User Tag List
Results 1 to 7 of 7
Thread: Helpful Hints Requested for two RSV issues
  1. #1
    Join Date
    Apr 2014
    Wilmington, NC
    NC
    Post Thanks / Like
    Mentioned
    19 Post(s)
    Tagged
    0 Thread(s)
    Default Helpful Hints Requested for two RSV issues
    The first issue is that when the key is inserted into the ignition switch it won't turn. After fiddling with it for a while it turns. I first sprayed some WD40 down the key hole and that didn't seem to help. Next I sprayed some Liquid Wrench penetration oil down the key hole and that didn't help. The key is the OE key ??
    The second issue is that when the key does turn to ON, I depress the start button and I hear only one click. Repeated button depressions followed by one click and the starter finally engages and spins with the engine starting. The battery is new and fully charged. ???
    Are these typical issues with the RSV? Any helpful hints on what to do to fix them would be appreciated.
    2007 Yamaha Royal Star Venture 23k miles
    1989 Yamaha Venture Royale 6k miles
    1985 Kawasaki ZN700 4cyl shaft 5k miles
  2. #2
    Join Date
    Oct 2006
    Edgewater, FL USA
    FL
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Helpful Hints Requested for two RSV issues
    Generally I would say yes those are fairly common issues.
    First question is do you have the key code that came with the original keys? That is a small tag with 4 or 5 numbers stamped on it, with those numbers a locksmith can punch a new key that will be as good as the one from the factory. If all you have is a worn key and get it copied all you have is a copy of a worn key. It may be better than the original worn key but not much and not for long. Generally it is never a good idea to put liquid lubes in a key hole, they attract dirt and collect particles of metal as the key and tumblers wear. I would recommend cleaning the key slot with some good plastic safe contact or brake cleaner to drive out the oil and dry out the inside, then use a dry lube specifically designed for locks, I use graphite.
    The electrical switch on the Ventures and many other Royal Stars are weak and minimally robust enough for the current that Yamaha puts through them, they are known to fail, just in the manner you are describing. There is a fellow here on the site , Dion, djh3 that makes a bypass electrical jumper that removes most of the load from the ignition switch, you may want to look into one of those.
    Steve K
    Edgewater , FL
    And the LORD said "Thou shalt have dominion over all of the animals, Except of course the cat."
    Hidden Content
    DR. Goldwing; has the antidote for the blues
  3. #3
    Join Date
    Aug 2012
    Danville
    NH
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Ditto on Dion's Ignition bypass relay. Plug and play. Super easy to install. 1st thing I recommend that anyone should do on RSV's and RSTD's.
    Ditto on cleaning out the stuff you put in the switch and using graphite instead. I use NAPA Lock-Ease. One can will last you a lifetime for all your vehicles.
  4. #4
    Join Date
    Jan 2016
    Stephenville
    TX
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Sounds like the key switch needs replacing. Second problem the starter solenoid needs replaced.
    Hidden Content
    Bill Donohue
    2001 RSV 44689 miles
  5. Thanks BlueSky gave thanks for this post
    Likes Steven G. liked this post
  6. #5
    Join Date
    Jul 2013
    Calgary
    Canada
    AB
    Post Thanks / Like
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Rafterd View Post
    My thoughts as well.
  7. #6
    Join Date
    Feb 2009
    Philipsburg, PA
    PA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I can punch new "Factory-like" keys for these motorcycles with or without the keycode. I have all the information in the Classifieds section. Or contact me for more information.
    I acquired the tools and supplies to make these after having the same issue with my key turning.
  8. #7
    Join Date
    Apr 2014
    Wilmington, NC
    NC
    Post Thanks / Like
    Mentioned
    19 Post(s)
    Tagged
    0 Thread(s)
    I have both of the original keys to my RSV. The one I was using appears to be the one the original owner always used. It is a little worn looking. It's attached to the dealer key chain. The other key looks like it was never used. So, I tried it and it took only 2 tries to get the key to turn. So, the worn key idea was a good suggestion.
Similar Threads
  1. Replies: 3
    Last Post: 08-15-2016, 09:48 AM
  2. Looking for some hints from my fellow Ventureriders
    By stickhandle2 in forum Watering Hole
    Last Post: 01-29-2016, 11:32 PM
  3. Hints for installing travel trunk wing light
    By yamadawg in forum Royal Star Venture Tech Talk ('99 - '13)
    Last Post: 07-25-2010, 04:37 PM
  4. Any hints or recommendations?
    By TINPUSHER in forum Watering Hole
    Last Post: 07-14-2008, 09:08 AM
  5. Help requested!!
    By jkt69 in forum Watering Hole
    Last Post: 07-11-2008, 09:45 AM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
