3j7TU5ofSbUW1V uh8qSyIx8qf6YNCCYovBedZAfXl8GF/VXp3Tk9GkTEmcHPtA6tf/5EK2AfjDrDgWnxe3NDx7F9CVDz/wiqfR1VLTwJGE xfrI7xVekDNuT/JYsPGCFBVfrYPln3nGczg5q603Y495x/L4N7lrQqfUiuUsY9YKUEiNubtmAe3WqK8NlaxILRct5QV1V6T0EmRiV5V2i9Vbn 9ILRc5JWpfeBUdiFlu53hc2H5lxN8r03DIw6v/iJ/PkggZ0lnMPZ1GzGglHDNFEsqUgpMvXsJKHxBIyqpWH09B5HV99hSHIejbNlpLMCJBHIpLKQ5QzUEoGapECRAFXVkM8PYmioB6MjGuY1X4rm2UtQVzeXeg0M5XvR2XsE2XoJoqghlVYgSimoGqDSSHwZuZyGxoZmyNkG7Dvahiee/wO27W1F32AvGmY3oKaeeHRqUDUVMEQoQhpmUYY qiFlCpiVrcHsujQUo4SMJCEjKrj5ppuxasVqHG47gcce/xV /ceXgLo06ubWIFtjICWTkHsN6ZQCCDUoaRJKuoiSIUBU0qipq0euYGBwWIM2PILGwgjOkUxccdFSfO5Tn0XLnHmQBOLRSirNWx6jpmFQoDq2HKP2sXKFtjMPmgsYeosahRxLVxX4YIEiy/OUvEILJAWgaWWc0KrxtAmraJP1LBPU qbv7ptZvT5Mp7D1evqvrnjU2XTh8bVyBbgCXAGuAFdgLAocEa3ImYYv3olZP/wBpGz9WLqp5P7zpYsrA0RXr/58cN421XqMVvJvuvuJ8ygqh 9vuw3DGwgoIy8XsHXm68ltR963Qn4r4NYpJBEBZst9WP3TnH1VeYy6xnDmxYDQFYn9GrLm6M b6AVYEwNGrRl5C7oAAdBVtpmKvqP2 qoFow7MJvvJsr3E54IZVFjQN8MXs0Ro/RzJYtKGxm26cDxZq2bMeAU7iKlXvWl8vVUwnaXp9nj27agqb1mzEQWjTJSX9hzauis8 mkhbDYUDHsuz uQfs3qf7A9uwdNGDrvOVBIyS0RKcsUgdWR7F0WeMrtHfp7vAmuu9UI1ZBdn8d9aW9RjYzCh6VxaZMU87NQmhOn JAAAgAElEQVRo/lQrTUG8jfj3Yguatm u5H0OSdvAuiO8Zzdub4I5YD1h9GH5pF3fkygYLRdL8n4LvMmu2E6 6m9nAU nvVXh3a63DqAR276UxYM/6QRoHziNxZccb0/fHJvP8RRrYhaCostjrO1761BOkJFAY7eqUb9oiv75gO4CheFO7mSy1/SXbDTXeEjKjjH VDNTHpuRYJRGzxOPUUOHQMLiIcAgJelJxk49h/6BkzjR SZUvR9Nc9KoqSXh8wIy6SwkMY3cqIpiXkexoCNfyGN4pAejuV7IqVosXXwV5s0heUaboMPAaKkPp3oOI1tP8m qSKfTkKQUNENAqUTgqoS 3lE0Nc5Ftn42Dhw/jv948QUcPtGOdzpPQpdMKDUiTBcYhS5BGxZRHChC0YC59fVomdOAGsWAZOoQTeBjN9 CNauuwIkTHfjX3z6Nx597GXkZyM7OQMnqMM1BGMYQzR/a0DjPArW6QOelpLJobGrGSM5A3yBQGhhF7egAFmYEvG/VCnz 05/DrLoG6jFK6jKRuvMk/p463o65Kr37yLCLEvmLEUWDURb8i/KYdI/pL77kh5xJwaJ/HTFzohIE2zDBKGnqh6MeKOromWQOM W64uvgCnAFuAJcAa7A6VGg85Zb6MA1H7kBdZ/ 1JjD6U/P7K1R2R yOvH6g89j3n3eit2nc558bK5AYgUSeL1Fe7EmHun0N4xNR3H6p8hnwBXgCnAFzlQFZiwYtULpNYiSDF0XoOsGSRsKWTZQ0ofx1tuvoLf/HUDMQRA1UmoJSoqEvSvIDasgzpskFF5VVeSLQ4BYwNzmBVh 2QfRWHsuDZFXjRLyxX709B BklUhSBqymTRkOQ1NE1AsCbSgUlfnAJoa56OhaR6OnjyJ7XtbIWQzOPDWW3j7 GEMFwdhyiQ/qYSUkkapAOT7TchaCk0ZAkVnobmpDqY6CrUwTAs73XLjJly5ZjX6 /rw29//Hr94 o/oyuWQnZ1FdpYMKVOCIBehpETki5YHLC0opWk0d2hdXRMGhjX0DipQhwuYY6i4qLkRG69cj0994s9o8LwCG4wahCkLECSSe3WsxZem/xFxii85OU6n/4z5DLkCXAGuAFeAK8AV4AokUSAk9yMBS/ wCOu5B0kSEXmb6abAWQRGq80HOd22is HK8AV4ApMZwXOaDBK4Cd5OX T/6b5RIlXI32PFBgiYfTWv0l4PanyLohFDBdO4eDbe9E32A4DeRimhmJJo HzJhTkcyUUCip9TlEk1GQVzJ 7ECsv/QDqsvNhgoSU69DUIZzofgOmOQIlDaRSEgWjBLCWigJGhksYGVZRk23CnNkt6Dx1Cjt27cDc fMxMDiIvqFedHS/g56 ThTUPPVsVVUJitSE2tRszGs Bw31dSiMDqG/7yT0EinUJOGmTX KK9esQn9vF/7tD3/A7oPv4PVjx9FfHIRYJ6J2dga1s7IQUwpUTYBaKiEtGUgLBmTTgCyKKKkSOrpMFIZLWFBThxWLzsW1a9Zh47UfREqUYGpEPZJmwMqbShxGORidzseZz40rwBXgCnAFuAJcAa6AV4FyaCcjrJx4051Y9ARW8Mg6bjZnogJnARhNksv0TNw6PmeuAFeAKzCdFDhjwSgLilbAqAVLdWg0PybxliTh9IJIoClxf1QxqvWg7fgbONl5GCO5Xmh6CZpuQNNBK8qXijo0TaegNZPJYM6s2WiZvwjLLrwS2cxskn8fpllCSR9Ed9/bMMxhKAqpx0SALPEUlaGpIvKjGtSSgGxmFmbNmofOzlPY9cpOzJ3bjFKhAE0tYHioG7nCACDo0E0TeRKCb5K8oAqytY1Q0hkMDQ2gr7cDpq5DhIjrP/ABrF zAsXcIP647WUc7x7GofZ2vNPTgd5cH4pCCXJdBpn6ehrSn0kpaEiZSOl5QM1DMg0YhoKBfAY1mSY0KVksnDULay9bgfdffR1m1zdBoliU/E yCzDNbDA6nQ4mnwtXgCvAFeAKcAW4AlwBrgBXgCvAFeAKcAW4AlwBrsDkKnBGgtFIKGoxUFpB3QKjInTDAnwiiaUXDJimirzWi1Pdx9Bxqg19/Z0oFEYp7CypGoaHc9B1E4IgQibFjjJZzGuejwUti7DkvBUUJJKXbhRQVPsxMPwOVG0QJkoQBBOSJEMQUzQUf3SkhGIRqCFgdPY5ONXdi527XsGc2bNAiKWRzyE32AO1OEjBqiCJKBgCdLEWI6oAMV0HU1bQNzCArs4OGuKeEhVce/XVWL3qMqjFYbz08kvo6B1E3 AgBnOD6BnuQe/wAEbUEgQljZFRDTVKCo0pIIMCFKOIjCIiU9sAsfYcNM1ZANmUUSun8Z53X4z3rrsac5vmQBGJl6hAw iJNgQpS7I0vuJLk2vPvHeuAFeAK8AV4ApwBbgCXAGuAFeAK8AV4ApwBbgCXAGuQCIFzlgw6g6fpyyUVgay/ia5NE1Th2YWLZgnpGgoOCV6MCAQZGoOYWC4Cx0dbejqOol8PgdREKGWVAwP5Wg/ipJCKqUglU6jpqYO58w/F 86592oq2mCKAnQjSJK6gCGRzswNNIFwyzSsSVJgiinaLj96GgRubyBmuwszJl7Lt451Yvntr2M5jnNqBNEgIDRnk4UhnohQoOoAEUISDU2Q03VAOk6FHTgZFc3Ot45QaFoQ6YO11x9JVZefsn/z96bB8lx3Xee38rMuru6qk gcRBgkwRJkSAhUQdoiSN6OLYoOtakrd0NQDsb5j/yDLzj2H8UITH0h8MRoyAVod39Y7zCTGhiTO/YAmPCliUfFCmLNq3DgA5LsCDxAEgQJI4 APRZXXdlbryXmVUvX748qroa6G78msEgUZX5js97 Rr1re/v90NlbRGv/sMruHTpMtqtBpJJC9BMlGsVXF1awUq5hlo9AavRwmg2ibG8gXSiBQ1N5EdGkJ 4DcgMQdMyKAwVcWD6AD704EMYyuRggBWl0qBZOsy2nYrASCVJGI31aNFFRIAIEAEiQASIABEgAkSACBABIkAEiAARIAKbmcC2EEZFUZTBZplEec7QVoULlUk9w3N srSjCZjQEhZMs4LV6gJmZt/D4sJVXpwpZaRZrDjMlglDN2AYTBRNQk8aqDeaKJXGUCiMI5cegq6z3KUs/L6MtcpVXF chZEEmq0GGq0GkNC4OFpvsMr2JvK5MYxP3o7XLlzB//jWtzAyNoGp4SKGNQ3m2iqaq0swWzW0Ey1UWk0MT 6EViiiqaVwfbWKS5fncG1mHmktibFiCY99/GM4ePBuLC3N4 9feRnvnX8LZrOGtNbCSDGPTDaLSq2JqwurMIwhVMoV7BodwZ6JEaBVxdWZS7BYsaexScwtl5EvjGH/vjvwvrvfh/fffwiaaUG3WK7TJM8xalksT6sJTSfH6GZ oGlsRIAIEAEiQASIABEgAkSACBABIkAEiAARIALxCGx5YdQnivKiS0wObcFEw/l/Fk7PxFDmKLWLMjGn5fLKdaTTOvK5HHQ9CTCPpJGGjiRarRaaLBRdA5KpJEwmpiKBaq2Oeq2OdrMBy2zAStQBNFBrlPn1zVYL0Cx T8LQUV6rorzWQGFoHDt33oOfvHER/9ef/inaCQO7RsewZ2wc40MFDGfSPLwduoVKvQotm0EjkcDCagUzc4tYWlhGvVyH1m5jvFTAJ37tUdz3wAFcXZrB97/3D7g6cxFmrYzluYvI6sDE2CgKhSIXR9tWms99z44pTJRKKC8t4eybr2GtUcPQjkmsVOsolcYxve8O3H/PffjgAx9gXlEkE0k7lJ6LoiyIn m927cqfbxHhq4iAkSACBABIkAEiMD2JsALvrxwBAe cQQTbKpS9Xrf zcNxyxdQUVo/M4PCRnTdtFOvt PxzT6H69DdwH5vCqefwg4eBKevzmF5vwz3cH72mG8F6I9rsYdIRl/LCZadOdJ8D3/X2 JcOn8RHP3 rVDDrfc7Re8u/EIMpDHcKp5 6gN3uObZBz1bUeTm4HRndUqdYF4D8SYsK60Uj6/mK6HOh5ya9N/B9 gygKJjIL3SKzrWD3l9n97fq7VtaGHVFUS7YOaH0LMSeSZgsj2jLqkDXdLRMEwuLS1hZWUW92cBaZQUrawsYGSlC11nBJANMz7y sALLZLlIU7xifLVe4TlJmcAJQ4OeTCKXzSOlGUjqQDqVQDZlgL3NKtc3anWYrDgS0zeTCWY Rb3OXKUJFAs7MT5 B06/fQXHv/6XuDB3FYVsHiNDwyjkhpBJpnileCOlw0y0YWkmGu0myiwUvtIA2gk0KzVUlhcxOVbAJx//1zjwvttxaeYdvPrqd3h1 h2lIprLC9DbDeTSKT73crWGkYldyGaHkNRTMBttVFbLWF1aRstsYmRqB4ZKRWQzORTyw9i3dz8 cN DyKdyMBKs6JIjjLI8o5YFjXKM3qpnBc2bCBABIkAEiAARuCUJ IWQfoSOjUG3uYW1WHPmH4JPoTSz2YXRWLPZVhdFCyC9i4RbH1Dvc 75vHCEn8w6hT3f m2QMOpd0975DGxPDIjbwMazTRuKPhfWP3FX4PaL287 QtgXNuvv/1ZsYcsKo 5iieIoF0X5v23uGG2bVZx7 ywuX5lBs9XG8EgRoxMjaLTrOHfhdZQrq1x8ZDHw1UYbc1cXkckVoBtpLJfLMJJMqDTQaLdYVSQ0mk2kk1mg1YSBNgrZDCZHRjDEijONjKGYL/Kq8dW1VdRrq6w8E4YLw9gxsQvFoUkk06M4/da7 NpLL FnZ9 CkU4jXxhGJlcE9DTvI5vLIJ1NYmV5HjCbsJptoGEBLRPlxUWgXceeqWE8fPgQbt 3C7Mzl/Cdb7 Ms fext5du1DKZlHM5ZBK6qjValiprCE3UkQ6M4Rm3YRZbyOdSCKfSkMzTehpDUYmCaYQZ/NDmL79Dnz40AcxnC1wYRQmc9gyt6jOkZNj9FY8JmjORIAIEAEiQASIwK1LgITRDV17EkY3FO96Go8WQG6iCLaeia3r3t7nTMLouoDHv5mE0fis1nFl9LmwjsY7tzrP2Tef9UYPOG5ScgMPgrG3jS0pjLIp8DpK/McOnef/Z9kFgiyzzV2h3/n7v8W1hXns2DWFPbfdBlNL4L3ZK5i7fhVVs4ZEWufh5M0EUGtaWFipYHJqL6xEEkurq8jl02AR9ssrKzD0JCprFQzl8rDqDSSaDWR1DXkjhUa5ilKuiL2Tu7BjbAKloSwMzUS7UUMmk8KuHXuQz44CWhZXFlfwo9d iW98 2XMr6zA1JPIDI0imS8ilc2jNFbCyEgBjeoy0GqgVamisrSKtaUlLF 7ij27R7F//xj2TJWwc3wE9fIavveP38N3v38KqVQGxWwROyemMDpaQiptIJHSkS3lWWZVlFdrsBoJ5I0Mhow0rAYL/a9grVpGleU1HR3DQ 9/CB//6CPI6BnoLI AxYpaMdeoxnO0ajy3qpc/L3vFl8BiV9rXOw7ewW9ZapEIEAEiQASIABEgAluPgCsOTB15ATNHv lM4EnuFJx89SmcdV97UnaCuB QhDl3QuhO4XTiYdROSKHkstjmw2Xft a LvXZFTL247J4HewPaQUn1F41Fx4O7vyIYZ3sJe HOTaG55A8cRhLR58BYLMQ7 805IYO sbrOkZPovDCw1jqYO2FoRC fhKYYSGMzo/vw6cb4sjffxIlPnbB7QkgfM7ehZCv1dk67n/eDqWPGovMJEZYJf9A350eeH9OCoKw/Wmvidedq77e yGe94eTmMLD3X49e01y/LqOvqi5x1gH/5Z3wlM7b/j3m4fPkydQOnwUS55QeulZfPYESqeOdkPp2bie22/fx7d0dx962Uf0zSwpnmfafwZECyPSM 48u256Br5 F47Y42fPTeD iZgz5xn3PHFScwAI5OFZW44j9bMi H9wUnTUXE/orfj72Zos5Lxjy0Tf4sv4DCySNYffgo2s4e5Xvg0Vdxasp9LeSMlLnxvcfOb/UZK58F4n7q/3eVfPYfllKCBHzJ1vl9KO97e1/B4xyW2gh55uQzQHnedlKwBP8 ij4XQvYzfzyCz4XQv8k4Zzw6Z4HznHme1RjPuZgWxx2PGKWw9f46tSEj3nzCaFfx9E2Yv8U0Op5H1Mkk2mpCN5hoZ7/WbDV5rs lpWv48v/9HzGxawwf/fhHURgt4e2Ll/HPv3gDs4urGBofR35sFEvVVTQTFhKpLKqNBNKZArL5EVQqVRhJC5reQr2 BgNArVLGcC4PNJqwqnVozSYSTCStt5GCgb2TU7jnjjtxYHo/SoUhmM06GvUahvIFpFN5GEaW1Z3H3PISfvDPP8bbFy/h4swcKk0LyWwew2MjmNg5gdGRYaTTBs8FWl5cRmWljGp5BeXFeezZO4LdewvIpFvIp1JItBO4cP49nH3rHczOXMfVmWXkMkWMjo4iX8iiUMohU0jxA7bJ0qG2WQZVAwbLudqoo9WsYa1ShpXQsGfvfvyrj/4rPHz4MJJIQmPCKJc6WRg9S83K0gwYgihtL5EthgpqqaOlbsiOpUaJABEgAkSACBABIrAFCXQ lEmiJhcn5dc6f1a4s6QPSyr3Srijxf/hyv7g1xW1vA6vkA z8jiF8D57vuiKnUEf8iTBxre0CodMd36PYp7lePymILr6 olmaOf1fEYhZAlCn9LZ6RV0o es2LhB7fpENWEsQXMMCa/07QnJXebfn3LIpkIYZYJGyDg7gkLgPlEJo tfB/Ue8grY8p5XPgOe flDWH3zC8gNKLft7jdXjApfG8X jfriQ5GDMGh XgFWJhdjzq4oKog14eeJKyLJz9Yz3S9OFM7Hfp4tdSh9 P7qp59452XIWdj5kqPLpCvGya9JDkJxyXzcXNFMvEfhRJTO2P5 V0l7R VelV6z5yiIvQG/IyKF0bB8nM6w4va1Jv0 ij4XYuznqJyhIX fEfdj9nnv72lVrtGoZ493FXV bMG/Xw1iyFtSGDUtVnWe5RK10GjWkUoatiDaaqLBc3qy/5bxn7/6/ D2u/bgngfvxnvzs/jZa dw6VoVFTONVHES tAQlutrTCtEemgYbaSxvFTFaGk32q02D8VPJlvIpkxozRpatTLy6QxTX2E0TeitNvRmC1OjE8jpBnZP7MCd /Zh/569KBUKSFgWVleX0Wq1ucjI8pOyavFtC6g0G7hw6QreufAeLs/OotqsIzOUQWYojaGhHIaGCrhy6QoWF5bB6kUljQQajUUMDwOlMSZUrqHZqMNqa0hYOjQ9hV eeRv/9N0zKK 0kE5nkUwB UIKesqCkUzC0DKAZcBq265aPWHx3Kh6Qsdwfhh333kPHn3kV3Hf6DnjCYAo1EQuP/sqr0TBHVEqxIlSOHBonYJIwO4tmkNogAESACRIAIEIFtRMD3gbvjmlK47FyXmusk8jgpFY4Zj/sjwEXqsLTHITt5vPfE 6AvteH5sKUeg7fv8HG6S6DtXFbdRhvR5BpC G3QIXdp5DdS5T74ftOHOOK4x6RTz3A7Cbc1EpfIeG0UaHPyv3hWdNVcKoIPbYn7g9DmafIMgu8YxTJYyGzT3OOvgZK/eQODcwx95ReHNaSqKgUkyQvmRQXROwLj5xP7CAU7znRJy1 osRxTPuOwckdjHm3PN5EsnjCCYCBD7ZGa/uuzsHtTAatr/6e4bDz8sYbfoEQVe8EsTiOIJWHG4BopjICvKXWnF V/keu6Av1JzfGwH7QPU7IloYldZUHksPfXn2mPI 6VyIs5/XJUR63c iszf2c06O0Vh/k9yawigstC1WYIkJjgkwobS8toryWhntdhtDuSwKuTR 8csfYq22ANNo4t25K7g4v4jVRhJLNQ1No4CWoaOdNNFMtNHkrsgMzHYSMHNoN9vQDROZtImU1kLSbCLRaiCfzkIzLRRSaZSyeQwlU9gxOobJ0VHcNjmFkYJdSImFoTMXa71eRaVWQ7PZRCabRj6XtwtCtS1cXVxGqTiC5dUVzC/MY6m8gPmFWS74Mh/m/PwCyqtVHr6ezRpIppoYGdcxPGyi2VpCpbKGZtNEIqGj1bRw7s3L OmP3sHykgldS0HTTKSzrIp8HRqrCGUm0W5paJttGIbGUwUUCgVkUxkU0gUcmD6AX33kV3HgwAHuEDVNi4 VCaf2jy2S2uH1zCHa8Yp6N1sMYfTM176EFy8Ktw0fwtPHPoEdsbbtOi868zV86cVlHHr6GD6xYw4vH38e56efxrFP2L3PvXwcr w6hk8fZH86g6996UXgic85f15n33Fvn3sZx58/jZW9T Bz9kA8P5zf8g1kFnfcdB0RIAJEgAgQASKgJKD6EO/9QG3fFuj2DAydlj54h34ICxbIRPEoljAa9mGLh6wqPqx6REpVmKSMLkoUChHKVNXEgxiqirKIH3j3q4QzyXkTa86KrREnx6jnw3cQEzULt8duGKnacabai15nkTqU/oBb8dvpSNxHalFbbAe8qvvqESekfxDrIKRyUD2IXScee1cKsbY DzfUXH4WuVgk73knvUCnKr1i/IHinXAtT03Bw4nVa9MZsy/NhmqGEc 481yo5 NtT7knPHPez9evM3/h9qDzxBbd5C9mhHQWbA1ksSnoTFN 6dEdhFoYhTe8W wLcc4tP/PQ8zLO2FXCvGpuUQJbgDAqCovh 9E s 3ULt416ul3lYPI21fUF3rOTYqzLloYldbU92skbF3dL0QUv49U55H0OzrWfg5oJ/ZflZSO03U851H7KPbAtteFW1YYZWIoqz7PbIzLK8s8HFzXdVt8zKSRM1jwewPNlWtoWWtYWlvG0loFi2sNXLg8j3K9jZrVxkp1CU2tiYRhcFE0mxlBs8GqseusJhMM3YSBBHLJLMaKJYyPjCOl6Sjm8xgtFJFPppHUdKQzaWisSJHZgsWKNTFpM8nclRZqjTpWy2XU6jVkszkUiyWslNdQKIxC03Q i2qjgoXVa5i5ehmnfngSSSONVpvVPtLAtEhNa0HTahguAsMjQCrTRNuso222YLDiUZUmLr27iHOvL2Lhahu1mol6vQbTbMBIWTDbJhdFEyxIPpVCLpdCJpuCaTbRrDdRyBbxwL0P4tcf zUcuPMATD4q5hBlc2IFrdifNSR1xpXPLlgYdd5WPioBgp8tlA47YuUGP2QeYVTqyxlf8UYLofKUXU4A9irGQsLoBu8Rap4IEAEiQASIwIAJ9CeMSrnyeLiqX4wQP7SusvBElSjI5yO1J8/RCYcdjDAqJLP09OOGTsYXRr0fjMXG4gijMRgOQpDjwmjUnBWbqk9htJMfVmoyNDTa/YDt3iMIbdtaGPXMWxRDg4UghijOc URfwOFUTf5re B64p0IWvTGYuQizEqJ2hHbBa69LkCfUKvd3xBX9J05 ycRYHTY fVYQ9HW0iK4KEURnt/tvoTRnvvJ1oYjWjzRgujqnUXzqFBCaOug5yf3/KXS0Fi4YYJowrxNKKvIBFZXO9Y 3m9wqjkxLef0uAvwiKfcxJGlX 727LCqC3UgQuD7166AMMwMFIcQTabha5ZYHKjxsLt6xVYCSYg1tC2LLR5dfkWD2cvN9ZQri3zMPNUOoPrq6s4d/ZdnD59FvPzV9Fs1pEfyuL22/bjQ4c xP87NjwCQ9NZx9ytmk6yPJ8mEkaSeU6ZzdIWbHkhdx3gAi5QrlaxsLSEpJHE1OROtM0Ed3Wy3J4Nk42njavXZvGjn53Ee5feQ73eQNLIIp3JIplMQmcCrV6DkW6gNJLA2GQateYKFpevIZ3NoFE3sboEXJvTsHQdKK80sLa2hkqljLXKMs 7arYN3mYmk0YqrcM0W2i1G7BMC7fvmcaH3/8RfOSDh7Frahcsng1Vs4so8QSjFv9zwimq1C24xFbBLcfEJs1 goov2e7M00WVC9J5DzfABbnFhFFgL5743Kch kZJGB3wp1VqjggQASJABIjABhPoSxhVfoAJypn5Agozn0dzSlGMqTO36JBqWRCakF1xkmA04bYtjjXIPelhHF8Y9RWXkuYji0AeQSQOw4EJoxEhnao91qcwGswk5kaWXEiDEUa9 0vtGBUdrzfCMRqw53371S cRAoM63GMhi2T0iHWvcF1/6pF8H5c4erBrMcxKrboF5IUjlHxhriO0Yit3p8w2vszHC2M9hHqfVMco/YzYDuY1 8YZcvjngEH9j/nbTOOk3ZnzOJLrFid5Pb2/qqJ4wQesGNUHMAGCqO9uLWVv6sjHPYxf5tsi8u2pDDKQs2ZkMhCwlmO0dm5GR4SXigMQddZqDeQ1JhQaTs4Ewnm4Gyw6kHMAsnu5u xXKQts45ypYx3Lr6L75/8IX7xizcwM7uEeoO13eBh7blsBhNjY7j/fffi4Q8fxv13vw l4RIXDJNaAq1mE41Wi7srWfg8d7MyAVFPoFytcOG11TZRrdXAvKgjhRKGssOo1ZtIJtNoWSYuXHwX3/n7l/F3f/8SJnZMYGRkDLlsgb fSiWRySaRyZhoW6vID7UxtacAS69gpXwVqSybK0sBUIDVnECjkke9CtRqdaytlXF9YY73zYovtZrgztXVVRaKv4LCcAE7JnbgkV/5OD7wwAcxVhxHOp3mTlLmZuW6qOMe1bnaa2u 8g8XhTtlmJhs6hZuEq4MEyRZCPuZM8DBg55wejnk3uOe5O0BTzwBvCjE5fsclvw6N25/GIcOFXH6tCKUftcrwnXcqonPfRr UHrBzcln50kD4IbmP4Hp8y/i9IozfylVAJ8X1GHy/A7XuXroEJZPnwYOdUP92dsqYdTLSnDfqrgrXosc07Y48mgSRIAIEAEiQARuDoF hFFluKsbDu6pTOu4Rw4/CzxzCoWg6u6BofphYdIBueLCQumVORulcFnHBRPsBmXrFCXkRjtGYzGMEkbj5BiNNWfF3utZGA1iEkdo9vbvE6xCc9HFzzHqrqcENjYAACAASURBVGlwjlEm4n8D9 1U5RgNCXWOsw6 D/pqLp78sAPNMSqNP0AAUouO3fWJej8s927fuQfl7akcuzevqrqvkPMkDg9ZGA3KnxshOPUsjIamzAgW30KF0ThjV12zQcJoUOEdf47RwQijdn9A/tlnsAbbQcx/ s37KRf7iiM69tCX5/dRnByjcfZznDGG/rVEnT4l9nOuErnFwog3569Em67XLSuMmlYbzVYDiyuL3BnJRNH8UJ67Fxv1JsDyYmoGd0pqzEHKwtETJqx2A81mjbs9U5kUFx1/8cuf49uvfAc/OPkjXHjvIlZXa2hDY55TW S0WkgaQKlYwIcf iB8mncOjgg0inUtBMcPFxZXkZWsKAaZpomSb0pIFMPodypQrd0KEZBndqpvUk0loSkyOTaLZY1fskFpYW8bcv/S3 5E//GGffegOlkRHs23c78rkCb5O5YVk 0HyehdVXMDmZxz3378HQCLBWvwZLayGTzEPTisgat0HHGCwzzZ2gjUYD5fIiKtUa6jUL9Vqb52JduD6P1fIKdu7Ygenb78RDhz6Efbv2O4WWmLjLijMZTEfmYfRM9mTCLwvGZz8J/o/7I1ZhYq93q9mLO57l7nz /HTMXKKOg3RFcEs6AmdH HQFT0F0tMXBkHs6oqYrHEo5Rn2h9FKOUafP4Y5QKTtd3XELIfBOm7K4GXoaCON47MpxPM 1UZYT1b5LFkbD5 3Pk qKqF0R2Z9rddOdVjQgIkAEiAARIAJbmEA/wuiE4xzrFlwQwsKlfIOdHJKReQj9Venlsa07lH6nE4bs fAlf7iLKeT5GLhtsw/uT6Mq5qh09offMSoWMVEwjBRGFZV8O6HP3byQNkexIFFUjtSgdsPEwa6ogBNObs6w3LS2CqHIBRlWcMsB6fnQrxJGFVXphTQOndyYclX6TqGhXoXReOvgPSacueMEOvlQhbB1T2X4Z S1FOfnb8c3vwABxCcQewSXqLW54CloFSYqdeat PJEHkOU8OqoV/a Edj517TX80RRxTuGENrPs9WzMHo4zrnl/yUU67wMOxdupDDaSaci5LOVzti flcF/m529gcAsXAQu9zz5QT7QsPh0D3X n/m5OFE9xX2BUrYuRBjP2 QMBqnKr0tTAu//zp5tt2UNlv4L1UDHvrWEUbtouj8h W/ZE5OVpX9yvwV7tJkrsbi8DA0LYGV8ioXJDPDw7i uACz3UbaSCKd1GHoFqx2E6bZxvDwEIbyBbz4rZfwp3/2Z3jr/HksrCyh1myh0WojoSWdUPImUmkN9UoVu6Ym8e9 93fxP33yNzBWGkWiDV746drcVRY1j7bJXJ0WMpkMRsbHuFOUjVtPJjGUyyOpaWjV6ti9YzcsGGi22vjByX/CH/9/f4y/ /u/Q9tsYq1Swc6dU8hkhrjIyKrSG0kNmTSQyrZx4K49ePhj92PvdAmmvoq12jIK SLMdg4ZfTeS jh0LccLQJncwVpDrd5AqwGeZ5QVglors/vWePqBnZO7MDm E/nMEC/SxERdJsYmjRSSCZZh1fGDcmHUFj3t kr Kkvdd/yFmXoK/w5wl3raUF3jETbVoftcoO0Ijb0IowGpAGL02dPc2Sb3tGkLmxdlAdgtvhSQF7Xb5yGc9qQwYO19H8vDK4BbdIq3cR7Tgvg64LOGmiMCRIAIEAEicEsT6PfDZkfwdOix8NnJC1OYEUQcUSwRxbJg4N0Pq/Y13qIvPtGkIyTZH6Z4DroYlW5VYz98xLX0xRRGua5nFz9qdybkjjfaMcrCByMZxhFGWd CoMaZnQRmpDDO8DmrVkQQapmA Oir3GHlCQ0NFE4EJpGCuCK/rOA67iuU/uhhlE6cwpKbM1IagytMlQ4fxZKbZlHldI5bfMkxm8VZBy9pxX6f2Y/5qaPwicvuOJ88AT5uT75eOV/tCZROHe0WHwoRQDqCojMwr0gUvjZurkYxr2xoLlnehzRn1RcpETlG7aFGzFnVV9R50hHFuqukFs1YfayuoN3zsyWcG7x9Xlwp tnqtZ o8/K zhdF3dyqnvW7ocKozdy7H70iWb /q4J 3yid487FMmt5H8j7uPP7z3Wf9iA6hvcV/PvIw0p5Lsg8JRFYMcYwx7efY9gXbOHPOWvLO 9nMcXPPte1f0v/tcwz S0ojDIJ1BZCG406Ls9eRj6Xw6XLF3kBpHQ6hZXyCq4tLmB01zguXb6MZsNE2rCLMhXyWeRyWbQaNR6uns8N489gL y1e/iqvX57G8tozhsSLvQTNSMPQUkrqFdC4Fq8pC8Zv49//ud/G//NansHN0Bw nb7UaWF5cQaPR4i5N9pNKZTA2PgZN17k4yQRTjeU3rVWxtraCnRM7kUgkcf69d3nff/H1r6NSK/M5rFXWoOtJGMkML3DUajTRbjWQQBP5go6DB /Axz5 CAffvx FUeD6wizGx8ZRq2pItEehJ0aQQNp2dGqAYZhcCIZlQNfS0DSDj7vZbiHBXtNZDlPddoTqOrKZLNLpDDKZHPLpIWSSWfseXpKKVah3xVHXGdoNrnelUlW9 l7EQVu8LPpya0IUQ edUHox/6ZCUPRVlA rSh/qGLUFymUprB0QBdNJX5V7tgy9zJ1vIHkcklNVbA hrMAZTopuXdb214GPTZ/Hi46Dl7cR281LBygRIAJEgAgQASKw6QgE5WzbdAPdPgOK57rbPvMVZ6IST SZBhXvGTSRW3kdBs2S2iMCgyUQlQ5lsL1Ra0SgXwKbXxgVFDZbcjR5eDv7x84vOoc9u3fhx//8Y6ysLvNwdeYaZVXe9ayOtWoFQ7kSUkYWCctCytBQLA7zQPldk3uQ0FL4sxMv4L9/7U9xbfEqLl15D7fduRvZfAal0QmMT0xhYmIMxUIWmVQK5eUVPP7rn8AHHjgE3dJ4ntOszkRIjTtF9YTOK8C32m1e0Im7LS2g1qihxYsdNVGvV3lOVA1p/Nfn/5i7VV97/TUe2p/JZTAxMYGVlTJvk93bbLJK900kDQujo3nccdduHHxwGvcd3IuRCR1zVy9i9 7dqKyZMBsFwCzCahtotVpAwoRutLjwyQovGXoGus7coEnovGCUDstKIJVKwTA0fg/rs9Vq89dLxVGMlyaRSw8hwcL6E0kujCYSLFuqBstXnT7Bw 9VeUh7CaUPvLYXYXSSuSBPw1dh3uOO7MUx6g9Jtx 8GyCMuuLqRTsFwK5XvoQXHceoLYy6yUzlo8BJKyDM dDp4/g6fhvHDp3G8eev42N2IlV8f8ybx7TfQ4XuIwJEgAgQASJABG48gd4cKDd fFu7R3 4sOtkWncRpC0K5uYIo7QOW3S70LBvVQKqXKm3Kgua96YmsCWFUSYwsuJLrVYT89euYnLHOIesWawauu0mZRXpE4km6u0GYCaR1DIwdJYz0 RiIQsOZ/k7W 0E3njzLZz l59ifuEKhkoZ7Nk/icmpCRRLYzCSWbRbJpqVOq5fW8COiQlMjjGhMMv7ZLotEwc1GJ0wc7swlAnDSPN3660mdI05MnWUa2WsVpYxNFTAP373 /iv/ 15/OjkD1GtVZEfGYKVsDA8PMxzg9oiK5tHAplUEo36Kh555CPYf/sUhoaAPbcVMTGVxezcexgfH0W9loBujcJIjKDZSKBcXkPbbKDeWOV5Qtl8deaATaa4IzSbzSGTZgWekmhbrEBVmztuDSMF07RQr7f4zNKpHPLZAobyRYyPTnCWesIRVR3x1uR1rRJ8rEHCqMft6eTK9DwdgujJxLtgx6jtgjzoFl/aJI7R8zwsHRvjGOWgnJD6vU/gCbwoCaMKd60XbqeI1MEzX8KZg5/Dpw 6Qi 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 AU 7ObczSAley6tavO78Xei8BBLiY7blkMY2UlSljdxKcYDY0IEAEiQASIABEgAkSACBABIkAEiAARIAJ9ENjcwqikrjEnaDeU3kKz1cTVhXkMDeWQz RhciHUhMHdmQkesp5JsWrtabR5tnaLV6gHWmi26nauUou5SJM8p2itsYqGuYZkigmELJyc5Q9lBYsAs2Fi5/hOLK4scTcnK2BUqVZQr9dRKBRxdeEaDD2J4WGWnxRYXllBuVpBZa3G84bu278Pw4UiFheWcOG9C/jla2/gL7/ DZx7 2202i1kcmkkUzp3uyY0C7qW4IIoK6DE/n90dBj/6//8FB489D7oWhtra9eQ0NaQSjfQbK0hk05B14awY xelAr7kdQLQFtH02qywXNHKBOCWVg 42a2m9zVCtPgc7cSTGxuwXSuY2H0tsuV8WEFmHQuEDOxdXiohLGRcQwPFXkuVVsGdcsxuVXrA3ajWxV 7xP4nGBPtKuku5Xi2b1xq9KHCaM8/hxfevEiOtXXb1BV g0TRjsh9YIw2nnNCZvn BRpBFxRVSjiZIvEK4C0Hn2cJXQLESACRIAIEAEiQASIABEgAkSACBABIkAEthSBzSeMKvHZ2UVtYZTLeGiZbTRadayUl3lhoZFiiRdjqjfqPGQ lU5x0RKWjmqlhVqtAdNswrSaaLbryGaSmJzcgXcuXEKlWkepWIKRBCq1VbTaFbTbTVSrTdRqTST1FHZP7UY m8NPT/8UK UyMlnmokzyPtKZDM6/8w4XRW fnuYV3efnr3JnZqVW4/lE73/f/Tzk/rXX38CZn5/BN77515idnYOVYHlETehJjVeer9UrSGgmLKuNBEykk0mMjpRw/3134/849hns37MHlfoyFhevoLw2i3Z7GUbKdpWmjBL27X4IY8U7kdSKSFhJtFlaASYYJ5ibFdw1yirfW5wFu4 JsYxsE22rgWa7wYVaJm ywlN6ghVd0rhztdloo1yuIJ/Nc1E0l80jmWT5VcWSS/afgjyj9vK6oqew2IJYJ24BWzB1XxGFU1f0jBBG2a2iyxLDOHSoiNOnl3muzk/skHKM oTHXXjlS1KYeUdcdcblERX97dlD6OYEZT5S273pFYc9Wz g0ryNzxY9VyRmXlZM65RC4537IBaPkoXjLXV80WCJABEgAkSACBABIkAEiAARIAJEgAgQASLQP4EtJIza8h376QijzRqWy0uYn5/Hvr17sVpexczsDNrtFi9gxNyZtXodqytVNBstaBrzmzZQqa1hcmIM9993EP/y81/g6rXrGB8f52Lq2toq6o01Hg7OnKK1WotXaX/wfjv0 8c//jHKlTWMjI6gVCqh3W5zgXF2dhbFYhF79uzl TvL5TKMpAHWUC7HhMQCrszM4vv/9E/47vf/Cf/43e9xUbFQLPKCTM1mgyVJ5TlBbdGShd4nkEkncdf0Hfjk47 G3/m3R1HKFlCuL2Fh QquXb ASmUOubyOWq2GTHIEd9x2GCPDd0JHgbthWTg8c8mynKpcrGQTA7PPsn8TvFI948n bCZY7lbmJG3z4kmaluSV6tl1lsl4tLnAnDIMnqeUhdHz9y07fN4uyhRWl77/jUp3EgEiQASIABEgAkSACBABIkAEiAARIAJEgAgQgUES2ALCqO0WteVQ1zHqiKOtBq4tXcPPz/wcBw7cyd2b586dxcLiAm677Tace/MNLtSxEHcW7j5cHIJhAKtrKxjK5XH3PXejXK5irVzhFdqZTsiEVJY7lLk8hwsl6FoSrUYL6WQKk OTPAydCa 6ocMwdP5nNkLmHjUSuj1Sy LCZrPdRMbIoN5o4NxbZ3Fp5gpOn/klXvzWy7g0O8vHm8mxIk4JHpbfajWQyaTRbFaRTCV5XlFWdOlDDz2E3/nf/zd87MOHeR34plnD6to8ZufewtLKReTzOsrlVWTT47hj38MYKdyBBIZ4ZXpWQCmdMZDgeVWZcMlGaKcksAVPg6cU4H9OMLHUdMRNNpFuLgNeVEnIHMp8oSx/q50HlemtCZ6rtOMWtTuiHyJABIgAESACRIAIEIFNTWAWv3xqCqtHZnD4yM5NPdJeB8cLBL1wBAe cQQT/OZuQRA8eUJ4vdvy eeeQvXpb A jsK HictHDoc0Pup5/CDh4Ep6/OY7nWAAHxjZEWent Pw58P6rCPTmLc4mcV46YbfIl3jDHWxjM/raibB93mubagDePbQBkGLsucGs5ymcfuoCdneenw2YyxZo8vxzCcycUp8X9vDtM3Tp8El89AY/t5H4 F55hl92KxWLm/3eq3h /FF8/l428wW88J9 ghcOfRDfeGQ0EtlNv D1HyLxAnDyDz Cw1tt7DcdXv8D2CLCqD U3g6oZzlAGzj145M8jycTQ7O5LKrVChfo0qkkL4TExDv235SR5MJgpV6G2Wwin2NCaYpXXnc9laynmtmAkWBuSAP1ZgOV6hqSMJBLZ5BKpnh UWapZI5QJhDawqJbod7kBY YMMpC nXoOPv2WZx9802Mjo2h0WrjhT//c/zNt17i7eSHhpBKpaExOyvPgcoKIbEwdh2ZTArF4SF8/JGP4d8ePYq9E1P8GuburNQWMXvtLVxfPI9k2kSlUkYmPYY79nwExcLtHmE0m2XzdhyjnAyvSMWFUmfoPDUB 4cNQ3MEXjYH9sPkTpbr1J2jvd0Strbq/shCKOmi/T VdCcRIAJEgAgQASJABG4Yge0rjMoIIwUOLiKcQmmmB2F0oOu0iQWWgc5zEI31KmLeIGHUt4cGMVepjRjC6CB6jXxeBtHJFmgjmsNmfW7j7PktsAC9DvHqz/HUH83i8JFfJ2G0V3a38PVbVhhlVem5h7Tdxrl33sRPfvITTO2awvvuuRejI6OoNWvIsarpCZ2HkTORj7tHE0wodavbt3nFeCvBCi/VsbC8hGsLC6g3W8jmckhlMjx/ab1cAWot5NM57No1xfOLNlqs FKVC6eNdhO6rmFm5goKwwWMT4zxcPp0Mo2rC3M4/S nuaP0wB0HeK7Ob/7tX MP/uA/IpMxYCZYxXom4maQSiVRqVSQy VQLAxjx QkDj34ID75iU/gVz5yGIU0c5eyHxONVhkLy 9ifuEttMwV1Os1ZNJF7N/9EEpD 5FAXgilZ5ZOZu/kAfJc1LQrxxsdYZTnG3W1U3aFUFm o3FaLEepPQL vhuZb7/SfYzcaPpb MGiqRMBIkAEiAARIAJEYGsQIGG0s04kjG6NLctHScJovy7luIscLQjGbWlrXxfNgYTRTbXCJIxuquXYKoPZIsIow9kNpWciJ/uHKXn1VhW1RhWvfOfvcH3hGvbt24cH7n8AE OT0DXbDWqaLTSaDbSY09O03Z2tVguVWhWNZp1HjNdbDVyZm8V7ly5xxa9QKqJQHEYqlQKabdQWVlBeWcX4 Bh2Tu1EOpvlYiprN5lOI5VJ8nyj6XQahaECz7158col/ORnP0F KI9777oX /fs40Wd3jj3Ov7iz/8SV65cwtm33sbCwiJq1RoPua/X6tzdmsvmcNcdd K3f u38FtPPYVdO3chrRnc/WrTqGNlbQbzC dQrs7zglGpZAF7px7kwqjGQumtFDTu5Gw5dlZXGHXSjQrCqJuwgLdtOalIHQHUNZjy192d7fyP0hhKwuhWef5pnESACBABIkAEiMANJSCEcvN n/WGYLMw6qmjPBO8 5MXwrjd8NipIy9g5ug3nUueFByOAZMRwintK8R7/MIoFwLs6Ev 4wvBlMcZEJYujqbnNp/1h6Xy XfmDYhsVDPvhhM/inkW6uoig/9euW17zhecUPqTwMMPY83tRByb7N7zraG0xtJAu2Pcj8sJoQ9hb4TOm/f3Agonj2D14e7e4eN/9FVhP4XvE1/otbxn ljjbrqCIOFI2nsx97 dGkEhjIbuc9c9dwKZo0c7a nd24o25TEp9qW7pOo9ZKenkPd/1N5FGH93z50EZpwwadaH6qzgrAL2SPAYnPXqPC/C3unp2Q9wLMpfQIS2qf7ixitWsn6eQ/LEYSwdZQdXyF4P3SP2SnrW6skTKB0 iiVPKL3E59kTKJ062g2lZ308t9jw nG4bv3Qf cYafk/K6hJyBynPoaVSfmkLzyAnUjtpnRWcPhK6B 1yozkHwM9I9GyP3tSNaCkcxnvU5O /CkdPncPSa82SN78TM7z8AMdHLqRPfxsNvdA/TThs8DH25 8Y9d8E6WnRC6XttN4UT/ FRHLHzsACs7e9kcWJ8FkdZ34px8et8cyw6YfHdYbFQ/6nvNDovdBk4/YSG0r D5/7gHDq/oqVx8LYvjeLEtVmbIWdwu pXJL0mENiEwqgnPrsToM7GbBcJYs7GNs83yv5ttxu8uNDpMz/Fz8/8DPV6FXt278Ed03fjzjveB11Lc6Xv2rWruL5wHfVaDc0WK6iU4flEWU5PI2WgXK3g6lW7kjxzhLJRMOEzmTSQTaVw5b33MHPlMhdKb5HbdP34HicIkLr x lqM0odsljljRp3cvvIv3Ll/kFevvu/d XtV KJ8HS8hZq65xUXRhYQGXr1zBwsJ1zF dx XLlzF7ZYa/zoTbhz7wQTz55JP42Ec/hkwqw8Py3aB906yj1lzA0uq7uL78HuqN6zCMHHZN3s9zjCa1EiwrzfN/6jpzjNo5Ru1/bZp28SVBxXSi7DvGUVf1dFRTJoxqKiXUvUFwnIoGUnriiAARIAJEgAgQASJwyxNwPnhCyHFoCymHbXHUeT8jC6FH0RE O8JLR5xxPigjJP dIrTX/vDtCnZe4cHnjpLH5QgLXUEpegyRbfrY Nu0595lAQVPeY/JYl k8yvAMbomCi3O/DsCgCiMKtYwqk/vGP0CYuS8O4JGV4Dtiivya8EirWccPg7Rjjj/PJ0vAZy96tnr7kK5gh1LXQD7S4HI/d/JGSuJmJH7vPulhCwGdZ9Jqc0Y 9J3rgWx 6bAXt5DciNR/F1xzye4dfvwrGdnjwhCXNQYXIFQFAQH8ezL7Ua2GVcYZeJc JcQttgspspwRdDg56Rz5nZY 8 mzvPmnsvu kgiuvfcZaZnO/ nux/Dz0nFMxiZtkEWpl1hVRJkI9fAfXa693W/BJBfE85o34Esh7gDtkAIR4C0c4EyMa8jFDoiI/6Nmx/UvUYQGx0xVL5HDqUPbxewxdaQdl3RNUxo9LlVnXavdcVd75y7QmpnjqE5Rh1RVBiDPG5XdH2yw yW/9tXLACbUBgVvyNXVThnwigTRdtc7EswNyRauLY4h9de/znePn OV6cvFcfx4Q9/HMXCGEZKo1hdXeVFmZgwygTP0nAR7baJ/FAWCV3D0vIyFhcXMToygqFCAdVaFYtLS9y9OTJcwMzcJSwuXodlJbBjxw7su20fRkcnYOgpR7DVcG3hOm/j4qXLmLkyg2w2j0MPHsLe3fugGSxTZwIGyyHKChw5qQBYIadarYqlpQVcmbmCS5cuYn5uFtVaHffcfQ8OHnwAu3ft5gKsk 2TpwRotRtomatYq83i2uJ5rFYu8dD4neP3Yax4AGljFDAzaJsWdMNycozaYfTdHKNsj7jiqDcaPtbucfVV WLKLxobH11IBIgAESACRIAI3BoEooqhKN XhDaluBTx4Zh/2IbkvvTcIwoPiCgiEiCQKQTB7qr2I6qxeiaiUKZ2nil5CNtpUMKot2CPNB9RGI0UKvx7PVwYjTFvlUCsEr0ixiaOA6JgH vxVIe1e4SeIOHfETp5n55CWfIekAtVefuM3udeodadlncPKdqUi 6E7nVX7BLEtwDuYYJ51L5WCXze50ViFfAlQpRo732/n2dfwcNx trPVMB542EcXxgNL6zliKBhZ6FCnO8UVnK/fFKup7S3VNcE7JsuY8fVHljAqZ98oQHCqKePOOuqeHZUeyri2eCC3elRr/vTIyQ6oue41 HIhT9XWOSiYdXr5GTbTLwmIJT aFi7CkGTnRFx vYckQHj615jC5unJNHSFjOztrM0RBj1XNdp1Num ppYB/ktfdEmFEabzoK4Ih77o NydJ2LTlV1WxxtIsHKBpk1XF YwzvvvoU33nwDM3NXMTK2GxMTU7jrjgMYHx1DJpvlRZpY1XlWLZ6FpbP/bzYbKJfXsLSyhEw6w3N8siJIzLWZTqUwXCig2a7xPKJ6wi64xATStmmiXmfFmaqoVuq4fGUGc7PzXHCd2jmFe9D8OFInTdgMkSiVpMGE1A59Ox85yyf5lIygoqsVD8erOOeqPGnZ7ZbJYXe0okWHEodqnOC0LZ4mYbplVFpXGVV6ZfXH0b9XoTO8buxfjI3cgkx5FwHKOslpK3NpJbfMkRRsneeUsfAjR5IkAEiAARIAJEYKMJRIuD4giCQqeV4mkPYpw6jNMrPHT7Vrmvgj6ch89vPW2uHpnB4f3P 5xenJfoOBTjLB2YgxJGvVXpQ4RRoep93ArQocJo0NpGOC2VXHoQRu3QaynUNvYjIqWLkJ12HVEmWOiJt/ Dc4yq93nA9Z49JF4Tvtf5vjyi2HQS50CRM2w9oviL4418VQAAIABJREFUYry7LqovUVyhOeg5UbUjrLM/XP1h MXHqLNN4uiZd5zzZD//skbmrRqb9zkN37DKPXKBOTjhTW8iOVyVAr5clV7BNXwf2H0WOqlC1M7XzphjpLWwZ68WRr0s46yBHS7vXfvgtBOi6ztoFdSh5Orq8aI4CVFAFBsXBUnEK74Uv12nQrxHsAyaWTfMXenYDBJOuTC7gCMsdP9aUFV62I5aSeDlK82EYdiCslKAjn1 37oXbklhlOcYtZiztAVNZ 5LVliICapNrK4t470r7 GtC /g9bcuoFKp8crv4 PjvGr99PQ0D4fPp/O8CnvaSCOpJ 0K96w94Z m2eSvM68nE08zqRQSbSaYtlGtV7FSXsX8/DVcuXwFMzNzmJrajR2TO7F3zz7smtrNc3VWqhVkMjkYmsGFVqZ4pnk1 64wygsjCX9mKQISFhND7eQBTAhlOUuZMMpC/W1hlIXHN9E2V1Gpz2N 4U2sLK9gYvQAF0azqVFoSNs7mxtv3SyiCscoCaO37glAMycCRIAIEAEiQARuAIEYBY6kHG88vHK/N7y4L2HUDevks3TCHrkA4LraFGPz3CPmyAsSo6LEkW7YaAd258O9JKRJq8EFRi6MCklPPdcE5xO88cIoG1gPeQBZFKXHKakSXSPmrXK5qYSwXoRRQVTp5FUNy9uoyMvIcluuMrey4Lj0iEPyeHre/6pQepeVap/3J4x25 /dmIHCt0oYlZ2wXMnwh3V7e5CfCzkMXhLwbpAw6hcfo599cY9790Sc82SAwmjEWTj5qpDaRFiM4PF3L/I4lgOFUTGzprja/jQL/nPSfkX 0gAhOW97EUbD13VAwqiUe5OHvo LImZMYVR2nTIwAxFGuzk/vc iE14fSxhld3ZTArjtBOZA9XTk5DSNEkbd3Kvy31yc8HoSRvv7K90mFkaZgOfmw5Qdo044vdWGprOJN2FaDZgWc4 a3AlaadTw9swlnH37bbxz4R3Mzs5yR bIyAhGR0dx3333Yffu3byCPcvfyQRR8Yf9OWExb6j9D/szc5eydt555x288cabmJ2ZRSaT4c7Qhx76EHeHplNZpIwUkNDQNttotZgQmubh7 zHbJuwzBZ0VtFdAzTNdXPaOVPdMvHtFsujyt7XuUuVWz6tBM PqiV0aBqrLM uqaJtLmNU1cu3odo8VpjJXuQCZVgoaUPSUujLK23dQEYqkl94L NhDdRQSIABEgAkSACBABIhBFIFo8UIa1hokdbpehAktAv4Gh9EEOuGdgfwBXfUBmA4kh/IqIPDn4gtoUbogUkdT8b44wKo4lIKefcEm0MOrNieibqSp8dSDCqGfBnAIrATkcI8OEWbEkb2j88Kte0bT3/S KanH2eYAIp3Aw2iJRP6HLfsEzjlNwOur46DiRHf4DcoxGhez34hgNdNB21v0FFGY j aU6DyM48q1w 3X7xiNsUduhmM0bO095 Rh35WuSBrsTl /Y9TmbhehW69j1BOW7s5GEUr/wiE3n6h9Uc/OzphV6WO1K1KPLYyKN7kiqSh6 lMBeBY3MJQ 2DHq a2jSlkQecbQBVtSGGXLZouOTei6BV1PoGXWecV3FqauGxpaVhtLzQpq9QYajSaWVpdwdeEqZmZmeJGjRr3BdUJD17mDlFWBHx4e5kInC6Nn4fDtFguzb6KxVkd1uYZWs8UrzO/etQu7d 9FqWiLqtlMFrl8Abqmw0ok L2maSHJwuCZuMpzgpq8QjwLpWdWUq3j4BSdo4Kb07L9oswgysL2mWPUDqm3hVo3z2oiwZyya1itX LFo4aHdmM4vxtJYxgakvYOZyKsRxgVNr6okVJuUDoRiAARIAJEgAgQASKwIQTC8/mphUX3g69bnKN3x2hI7sdnXAdatKjZ7TcgD15U3kUF0cg2xarjknO201xEKPDNF0b5x3qnsj0T2/wgQoXRIK7ivG IMBqRtkC5Do7j0RP264pTzyL/zDOC0NLP/veHvcuuNzv02N3nahEuOMdo0JcZ4evpc4L2kWNUeQCJYrdKwIt0jB6FWPiN9aHMyyp0PpAco7w9Z30PPws8cwoFVmyLfwcTJ7 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 /O2oq9IH5Cp9RtgHiiJTS57CSOIZp3BtRn4hFUcY7T4rwes6CGFUUfVdCK2383HajshQAbMTpt57VfrwdoPH16luH0cYVQi3cjEkX1V6RzjtFGTqsSq9sn1VuoGN HvNNmpzywqjdqpNqysmckdkt9q7XbfedP5xixzZQfHMhsnyiTI3KCuexPKHsryhzIXaaNaR1FkovAXDSPKw HQyg6FsgYe1c/clky5ZLSWLhcNrPLSd5f5kYfIme431wl7XNB76zkRPnV9nK5 8lBKfgC2Cck2Si5LMIWr/mf2X3cf tV2j3dfYOFhaAN4WC8XXWD6MVaxVy0glC9ASeSSQgpYQHaPseh6c761EL25mEka30aNNUyECRIAIEAEiQAQ2H4GQvIG 3JRMxLBDT9ecPHK9C6OMgNzns5ia2Y/5KddBJoeq nNk vLYSfkgw/PcsTH00aaiwIicXy qwFHPwqg4TiF1QPziS4pcqhG5OX1r2smD2BWxQue9AcIoC3v35TKUBE7fsyXnpX32JA7sf04SswXB37e 8h6J2v yGBa1z21hCSdPAg8/DDd3aEck5RMKdsHZn7zEfLtBp4swDyH/o7ogVPAJFcq/T2E0c IEakftolqdfMOK7BmdUamKQPX87Dutqb4YcjuKbFPaG 7e6uRujSOMxjkLbRietXryBEqHj2LJI4bL4zmB0qmj6IiaIU527z4AvPsv6pyU93j3SzP1ToopjPIjultwjbflyV06GGHUn3uThZfvw4U/OodneH7MYgxh1J4pd06 4c7aCVPn Tqk98d3Yub39 DVSMFV1S7QyQ3K3o4jjHauWxaWxD8 ufiUp1BTqDDKmu0WeLI7EURitpTKUPq4z0jwmbTd39mSwmhHU3RCzW290S5g1HFgarxWfUdo5CKjY4m077eD0kWXJHOEMmdpJpmBxZyn7E0rwUVPJoSy6vI81SdziLbttnkOUM2uFM/D77mTlYXKa9xxKkeqdzOnei2bvF3WD/ XOU 9OU/t9tsdwdX2nXIFFUgw8bWKZrsOXUvDMpnz1YChO8Iouy7hCqOOa9SS2yfH6HZ/2Gl RIAIEAEiQASIABEgAkSACNxiBCKdhTeAR595gm/AyKgLIkAEiAA2sTDqOBv5InmLL7nrxkTEVsvOMZrQmLOy7TgpbbcnD6h3iri7sqjjx Rip vg5Lohk1UtC41mA2mWG9QtlsScoJYJTdcdkVMhKDrjY 5TXbcFUf5jsTYdN6jj mR32yHzFg/Nd12hbn/u3FzhlY/NcY4yB2rnx9FVGQM2bl1vcI8sY2W2NViWtkmF0Tm8fPx5nF4Rn75hHHr6GD6xo4cn8szX8KUXgSc 92kcDLjtzNe hBeXD HpY5 Aqumo93sYTfClcy/j POn4Zlu5 q9wvhtLuenn8axnkCEjfIMvnb8Ch4LmP9A5sfX4aK6qWGR/Rl8zV4wfDpowXoekHd cy8fx/PnpwPXO6p5vh8CpgLPXKJaGuD7Mfa5rzdnzxUVrDkj9vDx RzCaWnPsfdf2XVsgGs0QBbUFBEgAkSACBABIkAEiEDvBDaBMBqVz7T3SdEdRIAIEIHBEdiEwmjLmZ2bD5P9US2M jCIoeB29Pxgfrhx1G1QHFd/zQ8kYt0zN6a ch rMyCWLqDrTeUvOqkGOnlGb4pj1BbHLu59Ap8T1TFHXNvbi2gWQzCKEj6j3u9vdaW7QkQqW4hzxdHBC6M3ZH58HZYVwrYjgMMVRwcvjA56fsHtBezbgWyQDWgkaM 5Irb8/LlDCNmrGzBKapIIEAEiQASIABEgAkTgRhC4icJoYG7RGzFv6oMIEAEiEJPA9hJGxUmLwmEvAqlbGF5siwmj2uDKt2 IMOqO1xVwfcKonWqAq8X8PbeQkzDRgQwsZOeFiJk9i1zbQBgFRLFwuwmjALjQdh7T3A28lYVRAIECcMyT9kZephI4o0RRNj4SRm/kKlFfRIAIEAEiQASIABEgAkSACBABIrAJCGxCYbST2lpIeukPIY/FLkwQdULsPe24r8nv2alGB/ZjZwd1OxEaDhpvUN/K602nOhQbrhT27 YZVQmjA5xfECg7jLcYGv4u3iuHNnscpQph1HP98CEcKp7G6Rih9Pw6N4RaCJlWi7W2wLd8yA5559dAcsCKkwgVm8S24A lV4The121/rQE9vvy62KqAsf96I5RmK8bZu3nfBHDznx9axsmGHrmrhBGfWH4UkoF3/y97tpuOgb7vkOn/aH0oXtImkyoOK9aR3l8HiemO98ngBdfRHd7yakSFKklxHY8 9y 9vr0ISyfttMzKF3W8lgDRVFBjN/1ijclgjuGwDUY2HFIDREBIkAEiAARIAJEgAgQASJABIgAEbhpBDahMMpcjfKPKq9nBLMBO0bFIk3rWy05xl8IzY8URsV7g9TazSuMuo60QEGnA9YVi4QcnHK4vSSMesPSmflNzKUYkmOUKVYdIUoK/1aJfr06B8OEUc97kmNUcZ89Jzhh685Yi4IoK43NL/T5Q8Jlbt57YoSQh/HwvCcJo4r7PGNRzF ej/xnb45ROZQ/2hEZKozK43XGh45grE4dYG8vJ69q0D3iGsrXKITR0ysROXlFdpNOjltl HzEnouxBus7C luIkAEiAARIAJEgAgQASJABIgAESACN5fAFhFGe7UzOqXjB8k2cAi9xOmzAQUJoyFj5n27/QjCMc8TKg MCaNuuLwsKLeF94RQ l7xroerqhiRXNgmQGzzCFeiYKQUHxXCmDRuWRTkbytcjq47lL3dc8h/oDAqi79ekUpZSChibPKyKIVDn2PX64B1w/vZnD92/XkhB2rAogcKo46o2llbrzCqdNqKbc0H5S7tjiNUGPWE8cfbsL3kGFVeq1gfOZ uxzWtHKMkeKuEUVFIVU3NHcehCGcpIoTRXr8EiIeZriICRIAIEAEiQASIABEgAkSACBABIrBpCGxCYVRmE1RFyRUKmfjHxEL2X/c1V2QcoOIXKoxGiaNibL6T57MzTVfcDInX53lD2Q 7V3TU8hr3Upw/E0bNgDyiQcKowO0Gbs2Oq9Pp0w3XDgy59wlnTlX6gHyjUSKmOgzeKxapHJSiUBqJSyUEuzd5BOHgHKMyJ9eB2AkTD6iY7h27wmHqjEPmIPYXWRDLFw4vEFGGlvur0nvD3V03ZDfkPyiMP0wYRY9pG9io5bB7z9oq5uLfB IazvOUC5ALigUJtkFh Qph9Py0HI4v7UKxrb1P4Am8iBcvqlymUS7l6DWI3P90AREgAkSACBABIkAEiAARIAJEgAgQgU1MYIsJo7IA6QqOrjAqkGZ5NFWV1/tZDFEU7YiUYkPuuIIEUjF5qcox6oqjTOSUBthxi4qiqChksnky96c7SCZ MmGUtal722M5RjtuUtcx6la0Z/0KYf39cOr7Hq97cpKJWuen8fQxKQQ QBjl1ytylypdl8IY4wijngJCMVyMPgSxC9qoRSqWdoD9cIHSCYsuCmKbLJp20wLI7lZFLktxsArh72KA4OqZY2xXoSqUvpN5004P4OMblEPVHkGkMKraQyF71C kK1I62D1z0dMdvdykLeTGEUal fE1mOR5RE 7rtD1CKOdNZXdu 6Io4RRdl34GvT9yNONRIAIEAEiQASIABEgAkSACBABIkAENgGBLSaMim5JURxUOB6ZMDgoYZQtlKs7MtEx8CfoPTnhqSRscrcr6yCuMCr24wrAhjMqVxhl7RkxhFHHYdoRRfvI5zqIjSwIbLyIjqpIkygSBf2/MJb HKNyaHlXPOKh5SHFnJQY hRGo0O1/b25IqnrsIzrGJVbEp2TgUWX3Jv6EkYD3KuhbbkCXdf5GCmM9lDoi8udrJCWb31VoqK8R1Qrryg2ZXeCL724HCAEC0LkAIRRUUC3 70o5NPt9tVxoEbuVf8aDOLRpzaIABEgAkSACBABIkAEiAARIAJEgAjcLAJbTBgV3ZYqd6ZY4f1mCKNScaSO/TOsEpQjiLrCqHInsPtlx6jQJneMysKoyjGqyj96o4TR4FBuPmWf0OmIRzu6QDYkx6gshAUVPTpfxF5cxHJUGLO8fpFik3uD6N5TVKjn6U/tglJh4e2iCzaqWJHds QaFIpcPXZFLPYUcET1JYyqRUNbkA0rLKTIUyqsn8chHHtcAftLnK7DpCsSB 1lcXzqwlXiGHm4v xqdcPgXbfnOhyjHmFUuX/iOEbldQ8QfG/WbzDqlwgQASJABIgAESACRIAIEAEiQASIwDoIbBFhVJxhmGNTuI47Rjcgx6gylF4cX5gIyq5Txcq7IexB43UF14B8q3yebmi8I34yodXnmGVh8 4Q3L7Ya4xp1BjWscvcW30Ck0oUZEqoIoRZEOw fVASUjv5IbtV7AdSlb4zPKeyNyKqgasQ9SWM7nDyXXbn4xaFYqH1Yqi2J8 l1JffAekX67z5XGXBL7qAlccBKYjYfhSioKZoV8hVyoVf IsvyblnQ4svuXsIh4SUDOFOzzCHsU 09VWYlx2n3XB7uSp9R7CU97QYtu6mMRigMNp9rtx93HvxpcD8vwM4HqgJIkAEiAARIAJEgAgQASJABIgAESACN5rAFhBGZSRRhY6c6wcpirImY2usMcfnW moDqLaFYTOTttRbboX3sjiS6r8jGrBUV2UxxmzouCS5/rhQzhUPI3TIaHvrrvSLk7jtOvJtekVbk97RDb7PXWeUmFx 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 86GoiQASIABEgAkSACBABIkAEiAARIAJEgAgQASJABLYBARJGt8Ei0hSIABEgAkSACBABIkAEiAARIAJEgAgQASJABIgAEeiNAAmjvfGiq4kAESACRIAIEAEiQASIABEgAkSACBABIkAEiAAR2AYESBjdBotIUyACRIAIEAEiQASIABEgAkSACBABIkAEiAARIAJEoDcCJIz2xouuJgJEgAgQASJABIgAESACRIAIEAEiQASIABEgAkRgGxAgYXQbLCJNgQgQASJABIgAESACRODGEFis1PE3v3iXd/bA7jE8uHvsxnRMvRABIkAEiAARIAJEgAgMnAAJowNHSg0SASJABIgAESACRIAIbFcCFxfLePbbP XT 4379 E37tu3XadK8yICRIAIEAEiQASIwLYnQMLotl9imiARIAJEgAgQASJABIjAoAjMrlTw/373F7y5f31gN371wO74TZ/5Cn7zCy FX3/gGL765U9iR/xWI66cw7cxm88thX8eVPBrV6Bl/5zS8AX/wr/N7B/js 85XP4tKnvgy7mxhtch6s299D79365zX3rc/iL/Z8eV1z6Hf23rn320of93GG53Hsqy53fxtnvvKb MJ5d1/516XndetjmJG3rGsvBLfunbvqOnsfHZ/ Iv5qPZs/coKb4IINYrwJZhZ7CJ69fovwiHq b9rZFXvV6EIisPEESBjdeMbUAxEgAkSACBABIkAEiMA2IWBaFuqtNp9NUtdgaFrfM2NC3meOT/cpDMbtNo4wGretkOt8Al0MYXQA3XaamPsWPvuZ45hep7jb15BiiJN9tRvnphh9h4qDMe6PM4x1X7NBIhUJo teme3TgLzXN2jPbSpgUc931PubajI0GCKwcQRIGN04ttQyESACRIAIEAEiQASIwDYiML9Wx5tXV/DapXncvWsCByaGsauQ6XuGJIz2jc5/IwmjjlPXj4aE0TAX9i3kGB3g47YlmyJhVHU4RDrOt Ra06CJQI8ESBjtERhdTgSIABEgAkSACBABInDrEXh9dhGvzS3jncVVnJ9bxKP37sOHb5vA/lKubxhBwqj9 tlOuweOhYXBA3BEwe4djwsuVNcx kU89soX0GnWE7LvdXdyIQ1fxBfxBXQi/0NC/NXjnXfC878IfOEL6CQQeFwIWZYdW6HzkDELTtg9f FNUSD0IY/tcdFRyvt7BY998TG88oXjcPlx3h/4KXeg2q8dCAxVD14rm2k3cYK4JgFbxjd/wDNedpsnHcMBHDs2jePHvaH0fP3cjg8cw7Hp4ziuCKX/1CXVPnPXTUirII/Lsxfi7C82cEeA7G5SNrlu Hoc954vFYV/XcLnrhjH48dw7Pzxbig96 NPbreZMYbCXD1tK/aE9312q/jc ufvW1uZs8jHt/bescU6hDyM464b23LCfoKwJ9fByn9myXs9mlfosy0BUT6n/NwAvsiPKOFJlV3nUeuigu 5h 3T38E7n mmK HjeeUxb9oUhXtTZi/uR/ssCB5/ Ln8V/A//5/F9PEv47z8 4ZcpbEeL7poaxMgYXRrr9/WGv3rP0TiheWAMRdx8g8/gsM9z2gBL/ynn Do F2wjt7ew93svp8DRx7FkYkebqNLiQARIAJEgAgQgVuSwDfPXMCP372KSqOFWrOJp95/Fw7tHsVkPt03D5Uwan8QFgQf5wM2gsRRhVPS6xDsCgwdIcbXpkIYZTpBR5hx2kCI8y4glP4lUUByhK3OOEShJnIeIcIoS2qquN/mi66oKc 7I150RcuuECG/FiJsynN32xWELbvdkDbijF/m1xl/d7/I/XTEkY7AJ6U4iEqB4PTZFfnkvRBnfylcmfJaRAmjgaJR8Dr55 7fx531dtfKFV8lUdK3ftJa Fy5nvVUzD9gz3Sfc2msvvn34XRVCKPsi5Lgc0Hx3IvzgpMzuUdW0c9qNK/IZ1t1Kisdoy8pxG/hOfWdlTHOwsBzpss6jjDqd3o7X7bIe9Un3gvjj/V8d79YUbnLo9NR9P0rkG4kApuGAAmjm2YpboGBOMLos0d HZ /1zvfUye jYffSOHEf hVqOxTGOVjqfbR3y2wTjRFIkAEiAARIAJEwEdgqdbE69fK OeL1/Hae1fw7x 5H/fsKCGlDzDHaEA4eGjIfaSbRy2ghBXkUYp4UaHqAR/Ave4jaSyiUBM5j16FUVtEkN1PHpYq0VkWH1m3UWOT3lcLCerxuLNSCiVR4ho3CwviL1R5VmUhpxdhNEB8izEuDwPXmespEBWyFxTnj ti9hRIErnHmbtyHVVik1TMKmDvd f4Afw0tIBT NrbW0wskOUAEPq13X3rzEesEkalolPR6yYsjopnJKtPAiq3pOe KF4xnu3Ywmj4Wketi6pel/Ie6VyJFkbVOZo9bcfh36Mw6j/rotaC/rJABLYHARJGt8c6bo1ZhAijgCNwXuvVOUrC6NZYfBolESACRIAIEIGtTaDSbOMH52fx7TcuYa1Wx//5qw/grokitESi74n5BM8gAS5UlOyGbKtD7tXFlyKFUchVuiOKOEV9AOeUwsSwqHn0KIyGsnwFjzGRTiWmqUS8noTRYCdfXOeVOkQ4oJiVOLZ5J7T2r34PBz36VUhV tB1CxJFxDlO8qrurzzmTfcQONegsOQox6g8n07ks OWjTF3pSAXuiftTgO/mBDGPNlJf6F2BXecqcqUFOGcOVshtYMvBD/uCaQQRsPWjfMKE2MVaxb6a91QAAAgAElEQVSHlbg3g8LhQ3nFebZ3KNV1bz5N1Z6LJdCGnYUB70lneLQwKo5fSsvh7qHI8au 1In3xUjnC6Wosy/u3qPriMAmJ0DC6CZfoG01vFBhFIDyfVcw7ZLwOk7Vwujs917F1Hca3Zvu6Ybah73njqFz4/hOzPz A9i5rRaCJkMEiAARIAJEgAj0SuB6pYFXz13B9966jKnRYRx9/zRuK V7bcZzvVoYhb9KfZRbU5G/sSuebBVhVBBOhTyUwSKQNC ZkePQUi QI6ZtoDAqC05sHKHCqCQY8nlPCg5Q8f 9ypKdJ/WrX8YHfqoWsrwiTDxhBDzPYoAY6xET4wijUr5IHgps33fcdSxGCaOe9RTFUNvxF2fu8ypXprsu7hcBgWKfmBxV3FVy2HI3V6UnH2RHYPVsbifHqpyP1rtru194yNcF575V7vt hFE5D6ZHr/ML8bLQ6R2Hwypqrzv729eWHEKunGQIE1nkixQW466LX8T05emE91mKI4x68os6YqhnD0eOvx9h1PkiwFn3oGdmXb/46GYisAkJkDC6CRdl2w4pShi9 nM89UezwL/5IL7xyCiAd/DcH5zDM6I46WvDL4z6w/KddgRx1BZAvaH0rmDaFV6dtkHi6LbdkzQxIkAEiAARIAIxCZxbWMN3z13GublF/Mrd /DQVAmTQ2kktRvlGHVcjionlFdutQWns65AMChhNCKkct2OUXkhXDEtSOiII4xKYbK LhSh5xvtGPU5ce1BRYfsbj7HqC3 ssjoCMeo0nXWSyh9gAu3R7fswB2jYWeHK TKBZSce1zRzxY97YJXfjEttAOnuFeMol5uM/0Io4NyjApTid7r/nl7ePGiSRHPtgpdn8Job syIMeoMjWEdE5skDBq54Blv2/sglG9zT/mL1S6jAhsMgIkjG6yBdnWw4kSRl0h1BEwbaESvjygtvDphtxLwqhPXHWIyn37hFGFeMpuDWpvWy8UTY4IEAEiQASIABGQCfzo8iK //YMFlfX8FsfOICcoXNhdDSb7BuWzzHaT45RZe iiNanMCoXClLmifSoHZJYoRLyehHDuFzoVLYXKqR3uowQRoNctqKYoLpm3cJokDM0TFhWr5ErBtmuWbU4uFlyjEaGZMvOQ9c16HEBKtzStmys3AeeQmUDzTEqjSMgnFjp hMeiaj3u3lTJfdsp42w/c8tqB23MKs/FvnTozC6IyqMWiXMRbKy87HK 8W719Uz6fD61CV89jPHMS1Xj4/lOhYE1UhhMSgtRvi6xM4xKonOnmdZmRrCcbBuaCg9YcR9OPAy dt9OOxNlfkRuQLiACm5cACaObd22238h6EkaLdrV5lVvTI2p6hdEgMdV1n55y3aiyMBo4tj5zmG6/1aMZEQEiQASIABG4pQn8j5 dx8l3ZtFumyjm0mA 0UfunMK/unMX0n0WYBpIVXqFEOFtt19hVFGVXirU4tkQ63WMRs5D3n4RwqhcmIh/sJfEyQ0SRt2q22d7qErvK3glhBt3QqkdF6JcRfwsbn5V tAco/K4xdQPYSKPJIIfxzF89cufhL2UTkV0vk1t4Vxm2H9Ver9AG7Q tjinEtDEvaZwhMp7T1EITBTYVPk 4 as7eqsYuh7nHNBLtwlPUPcudkrK/86dZ4XsALxAQ5aVY7O4 BpFGzRLkaRoJ4do674zDvClx11MJq7PJZuSH7n2Y16lh2h39cvz9TguIQjhd3 Qum5NOrmzFXmxL2l/ypAk9 mBEgY3aYLuymnFSWMetyZsIXRa0EzcSvYq4RRIbeodPuTEcJoIDcxDH9TwqVBEQEiQASIABEgAhtJ4L//6CwXRtNJA3vHS9hXyuH nSXcMT4MQ uvMn1QoZKggiSB8/Pl0xTDz MIIF4HlPvB/9j0cRx3UyYGhAR3xyTkkeTXQuHyi3CMhs4jQhh1w9HZeIUP8zJLT4GqQQmjotDX4RRQMCVwEaU8nFzstENZXxLZy7k2j03j HFvWLGcm5Cv43lXVJTdbjHWLahgEp9LnP0lCC3O/Nk6/M47n8EXXGdylNvPEb66GTwfxxe/ejv 5DMK0cq96MAxeOfeHe9xN9Xn48dw7PzxWLlOPVwFQdaekrx 4hcLXeFOyEDqiICCFU/mLIlS/vyd3jD6rgNVTEIrbLheHaPOrfK8vUK92uXbGyvVXvfn95SLy4U 28rnTNrrj3zPL wGngnH0ckOG0ss9I7/8WPHcP641 XqHb 7n4WUKfJ5 PgX8dXb/wT2lv8yPqlylfrGH/V8y 93ErxyV64ozPbsUN7IX8jUNhEYMAESRgcMlJoLIRAljHrej vUVAmjWZz8w4/gcNhiKB2j3pyjtJZEgAgQASJABIgAEXAJ/MPZyzg7v4RMKok7p8ZxYDSPkWwKxjpyjG5WutGOqM06choXEbiVCZzBV74C/B6zz9LP5iIQWUBvcw3XdmT3kcd1k02DhkME4hIgYTQuKbpu/QRChVF/oSM7LN4vcnpfV cYPXzk1/H5e4UhO27UzusBOUY7ofadW 3co/7X14 DWiACRIAIEAEiQASIwGYkQMLoZlwVGhMRiCBw5iv47KVPdUK idcmIrDFhNFI9/EmQktDIQKDIEDC6CAoUhvxCIQIo/5K8qxJRVV6XzGkOFXpFdXlZaEUgL8qPeAt9BRvmnQVESACRIAIEAEiQAS2MgESRrfy6tHYb1UCZ77yWVz6FBXK2ZTrv0WEUcotuil3Dw3qBhAgYfQGQKYuHAKOMKrkMb4TM7//AHb63nRETSHX6LMeN6g65N4VOTvN XKECu2KfctjDBwXrSoRIAJEgAgQASJABIgAESACRIAIEAEiQASIwFYmQMLoVl49GjsRIAJEgAgQASJABIgAESACRIAIEAEiQASIABEgAn0RIGG0L2x0ExEgAkSACBABIkAEiAARIAJEgAgQASJABIgAESACW5kACaNbefVo7ESACBABIkAEiAARIAJEgAgQASJABIgAESACRIAI9EWAhNG sNFNRIAIEAEiQASIABEgAkSACBABIkAEiAARIAJEgAhsZQIkjG7l1aOxEwEiQASIABEgAkSACBABIkAEiAARIAJEgAgQASLQFwESRvvCRjcRASJABIgAESACRIAIEAEiQASIABEgAkSACBABIrCVCZAwupVXj8ZOBIgAESACRIAIEAEiQASIABEgAkSACBABIkAEiEBfBEgY7Qsb3UQEiAARIAJEgAgQASJABIgAESACRIAIEAEiQASIwFYmQMLoVl49GjsRIAJEgAgQASJABIgAESACRIAIEAEiQASIABEgAn0RIGG0L2x0ExEgAkSACBABIkAEiAARIAJEgAgQASJABIgAESACW5kACaNbefVo7ESACBABIkAEiAARIAJEgAgQASJABIgAESACRIAI9EWAhNG sNFNRIAIEAEiQASIABEgAkSACBABIkAEiAARIAJEgAhsZQIkjG7l1aOxEwEiQASIABEgAkSACBABIkAEiAARIAJEgAgQASLQFwESRvvCRjcRASJABIgAESACRIAIEAEiQASIABEgAkSACPz/7d0LsCR1fS/w3yJEUbPcXVeWAIsuMRETFFzABxCjKAh5IeZGQHMhuSIaxFTdur5ijDHGeH2k6lZFJGq0EiwVSCICeaAg AgaH7AuYTXqNS6CEHZZFlkjCPs4t3oe58z06TkzZ2a6px frbLK3dP9f3x / 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 tGxevXq1jVo1r8Eo7OugP4JECBAgAABAgQIECBAgEABArt374477rgjVq1aFfvuu2/rf34RIECgSIHkOpT8L/kHmsMOO2zm1yHBaJHV1xcBAgQIECBAgAABAgQIEJiBQLJT9LbbbouDDz54Br3rkgABAosF7rrrrli/fv1MX khGLUyCRAgQIAAAQIECBAgQIBAzQW2b9/e2pn1qEc9quYzNT0CBKoi8OCDD8aePXtizZo1MxuyYHRm9DomQIAAAQIECBAgQIAAAQLFCNx 2td/p5fL4Yb70QIDBcoPeR 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 19ZbY p2r4qGdd8bePQ81ztmECVRdYJ9HPDIeufKQWPvzp8dj1x6V 3QEo7kT64AAAQIECBAgQIAAAQIECDRboIhg9L7vfy7u/c5l8fg1q2LlISfGIx61Nlbss1 z4c2eQEUE5vbuir0P3xcPbfuX NGO2 K B/aPNU8 O1Y94bm5zkAwmiuvxgkQIECAAAECBAgQIECAAIEigtHNV70sDvmZVfG4I34n9j78w4i9D0XMzcEnQKAKAitWROzzyNjnp/5bPPSf/xw7bv9S3PPAmjjy9I/mOnrBaK68GidAgAABAgQIECBAgAABAgSKCEa/eskJcdwL/3fE3l0RIRC16ghUU2BFrHjEo OBLX8dm7 zLZ5xzo25TkMwmiuvxgkQIECAAAECBAgQIECAAIEigtEvf/iYeOav/EF7p6hfBAhUV2CfR8bDd1wWX791Szzr5TfnOg/BaK68GidAgAABAgQIECBAgAABAgQKC0ZPfW3E3G7gBAhUWWDFvvHwnZ8QjFa5hsZOgAABAgQIECBAgAABAgQItAWKCkafccprkBMgUAOBXf/5j4LRGtTRFAgQIECAAAECBAgQIECAQOMFCgtGT351460BEKiDwK67/1kwWodCmgMBAgQIECBAgAABAgQIEGi6QHHB6O81ndr8CdRCYNfdnxKM1qKSJkGAAAECBAgQIECAAAECBBouUFgw oLzGy5t gTqIbBr63WC0XqU0iwIECBAgAABAgQIECBAgECzBQoLRp9/XrOhzZ5ATQR2bbteMFqTWpoGAQIECBAgQIAAAQIECBBotEBhwehJ/7PRziZPoC4Cu 75rGC0LsU0DwIECBAgQIAAAQIECBAg0GSBooLR4553bpOZzZ1AbQR2b/ CYLQ21TQRAgQIECBAgAABAgQIECDQYIHigtH/0WDlGUz9G1 Oda/8Ql/Hp7z1gvjwCx6b22A2fvTd8a9Pf328 hfbXWz7zBVxzFsPjqtufFZsyK1XDRctsHv7jYLRotH1R4AAAQIECBAgQIAAAQIECExfoLBg9Lkvm/7gtZgh8OO46g/ Mi688Ulx0ZUvitMf1znk3m/Fy1/0j3Htib8WN/ fI LAadt12t/w/tfOB6PT7kJ75RDYfe XBKPlKIVRECBAgAABAgQIECBAgAABApMIFBaM/vJZkwzTuSMKbPzY/43TP3BiXPWF4xbv0rz32/HyM/454o/Pjw8//zEjtjjiYZ22N/zl/xKMjkhW1cN27/iKYLSqxTNuAgQIECBAgAABAgQIECBAYEGgsGD0OS/BnrdAEk6FMRbzlvQPD549j4jYhDD4o48HELwei26/8hjnnb9xZGd/5L4o6X/cz879s/PyiuumJlvO/Fn4prOz85pdvPN74W6y740sL5J54aN//ZkyO6530 CWl/HFf94Yfiwl94Sdx80E09/R0eF13x6ws7W1tt3d3/Z91zo93u/G7XAf1OfTds3nWrWPu77/uaYLRiNTNcAgQIECBAgAABAgQIECBAIEOgqGD02F/6Tf55C3zz5jjsgn NN158YVzwC6N1tvHjF8WLPrg LrriV M3Vifn3B0XP/fv450nnhI3vf3nWyHkthv KY5925aIjD b72vHd K8F18bG3r6bp93UFz5uWNawejVb/7ruPDGiFPe8rvxoZOSYLb7Z8/uHBMRrTkkwWh3PMmYOsfF4jEtzHXxMaMJOGq5Ant uFEwulw0xxMgQIAAAQIECBAgQIAAAQLlEyguGD2jfJOv2Yi23XBNHPu2iIuuOK0Tcg6Z4I7/F e9 LrYcPEF/UHqNzfGYRd8Od7Y fPsdpMA9YrY JbfiQ d9OiIjLba562NKz 3ITbEA3H1m/8mLoyT46a3/9zCrs9WX1sXxpz fWsK6XPbfb/z/BfH7S89aGGSnTFEd0w1q29ZprPnh5sEo2UphnEQIECAAAECBAgQIECAAAEC4wsUFoyeePr4g3TmSALbbvhUHPunERd94tTRgtFvfj0Oe/XWjOO3xsXP 2Rs/KNzWqFnu921ceVnn97z3tL Y2LHd O83/xMbHjfq ZD1v7zknDzI3HhL5wRt7907cJ80mPIHFPn3HhB3PT2J8WBrWO Em/s6avd4IA RtJz0KgCe 7/N8HoqFiOI0CAAAECBAgQIECAAAECBMorUFgwesKvlRehLiP75qY47MKvxRsvesVIj9Jvu HaOPbtERf9/SmpIHVrXHzS1bHxzS/rBKPJcQfGlTcc3R MnnR1vPO832gHnTv I8777zfEhp6 2 13z3sgrv6jj8WFT kc3zVPj7n1 22pMXXOjZPipj/92Tiwc87AsnXHVJe6lmwee3Z QzBaspoYDgECBAgQIECAAAECBAgQIDCGQGHB6PG/MsbonLI8gW1x8fP/ITaez40PMenXnqxks/HC/60LFx5fVHxYZv3hKHvWZbXPR3J6eC0f52tn32unbAmZwz32r7mHee9 tx 9kHtoPR3/pcbHjvyxd2jPad90Bc/ZZL48KndI6fD0aTMdwUb yelzmmzrnx3LjpbUkwOmjcy9Ny9HgCe37074LR8eicRYAAAQIECBAgQIAAAQIECJRJoLhg9NQyTbu2Y9l46V/Hiz50TFx5/dN6QszOdHd8L877rc/Htef9aifMbP8 3nxmf5D6zX Lw15zc7zxvb/bCjm3ffb6OPbtj0 1mQSj/xTvTLW1oXNO0mP/eUm4eXlc JRO3/PBaH9f0er7nrjo757fE9Z2 jrhl Omtx0eB0b79xvT4x7457Ut90wmtudH3xaMzkRepwQIECBAgAABAgQIECBAgMBUBYoKRo959slTHbfGBgk8GFe/5e/iNV9aF /92 cthIs7tsQrXvIvcW08PT75mafOh6YbL/1InPHh3mPviYtfcE286/hfiq 9bX37W k/ 9k47s/W9J0X0Tnu5afF989 fHR///U//K34q ft3xpc/3mdcT2le3xn/N 8NZ7w 1 PN/zFOZ2dpul2I9pjjIhFY7qj57zucf3zs06mL7D3v74rGJ0 qxYJECBAgAABAgQIECBAgACBogUKC0af9fyip9bo/rZ99nNx3Dt 0Gdwypt cz607P1B tj0ce2fr4lPXndkzy7Ue Likz8d73r5C P7ZyXBaMTGyz7aDjDj6Naxh/ad92Bc/cefiNc8ZeH41kn/vjme8Pub4g1/8dtxwVM6o9pxW7zizBvj2s5vk/H83tZPxBn/fmJ87U euPCN9p1z5 dyfOrnjV4B U1 74 /JxjNj1fLBAgQIECAAAECBAgQIECAQFEChQWjz3xuUVPSDwECOQrsfeD7gtEcfTVNgAABAgQIECBAgAABAgQIFCRQWDD6jOcUNCPdECCQp8DeB 8QjOYJrG0CBAgQIECAAAECBAgQIECgGIHigtETi5mQXggQyFVg74N3CkZzFdY4AQIECBAgQIAAAQIECBAgUIhAUcHohuOeXch8dEKAQL4Ccz 5WzCaL7HWCRAgQIAAAQIECBAgQIAAgSIECgtGj31mEdPRBwECOQvMPbRNMJqzseYJECBAgAABAgQIECBAgACBAgQKC0aPOa6A2eiCAIG8BeYe3i4YzRtZ wQIECBAgAABAgQIECBAgED AoUFoxs25D8ZPRAgkLvA3K77BKO5K uAAAECBAgQIECAAAECBAgQyF2guGD06NznogMCBPIXmNt1v2A0f2Y9ECBAgAABAgQIECBAgAABAnkLFBaMPv1peU9F wQIFCAwt/tHgtECnHVBgAABAgQIECBAgAABAgQI5CxQVDD69KN/MeeZaJ4AgUIE9jwgGC0EWicECBAgQIAAAQIECBAgQIBArgKFBaNPOyJixYpc56JxAgRyFpibi5h7SDCaM7PmCRAgQIAAAQIECBAgQIAAgQIEighGv/qRE NpRxwSK1bsU8CMdEGAQG4Cc3tjz95dsfk72 IZ59yYWzdJw3fddVccfvjhufaxVOM7d 5s/XjTpk3zh62Ym0uiYb8IECBAgAABAgQIECBAgACBOggUEYxuvuq346CVO OnH7t/HcjMgUCjBX74w/vjngfWxJGnfzRXB8ForrwaJ0CAAAECBAgQIECAAAECBIoIRu/7/ufizk1/Fav2/1GsXrlf7LNP8ki9x qtPgLVEGjvkdy1e2/ce/ u2PnQyjj06a IVU94bq7DF4zmyqtxAgQIECBAgAABAgQIECBAoIhgNFHe9r0vxLf/9YPxX9u/G7t3PQieAIGKCey73/7x2DVPiic/ /w48PDn5D56wWjuxDogQIAAAQIECBAgQIAAAQLNFigqGG22stkTILBcAcHocsUcT4AAAQIECBAgQIAAAQIECCxLQDC6LC4HEyBQkIBgtCBo3RAgQIAAAQIECBAgQIAAgaYKCEabWnnzJlBuAcFouetjdAQIECBAgAABAgQIECBAoPICgtHKl9AECNRSQDBay7KaFAECBAgQIECAAAECBAgQKI AYLQ8tTASAgQWBASjVgMBAgQIECBAgAABAgQIECCQq4BgNFdejRMgMKaAYHRMOKcRIECAAAECBAgQIECAAAECowkIRkdzchQBAsUKCEaL9dYbAQIECBAgQIAAAQIECBBonIBgtHElN2EClRAQjFaiTAZJgAABAgQIECBAgAABAgSqKyAYrW7tjJxAnQUEo3WurrkRIECAAAECBAgQIECAAIESCAhGS1AEQyBAYJGAYNSiIECAAAECBAgQIECAAAECBHIVEIzmyqtxAgTGFBCMjgnnNAIECBAgQIAAAQIECL BDS8AACAASURBVBAgQGA0AcHoaE6OIkCgWAHBaLHeeiNAgAABAgQIECBAgAABAo0TEIw2ruQmTKASAoLRSpTJIAkQIECAAAECBAgQIECAQHUFBKPVrZ2RE6izgGC0ztU1NwIECBAgQIAAAQIECBAgMGOBubm5 MEPfhCPf/zjZzwS3RMgQKBf4J577olDDz00VqxYMROanTt3tvrdtGnTfP8r5pKrpl8ECBAgQIAAAQIECBAgQIBALQRuv/32WL16dey77761mI9JECBQfYHdu3fHjh074rDDDpvZZASjM6PXMQECBAgQIECAAAECBAgQKEZg 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 9fdbsWJFTKvOSTvTbK rP63xaW y9cyP3zgCVfj8TvO61dTr4DhrI31OUodp/sqjvW59pzHO7rrLY5zTGF 3DeObTJMfv UIVGG9uA4up6LZx1ahzpPPcqEF851Ms x k81u/LNrHYz2skz7ZipNnnf7eYUIg5ZO3vPJu/28vao /rx9iv581Kke0wxV1GH8vxyTM/NeV3m3n/fnvOrjz9vH52 yz18eZ0/7ZmDQGPPuJ /28wox015Vn0fVx19UnevWT151z sfN r2ubOexvvbMc91O96IlndWXuOv23oqaj5512N5q2M6RzcmGB2Fq6ibvFmFkaMYFBkmDxvPrOtR9E0tj2EC/T 3PngstWKsD vD hj9mlq2z8voI8/vyFn/R/ s 59VmDKrsHm5K2nW9Zl1/9bH0itm1vWZdf/Wh/WxnGvqrNfrrPv3eVnOasnvWMFofratlut2s1G3 ZQt/Jz2cszrMcxpj3O57dV1HarXclfCbI6v6/rratZtfj5Xs/mc6HVBoGw3XZPWpqidbZOOc7nn161OZbvZXm49hh1ft3rV9XPVraN6DVvR5fh53erkOliOdVWFUQhGK1Clut2kToucy2iSnLKduCy9fvgMXjd5vu5gtE91 Y yflx3yr9KqznCut 0jlsVLkvL1T10G3fd1DW0m9Sj7mHStHxcd0aT5JTtxGW09VPUUYLRoqQn7MdNppvMcZZQXXdKjWORdY7PlXB0nLVk3YymxsnfW6OtFEeNKuAmys3lqGsl6zjrx/oZZ/1YN4PXTfc axzXppxj/bjuVGWtC0YrUCk3l24uJ1mm1o/1M876sW4Grxs7RoevKOvHdWf4KnHEOAJuMt1kjrtuhDiD5Xyull5VfFx3xrnudM xfqyfSdZPUecKRouSnrAfN5luMsdZQnaMLq3mc8Vn3M/VOOc17RyfL39vNW3N5z1fN5duLidZY9aP9TPO rFuBq8b/9gwfEVZP647w1dJOY4QjJajDkuOws2lm8tJlqn1Y/2Ms36sm8Hrxo7R4SvK nHdGb5KHDGOgJtMN5njrhshzmA5n6ulVxUf151xrjvdc6wf62eS9VPUuYLRoqQn7MdNppvMcZaQHaNLq/lc8Rn3czXOeU07x fL31tNW/N5z9fNpZvLSdaY9WP9jLN rJvB68Y/NgxfUdaP687wVVKOIwSj5ajDkqNwc nmcpJlav1YP OsH tm8LqxY3T4irJ XHeGrxJHjCPgJtNN5rjrRogzWM7naulVxcd1Z5zrTvcc68f6mWT9FHWuYLQo6YL6cTM6GTQ/fpMJTHa2Hb6T XXP9jmezJEfv8kEnD0rATefk8nz4zeZwGRnd//R1Tqc3HGyFpp9tvU3Wf35TeY3y7MFo7PUn3LfbmYnA U3uZ ddJMZJmdbh5MZ8uM3mcBkZ/vHjcn8nD2 gFBlfLveM93UTubIj99kApOd7To4mV/3bJ/jyRz5TeY3q7MFo7OSz6lfocBksPz4TSYw2dlClcn8umf7HE/myI/fZALOnpWAm7HJ5Pnxm0xgsrOFepP5CfX4TUdgslb8PTKZ3yzPFozOUn/KfbuZnQyU3 R doxOZpicbR1OZsiP32QCk53tHzcm83P2 AJClfHtes90UzuZIz9 kwlMdrbr4GR wmV 0xGoZiuC0WrWbeCohQKTFZQfv8kEJjtbqDKZX/dsn PJHPnxm0zA2bMSEEpNJs P32QCk50t1JvMT6jHbzoCk7Xi75HJ/GZ5tmB0lvpT7tvN7GSg/Cb3s2N0MsPkbOtwMkN /CYTmOxs/7gxmZ zxxcQqoxv13umm9rJHPnxm0xgsrNdByfzEy7zm45ANVsRjFazbhOPWngwMeGyGuC9LK6JD Y9MeGyGuC9LK6xDxa6jU030YnW90R8Ti6xgBCr2OIIbYr3LrbHZvfmelJs/XnzLlag/r0JRutf40UzdJNXbNGFGcV7F9tjs3tzPSm2/rx5Fyugt7oLuLkutsK8eRcrUGxv1ncx3v6RpRjndC/W92zci pVMFqUdMn6cXNdbEF48y5WoNjerO9ivP0jSzHO6V6s79m46zV/ATd5 Rv39iDMKN672B6b3ZvrSbH15827WIH69yYYrX NF83QTV6xRRdmFO9dbI/N7s31pNj68 ZdrIDe6i7g5rrYCvPmXaxAsb1Z38V4 0eWYpzTvVjfs3EvqlfBaFHSJevHzXWxBeHNu1iBYnuzvovx9o8sxTine7G Z Ou1/wF3OTlb9zbgzCjeO9ie2x2b64nxdafN 9iBerfm2C0/jVeNEM3ecUWXZhRvHexPTa7N9eTYuvPm3exAnqru4Cb62IrzJt3sQLF9mZ9F PtH1mKcU73Yn3Pxr2oXgWjRUmXrB8318UWhDfvYgWK7c36LsbbP7IU45zuxfqejbte8xdwk5e/cW8PwozivYvtsdm9uZ4UW3/evIsVqH9vgtH613hqM3RTPjXKQhtyU18o98SdqdfEhLk24DqYK29ujftc5Uar4YYKuCmvVuGFstWol89VNerUHaV6Va9e3f Or9bIjbYIAcFoEco16sPNZbWKKcRRr2oJVGO0roPVqFN3lK6D1aqX0ZZfQMhW/hpljVCIU 66 VyVuz7p0alXteolzK5mvYoctWC0SO2K9 XmspoFFOJUq27qVe56uQ6Wuz6DRudzVc26GXV5BYRs5a3NoFDUTqny18znqvw16h2helWvXq6D1apZkaMVjBapXYO 3FxWq4hCHPWqlkA1Rus6WI06dUfpOlitehlt QXslCp/jQaFo9UceTNG7XNVrTqrV7Xq1R2tMLuadSti1ILRIpRr0oeby2oWUohTrbqpV7nr5TpY7voMGp3PVTXrZtTlFXBzWd7aDApF7ZQqf818rspfo94Rqlf16uU6WK2aFTlawWiR2jXoy81ltYooxFGvaglUY7Sug9WoU3eUroPVqpfRll/ATqny12hQOFrNkTdj1D5X1aqzelWrXt3RCrOrWbciRi0YLUK5Jn24uaxmIYU41aqbepW7Xq6D5a7PoNH5XFWzbkZdXgE3l WtzaBQ1E6p8tfM56r8NeodoXpVr16ug9WqWZGjFYwWqa2voQJuXocS1foA9a91eYdOTv2HEtX6APWvdXlNjsDIAsKGkalqeaD617KsI09K/UemquWB6l/LslZiUoLRSpSpGYN0U9yMOg apfqrf7MFmj17n/9m19/sCaQF3Bw3e02ov/o3W6DZs/f5b3b9ZzV7weis5PWbKeDmuNkLQ/3Vv9kCzZ69z3 z62/2BLoCboqbvRbUX/2bLdDs2fv8N7v s5y9YHSW vruE3BT3OwFof7q32yBZs/e57/Z9Td7AmkBN8fNXhPqr/7NFmj27H3 m13/Wc1eMDoref1mCrg5bvbCUH/1b7ZAs2fv89/s ps9ga6Am JmrwX1V/9mCzR79j7/za7/LGcvGJ2lvr77BNwUN3tBqL/6N1ug2bP3 W92/c2eQFrAzXGz14T6q3 zBZo9e5//Ztd/VrMXjM5KXr ZAm6Om70w1F/9my3Q7Nn7/De7/mZPoCvgprjZa0H91b/ZAs2evc9/s s/y9kLRmepr 9SCbgpL1U5GjsY67CxpS/FxK2/UpTBIAgQmJGAm/IZweu2JWD9WQhlELAOy1AFYyhaQDBatLj Si0gFCh1eWo/uGT9Jf8xYh3WvtSlnqD1V ryGBwBAjkJCANygtXsSALd//6zDkficlBOAtZfTrCaLb2AYLT0JTLAogSEAUVJ62cpAeuwqPVxW7zrT74bb rp7vTnHxNXnLiqgAHcF5dfdHO8dM2TYs9ZT4z41lfjEZdHfPGPnxHPavV W7zroh/FuRc NQ5Kfrvo5/kNcdL1d/eN/xKH3vBwa4B/9pLnxxuO6B/rly /Pk7cvjZ 8Ooj23Pr/bV9c7z44q3xzIzzpjbjbdfFBz yI45/7ZlxZGaj98Xl79sYL7s3u8esOfUd a2vxb5/G3HjW47r1HJqI59OQx3jq5/8s7H7zCcuanPJ gwaQdLm9Y NK1rttf0uP2pDAZ lzXH5n38q7ugd17pT47VnZle2b/ibL48//1TPmSuPinPOPzkO7D ov/2stlPtrDv1tZHufvPlfx4LXa2Mo845P07u7yhDNj23rPNSxyw19yXWff/41sWpAz8bw5fgtus GB 5ZWfEqHUY3mThR9QhFNh82XvimjgtXnfWCJ FwoV1uJRAHdafCldfwDqsfg3NYPkCgtHlmzmjxgKThgI1pjG1AgTsGC0AOSLuvvELccj1D8c7znxBT3DXCUoftzbu7AaSuQ0nFYym vnyZZ JE7YXMY7sCY59HRwh2KxMMLomIzhshZ47MwPf3JbKtBvuBqPjBNeZY kEyVle0x57T3vdAC4dRA7686xQdOHcbXHdBz8St0RvONoOHe8/6pw4v5Vipn f/FESrt6/EHSmfx8R7fEcMB82tn8fQ8LRTuDZEy4uPm E8c1PuhugLg4926Foz5 35hBjhqNtxx0HrIs77uhxyXEdTLvpuoQBgtFpr4xi2rNjtBhnvSwtUJfroDoTWK6AYHS5Yo6vrcDYYUBtRUxsFgLWYc7q22 NF79vazyzLxTt9Nn5WeS c7S8wehE66/uwWhEtILdyN5tmfPKnU7zPcFoxMpFO1uXv2N0BsFob3jXt2Ozs6sykl3BW2L9gJ2ZrTAwUjtLWzsqb4kDOjs 04FmC78vNOyEqQf0t9PfdkaYGu3ztqzvBq4ZZc0MJ/v7Gz6 Trt9PqlgNDXn7kgyfUZZffPB8PGx4yO9ofIoJ5fnmDqEAoLR8qyn5Y6kDutvuXN2fPkErMPy1cSI8hcQjOZvrIcKCUwUClRonoZaTgE7RvOvy9K7Me LL38r4llH9DxO3wlLr oOrW9HaTvgvPzoJ8WZm74bL 0 fr1o12knCO3 /Mlr4 Pbt2Y8Sv9z8f3kEfv5x7h/Kj7 6ufEmdvTj9pHtObx7QWvvt2v3Ufvz4w44fKd8wf175BNjSlifgft4OvgbfGut/1H/OF8iz3BWmc35fyPHpf9uPxyd4y2ju Z52 clHpEuy/oi4gBj4jPj2vUR kH7IDsHX8krw24c1V8bPvW9qP3Sd9H3TP/KH0MeG1Af7ia8ej ojkMcm// VfSJq1a/CQ dsEvxZlrUp pbnh90tr4yg1bI1LnZtWn9/UISWsLNcga15Pi 4sepV9i3bSGl/r5gLXTnkkSNn4pViehZzoA7QkUD0x2Zu44frTH6ufbbW2VbD0Knx0OtoPO9jG9/7/HuC/UHDMYHXAZ7B3T8PF1g9w7YuVR58SL4sq navtKWfvDm2FrlvWZ7xaYOnrc2tM97d33W7r f/zbw1offa2xPpT18eWT90S3StTMr7zj7qlFUy3/yz92oBOKLxwKet5VD/jZ91h9r0eIf1qgv6QuDvn09ZviWuSVwF0x3HuK OUpV57sO3a MAlC3OJlUfFua88ZeGVDEv fHNc9p5rIk47LeKaaxZeCbEueQQ Wj/rvuxh3Wmvi U8Fd8fjG6Laz9wSWxZf1qs33JNLEwvNdZkSSSP4Pe8YWK5/eb/N3i9e7BjtN71rcrshKJVqZRxTltAMDptUe0RKJmAsLdkBTGcGQrsiMtaQeYx8ckTVw8fx7e Gvtcdn c/oLu8TvisvfeHC9dsTbufHXy/s FcHE dFy067RzTCw8Gj8faj45 x2ji8LbvneMdvtcufBO0tbPdy68GqDzgJaNt9ds/J2LHaOucn7SA2HaYlUt2AuDvmZPdkX5sLx2Tuxu1oLxlMp3bzLjo2vdt3BOtFRW4FFTvihNedNfgdo73vf 1roN t 0qGvnfT9tYq07T9yoZo7VjOqEN6Thm7mNv9PqpV/8h47cKoxuduT9qJvpqnz23XuBPQJ tikHn3fbmdz0TyGWu9r3fI J VhKLJu36XWle9Ndh8Wbzni6tb4dO2y94TX1x9brwyM7lKQqfNceTAOqdWRtLuNffHUa0grBskpdtuB1n3H3VuvPLoTfGBS7bE nRw1tdOxLZrPxCX3HJAnNYZR/v30eln CVo4Yievk JTtC1xPhSJulxtIPRZM4xP7ZuX5nHDh1q7/gO7LTd9eycPB8SrpvvcyGIS/9Z9/ftWtxyQM/7MjvtRFKHrNq35nVHzId63X5bgWP7nZvtfhf6bM85eTdq95hOv7E4PJynSPfTbff zjmdn6 cH2e6zbbZHUkQ3FlH8 NY9GfLWzNZwWh7eq Ls5 6ImLrp P97YUYr3rh2ojYGp9 /yWt10mc 6oXRvIn3WMOOO31cfZThy4ABxBopIAQsZFlN maCghGa1pY0yKQCNiBaB0Q6BXYEu9863fjK/NB51I67RA1 YKkvWetXzhw 7/FGRd1H8XPfiS L1xaIhybD4NSX660ZDA6IMAc2mdfqNgOo76yjFcGZIdtqXaWek3BsoPRpV83kDSXOaZhY5ggGE2/m7Y3oGx/aVb6i7IynHtr3RrrfXFmXxidEb5uWjX4vbeL1sOQ2masgzelA/Tu 20HWPbPO12n7i7qdjDaOnaJ8WcadsLSrPXZCo52nNAKuJLwZ/ORg3bSJSHUJyPOGLLjr1W0dGA1vWC0k8K1grr2r4UwbjnX5v5AdYTxjRKMdgLDA1K7EdOh4UjjTAXCyc7eVujXE0ZGVqCZES62A9tOqBrJP2SkA iMsHR kKmANh1WDjhucHCcCnd7MJZ XH3AGPvMRzQaUKel6pIZjB5wWry J G89dJ3xzVJiJsEoa2gNHF VbRyUr8IEBgqYIfvUCIHEKiUgGC0UuUyWALLF7BjdPlmzqirwHKC0exj5 Z2xOXvuzle rhkt cBnUfp 7/Nvjewi8xgaOlvpV8qGH1iz27B TBuPpDr7PjMePS u3Ovu5tzftfqSF82NTik7BvrsFByUJjZXW6p87tBZPJobbI7smA8Oz/mBu0UoeNRjN/Fb6np2T3S/xSod S4bcS4S96Vc2tHZQttdXEs7vOWvxN8i355YKQkfc Tu/q7ezu7i763VowJ502VenpYLRGDL IesqFs87HYwO3jE6ejDaDgIXdu11g9It6yfdMZqx6zArCBx2uR2w83DJ8Y0SjHYD4Z09YW2nr UFuNkh4KKwMSvga/1ZKvhcFLJ2gNKPpfeGrq1DsnZ5Dg5RW3Xv7O6MJHDfsr7/MfhB42j1tTiA7S/joJ/3jqf9uHxrB/J8vbqP1/cE/lMKRrvrpbvDrTcYjU /v72z fVnh82hwz6Qfk5gQcCOUauBQH0EBKP1qaWZEFgkYMeoRUGgV2A5j9K3g9E46 R44xGpNpLH6Vth1fBg9LYB3zDfCqC6wc8ydoy2gtGsHXi9gdgIwWgyo4XgsTO/nseZ 9fN4LBx sFoagdl97UA3QHNB7mdR7AHLPC x9t7jxk1GF0yjGw3mLkbMlXL6K1LpL/4K/3u2XQYmr2 0lPuHceg9TZ/TkZ43fu4/BM 85k4obtjND2XbiPLDEbnH6tfVKvF77ntOyRrPfY8Sn9gupZ9Idtoj9IvDkWTEYywI3OUR m39T6evzCz3kBuqddXts5YFIqOOL6RgtGFtubfO7nutDh39Rf7Hv8f ndIOrBMnZB pL1vh rQYLQTJHZf 9kKQw9c/Hh9UrXUawvawxhUy87j9BMGozHw3Z8ZAWfPeNqvBig GG0/Nt/ tSgYTYLh7mP0Q4vuAAIE7Bi1BgjUS0AwWq96mg2BRQJ2jFoUBBYEvnzZdXH89rVx14VPi4MyYBZ /tPxNxmP3Xd3jF5 VLJLtL0jLh38zG7HaLR3VmYFWkN2c2a L3PeZ8SdfSPsGF3y0ephux27IWkrMItlvw6gnUtM8o7R/gUzUjDas6Pz4rh1/t2grd2vmfPttR5lx2h3B2cSKB8Wt71vyCsSMmu08J7PL8Z3U8Foxntn 14BkM O0cHXrCRw mKs7r7bc36HY3JG6l2NnUfuB7WVHYq2j85 TLo37BoQfPW t3PoOzyPjM09X7CT9Nv3ZTeZoeio4 uf9XLeG7qs4HZgINn6sPUHmOPsGM0MlzN2gQ7ciTtkx2i03yna8ilwx2h79 Y2O0b9xwmBigvYMVrxAho gR4BwajlQKDGAnaM1ri4pjaeQPcdoYt2giYBU/v9odF6B2mM/I7RpYLRg2b2jtFOSNpVGiG07NvFmtKd1jtG22Fgamydvoa9jzI5bOGYQ PzmY Z9365UcYSKTwY7b4LdWW8I3bGm3p2ombON/UlV0t kdL89Do7etesjPj2T1LvLE0ZDFoHvTtzu7typ/CO0WHjz/75kNchDAgc52eatQsxxbBUKNqK9LJ2H/b1mx249QWqAx7Fzgzh0kt1iVB0tPGNEIxmPqI97BHx9ECXet9n17HzxUGt94XeEsvZMXr0pozActGXKS095uygt/ c5QejS897USjcZct4x2iRj9IP2jG69tZL492t97p6x h4/2HhrCYK2DHaxKqbc50FBKN1rq65Eeh8ARMIAgQWBO6 8fNx8Gcejnf0haPtR fftKZnN mI30q/ZDDa/eb6wr VfqlgNOMLeoYFp1P6VvrI8GhVphPMvaP1be3JH2TtUs3 sqfo RKpYUFc8TtGF aWzGphfkvMOXm/aSqc7J1j1k7T dciDHtn7BJ1znrvbB7fSt8//sXfSp/9hUxZQd/O/h2W84Hm4j/vPXu0b4ZPfzFORviW3qW4KAgd8x2jw751vTWZEcbXM mlHjNvfRP5K0 J5LH ZX/x0rB3pvbOpfX6geUFo6e0doz2fMP8/HtRkw3CybiPjk3Jt9Yv9e3xo34r/bJ2jC685qB3l2 f84jfSl9kMJq8yzTrHaNrs76VPm6NS9/dfgdqb6DqvyUIEFgQsGPUaiBQHwHBaH1qaSYECFRcwA7fAgvY2R16VU Xp2d9W336uCN6v6U52lix/X73zD/fZOZ0esjY9v37rwjfetADbiS2/tfMFQT5 t8DZSP299idF1cfy3uoP/qfj4hb8cZ63p/D7dXvLHi3bKdoLgYfPvK0nqnN4QObOPwfXsH39yXGoOrVNTbskf9fkvzGu jukxpYfQ vblHXHCwC8Z6fS5prfO2fNoBeybVvW/liHLPrpuByzUuNNkN6Tv9pCswTf84OY4/lu9x6ZrlWHVt9t59WD4EXZMX5UyTI x/x8U2gHvPpfd36nhUyMua79e4pMndscxbPzpny92yp5QO7jpft9765h1/d 8vfi8jHN6DlrZFwKljs1qu7XTbmEE6057ffR88Xer5da7HHsGmXVM7zjTx/fNIQkD598DOcL4OidvHfjlOlvj0/JObfMdrXfmv0LePImNfC3NYt8aU9nfaT4PKMiE 2gtEeo6xvkIHGqgAABmJJREFUQ0/tXmyPvfuS0SQPPTdO2HFJXHPHujjttIhrenH7sHrHlbJKzbPVR/odm1njSB/TGv8tsTC6lEX6531rKCt4zPDutNF1yxxraqG31lB0PwvtGiSP7w/cMdo5P732ej8P/W0OvsT4yfgCdiCOb dMAgQITCogGJ1U0PkECBCYooB3wk4RU1ME0gJDg9GKkrXCyQf7A/KKTsWwSyZw66VxaZy9KPAt2SgbNJyt8elLN8XRZ78wFr5KqUHTr/lU7UCseYFNjwCB0goIRktbGgMjQKBpAnaMNq3i5lu4QE2D0dYO3Bi y7Vwbx1WXuDWS98fd53k3ZOlKWRyDbvh4HhVemtyaQZoIOMK2DE6rpzzCBAgMLmAYHRyQy0QIEBgagJ2jE6NUkMEFgvULBidf8x92CsErAUCYwncGpe /644af7x/bEacdIUBZJH6W84 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
ABS plumbing pipe cut up and dissolved in MEK will make a putty that bonds well to fairing parts also. Maybe not as easy as Carl's stuff to work with but you don't have to go next door to buy it. Several posts about it scattered on the site.
Appreciate the comment, Ronnie.
Polivance must have been thinking the same thing, but realized they could make it easy for us......Plastifix kit.jpg
Back in 2007 when my bike was written off and I bought it back from the insurance, I used two whole Plasti-fix kits to rebuild the trunk, saddlebags, side fairings and front fairings. The left front fairing is actually made up of an upper and lower half of two different fairings I joined together. I used the included mold blocks to make molds in order to replace broken and/or missing tabs. this is done by warming up the blocks to make them pliable and shaping them around a good tab. You then fill and set them in place then add more plasti-fix to bond them to the part. I embed a cople of layers of fiberglass dry wall tape in order to add strength. Once sanded, adding additional plasti-fix, to pinholes and imperfections as you go, ( and the stuff sands better than spot putty, which I did not need to use ), the surface was flawless and to this day no one can tell were the repairs are. it even held together last year when my bike fell off the lift table.
Edited by saddlebum
I assume you got the Plastifix from Aircraft Spruce...........or CARL!!
Initially the first kit I got was called plastex and that I got when Carl had a rep do a demo at one of his earlier meet and greets in 2006. When I had my accident in 2007 and I used it up and needed more, I found Home Hardware carried it. Later when they stopped carrying it (I guess because no one really new what it was and its potential ) and I needed more Plus the original source Carls Rep worked for was gone, I looked on Line and found Aircraft spruce carried it under the name Plasti-fix and then found out there was an Aircraft spruce right by Carl's house so naturally I had to tell him about it because I new he loved the stuff as much as I did. The look on his face when I told him there was a source right by his house was priceless. You would have thought I handed him a whole dime which to a Dutchman is a whole lot of money.
BTW I added before and after pics to my previous post
Edited by saddlebum
Initially the first kit I got was called plastex and that I got when Carl had a rep do a demo at one of his earlier meet and greets in 2006. .........an Aircraft spruce right by Carl's house so naturally I had to tell him about it because I new he loved the stuff as much as I did. The look on his face when I told him there was a source right by his house was priceless. You would have thought I handed him a whole dime which to a Dutchman is a whole lot of money.
Thanks for the follow-up!
I spoke with Carl earlier today; he's BRINGING me a kit from AS. What a NICE guy!!
Of course he DOES have a vested interest in visiting St. Catharines.....if you know what I mean!
Cheers!
